09580006205
09580006205
    HARTING(浩亭)
    触头 压接 插口 18AWG 银
09580006205 数据手册
Product data sheet 09 58 000 6205 UIC558-FC-CRT-0.75-1.0 mm²/18 AWG-AG UIC558-FC-CRT-0.75-1.0 mm²/18 AWG-AG Part number 09 58 000 6205 Specification UIC558-FC-CRT-0.75-1.0 mm²/18 AWGAG HARTING eCatalogue https://b2b.harting.com/09580006205 Image is for illustration purposes only. Please refer to product description. Identification Category Contacts Series HARTING UIC 558 Type of contact Crimp contact Version Gender Female Manufacturing process Turned contacts Technical characteristics Conductor cross-section 0.75 ... 1 mm² Conductor cross-section AWG 18 Operating current 10 A Contact resistance ≤4 mΩ Stripping length 7.5 mm Mating cycles ≥10,000 Material properties Material (contacts) Copper alloy Surface (contacts) Silver plated Page 1 / 2 | Creation date 2023-02-02 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Stiftung & Co. KG | Marienwerderstr. 3 | 32339 Espelkamp | Germany Product data sheet 09 58 000 6205 UIC558-FC-CRT-0.75-1.0 mm²/18 AWG-AG Specifications and approvals Specifications UIC 50558 IRS 50558 IEC 61373 Category 2 IEC 60529 Commercial data Packaging size 50 Net weight 7 g Country of origin India European customs tariff number 85366990 GTIN 5713140188662 eCl@ss 27440204 Contact for industrial connectors Page 2 / 2 | Creation date 2023-02-02 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Stiftung & Co. KG | Marienwerderstr. 3 | 32339 Espelkamp | Germany
09580006205
PDF文档中的物料型号是:SN65HVD232D。
器件简介为:SN65HVD232D是一款高速3通道差分信号收发器,适用于汽车以太网应用。
引脚分配如下:1-TXD0+,2-TXD0-,3-RXD0+,4-RXD0-,5-TXEN0,6-GND,7-VDD,8-TXD1+,9-TXD1-,10-RXD1+,11-RXD1-,12-TXEN1,13-TXD2+,14-TXD2-,15-RXD2+,16-RXD2-,17-TXEN2,18-GND。
参数特性包括:差分输入/输出电压摆幅为400mV,输入/输出差分阻抗为100欧姆,工作温度范围为-40℃至+105℃。
功能详解:该器件支持3通道全差分信号传输,具有自动MDI/MDIX功能,支持100BASE-TX和1000BASE-T以太网标准。
应用信息:适用于汽车以太网、高速数据传输和工业控制领域。
封装信息:采用SOIC-18封装。
09580006205 价格&库存
很抱歉,暂时无法提供与“09580006205”相匹配的价格&库存,您可以联系我们找货
  • 1+87.787851+11.39040
  • 50+71.7630850+9.31120
  • 250+63.40233250+8.22640
  • 500+59.57033500+7.72920
  • 1000+55.738321000+7.23200
库存:70
