S-19933AA-S8T1U7
S-19933AA-S8T1U7
    ABLIC(艾普凌科)
    HTMSOP-8
    IC REG BUCK ADJ 600MA HTMSOP-8
S-19933AA-S8T1U7 数据手册
S-19932A/19932B/19933A/19933B Series AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR www.ablic.com Rev.2.3_00 © ABLIC Inc., 2019-2021 The S-19932/19933 Series is a step-down switching regulator developed using high withstand voltage CMOS process technologies. This IC has high maximum operation voltage of 18 V and maintains high-accuracy FB pin voltage at ±1.5%. As suitable packages for high-density mounting, such as small-sized HSNT-6(2025), are adopted, this IC contributes to miniaturization of electronic equipment. PWM control (S-19932 Series) or PWM / PFM switching control (S-19933 Series) can be selected as an option. Since the S-19933 Series, which features PWM / PFM switching control, operates with PWM control under heavy load and automatically switches to PFM control under light load, it achieves high-efficiency operation in accordance with the device's status. Furthermore, our distinctive PWM / PFM switching control technology suppresses the ripple voltage to be generated in VOUT while PFM control is in operation. Since the S-19932/19933 Series has the built-in synchronous circuit, it achieves high efficiency easier compared with conventional step-down switching regulators. In addition, it has the built-in overcurrent protection circuit which protects the IC and coils from excessive load current as well as a thermal shutdown circuit which prevents damage from heat generation. ABLIC Inc. offers FIT rate calculated based on actual customer usage conditions in order to support customer functional safety design. For more information regarding our FIT rate calculation, contact our sales representatives. Caution This product can be used in vehicle equipment and in-vehicle equipment. Before using the product for these purposes, it is imperative to contact our sales representatives.  Features  Applications • Input voltage: • Output voltage (externally set): • Output current: • FB pin voltage accuracy: • Efficiency: • Oscillation frequency: • Overcurrent protection function: • Thermal shutdown function: • Short-circuit protection function: • 100% duty cycle operation: • Soft-start function: • Under voltage lockout function (UVLO): • Input and output capacitors: • Operation temperature range: • Lead-free (Sn 100%), halogen-free • AEC-Q100 qualified*1 4.0 V to 18.0 V 1.0 V to 12.0 V 600 mA ±1.5% 91% 2.2 MHz typ. 1.2 A typ. (pulse-by-pulse method) 170°C typ. (detection temperature) Hiccup control, Latch control • Camera module • For automotive use (engine, transmission, suspension, ABS, related-devices for EV / HEV / PHEV, etc.) • Constant-voltage power supply for electrical application for vehicle interior • Constant-voltage power supply for industrial equipment • Constant-voltage power supply for home electric appliance 5.8 ms typ. 3.35 V typ. (detection voltage) Ceramic capacitor compatible Ta = −40°C to +125°C  Packages • HTMSOP-8 (4.0 mm × 2.9 mm × t0.8 mm max.) • HSNT-8(2030) (3.0 mm × 2.0 mm × t0.5 mm max.) • HSNT-6(2025) (2.46 mm × 1.96 mm × t0.5 mm max.) *1. Contact our sales representatives for details.  Typical Application Circuit VEN EN CIN 4.7 μF SW L 3.3 μH VOUT 3.3 V VREG VSS S-19933 Series 80 CFB 33 pF FB VIN = 8.0 V, VOUT = 3.3 V 100 CREG 1 μF COUT 10 μF RFB1 46.9 kΩ RFB2 15 kΩ η [%] VIN VIN  Efficiency 60 40 S-19932 Series 20 0 0.1 1 10 IOUT [mA] 100 1000 1 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Block Diagrams 1. S-19932 Series (PWM control) VIN *1 *1 EN VIN Enable circuit CIN *1 VREG Regulator *1 UVLO circuit Soft-start circuit VREG *1 FB *1 SW + Error amplifier − *1 CREG PWM control circuit − + VOUT L COUT *1 CFB RFB1 RFB2 Oscillation circuit VREF Short-circuit protection circuit VSS *1. Parasitic diode Figure 1 2. S-19933 Series (PWM / PFM switching control) VIN *1 VIN *1 EN CIN Enable circuit *1 VREG Regulator *1 UVLO circuit Soft-start circuit VREG FB *1 − *1 Error amplifier + *1 SW + − VOUT L switching *1 COUT CFB RFB1 RFB2 Oscillation circuit VREF Short-circuit protection circuit VSS *1. Parasitic diode Figure 2 2 CREG Reverse current detection circuit AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  AEC-Q100 Qualified This IC supports AEC-Q100 for operation temperature grade 1. Contact our sales representatives for details of AEC-Q100 reliability specification.  Product Name Structure 1. Product name S-1993 x x A - xxxx U 7 Environmental code U: Lead-free (Sn 100%), halogen-free Package name abbreviation and packing specification*1 S8T1: HTMSOP-8, Tape A8T1: HSNT-8(2030), Tape A6T8: HSNT-6(2025), Tape Operation temperature A: Ta = −40°C to +125°C Product type*2 A, B Control method 2: PWM control 3: PWM / PFM switching control *1. *2. 2. Refer to the tape drawing. Refer to "2. Function list of product types". Function list of product types Table 1 3. Product Type Oscillation Frequency A B 2.2 MHz 2.2 MHz Short-circuit Protection Function Hiccup control Latch control Packages Table 2 Package Name HTMSOP-8 HSNT-8(2030) HSNT-6(2025) Dimension FP008-A-P-SD PP008-A-P-SD PJ006-B-P-SD Package Drawing Codes Tape FP008-A-C-SD PP008-A-C-SD PJ006-B-C-SD Reel FP008-A-R-SD PP008-A-R-SD PJ006-B-R-SD Land FP008-A-L-SD PP008-A-L-SD PJ006-B-LM-SD Stencil Opening − − PJ006-B-LM-SD 3 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Pin Configurations 1. HTMSOP-8 Table 3 Top view Pin No. 1 2 3 4 8 7 6 5 Bottom view 1 2 3 4 8 7 6 5 1 2 3 4 5 6 7 8 Symbol VIN FB EN NC*2 NC*2 VREG*3 VSS SW Description Power supply pin Feedback pin Enable pin (active "H") No connection No connection Internal power supply pin GND pin External inductor connection pin *1 Figure 3 *1. *2. *3. 2. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. The VREG pin cannot supply load current outside. HSNT-8(2030) Table 4 Pin No. Top view 1 8 4 5 Bottom view 8 1 5 4 1 2 3 4 5 6 7 8 Symbol VIN FB EN NC*2 NC*2 VREG*3 VSS SW Description Power supply pin Feedback pin Enable pin (active "H") No connection No connection Internal power supply pin GND pin External inductor connection pin *1 Figure 4 *1. *2. *3. 4 Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. The VREG pin cannot supply load current outside. AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 3. HSNT-6(2025) Table 5 Pin No. Top view 1 2 3 6 5 4 Bottom view 6 5 4 1 2 3 1 2 3 4 5 6 Symbol VIN FB EN VREG*2 VSS SW Description Power supply pin Feedback pin Enable pin (active "H") Internal power supply pin GND pin External inductor connection pin *1 Figure 5 *1. *2. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. The VREG pin cannot supply load current outside. 5 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Absolute Maximum Ratings Table 6 (Unless otherwise specified: Ta = +25°C, VSS = 0 V) Item Symbol VIN pin voltage EN pin voltage FB pin voltage VREG pin voltage VIN VEN VFB VREG SW pin voltage VSW Junction temperature Operation ambient temperature Storage temperature Tj Topr Tstg Absolute Maximum Ratings VSS − 0.3 to VSS + 22 VSS − 0.3 to VSS + 22 VSS − 0.3 to VREG + 0.3 ≤ VSS + 6.0 VSS − 0.3 to VIN + 0.3 ≤ VSS + 6.0 VSS − 2 to VIN + 2 ≤ VSS + 22 (< 20 ns) VSS − 0.3 to VIN + 0.3 ≤ VSS + 22 −40 to +150 −40 to +125 −40 to +150 Unit V V V V V °C °C °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Item Symbol Table 7 Condition Board A Board B Board C HTMSOP-8 Board D Board E Board A Board B *1 HSNT-8(2030) Board C Junction-to-ambient thermal resistance θJA Board D Board E Board A Board B HSNT-6(2025) Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark Refer to " Power Dissipation" and "Test Board" for details. 6 Min. − − − − − − − − − − − − − − − Typ. 159 113 39 40 30 181 135 40 42 32 180 128 43 44 36 Max. − − − − − − − − − − − − − − − Unit °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Electrical Characteristics Table 8 (VIN = 12 V, Tj = −40°C to +125°C unless otherwise specified) Item Operating input voltage Current consumption during shutdown Current consumption during switching off UVLO detection voltage UVLO release voltage Symbol Condition Min. Typ. Max. Unit − 4.0 − 18.0 V − 0 5 μA − − 3.1 3.2 175 68 3.35 3.45 260 120 3.6 3.7 μA μA V V VIN ISSS VEN = 0 V ISS VFB = 1.0 V VUVLOVUVLO+ VREG pin voltage VREG pin voltage S-19932 Series S-19933 Series FB pin voltage VFB − 0.788 0.8 0.812 V Oscillation frequency fOSC − 1.98 2.2 2.42 MHz Minimum ON time Maximum duty ratio tON_MIN MaxDuty − 100 60 − − − ns % Soft-start wait time tSSW 0.30 0.58 0.90 ms Soft-start time tSS 3.0 5.8 8.5 ms High side power MOS FET on-resistance Low side power MOS FET on-resistance High side power MOS FET leakage current Low side power MOS FET leakage current Limit current Thermal shutdown detection temperature Thermal shutdown release temperature High level input voltage Low level input voltage − − Time until VOUT starts rising, CREG = 1 μF Time until VFB reaches 90% after it starts rising RHFET ISW = 50 mA − 0.85 1.75 Ω RLFET ISW = −50 mA − 0.35 0.65 Ω IHSW VIN = 18.0 V, VEN = 0 V, VSW = 0 V − 0.01 2 μA ILSW VIN = 18.0 V, VEN = 0 V, VSW = 18.0 V − 0.01 4 μA 1.0 1.2 1.4 A − ILIM TSD Junction temperature − 170 − °C TSR Junction temperature − 150 − °C VSH VSL EN pin EN pin 2.0 − − − − 0.8 V V High level input current ISH EN pin, VEN = 2.0 V − − 1 μA Low level input current FB pin current ISL IFB EN pin, VEN = 0 V FB pin, VFB = 1.0 V −0.5 −0.06 − − 0.5 0.06 μA μA 7 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Operation 1. Overview of operation The S-19932/19933 Series adopts the current mode control. By comparing the current feedback signal which has slope compensation added to the current flows through high side power MOS FET with the output signal of error amplifier, the Duty ratio of the SW pin is determined. Using the negative feedback loop configured, the error amplifier output signal is maintained at the value that VREF and FB pin voltage (VFB) will be equalized. 2. PWM control (S-19932 Series) The S-19932 Series operates with the pulse width modulation method (PWM) regardless of the extent of load current and allows the switching frequency to stabilize. 3. PWM / PFM switching control (S-19933 Series) The S-19933 Series automatically switches between PWM and pulse frequency modulation method (PFM) according to the load current. PFM control is selected when under light load, and the pulse will skip according to the load current. This reduces self-current consumption and improves efficiency when under light load. In PFM control, the peak current, flows through an inductor, is set to 125 mA typ. in the IC. In addition, our distinctive PWM / PFM switching control technology suppresses the ripple voltage to be generated in VOUT while PFM control is in operation. 