97 53 18
97 53 18
    KNIPEX(凯尼派克)
    手动压接器 工具 环箍
97 53 18 数据手册
97 53 18 KNIPEX Twistor16 Self-Adjusting Crimping Pliers for End Sleeves (ferrules) With rotatable die head ● ● ● ● ● ● ● ● ● ● ● Article No. 97 53 18 EAN 4003773082729 Pliers chrome plated Handles with multi-component grips Applications End Sleeves (ferrules) Capacity in square millimetres mm² 0,14 - 16,0 Number of crimping positions 1 AWG 26 - 5 Length mm 200 Net weight g 478 For crimping end sleeves (ferrules) according to DIN 46228 parts 1 + 4 Square crimp profile, high capacity range of 0.14 to 16 mm² 360° rotatable crimping die; with 8 tactile locking positions Self-adjustment to the desired size of end sleeve (ferrule): no crimping errors due to using the wrong crimping die or to an incorrect setting Crimping of twin end sleeves (ferrules) up to 2 x 6 mm² possible Slim head for ideal accessibility Repetitive, high crimping quality due to integral lock (self-releasing mechanism) Favourable lever ratio due to toggle lever Crimping pressure has been set precisely (calibrated) in the factory, re-adjustable Handy shape and low weight provide high operation comfort Chrome vanadium electric steel in special quality, oil-hardened Crimp head can be rotated 360° for optimal accessibility, even in confined spaces Twin end sleeves (ferrules) up to 2 x 6 mm² can be crimped without adjustment Uniquely flexible: connectors can be inserted in the rotatable crimp head from almost any position technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
97 53 18 价格&库存
很抱歉,暂时无法提供与“97 53 18”相匹配的价格&库存,您可以联系我们找货
