ASMD0603-003
ASMD0603-003
    JDTFUSE(集电通)
    PTC自恢复保险丝 30V 20A It=90mA Ih=30mA 0603
ASMD0603-003 数据手册
PRODUCT DATASHEET Surface Mount PTC Devices ASMD0603 Series Surface Mount PTC Devices ASMD0603 Series Surface Mount PTC Devices Description The ASMD0603 series provides miniature surface mount resettable overcurrent protection with holding current from 10mA to 1A. This world’s smallest PTC is suitable for ultra portable applications where space is at a premium and the device current is low. Features ● RoHS compliant and lead-free ● Low profile ● Halogen-free ● Fast response to fault current ● Compact design saves board space ● Compatible with high temperature solders Agency Approvals Agency File Number E472196 Applications ● Mobile phones and PDAs ● USB peripherals Regulation Standard   2002/95/EC   EN14582 JDT Fuse Industrial Co., Ltd www.jdtfuse.com ● Portable MP3 and media player ● IC VCC protection ● Mobile Internet Device (MID) Page 1/8 Revised 03/20/23 ASMD0603 Series Surface Mount PTC Devices Performance Specification Model V max (V dc) I max (A) I hold I trip Pd @25°C (A) @25°C (A) Typ. (W) Maximum Time To Trip Resistance Current (A) Time (Sec) R i min R1max (Ω) (Ω) ASMD0603-001 60 20 0.01 0.03 0.5 0.2 1.0 15.0 100 ASMD0603-002 60 20 0.02 0.06 0.5 0.2 1.0 12.0 70.0 ASMD0603-002-9V 9.0 20 0.02 0.06 0.5 0.2 1.0 12.0 70.0 ASMD0603-003 30 20 0.03 0.09 0.5 0.2 1.0 6.00 50.0 ASMD0603-003-9V 9.0 20 0.03 0.09 0.5 0.2 1.0 6.00 50.0 ASMD0603-004 15 20 0.04 0.12 0.5 0.2 1.0 4.00 40.0 ASMD0603-004-24V 24 20 0.04 0.12 0.5 0.2 1.0 4.00 40.0 ASMD0603-005 15 20 0.05 0.15 0.5 0.25 1.0 3.80 30.0 ASMD0603-005-9V 9.0 20 0.05 0.15 0.5 0.25 1.0 3.80 30.0 ASMD0603-010 15 40 0.10 0.30 0.5 0.5 1.0 0.90 8.00 ASMD0603-010-24V 24 40 0.10 0.30 0.5 0.5 1.0 0.90 8.00 ASMD0603-020 9.0 40 0.20 0.50 0.5 1.0 0.6 0.55 3.50 ASMD0603-020-16V 16 40 0.20 0.50 0.5 1.0 0.6 0.55 3.50 ASMD0603-025 9.0 40 0.25 0.55 0.5 8.0 0.08 0.50 3.00 ASMD0603-025-16V 16 40 0.25 0.55 0.5 8.0 0.08 0.50 3.00 ASMD0603-035 6.0 40 0.35 0.75 0.5 8.0 0.1 0.20 1.40 ASMD0603-035-16V 16.0 40 0.35 0.75 0.5 8.0 0.1 0.20 1.40 ASMD0603-050 6.0 40 0.50 1.00 0.5 8.0 0.1 0.10 0.80 ASMD0603-050-12V 12 40 0.50 1.00 0.5 8.0 0.1 0.10 0.80 ASMD0603-060 6.0 40 0.60 1.20 0.5 8.0 0.1 0.08 0.60 ASMD0603-065 6.0 40 0.65 1.30 0.5 8.0 0.1 0.07 0.55 ASMD0603-075 6.0 40 0.75 1.40 0.5 8.0 0.1 0.06 0.45 ASMD0603-100 6.0 40 1.00 2.00 0.5 8.0 0.1 0.05 0.30 I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 2/8 Revised 03/20/23 ASMD0603 Series Surface Mount PTC Devices Environmental Specifications Test Resistance change change Resistance Conditions Conditions Passive aging     +85°C, 1000 hrs. ±5% typical Humidity aging     +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock     +85°C to -40°C, 20 times ±33% typical Resistance to solvent     MIL-STD-202,Method 215 No change MIL-STD-202,Method 201 No change Vibration     Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C Percentage of Derated Current Thermal Derating Curve 200 150 100 50 0 -40 -20 0 20 40 Temperature (°C ) 60 80 0.35A 0.4A 0.5A 0.6A 0.65A 0.75A 1.0A 0.25A 0.2A 0.1A 0.05A 0.03A 100 0.02A 0.01A Average Time-Current Curve TIME IN SECONDS 10 1 0.1 0.01 JDT Fuse Industrial Co., Ltd www.jdtfuse.com 0.01 0.1 1.0 CURRENT