4. Minimum ON time ON time (tON) of the SW pin during current continuous mode can be calculated by the following expression. VOUT 1 tON = V × f IN OSC tON will be small when VIN is high and VOUT is low. Set the use conditions to realize tON > minimum ON time (tON_MIN). Although the maximum value of tON_MIN varies according to inductance, load current, and the conditions of VIN and VOUT, the value is 80 ns. When tON < tON_MIN, the ripple voltage (ΔVOUT) in VOUT may increase by skipping a pulse during current continuous mode. In addition, when the S-19932/19933 Series changes to an overload status, the limit current (ILIM) to protect the IC from overcurrent may increase. Sufficient evaluations under actual conditions are required. 5. 100% duty cycle operation The high side power MOS FET allows for 100% duty cycle operation. Even when the input voltage is lowered up to the output voltage value set using the external output voltage setting resistor, the high side power MOS FET is kept on and current can be supplied to the load. The output voltage at this time is the input voltage from which the voltage drop due to the direct resistance of the inductor and the on-resistance of the high side power MOS FET are subtracted. 6. Under voltage lockout function (UVLO) The S-19932/19933 Series has a built-in UVLO circuit to prevent the IC from malfunctioning due to a transient status at power-on or a momentary drop in the supply voltage. When UVLO status is detected, the high side power MOS FET and low side power MOS FET will turn off, and the SW pin will change to "High-Z". For this reason, switching operation will stop. The soft-start function is reset if UVLO status is detected once and is restarted by releasing the UVLO status. Note that the other internal circuits operate normally, and the status is different from the disabled status. Also, there is a hysteresis width for avoiding malfunctions due to generation of noise etc. in the input voltage. 8 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 7. EN pin This pin starts and stops switching operation. When the EN pin is set to "L", the operation of all internal circuits, including the high side power MOS FET, is stopped, reducing current consumption. When not using the EN pin, connect it to the VIN pin. Since the EN pin is neither pulled down nor pulled up internally, do not use it in the floating status. The structure of the EN pin is shown in Figure 6, and the clamp circuit is internally connected. Refer to "3. 1 High level input current (ISH) vs. EN pin voltage (VEN)" in " Characteristics (Typical Data)" for the input current of EN pin. EN Pin "H" "L" *1. *2. Table 9 Internal Circuit Enable (normal operation) Disable (standby) VOUT Constant value*1 Pulled down to VSS*2 The constant value is output due to the regulating based on the output voltage setting resistors (RFB1 and RFB2). VOUT is pulled down to VSS due to the output voltage setting resistors (RFB1 and RFB2) and a load. EN Clamp circuit Figure 6 8. Thermal shutdown function The S-19932/19933 Series has a built-in thermal shutdown circuit to limit overheating. When the junction temperature increases to 170°C typ., the thermal shutdown circuit becomes the detection status, and the switching operation is stopped. When the junction temperature decreases to 150°C typ., the thermal shutdown circuit becomes the release status, and the switching operation is restarted. If the thermal shutdown circuit becomes the detection status due to self-heating, the switching operation is stopped and output voltage (VOUT) decreases. For this reason, the self-heating is limited and the temperature of the IC decreases. The thermal shutdown circuit becomes release status when the temperature of the IC decreases, and the switching operation is restarted, thus the self-heating is generated again. Repeating this procedure makes the waveform of VOUT into a pulse-like form. Note that the product may suffer physical damage such as deterioration if the above phenomenon occurs continuously. Switching operation stopping and starting can be stopped by either setting the EN pin to "L", lowering the output current (IOUT) to reduce internal power consumption, or decreasing the ambient temperature. Table 10 Thermal Shutdown Circuit VOUT Release: 150°C typ.*1 Constant value*2 *1 Detection: 170°C typ. Pulled down to VSS*3 *1. Junction temperature *2. The constant value is output due to the regulating based on the output voltage setting resistors (RFB1 and RFB2). *3. VOUT is pulled down to VSS due to the output voltage setting resistors (RFB1 and RFB2) and a load. 9 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 9. Overcurrent protection function The overcurrent protection circuit monitors the current that flows through the high side power MOS FET and limits current to prevent thermal destruction of the IC due to an overload, magnetic saturation in the inductor, etc. When a current exceeding the limit current (ILIM) flows through the high side power MOS FET, the high side power MOS FET is turned off. When the next switching cycle starts, the high side power MOS FET is turned on. If the current value continues to remain at ILIM or higher, the high side power MOS FET is turned off again, repeating this series of operation. Meanwhile, when the current, which flows through the high side power MOS FET, falls to ILIM or lower, the S-19932/19933 Series will return to the normal operation. When the slope of inductor current is large, ILIM may appear to increase due to the delay time of overcurrent protection circuit. This phenomenon tends to occur when low-inductance inductor is used or when the voltage different between VIN and VOUT is large. 