NJM2882F05-TE1
NJM2882F05-TE1
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 300mA SOT-23-5(MTP5)
NJM2882F05-TE1 数据手册
NJM2881/82 LOW DROPOUT VOLTAGE REGULATOR GENERAL DESCRIPTION NJM2881/82 is a low dropout voltage regulator with ON/OFF control. Advanced Bipolar technology achieves low noise, high ripple rejection and low quiescent current. It is mounted on SOT-23-5 as small package and 1.0 F ceramic capacitor is available. Therefore it is suitable for cellular phone, camcorder, IC decoder, camera, and other portable items. PACKAGE OUTLINE NJM2881/82F FEATURES High Ripple Rejection 75dB typ. (f=1kHz ,Vo=3V version) Low Output Noise Voltage Vno=30 Vrms (Cp=0.01 F) Output capacitor with 1.0 F ceramic capacitor (Vo 2.7V) Output Current Io(max.)=300mA High Precision Output Vo 1.0% Low Dropout Voltage 0.10V typ. (Io=100mA) ON/OFF Control (Active High) Internal Short Circuit Current Limit Internal Thermal Overload Protection Bipolar Technology Package Outline SOT-23-5 PIN CONFIGURATION 5 4 1 2 3 1. 2. 3. 4. 5. CONTROL (Active High) GND NOISE BYPASS VOUT VIN NJM2881F 5 4 1 2 3 1. 2. 3. 4. 5. VIN GND CONTROL (Active High) NOISE BYPASS VOUT NJM2882F BLOCK DIAGRAM VIN V OUT Control Thermal Protection Bandgap Reference Noise Bypass GND Ver.2017-06-29 -1- NJM2881/82 OUTPUT VOLTAGE RANK LIST Device Name VOUT Device Name NJM288*F15 1.5V NJM288*F29 NJM288*F17 1.7V NJM288*F03 NJM288*F18 1.8V NJM288*F31 NJM288*F21 2.1V NJM288*F32 NJM288*F25 2.5V NJM288*F33 NJM288*F28 2.8V NJM288*F345 NJM288*F285 2.85V NJM288*F35 VOUT 2.9V 3.0V 3.1V 3.2V 3.3V 3.45V 3.5V Device Name NJM288*F38 NJM288*F04 NJM288*F43 NJM288*F47 NJM288*F05 VOUT 3.8V 4.0V 4.3V 4.7V 5.0V ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL Input Voltage VIN Control Voltage VCONT (Ta=25 C) RATINGS UNIT +14 V +14(*1) V 350(*2) Power Dissipation PD SOT-23-5 mW 200(*3) Operating Temperature Topr -40 +85 C Storage Temperature Tstg -40 +125 C (*1): When input voltage is less than +14V, the absolute maximum control voltage is equal to the input voltage. (*2): Mounted on glass epoxy board based on EIA/JEDEC. (114.3x76.2x1.6mm: 2Layers) (*3): Device itself. Operating voltage VIN=+2.3 +6V (In case of Vo2.0V version: VIN=Vo+1V, CIN=0.1 F, Co=1.0 F: Vo 2.7V (Co=2.2 F: Vo 2.6V), Cp=0.01 F, Ta=25 C) PARAMETER SYMBOL Output Voltage Vo Quiescent Current Quiescent Current at Control OFF Output Current Line Regulation IQ Load Regulation Dropout Voltage Ripple Rejection IQ(OFF) Io Vo/ VIN Vo/ Io VI-O RR MIN. TYP. MAX. UNIT Io=30mA Io=0mA, except Icont VCONT=0V TEST CONDITION -1.0% - +1.0% V - 120 180 A - - 100 nA Vo-0.3V 300 - 400 - 0.10 mA %/V - 0.10 0.03 0.18 %/mA V - 75 - dB - ppm/ C VIN=Vo+1V Vo+6V, Io=30mA Io=0 300mA Io=100mA ein=200mVrms,f=1kHz,Io=10mA, Vo=3V version Ta=0 85 C, Io=10mA Average Temperature Coefficient of Output Voltage Output Noise Voltage Control Voltage for ON-state VCONT(ON) 1.6 