IN AMPERES 10 Page 3/8 Revised 03/20/23 ASMD0603 Series Surface Mount PTC Devices Thermal Derading Chart Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) Model - 40°C - 20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C ASMD0603-001 0.016 0.014 0.012 0.010 0.008 0.007 0.006 0.005 0.0035 ASMD0603-002 0.031 0.027 0.024 0.020 0.016 0.014 0.012 0.011 0.007 ASMD0603-003 0.047 0.041 0.036 0.030 0.024 0.021 0.018 0.016 0.0108 ASMD0603-004 0.052 0.048 0.044 0.040 0.032 0.028 0.024 0.020 0.012 ASMD0603-005 0.065 0.060 0.055 0.050 0.040 0.035 0.031 0.025 0.015 ASMD0603-010 0.13 0.12 0.11 0.10 0.08 0.07 0.06 0.05 0.03 ASMD0603-020 0.27 0.25 0.23 0.20 0.17 0.14 0.12 0.10 ASMD0603-025 0.32 0.29 0.27 0.25 0.21 0.18 0.16 0.14 ASMD0603-035 0.47 0.41 0.38 0.35 0.29 0.26 0.24 0.22 0.16 ASMD0603-050 0.67 0.59 0.54 0.50 0.41 0.37 0.34 0.29 0.20 ASMD0603-060 0.81 0.70 0.651 0.60 0.49 0.44 0.41 0.34 0.24 ASMD0603-065 0.87 0.76 0.71 0.65 0.54 0.48 0.44 0.37 0.26 ASMD0603-075 0.98 0.85 0.81 0.75 0.60 0.54 0.44 0.40 0.31 ASMD0603-100 1.19 1.13 1.08 1.00 0.80 0.72 0.59 0.54 0.43   0.07 0.10 Soldering Parameters TP 20~40 S TP 260 Critical Zone Ramp-up TL 217 TL to TP tL Tsmax Temperature (°C ) 3°C/second mac. Preheat Tsmin Ramp-down ts Preheat 60~180 s 25 Average Ramp-Up Rate Pb-Free Assembly (Ts max to T p) 60~150 s 200 150 Profile Feature t 25°C to peak Time ● Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free. ● Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. ● Note 1:All temperature refer to topside of the package, measured on the package body surface. ● Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. JDT Fuse Industrial Co., Ltd www.jdtfuse.com -Temperature Min(Ts min) 150°C -Temperature Max(Ts max) 200°C -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217°C -Time(tL) 60~150 seconds Peak Temperature(Tp) 260°C Ramp-Down Rate 6°C/second max. Time 25°C to Peak Temperature 8 minutes max Storage And Handling: Storage conditions 0°C~ 35°C,30% ~60%R.H. Devices may not meet specified performance if storage conditions are exceeded. Page 4/8 Revised 03/20/23 ASMD0603 Series Surface Mount PTC Devices Physical Dimensions(mm.) C A Marking D B E A Model B C D E Min. Max. Min. Max. Min. Max. Min. Min. ASMD0603-001 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-002 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-002-9V 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-003 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-003-9V 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-004 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-005 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-005-9V 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-010 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-010-24V 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-020 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-020-16V 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-025 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-025-16V 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-035 1.45 1.85 0.65 1.05 0.35 0.90 0.15 0.10 ASMD0603-035-16V 1.45 1.85 0.65 1.05 0.35 1.15 0.15 0.10 ASMD0603-050 1.45 1.85 0.65 1.05 0.55 1.15 0.15 0.10 ASMD0603-050-12V 1.45 1.85 0.65 1.05 