BRFL10N65
BRFL10N65
    BLUEROCKET(蓝箭电子)
    TO-220FL
    MOSFETs N-Channel TO220FL Vdss=650V Id=9.5A Vgss=±20V Pd=50W
BRFL10N65 数据手册
BRFL10N65 Rev.H Nov.-2022 描述 / DATA SHEET Descriptions TO-220FL 塑封封装 N 沟道 MOS 场效应管。N-CHANNEL MOSFET in a TO-220FL Plastic Package. 特征 / Features 低栅电荷,低反馈电容,开关速度快。 Low gate charge, low crss, fast switching. 用途 / Applications 用于高功率 DC/DC 转换和功率开关。 These devices are well suited for high efficiency switching DC/DC converters. 内部等效电路 引脚排列 PIN1:G 印章代码 / Equivalent Circuit / Pinning PIN 2:D PIN 3:S / Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1/6 BRFL10N65 Rev.H Nov.-2022 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter Drain-Source Voltage 符号 Symbol VDSS 数值 Rating 650 单位 Unit V Drain Current ID(Tc=25℃) 10 A Drain Current ID(Tc=100℃) 5.7 A IDM 38 A Gate-Source Voltage VGSS ±30 V Single Pulsed Avalanche Energy EAS 700 mJ Repetitive Avalanche Energy EAR 15.6 mJ Avalanche Current IAR 9.5 A Thermal Resistance, Junction to Case RθJC 2.5 ℃/W Thermal Resistance, Junction to Ambient RθJA 62.5 ℃/W PD(Tc=25℃) 50 W TJ,TSTG -55 to 150 ℃ Drain Current - Pulsed Power Dissipation Operating and Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Drain-Source Breakdown Voltage Zero Gate Voltage Drain Current Gate-Body Leakage Current Forward Gate Threshold Voltage Static Drain-Source On-Resistance Forward Transconductance Drain-Source Diode Forward Voltage Input Capacitance 符号 测试条件 Symbol Test Conditions BVDSS VGS=0V ID=250μA VDS=600V VGS=0V 1.0 μA VDS=480V TC=125℃ 10 μA VGS=±30V VDS=0V ±10 μA VGS(th) VDS=VGS ID=250μA 4.0 V RDS(on) VGS=10V ID=4.75A 0.75 0.85 Ω gFS VDS=40V ID=4.75A 8.0 VSD VGS=0V IS=9.5A VDS=25V f=1.0MHz VGS=0V IDSS IGSS Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Turn-On Delay Time td(on) Turn-On Rise Time tr Turn-Off Delay Time td(off) Turn-Off Fall Time http://www.fsbrec.com 最小值 典型值 最大值 单位 Min Typ Max Unit 650 V tf VDD=300V RG=25Ω ID=9.5A 2.0 S 1.4 V 1570 2040 pF 166 215 pF 18 24 pF 23 55 ns 69 150 ns 144 300 ns 77 165 ns 2/6 BRFL10N65 Rev.H Nov.-2022 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 BRFL10N65 Rev.H Nov.-2022 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 BRFL10N65 Rev.H Nov.-2022 印章说明 / DATA SHEET Marking Instructions BR 10N65 **** 说明: BR: 为公司代码 10N65: 为型号代码 ****: 为生产批号代码,随生产批号变化 Note: BR: Company Code 10N65: Product Type ****: Lot No. Code, code change with Lot No http://www.fsbrec.com 5/6 BRFL10N65 Rev.H Nov.-2022 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 Package Type 封装形式 使用说明 Temp.:270±5℃ Time:10±1 sec / Packaging SPEC. 套管包装 TO-220FL 时间:10±1 sec. / TUBE Units 包装数量 Dimension 包装尺寸 (unit:mm3) Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 50 20 1,000 5 5,000 532×33×7.0 555×164×50 575×290×180 / Notices http://www.fsbrec.com 6/6
BRFL10N65 价格&库存
很抱歉,暂时无法提供与“BRFL10N65”相匹配的价格&库存,您可以联系我们找货
BRFL10N65
  • 1+2.74320
  • 10+2.44080
  • 50+2.28960
  • 100+2.13840
  • 500+2.04120
  • 1000+1.99800
库存:1565