30 - - Vrms V Control Voltage for OFF-state VCONT(OFF) - - 0.6 V -2- Vo/ Ta VNO f=10Hz 80kHz, Io=10mA, Vo=3V version - 50 Ver.2017-06-29 NJM2881/82 ELECTRICAL CHARACTERISTICS (Vo 2.0V version: VIN=Vo+1V, CIN=0.1 F, Co=2.2 F: Vo 1.9V (Co=4.7 F: Vo 1.8V), Cp=0.01 F, Ta=25 C) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT -1.0% - +1.0% V Output Voltage Vo Io=30mA Quiescent Current Quiescent Current at Control OFF Output Current Line Regulation IQ Io=0mA, except ICONT - 120 180 A IQ(OFF) VCONT=0V - - 100 nA Io Vo/ VIN Vo-0.3V VIN=Vo+1V Vo+6V, Io=30mA 300 - 400 - 0.10 mA %/V Load Regulation Vo/ Io - - 0.03 %/mA Ripple Rejection RR Io=0 300mA ein=200mVrms,f=1kHz,Io=10mA, Vo=1.8V version - 80 - dB Ta=0 85 C, Io=10mA - - ppm/ C Average Temperature Coefficient of Output Voltage Output Noise Voltage Control Voltage for ON-state VNO VCONT(ON) Control Voltage for OFF-state VCONT(OFF) Vo/ Ta f=10Hz 80kHz, Io=10mA, Vo=1.8V version 50 1.6 20 - - Vrms V - - 0.6 V The above specification is a common specification for all output voltages. Therefore, it may be different from the individual specification for a specific output voltage. TEST CIRCUIT IIN A VIN VOUT IOUT VIN 0.1 F A V VCONT ICONT NJM2881/82 CONTROL GND NOISE BYPASS V VOUT 1.0 F *4 (ceramic) Cp=0.01 F *4 1.9V Vo 2.6V version: Co=2.2 F(ceramic) Vo 1.8V version: Co=4.7 F(ceramic) Ver.2017-06-29 -3- NJM2881/82 TYPICAL APPLICATION In the case where ON/OFF Control is not required: VIN VOUT VOUT VIN 0.1 F 1.0 F *5 NJM2881/82 R (0 300k ) NOISE BYPASS CONTROL Cp=0.01 F GND *5 1.9V Vo 2.6V version: Co=2.2 F Vo 1.8V version: Co=4.7 F Connect control terminal to VIN terminal In use of ON/OFF CONTROL: VIN VIN NJM2881/82 0.1 F VOUT VOUT 1.0 F *5 R CONTROL GND NOISE BYPASS Cp=0.01 F *5 1.9V Vo 2.6V version: Co=2.2 F Vo 1.8V version: Co=4.7 F State of control terminal: “H” output is enabled. “L” or “open” output is disabled. *Noise bypass Capacitance Cp Noise bypass capacitance Cp reduces noise generated by band-gap reference circuit. Noise level and ripple rejection will be improved when larger Cp is used. Use of smaller Cp value may cause oscillation. Use the Cp value of 0.01μF greater to avoid the problem. *In the case of using a resistance "R" between VIN and control. If this resistor is inserted, the control current could be reduced when the control voltage is high. The applied voltage to control pin should set to consider voltage drop through the resistor “R” and the minimum control voltage for ON-state. The VCONT (ON) and ICONT have temperature dependence as shown in the "Control Current vs. Temperature" and " Control Voltage vs. Temperature" characteristics. Therefore, the resistor "R" should be selected to consider the temperature characteristics. -4- Ver.2017-06-29 NJM2881/82 *Input Capacitor CIN The input capacitor CIN is required in order to prevent oscillation and reduce power supply ripple