KN13C0.7-30DS-0.4V(895)
    HRS(广濑)
    插件,P=0.4MM
    CONN 0.4MM SMD RCPT 30POS
KN13C0.7-30DS-0.4V(895) 数据手册
New Product Introduction KN13C Series Data Sheet Click Here To Order Sample Number: US-KN13CSAMPLE-21 KN13C Series 0.4mm Pitch, 0.7mm Stacking Height, Board to FPC Connectors FEATURES: Space saving : 0.7mm stacking height, 2.5mm width Robust design with metal solder tabs and ample housing thickness Highly reliable 2-point contact design Easy mating operation with clear tactile click and wide self alignment range ◗ Wide vacuum pick & place area with 2.5mm width ◗ Solder wicking prevention and contact protection against dust ◗ ◗ ◗ ◗ Highly Reliable Contact Design Wide Vacuum Pick-up Area PLUG 0.8m m Robust Design Space Saving by Narrow Width RECEPTACLE PLUG 0.8m m RECEPTACLE INSERT CASE INSERT CASE 0.7 CONTACT 0.4 0.4 CONTACT Space saving, yet sufficient vacuum pick & place area Accepts universal vacuum pick & place nozzle. 1.35 2.0 METAL FITTING METAL FITTING 2.45 2.5 Hirose Electric Co., LTD | www.hirose.com | US-KN13C-DS-21-341-1.0 | Issued March 2021 Long Effective Mating Length Insertion Force Load Curve 0.15mm Load (N) Drastic Drop Clear Tactile Click Stroke(㎜) 0.15 mm long effective mating length provides clear tactile and high contact reliability Specifications MATERIAL AND FINISH Component Material Finish, Remarks Housing LCP *1 Black / UL94V-0 Contact Phosphor bronze Au plating over Nickel barrier Metal fitting Plug Phosphor bronze Receptacle Phosphor bronze Au plating over Nickel barrier * Note 1 : This product satisfies halogen free requirements defined as 900ppm maximum chlorine. 900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine. PERFORMANCE CHARACTERISTICS Rating Current 0.3A Rating Voltage 50V AC Operating Temperature*2 -40~+85 °C Contact Resistance 100m Voltage Proof 250V AC For 1Min Insulation Resistance 100M MAX MIN (100V DC) * Note 2 : Include the temperature rising by current flow. For additional information please go to https://www.hirose.com/product/series/KN13C STAY CONNECTED Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings, or availabilities. Hirose Electric Co., LTD | www.hirose.com | US-KN13C-DS-21-341-1.0 | Issued March 2021
KN13C0.7-30DS-0.4V(895) 价格&库存
很抱歉,暂时无法提供与“KN13C0.7-30DS-0.4V(895)”相匹配的价格&库存,您可以联系我们找货