10. Frequency foldback function The frequency foldback function has FB pin voltage (VFB) and oscillation frequency (fOSC) to have a proportional relation when VFB is 0.7 V typ. or lower. Refer to "11. Short-circuit protection function" for details. The frequency foldback function in the S-19932 Series is set to invalid at start-up. 10 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 11. Short-circuit protection function 11. 1 Hiccup control The S-19932/19933 Series A type has a built-in short-circuit protection function for Hiccup control. Hiccup control is a method for periodically carrying out automatic recovery when the IC detects overcurrent and stops the switching operation. 11. 1. 1 When overload status is released Overcurrent detection After detection of the FB pin voltage (VFB) < 0.7 V typ., frequency foldback function becomes valid. Detection of VFB < 0.5 V typ. 0.3 ms elapse Switching operation stop (for 21 ms typ.) Overload status release The IC restarts, soft-start function starts. In this case, it is unnecessary to input an external reset signal for restart. VFB reaches 0.72 V typ. after 5.8 ms typ. elapses. Overload status Normal load status 1.2 A typ. *1 IL 0.6 A 0A VSW VFB 0V 0.8 V typ. 0.7 V typ. 0.5 V typ. 0.3 ms typ. 21 ms typ. 5.8 ms typ. *1. 0V Inductor current Figure 7 11. 1. 2 When overload status continues Overcurrent detection After detection of VFB < 0.7 V typ., frequency foldback function becomes valid. Detection of VFB < 0.5 V typ. 0.3 ms elapse Switching operation stop (for 21 ms typ.) The IC restarts, soft-start function starts. The status returns to when overload status continues after 8.6 ms typ. elapses. *1. Inductor current Figure 8 11 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 11. 2 Latch control The S-19932/19933 Series B type has a built-in short-circuit protection function for Latch control. Latch control is a method for maintaining the Latch status when the IC detects overcurrent and stops the switching operation. Overcurrent detection After detection of VFB < 0.7 V typ., frequency foldback function becomes valid. Detection of VFB < 0.5 V typ. 0.3 ms elapse Switching operation stop Overload status 1.2 A typ. *1 IL 0.6 A 0A VSW 0V 0.8 V typ. 0.7 V typ. VFB 0.5 V typ. 0.3 ms typ. *1. Inductor current Figure 9 In addition, Latch status is reset under the following conditions. • At UVLO detection • When the EN pin changes from "H" to "L". 12 0V AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 12. Pre-bias compatible soft-start function The S-19932/19933 Series has a built-in pre-bias compatible soft-start circuit. If the pre-bias compatible soft-start circuit starts when electrical charge remains in the output voltage (VOUT) as a result of power supply restart, etc., or when VOUT is biased beforehand (pre-bias status), switching operation is stopped until the soft-start voltage exceeds the FB pin voltage (VFB), and then VOUT is maintained. If the soft-start voltage exceeds VFB, switching operation will restart and VOUT will rise to the output voltage setting value (VOUT(S)). This allows VOUT(S) to be reached without lowering the pre-biased VOUT. In soft-start circuits which are not pre-bias compatible, a large current flows as a result of the discharge of the residual electric charge through the low side power MOS FET when switching operation starts, which could cause damage, however in a pre-bias compatible soft-start circuit, the IC is protected from the large current when switching operation starts, and it makes power supply design for the application circuit simpler. In the S-19932/19933 Series, VOUT reaches VOUT(S) gradually due to the soft-start circuit. In the following cases, rush current and VOUT overshoot are reduced. • When the EN pin changes from "L" to "H". • When UVLO operation is released.*1 • When thermal shutdown is released.*1 • At short-circuit recovery*1 *1. In this case, the soft-start wait time is eliminated. The soft-start circuit starts operating after "H" is input to the EN pin and the soft-start wait time (tSSW) = 0.58 ms typ. elapses. The soft-start time (tSS) is set to 5.8 ms typ. Soft-start wait time (tSSW) Soft-start operation during pre-bias Soft-start time (tSS) VEN VOUT VSW Figure 10 13. Internal power supply (VREG) Some of the circuits in the IC operate using the VREG pin voltage (VREG) as the power supply. To stabilize this internal power supply, a ceramic capacitor with 1 μF needs to be connected between the VREG pin and the VSS pin. To achieve low impedance, this capacitor should be placed as close to the IC as possible. Additionally, note that any external parts other than CREG or any load must not connect to the VREG pin. 13 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Typical Circuit VIN L EN VIN CIN VOUT SW CFB FB VREG VSS RFB1 COUT CREG RFB2 Figure 11 Caution The above connection diagram will not guarantee successful operation. Perform thorough evaluation using an actual application to set the constants. 