0.55 1.15 0.15 0.10 ASMD0603-060 1.45 1.85 0.65 1.05 0.55 1.15 0.15 0.10 ASMD0603-065 1.45 1.85 0.65 1.05 0.55 1.15 0.15 0.10 ASMD0603-075 1.45 1.85 0.65 1.05 0.55 1.15 0.15 0.10 ASMD0603-100 1.45 1.85 0.65 1.05 0.55 1.15 0.15 0.10 Termination Pad Characteristics Terminal pad materials:Tin-plated Nickel-Copper Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 5/8 Revised 03/20/23 ASMD0603 Series Surface Mount PTC Devices Packaging Quantity and Marking 1.0±0.1 Part Number 1.0±0.1 Quantity SMD0603 Series 4,000 pcs/reel Tape & reel packaging per EIA481-1 0.7±0.1 0.7±0.1 Tape And Reel Specifications (mm) Governing Specifications P1 EIA 481-1 W 16.00 ± 0.3 P0 4.00 ± 0.10 P1 8.00 ± 0.10 P2 2.00 ± 0.05 A0 5.70 ± 0.10 B0 8.00 ± 0.10 B1max. 12.10 D0 1.50 + 0.1, -0 F 7.50 ± 0.05 E1 1.75 ± 0.10 E2min. 14.25 T 0.60 T1max. 0.10 K0 0.80 ± 0.1 Leader min. 390 Trailer min. 160 Reel Dimensions   A max. 178 N min. 60 W1 16.40 ± 0.5 W2 22.40 P2 D0 P0 E1 F W T D2 K0 A0 B0 H W4 W3 D C W2 W F W1 H1 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 6/8 Revised 03/20/23 ASMD0603 Series Surface Mount PTC Devices Part Number System ASMD 0603 - Special Voltage Rating(Optional) Holding Current Rating Device Dimensions: Length/width(Unit:1/100 inch) Size 1508 mm / 0603 inch Surface Mount Device Cross Reference Cross Reference Model Tyco / PolySwitch® Littelfuse / POLY-FUSE® Polytronics / EVERFUSE® ASMD0603-005 - - - ASMD0603-010 - 0603L010 SMD0603P010TF ASMD0603-020 - 0603L020 SMD0603P020TF ASMD0603-025 - 0603L025 SMD0603P025TF ASMD0603-035 - 0603L035 SMD0603P035TF ASMD0603-050 - 0603L050 SMD0603P050TF “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 7/8 Revised 03/20/23 ASMD0603 Series Surface Mount PTC Devices Application Notice 1. Operation of these PPTC devices beyond the stated maximum ratings could result in damage to the devices and lead to electrical arcing and/or fire; PPTC 器件在超过规定的最大值额定值运行可能会导致器件损坏以及导致电弧和/或火灾。 2. These PPTC devices are intended to protect against the effects of temporary over-current or over-temperature conditions and shall not be taken for use as switch. PPTC 的作用是防止临时的过流或过温造成的不良影响,不能当作开关使用。 3. Exposure to lubricants, silicon-based oils, solvents, gels, electrolytes, acids, and other related or similar materials may adversely affect the performance of PPTC devices. PPTC 接触润滑剂、硅基油、溶剂、凝胶、电解质、酸和其他相关或类似材料可能会对 PPTC 器件的性能有不利影响。 4. Circuits with inductance may generate a voltage above the rated voltage of the PPTC device and should be thoroughly evaluated within the user’s application during the PPTC selection and qualification process. 带有电感的电路可能产生高于 PPTC 额定电压的电压,因此客户在选型和认定过程中应进行彻底的评估。 5. Please do not smash, clamp, pull, dent or twist by tool during assembling process,as they may result in the PPTC damage. 在装配过程中,避免有砸、挤、拉、扭等方式外力作用于 PPTC 本体上,因为它们可能导致 PPTC 损坏。 6. Hand-soldering of PPTC devices on boards is generally not recommended.Users shall define and verify this process if needed. 不推荐使用手工焊接的方式焊接 PPTC。如果需要,用户需要定义和验证此过程。 7. Recommended storage conditions should be followed at all times , The MSL classification of PPTC is grade 2a. 必须始终遵守推荐的保存条件要求, PPTC 的 MSL 等级为 2 a级。 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 8/8 Revised 03/20/23
ASMD0603-003 价格&库存
很抱歉,暂时无法提供与“ASMD0603-003”相匹配的价格&库存,您可以联系我们找货