of applications when high power supply impedance or a long power supply line. Therefore, the recommended capacitance (refer to conditions of ELECTRIC CHARACTERISTIC) or larger input capacitor, connected between VIN and GND as short path as possible, is recommended in order to avoid the problem. *Output Capacitor CO The output capacitor CO is required for a phase compensation of the internal error amplifier, and the capacitance and the equivalent series resistance (ESR) influence stable operation of the regulator. If use a smaller output capacitor than the recommended capacitance (refer to conditions of ELECTRIC CHARACTERISTIC), it may cause excess output noise or oscillation of the regulator due to lack of the phase compensation. Therefore, the recommended capacitance or larger output capacitor, connected between VOUT and GND as short path as possible, is recommended for stable operation. The recommended capacitance may be different by output voltage, therefore confirm the recommended capacitance of the required output voltage. Furthermore, a larger output capacitor reduces output noise and ripple output, and also improves Output Transient Response when a load changes rapidly. Selecting the output capacitor, should consider varied characteristics of a capacitor: frequency characteristics, temperature characteristics, DC bias characteristics and so on. Therefore, the capacitor that has a sufficient margin of the rated voltage against the output voltage and superior temperature characteristics, is recommended for CO. Ver.2017-06-29 -5- NJM2881/82 POWER DISSIPATION vs. AMBIENT TEMPERATURE NJM2881/82F Power Dissipation (Topr=-40~+85℃,Tj=125℃,PD =200mW(Ta≦25℃)) Power Dissipation PD (mW) 500 On Board(114.3×76.2×1.6mm, FR-4) 400 300 Device itself 200 100 0 -50 -25 0 25 50 75 100 Ambient Temperature Ta(℃) -6- Ver.2017-06-29 NJM2881/82 ELECTRICAL CHARACTERISTICS NJM2881/82_3.0V Output Voltage v.s. Input Voltage NJM2881/82_3.0V Output Voltage vs. Output Current 3.5 o @:Ta=25 C Co=1.0 F(Ceramic) Cp=0.01 F 3 3.2 Output Voltage :Vo [V] Output Voltage :Vo [V] 3.4 Io=0A 3 2.8 Io=100mA 2.5 2 1.5 1 o @:Ta=25 C Co=1.0 F(Ceramic) Cp=0.01 F 0.5 Io=300mA 2.6 0 2.6 2.8 3 3.2 3.4 0 100 200 Input Voltage :Vin [V] NJM2881/82_3.0V Ground Pin Current vs. Output Current 20 400 500 600 NJM2881/82_3.0V Dropout Voltage vs. Output Current 0.3 o @:Ta=25 C Co=1.0 F(Ceramic) Cp=0.01 F o @:Ta=25 C Co=1.0 F(Ceramic) Cp=0.01 F 0.25 15 Dropout Voltage :dVi-o [V] Ground Pin Current :IGND [mA] 300 Output Current :Io [mA] 10 5 0.2 0.15 0.1 0.05 0 0 0 100 200 300 400 500 0 100 NJM2881/82_3.0V Control Current v.s. Control Voltage 20 200 300 400 500 Output Current :Io [mA] Output Current :Io [mA] NJM2881/82_3.0V Output Voltage v.s. Control Voltage 4 o 3.5 15 Output Voltage :Vo [V] Control Current :ICONT [ A] @:Ta=25 C Co=1.0 F(Ceramic) Cp=0.01 F Io=30mA 10 Rc=100k Rc=50k Rc=0 5 3 Rc=0 