LT86102UXE
LT86102UXE
    LONTIUM(龙迅)
    QFN-76(9x9)
    HDMI2.0 1进2出分路器 QFN76_9X9MM
LT86102UXE 数据手册
                    LT86102UXE ADVANCE INFORMATION – CONFIDENTIAL AND PROPRIETARY  LT86102UXE --- Product Brief HDMI2.0 1-In 2-Out Splitter    Digital Audio Output 1. Features  Up to four I2S interface supporting 8-channel audio, with  HDMI2.0 Receiver sample rates of 32~192 kHz and sample sizes of 16~24  Compliant with HDMI2.0b, HDMI1.4 and DVI1.0 bits  Compliant with HDCP2.3, HDCP2.2 and HDCP1.4  SPDIF interface supporting PCM, Dolby Digital, DTS digital  Data rate up to 6Gbps audio at up to 192kHz frame rate  Support 4Kx2K@60Hz  IEC60958 or IEC61937 compatible  Miscellaneous  Adaptive receiver equalization  Support data channel swap(arbitrarily) and polarity  Internal rterm calibration inversion(independent)  External crystal supports 25MHz  AC and DC couple capable  Integrated microprocessor  Support 3D and HDR  Integrated SPI master  Support 8/10/12-bit color depth  Embedded SPI flash for firmware and HDCP keys  Support TMDS descrambling for EMI/RFI reduction  Integrated 100/400kHz I2C slave for debug and firmware  Support SCDC and CEC2.0 update  Integrated EDID shadow  1.2V core power supply & 3.3V I/O power supply  5V tolerance DDC/HPD I/Os  -40°C to +125°C ambient operating temperature range  HDMI2.0 Transmitter  76-pin 9x9mm QFN package  Compliant with HDMI2.0b, HDMI1.4 and DVI1.0 2. General Description  Compliant with HDCP2.2 and HDCP1.4  Data rate up to 6Gbps The Lontium LT86102UXE HDMI2.0 Splitter features a 1:2  Support 4Kx2K@60Hz splitter compliant with HDMI2.0/1.4 specification, max 6Gbps  Programmable transmitter swing and pre-emphasis high speed data rate, adaptive equalization RX input and  Support channel swap(arbitrarily) and inversion(independent) polarity pre-emphasized TX output to support long cable application, internal TX lane swap for flexible PCB routing.  DC couple capable LT86102UXE HDMI2.0 Splitter automatically detect the cable  Downstream receiver sensing loss, and adaptively optimize the equalization setting .The  Support 3D and HDR CDR cleans the input  Support 8/10/12-bit color depth cable and cascade application. It support RX termination  Support TMDS scrambling for EMI/RFI reduction resistor calibration to further improve signal integrity.  Support SCDC and CEC2.0 LT86102UXE support DDC/SCDC compliant with HDMI2.0/  5V tolerance DDC/HPD I/Os 1.4 specification. This package is QFN76 9mmx9mm. It Lontium Semiconductor Corporation LT86102UXE Product Brief – Rev 1.0                                          1  data jitter, make it suitable for long www.lontiumsemi.com                     LT86102UXE ADVANCE INFORMATION – CONFIDENTIAL AND PROPRIETARY  operates from −40°C to +125°C.  Multiple display/TV support 3. Applications  HDMI/DVI signal splitting/repeating   LT86102UXE   Figure 3.1 Application Diagram 4. Ordering Information Table 4.1 Ordering Information Part Number Operating Temperature Range Package Packing Method LT86102UXE −40°C to +125°C QFN76 (9*9) Tray Lontium Semiconductor Corporation LT86102UXE Product Brief – Rev 1.0                                          2  www.lontiumsemi.com                     LT86102UXE ADVANCE INFORMATION – CONFIDENTIAL AND PROPRIETARY  Copyright © 2019 Lontium Semiconductor Corporation, All rights reserved. Lontium Semiconductor Proprietary & Confidential This document and the information it contains belong to Lontium Semiconductor. Any review, use, dissemination, distribution or copying of this document or its information outside the scope of a signed agreement with Lontium is strictly prohibited. LONTIUM DISCLAIMS ALL WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING THOSE OF NONINFRINGEMENT, MERCHANTABILITY, TITLE AND FITNESS FOR A PARTICULAR PURPOSE. CUSTOMERS EXPRESSLY ASSUME THEIR OWN RISH IN RELYING ON THIS DOCUMENT. LONTIUM PRODUCTS ARE NOT DESIGNED OR INTENDED FOR USE IN LIFE SUPPORT APPLIANCES, DEVICES OR SYSTEMS WHERE A MALFUNCTION OF A LONTIUM DEVICE COULD RESULT IN A PERSONAL INJURY OR LOSS OF LIFE. Lontium assumes no responsibility for any errors in this document, and makes no commitment to update the information contained herein. Lontium reserves the right to change or discontinue this document and the products it describes at any time, without notice. Other than as set forth in a separate, signed, written agreement, Lontium grants the user of this document no right, title or interest in the document, the information it contains or the intellectual property in embodies. Trademarks Lontium™ 龙迅™ and ClearEdge™ is a registered trademark of Lontium Semiconductor. All Other brand names, product names, trademarks, and registered trademarks contained herein are the property of their respective owners. Visit our corporate web page at: www.lontiumsemi.com Technical support: support@lontium.com Sales: sales@lontium.com        Lontium Semiconductor Corporation LT86102UXE Product Brief – Rev 1.0                                          3  www.lontiumsemi.com
LT86102UXE 价格&库存
很抱歉,暂时无法提供与“LT86102UXE”相匹配的价格&库存,您可以联系我们找货
