IP303012-1
IP303012-1
    DBUNLIMITED
    插件,D=30.2mm
    压电 蜂鸣器 指示灯,内部驱动 12 V 10mA 3kHz 100dB @ 12V,10cm 通孔 PC 引脚
IP303012-1 数据手册
4 3 2 1 Part Number: DRAWN IP303012-1 8/9/2021 CJ CHECKED 8/10/2021 L.L. Description: APPROVED Piezo Indicator 8/10/2021 J.S. D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com 14.7 Ø30.2 ± 0.2 C Bottom View Side View Top View C Date Code Marking "21 H" 21=2021, H=Aug. 2 - 1 ± 0.05 17.5 ± 0.2 + _ 6 B A B Items Specifications Conditions Min. Sound Pressure Level 100 dB (@ 10cm) Tone Single Resonant Frequency 3,000 Hz Rated Voltage 12 V Voltage Range 3 ~ 20 V Max. Rated Current 10 mA Storage Temperature -30 ~ +70 °C Operating Temperature -20 ~ +60 °C REVISION HISTORY REV 1 DESCRIPTION DATE Released from Engineering 10/21/2013 J.S. Updated drawing, temperature and weight 8/10/2021 L.L. NOTES Connection Method PC Pin 1) All dimensions are in mm unless otherwise noted Mount Type Thru Hole 2) All tolerances are ± 0.5 mm unless otherwise noted Housing Material ABS Weight 7 4 APPROVED 3) All parts meet RoHS g 3 4) Subject to change or redrawn without notice 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
IP303012-1 价格&库存
很抱歉,暂时无法提供与“IP303012-1”相匹配的价格&库存,您可以联系我们找货
IP303012-1
    • 1+15.62760
    • 200+6.04800
    • 500+5.84280
    • 1000+5.73480