2.5 Rc=50k 2 Rc=100k 1.5 1 o @:Ta=25 C Vin=4.0V Co=1.0 F(Ceramic) Cp=0.01 F Io=30mA 0.5 0 0 0 0.5 1 1.5 2 Control Voltage :VCONT [V] Ver.2017-06-29 2.5 3 0 0.5 1 1.5 2 2.5 3 Control Voltage :VCONT [V] -7- NJM2881/82 ELECTRICAL CHARACTERISTICS NJM2881/82_3.0V Peak Output Current vs. Input Voltage NJM2881/82_3.0V Load Regulation vs. Output Current 0 1000 800 Peak Output Current :Io MAX [mA] Load Regulation :dVo/dIo [mV] -10 -20 -30 -40 o @:Ta=25 C VIN=4V Co=1.0 F(Ceramic) Cp=0.01 F -50 400 200 o @:Ta=25 C Co=1.0 F(Ceramic) Cp=0.01 F -60 0 600 100 200 300 400 0 500 4 6 8 Output Current :Io [mA] 10 NJM2881/82_3.0V Quiescent Current v.s. Input Voltage 2000 o @:Ta=25 C VIN=4V Co=1.0 F(Ceramic) Io=10mA Output Noise Voltage : Vn ( Vrms) Quiescent Current : Iq [ A] o @:Ta=25 C Output is open. Co=1.0 F(Ceramic) Cp=0.01 F including Icont 1200 800 400 0 0 5 10 150 100 50 0 0.000001 15 20 Io=10mA Io=30mA 60 40 o @:Ta=25 C VIN=4.0V ein=200mVrms Co=1.0 F(Ceramic) Cp=0.01 F 20 0 1 Output Current :Io [mA] -8- 0.1 80 40 0.1 0.01 Io=0mA Ripple Rejection Ratio :RR [dB] Output Noise Voltage :Vn [ Vrms] @:Ta=25 C VIN=4V Co=1.0 F(Ceramic) Cp=0.01 F 0.01 0.001 100 60 0 0.001 0.0001 NJM2881/82_3.0V Ripple Rejection Ratio v.s. Frequency NJM2881/82_3.0V Output Noise Voltage vs. Output Current o 80 0.00001 Noise Bypass Capacitor : Cp( F) Input Voltage :Vin [V] 100 14 NJM2881/82_3.0V Output Noise Voltage vs. Noise Bypass Capacitor 200 1600 12 Input Voltage :Vin [V] 10 100 10 10 100 1k 1000 4 10k 10 5 100k 10 Frequency :f [Hz] Ver.2017-06-29 NJM2881/82 ELECTRICAL CHARACTERISTICS NJM2881/82_3.0V Equivalent Series Resistance vs. Output Current NJM2881/82_3.0V Ripple Rejection vs. Output Current 100 100 o Equivalent Series Resistance :ESR [ ] f=1kHz Ripple Rejection : RR (dB) 80 60 f=10kHz 40 o @:Ta=25 C VIN=4.0V ein=200mVrms Co=1.0 F(Ceramic) Cp=0.01 F 20 0 0.001 @:Ta=25 C VIN=4V Co=1.0 F(Ceramic) Cp=0.01 F 10 STABLE REGION 1 0.1 0.02 0.01 0.1 1 10 100 0.001 1000 0.01 0.1 Output Current : Io(mA) 1 10 100 1000 Output Current :Io [mA] NJM2881/82_3.0V ƒf [ƒ^ Dropout Voltage v.s.1Temperature NJM2881/82_3.0V Output Voltage v.s. Temperature 3.1 0.3 @:VIN=4V Io=30mA Co=1.0 F(Ceramic) Cp=0.01 F @:Io=100mA Co=1.0 F(Ceramic) Cp=0.01 F 0.25 Output Voltage :Vo [V] Dropout Voltage : Vi-o [V] 3.05 0.2 0.15 0.1 3 2.95 0.05 2.9 0 -50 0 50 100 -50 150 0 100 150 Temperature :Ta [ C] NJM2881/82_3.0V Control Voltage v.s. Temperature NJM2881/82_3.0V Control Current v.s. Temperature 10 2 @:VIN=4V Output is open. Co=1.0 F(Ceramic) Cp=0.01 F @:VIN=4V Output is open. Co=1.0 F(Ceramic) Cp=0.01 F V CONT=1.6V 8 1.5 Control Current : ICONT ( A) Control Voltage :Vcont-off [V] 50 o o Temperature :Ta [ C] 1 0.5 6 4 2 0 -50 0 50 o Temperature :Ta [ C] Ver.2017-06-29 100 150 0 -50 0 50 o 100 150 Temperature Ta ( C) -9- NJM2881/82 ELECTRICAL CHARACTERISTICS NJM2881/82_3.0V Quiescent Current v.s. Temperature