NN02-101
NN02-101
    IGNION
    ANT_3X2MM
    2.45GHz 蓝牙,Wi-Fi 芯片 RF 天线 2.4GHz ~ 2.5GHz 2.4dBi 焊接 表面贴装型 ANT_3X2MM
NN02-101 数据手册
NANO mXTEND (NN02-101) DATASHEET TM DATASHEET NANO mXTENDTM (NN02-101) NANO mXTEND™ (NN02-101) The NANO mXTEND™ antenna booster is the smallest Virtual Antenna™ ever. It´s the product of choice when you´re looking for a reliable and repetitive antenna solution for Bluetooth and Wi-Fi and you have a strictly limited device space. Product Benefits • Smallest clearance: 5mm x 5mm. • Miniature: Smallest Virtual Antenna™ form factor of 3.0 mm x 2.0 mm x 0.8 mm. • Versatile: Can be mounted either on the device corner or on the center edge. • Reliability: Off-the-Shelf standard product, no antenna part customization (electronic optimization). • Use cases: smart home, tracking devices, wearables, gaming devices, IoT modules. Operation Bands Summary • Bluetooth and Wi-Fi (2400 – 2500MHz) Last Update: October 2022 2 DATASHEET NANO mXTENDTM (NN02-101) 1. AVAILABLE SOLUTIONS SUMMARY Class Frequency Regions Frequency range More detailed info 1 Port 1 2400 MHz to 2500 MHz BLUETOOTH/Wi-Fi 2. DETAILED AVAILABLE SOLUTIONS 2.1 BLUETOOTH AND Wi-Fi SOLUTION Last Update: October 2022 3 DATASHEET NANO mXTENDTM (NN02-101) 2.1.1 ANTENNA FOOTPRINT: IN THE CORNER Technical features 2400 MHz – 2500 MHz Average Efficiency Peak Gain VSWR Radiation Pattern Polarization Weight (approx.) Temperature Impedance Dimensions (L x W x H) >55 % 2.4 dBi < 2.5:1 Omnidirectional Linear 0.01 g. -40 to +125 ºC 50 Ω 3.0 mm x 2.0 mm x 0.8 mm Technical features. Measurements from the evaluation board (80 mm x 40 mm x 1 mm). Measure A B C D E mm 1.00 0.50 1.30 0.80 0.15 Tolerance: ±0.05mm Footprint dimensions for the NANO mXTEND™ (NN02-101) antenna booster (in the corner). Last Update: October 2022 4 DATASHEET NANO mXTENDTM (NN02-101) 2.1.2 ANTENNA FOOTPRINT: IN THE MIDDLE Technical features 2400 MHz – 2500 MHz Average Efficiency Peak Gain VSWR Radiation Pattern Polarization Weight (approx.) Temperature Impedance Dimensions (L x W x H) >65 % 2.4 dBi < 3.0:1 Omnidirectional Linear 0.01 g. -40 to +125 ºC 50 Ω 3.0 mm x 2.0 mm x 0.8 mm Technical features. Measurements from the evaluation board (80 mm x 40 mm x 1 mm). Measure A B C D E F mm 1.875 1.35 0.50 1.00 3.15 4.00 Tolerance: ±0.05mm Footprint dimensions for the NANO mXTEND™ (NN02-101) antenna booster (in the middle). If you need assistance to design your matching network beyond this application note, please contact support@ignion.io, or if you are designing a different device size or a different frequency band, we can assist you in less than 24 hours. Please, try our free-of-charge1 Antenna Intelligence Cloud, which will get you a complete design report including a custom matching network for your device in 24h 1. Additional information related to Ignion’s range of R&D services is available at: https://ignion.io/rdservices/ 1 See terms and conditions for a free Antenna Intelligence Cloud service in 24h at: https://www.ignion.io/antenna-intelligence/ Last Update: October 2022 5 DATASHEET NANO mXTENDTM (NN02-101) Contact: support@ignion.io +34 935 660 710 Barcelona Av. Alcalde Barnils, 64-68 Modul C, 3a pl. Sant Cugat del Vallés 08174 Barcelona Spain Shenzen Topway Information Building, Binhai Avenue, Nanshan District, Nº 3369 – Room 2303 Shenzen, 518000 China +86 13826538470 Tampa 8875 Hidden River Parkway Suite 300 Tampa, FL 33637 USA Last Update: October 2022 6
NN02-101 价格&库存
很抱歉,暂时无法提供与“NN02-101”相匹配的价格&库存,您可以联系我们找货