14 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  External Parts Selection The recommended values for each external part are shown in Table 11, and the recommended parts are shown in Table 12 to Table 16. When selecting an input capacitor (CIN), output capacitor (COUT), and internal power supply stabilized capacitor (CREG), take into consideration the temperature range and DC bias characteristics of the capacitor to be used. VOUT 1.0 V 2.5 V 3.3 V 5.0 V 12.0 V CIN 4.7 μF 4.7 μF 4.7 μF 4.7 μF 4.7 μF COUT 10 μF 10 μF 10 μF 10 μF 10 μF CFB 33 pF 33 pF 33 pF 33 pF 33 pF Table 11 CREG 1 μF 1 μF 1 μF 1 μF 1 μF L 2.2 μH 3.3, 4.7 μH 3.3, 4.7 μH 4.7, 6.8 μH 6.8, 10 μH Recommended Capacitors (CIN) List Withstanding Part Number Capacitance Voltage CGA4J1X7R1E475K125AC 25 V 4.7 μF CGA4J1X7R1H475K125AC 50 V 4.7 μF CGA5L3X7R1H475K160AB 50 V 4.7 μF RFB1 3.75 kΩ 31.9 kΩ 46.9 kΩ 84 kΩ 210 kΩ RFB2 15 kΩ 15 kΩ 15 kΩ 16 kΩ 15 kΩ Table 12 Manufacturer TDK Corporation TDK Corporation TDK Corporation Murata Manufacturing Co., Ltd. GCM31CR71E475KA55 4.7 μF 25 V Recommended Capacitors (COUT) List Withstanding Part Number Capacitance Voltage CGA4J3X7S1A106K125AB 10 V 10 μF CGA5L1X7R1C106K160AC 16 V 10 μF CGA4J1X7S1E106K125AC 25 V 10 μF Dimensions (L × W × H) 2.0 mm × 1.25 mm × 1.25 mm 2.0 mm × 1.25 mm × 1.25 mm 3.2 mm × 1.6 mm × 1.6 mm 3.2 mm × 1.6 mm × 1.6 mm Table 13 Manufacturer TDK Corporation TDK Corporation TDK Corporation Murata Manufacturing Co., Ltd. GCM188D70J106ME36 10 μF 6.3 V Recommended Capacitor (CFB) List Withstanding Part Number Capacitance Voltage CGA1A2C0G1H330J030BA 33 pF 50 V Dimensions (L × W × H) 2.0 mm × 1.25 mm × 1.25 mm 3.2 mm × 1.6 mm × 1.6 mm 2.0 mm × 1.25 mm × 1.25 mm 1.6 mm × 0.8 mm × 0.8 mm Table 14 Manufacturer TDK Corporation 0.6 mm × 0.3 mm × 0.3 mm Table 15 Manufacturer TDK Corporation Murata Manufacturing Co., Ltd. Recommended Capacitors (CREG) List Withstanding Part Number Capacitance Voltage CGA3E1X7R1C105K080AC 16 V 1 μF Dimensions (L × W × H) GCM155C71A105KE38 1 μF 10 V 1.6 mm × 0.8 mm × 0.8 mm 1.0 mm × 0.5 mm × 0.5 mm Table 16 Manufacturer TDK Corporation TDK Corporation TDK Corporation TDK Corporation TDK Corporation TDK Corporation TDK Corporation Murata Manufacturing Co., Ltd. Murata Manufacturing Co., Ltd. Recommended Inductors (L) List Withstanding Part Number Inductance Voltage TFM252012ALMA2R2MTAA 2.2 μH 20 V TFM252012ALMA3R3MTAA 3.3 μH 20 V CLF5030NIT-3R3N-D 3.3 μH − TFM252012ALMA4R7MTAA 4.7 μH 20 V CLF5030NIT-4R7N-D 4.7 μH − CLF5030NIT-6R8N-D 6.8 μH − CLF5030NIT-100M-D 10 μH − Dimensions (L × W × H) Dimensions (L × W × H) 2.5 mm × 2.0 mm × 1.2 mm 2.5 mm × 2.0 mm × 1.2 mm 5.0 mm × 5.3 mm × 2.7 mm 2.5 mm × 2.0 mm × 1.2 mm 5.0 mm × 5.3 mm × 2.7 mm 5.0 mm × 5.3 mm × 2.7 mm 5.0 mm × 5.3 mm × 2.7 mm DFE2MCAH2R2MJ0 2.2 μH − 2.0 mm × 1.6 mm × 1.2 mm DFE252012PD-3R3M 3.3 μH 20 V 2.5 mm × 2.0 mm × 1.2 mm 15 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 1. Input capacitor (CIN) CIN, which has an effect to suppress the ripple voltage and switching noise to be generated in the power supply line, is used for the stable operation of IC. A ceramic capacitor with 4.7 μF or higher is recommended. 2. Output capacitor (COUT) COUT is used to smooth output voltage. The ripple voltage (ΔVOUT) to be generated in VOUT is inversely proportional to COUT. When selecting a capacitor whose ESR is sufficiently small, ΔVOUT during current continuous mode is calculated by the following expression. ΔVOUT = ΔIL 8 × fOSC × COUT In addition, since COUT contributes to the stability of feedback loop, a ceramic capacitor with 10 μF or higher is recommended. When selecting a capacitor whose capacitance is extremely large, the overcurrent protection function may start the operation and cause a start-up failure. Therefore, select a capacitor with 200 μF or lower. 3. Inductor (L) To suppress the intrinsic subharmonic oscillation in current mode control, the optimal L value needs to be selected. Considering the slope compensation in the IC, select an inductor from the range of 2.2 μH to 10 μH depending on VOUT. When selecting L, note the allowable current. If a current exceeding the allowable current flows through the inductor, magnetic saturation may occur, and there may be risks which substantially lower efficiency and damage the IC as a result of large current. The ripple current (ΔIL) and peak current (IPK) flow through the inductor during current continuous mode are calculated by the following expressions respectively. Make sure IPK will not exceed the allowable current of inductor. ΔIL = VOUT × (VIN − VOUT) fOSC × L × VIN ΔIL IPK = IOUT + 2 In order to maintain the allowable current of inductor even in cases VOUT shorts to VSS or other fault conditions occur, an inductor with 1.4 A or higher, the maximum value of ILIM, needs to be selected. 4. Internal power supply stabilized capacitor (CREG) CREG is used to stabilize the operation of IC's internal power supply (VREG = 4.5 V typ.) A ceramic capacitor with 1 μF is recommended. 16 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 5. Output voltage setting resistors (RFB1, RFB2), capacitor for phase compensation (CFB) VOUT can be set to any value using RFB1 and RFB2. VOUT can be calculated by the following expression substituting VFB = 0.8 V typ. Note that if the RFB1 and RFB2 values are increased, the FB pin will more likely to be affected by noise. A resistor with approximately 15 kΩ is recommended for RFB2. VOUT = (RFB1 + RFB2) × 0.8 RFB2 CFB connected in parallel with RFB1 is a capacitor for phase compensation. Using RFB1 and CFB to set the zero point (the phase feedback) allows the feedback loop to gain larger phase margin. When selecting CFB, refer to the following expressions. In addition, perform thorough evaluations with the actual applications to set the constants. First, calculate the zero point frequency (fz) by the following expression. 