DB10E1BH1
DB10E1BH1
    GLOBTEK
    SIP5
    隔离模块 直流转换器 2 输出 15V -15V 34mA,34mA 4.5V - 5.5V 输入
DB10E1BH1 数据手册
PROPRIETARY INFORMATION: REVISION DESCRIPTION INITIAL RELEASE, RFS.5273 , 5293 DMR REV A PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. DATE APPROVED 12/28/04 DMR 1. NOTES: DIMENSIONS ARE IN MM UNLESS SPECIFIED OTHERWISE. 2. ELECTRICAL SPECIFICATIONS: INPUT VOLTAGE: INPUT CURRENT: 5 VDC + 10% < 0.35A OUTPUT VOLTAGE / CURRENT: ± 15.0 VDC @ ± 34 mA OUTPUT CURRENT : OUTPUT VOLTAGE ACCURACY: OUTPUT REGULATION (LINE/LOAD): LINE REGULATION: LOAD REGULATION: TURN ON/ TURN OFF OVERSHOOT: TURN-ON DELAY: EFFICIENCY: NO LOAD TO FULL LOAD, 10% MINIMUM LOAD REQUIRED TO MAINTAIN SPECIFIED REGULATION 1 WATTS MAX 100 MHz TYP. 20 MHz BAND LIMITED < 150mV @ IV = 3.3 VDC AND 48.0VDC < 100mV @ IV = 5.0 VDC AND 24.0VDC < + 5% + 5 % MEASURED AT O/P PINS + 1.2% / 1% OF Vin MAX AT FULL LOAD 15% MAX AT FULL LOAD 4% MAX 500uS MAX RECOVERY TIME FOR 25% STEP LOAD 1 SEC MAX 70 % ISOLATION RESISTANCE: DIELECTRIC WITHSTAND VOLTAGE: OPERATING TEMPERATURE: STORAGE TEMPERATURE: HUMIDITY: 100 Mohm MIN @ 500 VDC 1000 VDC MIN. PRIMARY TO SECONDARY 0°C TO 70° C -20°C TO 80° C 0 TO 95% RELATIVE HUMIDITY OUTPUT POWER (RATED): SWITCHING FREQUENCY: OUTPUT RIPPLE (PEAK TO PEAK): Foot Note: Globtek Inc. will not be liable for the safety and performance of these power supplies if unauthorized access and repair occurs. End user should consult for the proper installation instruction the applicable UL,CSA and EN standards. Limitation of Use: Globtek product are not authorized for use as mission critical components in life support, hazardous environment, nuclear or aircraft applications without prior written approval from the CEO of Globtek Inc. Contents of this document are subject to change without prior notice DASH NO. PART NO DESCRIPTION REV. NOTES TABULATION BLOCK TOLERANCES: DECIMALS .xx +/- 0.1 .xxx +/- .005 INIT.BY: DMR DATE: 12/28/04 DATE: DRAWN: NF 12/28/04 APRVD : DMR DATE: 12/28/04 ANGULAR +/- 1 o www.globtek.com MILLIMETERS ANGULAR +/- 1 .xx +/- 0.3 .xxx +/- .013 o FSCN No.: G, Y SIZE A SCALE: NONE 186 Veterans Dr. Northvale, NJ 07647 Tel. 201-784-1000 Fax 201.784.0111 DWG TITLE: DC / DC CONVERTER, DUAL 1W, I/P: 5 VDC; O/P: ± 15 VDC MODEL NO: DB10E1BH1 PART NO: DB10E1BH1 REV. A SHEET 1 OF 2 PROPRIETARY INFORMATION: PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. 3. MECHANICAL DIMENSIONS: MM HOUSING: 7 PIN SIP PACKAGE, 94V- 0 PLASTIC MATERIAL WITH 94V-0 POTTING MATERIAL, BLACK 4. MARKING: PERMANENT PAD PRINTING, WHITE: DB10E1BH1 WWYY XXXX DATE CODE WW - WEEK YY - YEAR XXXX - USA OR CHINA 1 2 4 5 6 PIN CONNECTION PIN OUTPUT 1 +INPUT 2 - INPUT 4 - OUTPUT 5 COMMON 6 + OUTPUT www.globtek.com 186 Veterans Dr. Northvale, NJ 07647 Tel. 201-784-1000 Fax 201.784.0111 DWG TITLE: DC / DC CONVERTER, DUAL 1W, I/P: 5 VDC; O/P: ± 15 VDC MODEL NO: DB10E1BH1 PART NO: DB10E1BH1 REV. A SHEET 2 OF 2
DB10E1BH1 价格&库存
很抱歉,暂时无法提供与“DB10E1BH1”相匹配的价格&库存,您可以联系我们找货