NJM2881/82_3.0V Short Circuit Current v.s. Temperature 300 200 @:VIN=4V Output is open Co=1.0 F(Ceramic) Cp=0.01 F Include Icont Short Circuit Current :Isc [mA] Quiescent Current : Iq [ A] 250 @:VIN=4.0V Output is short to ground. Co=1.0 F(Ceramic) Cp=0.01 F 200 150 100 150 100 50 50 0 0 -50 0 50 100 -50 150 0 100 150 Temperature :Ta [ C] NJM2881/82_3.0V Load Regulation v.s. Temperature NJM2881/82_3.0V Line Regulation v.s. Temperature 0.03 0.2 @:VIN=4.0-9.0V Io=30mA Co=1.0 F(Ceramic) Cp=0.01 F @:VIN=4.0V Io=0-100mA Co=1.0 F(Ceramic) Cp=0.01 F 0.025 Load Regulation :dVo/dIo [%/mA] Line Regulation :dVo/dVin [%/V] 50 o o Temperature :Ta [ C] 0.1 0 -0.1 -0.2 0.02 0.015 0.01 0.005 0 -50 0 50 100 150 o -50 0 50 100 150 o Temperature :Ta [ C] Temperature :Ta [ C] NJM2881/82_3.0V Output Voltage v.s. Temperature 3.5 3 Output Voltage :Vo [V] 2.5 2 1.5 1 @:VIN=4.0V Io=30mA Co=1.0 F(Ceramic) Cp=0.01 F 0.5 0 -50 0 50 100 150 200 o Temperature :Ta [ C] - 10 - Ver.2017-06-29 NJM2881/82 ELECTRICAL CHARACTERISTICS NJM2881_3.0V ON/OFF Transient Response NJM2881_3.0V ON/OFF Transient Response without Load 20 10 5 6 0 -5 4 Output Voltage Output Voltage : Vo [V] 10 Control Voltage 8 @:Ta=25 C VDD =4.0V Co=1.0 F(Ceramic) Cp=0.01 F Io=30mA 15 Control Voltage : Vo [V] 15 10 Control Voltage 8 5 6 0 -5 4 Output Voltage -10 2 -10 2 -15 -15 0 0 -20 0 1 2 3 Time : t [S] 4 -20 5 0 4 8 NJM2881/82_3.0V Load Transient Response 12 Time : t [ mS] 400 3.12 10 o o 3.1 300 3.08 3.06 250 3.04 200 3.02 150 Output Voltage 3 100 2.98 2.96 0 40 80 120 Time : t [ S] 160 200 Output Voltage : Vo [V] Output Voltage : Vo [V] 3.08 350 Output Current : Io [mA] @:Ta=25 C VDD =4.0V Co=1.0 F(Ceramic) Cp=0.01 F Output Current 20 NJM2881/82_3.0V Input Transient Response 3.12 3.1 16 @:Ta=25 C VDD =4.0V Co=1.0 F(Ceramic) Cp=0.01 F Io=30mA 8 6 Input Voltage 3.06 4 3.04 2 3.02 Output Voltage 0 3 50 2.98 0 2.96 Input Voltage : VIN [V] Output Voltage : Vo [V] 10 20 o 12 Control Voltage : Vo [V] @:Ta=25oC V DD =4.0V Co=1.0 F(Ceramic) Cp=0.01 F Io=0mA 12 -2 -4 0 40 80 120 Time : t [ S] 160 200 [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2017-06-29 - 11 -
NJM2882F05-TE1 价格&库存
很抱歉,暂时无法提供与“NJM2882F05-TE1”相匹配的价格&库存,您可以联系我们找货
NJM2882F05-TE1
  • 3000+2.891663000+0.37326
  • 6000+2.818986000+0.36388
  • 9000+2.782599000+0.35918
  • 15000+2.7422715000+0.35398
  • 21000+2.7186921000+0.35093
  • 30000+2.6960530000+0.34801
库存:3539
NJM2882F05-TE1
    • 1+9.39600
    库存:30
    NJM2882F05-TE1
    • 1+2.05650
    • 10+1.52130
    • 100+1.30400
    • 1000+1.08660
    NJM2882F05-TE1
      • 1+1.74215
      • 200+0.67425
      • 500+0.65049
      • 1000+0.63882
      NJM2882F05-TE1
      • 1+6.365181+0.82162
      • 10+4.5208810+0.58356
      • 25+4.0553125+0.52346
      • 100+3.54845100+0.45804
      • 250+3.30621250+0.42677
      • 500+3.16042500+0.40795
      • 1000+3.040201000+0.39243
      库存:3539