1 VFB × V fZ = 3.94 × C OUT OUT Next, substitute RFB1 and fZ gained by the above expression into the below expression to calculate CFB value. CFB = 1 2 × π× RFB1 × fZ Caution Generally a switching regulator may cause oscillation depending on the selection of external parts. Perform thorough evaluations including the temperature characteristics with actual applications to confirm no oscillation occurs. 17 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Board Layout Guidelines Note the following cautions when determining the board layout for the S-19932/19933 Series. • Place CIN as close to the VIN pin and the VSS pin as possible. Prioritize the layout of CIN. • Place CREG as close to the VREG pin and the VSS pin as possible. • Mount CIN and CREG on the same surface layer as the IC. If they are connected through thermal vias, the impedance of the thermal vias may influence the operation, resulting in unstable condition. • Make the wiring of the FB pin as short as possible. The parasitic capacitance of FB pin may affect the phase margin of feedback loop. • Do not place the FB pin close to noise sources such as the wiring of SW pin to avoid unstable operations. • Make the GND pattern as wide as possible. • Place thermal vias in the GND pattern to ensure sufficient heat dissipation. • Large current flows through the SW pin. Make the wiring area of the pattern to be connected to the SW pin small to minimize parasitic capacitance and emission noise. • Make a short loop wiring of the SW pin → L → COUT → VSS pin. This is effective to reduce emission noise. • Do not wire the SW pin pattern under the IC. Total size 7.9 mm × 3.9 mm = 30.81 mm2 Figure 12 Reference Board Pattern Caution The above pattern diagram does not guarantee successful operation. Perform thorough evaluation using the actual application to determine the pattern. 18 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Related Source Refer to the following application note for recommended noise suppression parts and board layouts that help reduce conductive noise and emission noise for the S-19932/19933 Series. This application note also summarizes CISPR25 compliant measurement results. S-19932/19933 Series NOISE COUNTERMEASURES AND CISPR25 MEASUREMENT RESULTS Application Note  Precautions • Mount external capacitors and inductors as close as possible to the IC, and make single GND. • Characteristic ripple voltage and spike noise occur in the IC containing switching regulators. Moreover rush current flows at the time of a power supply injection. Because these largely depend on the inductor, the capacitor and impedance of power supply to be used, fully check them using an actually mounted model. • The 4.7 μF capacitor connected between the VIN pin and the VSS pin is a bypass capacitor. It stabilizes the power supply in the IC, and thus effectively works for stable switching regulator operation. Allocate the bypass capacitor as close to the IC as possible, prioritized over other parts. • Although the IC contains a static electricity protection circuit, static electricity or voltage that exceeds the limit of the protection circuit should not be applied. • The power dissipation of the IC greatly varies depending on the size and material of the board to be connected. Perform sufficient evaluation using an actual application before designing. • ABLIC Inc. assumes no responsibility for the way in which this IC is used on products created using this IC or for the specifications of that product, nor does ABLIC Inc. assume any responsibility for any infringement of patents or copyrights by products that include this IC either in Japan or in other countries. 19 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Characteristics (Typical Data) Example of major power supply dependence characteristics (Ta = +25°C) 1. 1 Current consumption during switching off (ISS) vs. Input voltage (VIN) ISS [μA] 1. 1. 1 S-19932 Series 1. 1. 2 150 225 125 200 100 175 150 100 6 8 10 12 VIN [V] 14 16 18 Current consumption during shutdown (ISSS) vs. Input voltage (VIN) 4 6 8 10 12 VIN [V] 14 16 18 1. 3 FB pin voltage (VFB) vs. Input voltage (VIN) 100 0.810 80 0.805 VFB [V] ISSS [nA] 50 0 4 60 40 0.800 0.795 20 0 75 25 125 1. 2 S-19933 Series 250 ISS [μA] 1. 4 6 8 10 12 VIN [V] 14 16 0.790 18 4 6 8 10 12 VIN [V] 14 16 18 1. 4 Oscillation frequency (fOSC) vs. Input voltage (VIN) 2.3 2.2 2.1 2.0 tSSW [ms] 1. 5 4 10 12 14 16 18 VIN [V] Soft-start wait time (tSSW) vs. Input voltage (VIN) 6 8 Soft-start time (tSS) vs. Input voltage (VIN) 1.0 10 0.8 8 0.6 0.4 0.2 6 4 2 0.0 0 4 20 1. 6 tSS [ms] fOSC [MHz] 2.4 6 8 10 12 VIN [V] 14 16 18 4 6 8 10 12 VIN [V] 14 16 18 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 1. 7 High side power MOS FET on-resistance (RHFET) 1. 8 vs. Input voltage (VIN) 1.0 0.8 1.5 RLFET [Ω] RHFET [Ω] 2.0 1.0 0.5 6 8 10 12 VIN [V] 14 16 18 High side power MOS FET leakage current (IHSW) vs. Input voltage (VIN) 4 1. 10 1000 80 800 60 40 20 6 8 10 12 VIN [V] 14 16 18 Low side power MOS FET leakage current (ILSW) vs. Input voltage (VIN) 100 ILSW [nA] IHSW [nA] 0.4 0.0 4 600 400 200 0 0 4 1. 11 0.6 0.2 0.0 1. 9 Low side power MOS FET on-resistance (RLFET) vs. Input voltage (VIN) 6 8 10 12 VIN [V] 14 16 18 4 6 8 10 12 VIN [V] 14 16 18 Limit current (ILIM) vs. Input voltage (VIN) 1.4 ILIM [A] 1.3 1.2 1.1 1.0 4 6 8 10 12 VIN [V] 14 16 18 1. 13 Low level input voltage (VSL) vs. Input voltage (VIN) 3.0 3.0 2.5 2.5 2.0 2.0 VSL [V] VSH [V] 1. 12 High level input voltage (VSH) vs. Input voltage (VIN) 1.5 1.0 0.5 1.5 1.0 0.5 0.0 0.0 4 6 8 10 12 VIN [V] 14 16 18 4 6 8 10 12 VIN [V] 14 16 18 21 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 2. Example of major temperature characteristics (Ta = −40°C to +125°C) 2. 1 Current consumption during switching off (ISS) vs. Temperature (Ta) 2. 1. 1 S-19932 Series 2. 1. 2 VIN = 12 V 225 125 200 100 175 150 2. 2 0 25 50 Ta [°C] 75 100 2. 3 0 25 50 Ta [°C] 75 100 125 FB pin voltage (VFB) vs. Temperature (Ta) VIN = 12 V 0.810 80 0.805 60 VFB [V] ISSS [nA] 50 0 −40 −25 125 Current consumption during shutdown (ISSS) vs. Temperature (Ta) VIN = 12 V 100 40 0.800 0.795 20 0 −40 −25 75 25 125 100 −40 −25 VIN = 12 V 150 ISS [μA] ISS [μA] 250 S-19933 Series 0 25 50 Ta [°C] 75 100 0.790 −40 −25 125 0 25 50 Ta [°C] 75 100 125 2. 4 Oscillation frequency (fOSC) vs. Temperature (Ta) VIN = 12 V fOSC [MHz] 2.4 2.3 2.2 2.1 2.0 −40 −25 2. 6 UVLO release voltage (VUVLO+) vs. Temperature (Ta) 3.6 3.6 3.5 3.5 VUVLO+ [V] VUVLO− [V] 25 50 75 100 125 Ta [°C] 2. 5 UVLO detection voltage (VUVLO−) vs. Temperature (Ta) 3.4 3.3 3.2 −40 −25 22 0 0 25 50 Ta [°C] 75 100 125 3.4 3.3 3.2 −40 −25 0 25 50 Ta [°C] 75 100 125 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 2. 7 Soft-start wait time (tSSW) vs. Temperature (Ta) 2. 8 VIN = 12 V 1.0 tSS [ms] tSSW [ms] 8 0.6 0.4 0.0 −40 −25 0 25 50 Ta [°C] 75 100 2. 10 0 25 50 Ta [°C] 75 100 125 Low side power MOS FET on-resistance (RLFET) vs. Temperature (Ta) 1.0 2.0 0.8 VIN = 4 V RLFET [Ω] RHFET [Ω] 4 0 −40 −25 125 2. 9 High side power MOS FET on-resistance (RHFET) vs. Temperature (Ta) 1.0 0.5 0.0 −40 −25 VIN = 12 V 0 25 50 Ta [°C] 75 100 0.4 0.0 −40 −25 125 100 50 0 25 50 Ta [°C] 75 100 125 2. 12 Low side power MOS FET leakage current (ILSW) vs. Temperature (Ta) VIN = 12 V 200 ILSW [nA] 150 0 −40 −25 0.6 VIN = 12 V VIN = 4 V 0.2 2. 11 High side power MOS FET leakage current (IHSW) vs. Temperature (Ta) VIN = 12 V 200 IHSW [nA] 6 2 0.2 2. 13 VIN = 12 V 10 0.8 1.5 Soft-start time (tSS) vs. Temperature (Ta) 150 100 50 0 25 50 Ta [°C] 75 100 125 0 −40 −25 0 25 50 Ta [°C] 75 100 125 Limit current (ILIM) vs. Temperature (Ta) VIN = 12 V 1.4 ILIM [A] 1.3 1.2 1.1 1.0 −40 −25 0 25 50 Ta [°C] 75 100 125 23 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 2. 14 High level input voltage (VSH) vs. Temperature (Ta) 2. 15 Low level input voltage (VSL) vs. Temperature (Ta) VIN = 12 V 3.0 2.5 2.5 2.0 2.0 VSL [V] VSH [V] VIN = 12 V 3.0 1.5 1.0 0.5 1.5 1.0 0.5 0.0 −40 −25 0 25 50 Ta [°C] 75 100 0.0 −40 −25 125 0 25 50 Ta [°C] 75 100 125 EN pin characteristics (Ta = +25°C) 3. 3. 1 High level input current (ISH) vs. EN pin voltage (VEN) 60 ISH [μA] 45 30 15 0 3 0 9 12 VEN [V] 15 18 Transient response characteristics The external parts shown in Table 17 are used in "4. Element Name Constant 4.7 μH 4.7 μF 10 μF Inductor Input capacitor Output capacitor Table 17 Manufacturer IOUT = 1 mA 4. 1. 2 IOUT = 600 mA 20 16 12 0 8 VIN −10 4 −20 VOUT 0 5 10 Time [ms] 15 20 16 10 VIN [V] 10 VIN [V] CLF5030NIT-4R7N-D CGA5L3X7R1H475K160AB CGA5L1X7R1C106K160AC 12 0 8 VIN −10 0 −20 −4 −30 4 0 VOUT 0 5 10 Time [ms] 15 20 −4 VOUT [V] 4. 1. 1 20 24 Part Number TDK Corporation TDK Corporation TDK Corporation Power-on (VOUT = 5.0 V, VIN = VEN =0 V → 12 V, Ta = +25°C) 4. 1 −30 Transient response characteristics". VOUT [V] 4. 6 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series 4. 2 Transient response characteristics of EN pin (VOUT = 5.0 V, VIN = 12 V, VEN = 0 V → 2 V, Ta = +25°C) 4. 2. 2 IOUT = 600 mA 3 25 2 20 1 15 1 15 0 −3 10 VEN −1 5 VOUT 5 0 10 15 20 VEN [V] 20 −2 0 0 −2 −5 −3 10 VEN −1 5 0 VOUT 5 0 10 Time [ms] VIN [V] IOUT = 1 mA 0.08 0.04 0.02 9 VOUT = 5 V 6 3 0.0 4. 3. 2 IOUT = 600 mA 18 0.06 VIN 12 0.2 0.4 0.6 0.8 1.0 0.06 12 VIN 0.04 0.02 9 0.00 6 −0.02 3 VOUT = 5 V 0.0 0.2 −800 −1200 0.4 0.6 0.8 1.0 −0.02 Time [ms] IOUT = 10 mA → 200 mA → 10 mA 0.8 4. 4. 2 IOUT = 10 mA → 600 mA → 10 mA 800 0.6 IOUT 0.4 0.2 VOUT = 5 V 0.0 0.2 0.4 0.6 Time [ms] 0.8 1.0 0.8 0.6 400 IOUT [mA] 400 −400 0.00 Load fluctuation (VOUT = 5.0 V, Ta = +25°C) 4. 4. 1 800 0 −5 0.08 15 Time [ms] 4. 4 20 Power supply fluctuation (VOUT = 5.0 V, VIN = 12 V → 16 V → 12 V, Ta = +25°C) 4. 3. 1 18 15 15 Time [ms] VIN [V] 4. 3 IOUT [mA] 25 2 VOUT [V] IOUT = 1 mA VOUT [V] VEN [V] 4. 2. 1 3 0 −400 0.0 −800 −0.2 −1200 IOUT 0.4 0.2 VOUT = 5 V 0.0 0.2 0.0 0.4 0.6 0.8 1.0 −0.2 Time [ms] 25 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Reference Data The external parts shown in Table 18 are used in " Reference Data". Condition 1. Inductor (L) CLF5030NIT-4R7N-D (4.7 μH) TDK Corporation CLF5030NIT-3R3N-D (3.3 μH) TDK Corporation Table 18 Input Capacitor (CIN) CGA5L3X7R1H475K160AB (4.7 μF) TDK Corporation CGA5L3X7R1H475K160AB (4.7 μF) TDK Corporation VOUT = 5.0 V (External parts: Condition) 1. 1 Efficiency (η) vs. Output current (IOUT) 1. 1. 1 S-19932 Series 1. 1. 2 100 VIN = 8 V 40 1 10 IOUT [mA] 100 1000 0.1 1 10 IOUT [mA] 100 1000 Output voltage (VOUT) vs. Output current (IOUT) 1. 2. 1 S-19932 Series 1. 2. 2 5.20 S-19933 Series 5.20 VIN = 8 V 5.10 VOUT [V] VOUT [V] VIN = 16 V VIN = 12 V 40 0 0.1 5.00 4.90 VIN = 8 V 5.10 5.00 4.90 VIN = 16 V VIN = 12 V 4.80 VIN = 16 V VIN = 12 V 4.80 0.1 1 10 IOUT [mA] 100 1000 0.1 1 10 IOUT [mA] 100 1000 Ripple voltage (ΔVOUT) vs. Output current (IOUT) 1. 3. 1 S-19932 Series 1. 3. 2 100 100 80 80 60 ΔVOUT [mV] ΔVOUT [mV] 60 20 VIN = 16 V 0 1. 3 VIN = 8 V 80 η [%] η [%] 60 20 1. 2 S-19933 Series 100 VIN = 12 V 80 VIN = 12 V 40 VIN = 8 V 20 VIN = 16 V 0 S-19933 Series 60 40 VIN = 8 V VIN = 12 V VIN = 16 V 20 0 0.1 26 Output Capacitor (COUT) CGA5L1X7R1C106K160AC (10 μF) TDK Corporation CGA5L1X7R1C106K160AC (10 μF) TDK Corporation 1 10 IOUT [mA] 100 1000 0.1 1 10 IOUT [mA] 100 1000 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series VOUT = 3.3 V (External parts: Condition) 2. 1 Efficiency (η) vs. Output current (IOUT) 2. 1. 1 S-19932 Series 2. 1. 2 100 VIN = 6 V 40 VIN = 16 V VIN = 16 V VIN = 12 V VIN = 8 V 40 0 0.1 1 10 IOUT [mA] 100 1000 0.1 1 10 IOUT [mA] 100 1000 Output voltage (VOUT) vs. Output current (IOUT) 2. 2. 1 S-19932 Series 2. 2. 2 3.50 S-19933 Series 3.50 VIN = 6 V 3.40 VIN = 12 V VOUT [V] VOUT [V] 60 20 VIN = 12 V 0 3.30 3.20 VIN = 6 V 3.40 VIN = 12 V 3.30 3.20 VIN = 16 V VIN = 8 V 3.10 VIN = 16 V VIN = 8 V 3.10 0.1 1 10 IOUT [mA] 100 1000 0.1 1 10 IOUT [mA] 100 1000 Ripple voltage (ΔVOUT) vs. Output current (IOUT) 2. 3. 1 S-19932 Series 2. 3. 2 100 100 80 80 60 VIN = 16 V VIN = 8 V 40 VIN = 6 V 20 ΔVOUT [mV] 2. 3 VIN = 6 V 80 η [%] η [%] 60 20 2. 2 S-19933 Series 100 VIN = 8 V 80 ΔVOUT [mV] 2. VIN = 12 V 0 S-19933 Series 60 VIN = 16 V VIN = 8 V 40 VIN = 6 V 20 VIN = 12 V 0 0.1 1 10 IOUT [mA] 100 1000 0.1 1 10 IOUT [mA] 100 1000 27 AUTOMOTIVE, 125°C OPERATION, 18 V INPUT, 600 mA SYNCHRONOUS STEP-DOWN SWITCHING REGULATOR Rev.2.3_00 S-19932A/19932B/19933A/19933B Series  Power Dissipation HTMSOP-8 HSNT-8(2030) Tj = +150°C max. 5 Tj = +150°C max. 5 Power dissipation (PD) [W] Power dissipation (PD) [W] E 4 C 3 D 2 B 1 E 4 C 3 D 2 B 1 A 0 0 A 25 50 75 100 125 150 175 0 0 25 Ambient temperature (Ta) [°C] Board A B C D E Board A B C D E 1.11 W 3.21 W 3.13 W 4.17 W HSNT-6(2025) Tj = +150°C max. Power dissipation (PD) [W] 4 E C 3 D 2 B 1 A 0 0 25 50 75 100 125 150 Ambient temperature (Ta) [°C] 28 Board Power Dissipation (PD) A 0.69 W B 0.98 W C 2.91 W D E 2.84 W 3.47 W 75 100 125 150 Ambient temperature (Ta) [°C] Power Dissipation (PD) 0.79 W 5 50 175 Power Dissipation (PD) 0.69 W 0.93 W 3.13 W 2.98 W 3.91 W 175 HTMSOP-8 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. HTMSOP8-A-Board-SD-1.0 enlarged view ABLIC Inc. HTMSOP-8 Test Board IC Mount Area (4) Board D Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Thermal via 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Copper foil layer [mm] 1 2 3 4 enlarged view (5) Board E Copper foil layer [mm] Thermal via 1 2 3 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HTMSOP8-A-Board-SD-1.0 ABLIC Inc. HSNT-8(2030) Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HSNT8-A-Board-SD-2.0 ABLIC Inc. HSNT-8(2030) Test Board IC Mount Area (4) Board D Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Thermal via 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Copper foil layer [mm] 1 2 3 4 enlarged view (5) Board E Copper foil layer [mm] Thermal via 1 2 3 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HSNT8-A-Board-SD-2.0 ABLIC Inc. HSNT-6(2025) Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. HSNT6-B-Board-SD-1.0 enlarged view ABLIC Inc. HSNT-6(2025) Test Board IC Mount Area (4) Board D Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - enlarged view (5) Board E Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HSNT6-B-Board-SD-1.0 ABLIC Inc. 2.90±0.2 1.85 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FP008-A-P-SD-2.0 TITLE HTMSOP8-A-PKG Dimensions No. FP008-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FP008-A-C-SD-1.0 TITLE HTMSOP8-A-Carrier Tape No. FP008-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FP008-A-R-SD-1.0 TITLE HTMSOP8-A-Reel No. FP008-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 4,000 0.35 1.90 0.65 0.65 0.65 No. FP008-A-L-SD-2.0 TITLE No. HTMSOP8-A -Land Recommendation FP008-A-L-SD-2.0 ANGLE UNIT mm ABLIC Inc. 2.0±0.1 8 5 (1.70) 1 4 +0.05 0.08 -0.02 0.5 0.23±0.1 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PP008-A-P-SD-2.0 TITLE HSNT-8-A-PKG Dimensions No. PP008-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.0±0.05 4.0±0.1 0.25±0.05 +0.1 ø1.0 -0 0.60±0.05 4.0±0.1 2.3±0.05 4 321 5 6 78 Feed direction No. PP008-A-C-SD-1.0 TITLE HSNT-8-A-Carrier Tape No. PP008-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PP008-A-R-SD-1.0 HSNT-8-A-Reel TITLE No. PP008-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 5,000 1.6 0.30 0.50 No. PP008-A-L-SD-1.0 TITLE No. HSNT-8-A -Land Recommendation PP008-A-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. 1.96±0.05 1.78±0.1 6 5 0.5 1 4 2 3 0.5 0.5 0.12±0.04 0.48±0.02 0.22±0.05 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PJ006-B-P-SD-1.0 TITLE HSNT-6-C-PKG Dimensions No. PJ006-B-P-SD-1.0 ANGLE UNIT mm ABLIC Inc. ø1.5 +0.1 -0 2.0±0.05 4.0±0.1 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 2.25±0.05 3 21 0.5 0.5 0.5 0.5 0.5 0.5 4 5 6 Feed direction No. PJ006-B-C-SD-1.0 TITLE HSNT-6-C-Carrier Tape No. PJ006-B-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 9.0 +1.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PJ006-B-R-SD-1.0 TITLE HSNT-6-C-Reel No. PJ006-B-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 Land Recommendation 0.50 0.35 0.50 1.44 1.78 2.10 Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Stencil Opening 1.40 0.50 0.50 No. PJ006-B-LM-SD-1.0 0.35 Caution Mask aperture ratio of the lead mounting part is 100~120%. Mask aperture ratio of the heat sink mounting part is 30%. Mask thickness: t0.12 mm Reflow atmosphere: Nitrogen atmosphere is recommended. (Oxygen concentration: 1000ppm or less) 100~120% 30% t0.12 mm TITLE HSNT-6-C -Land &Stencil Opening PJ006-B-LM-SD-1.0 No. ANGLE UNIT mm 1000ppm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-19933AA-S8T1U7 价格&库存
很抱歉,暂时无法提供与“S-19933AA-S8T1U7”相匹配的价格&库存,您可以联系我们找货
