YS1505A
YS1505A
    COSEL
    DIP5 模块
    AC/DC POWER SUPPLY
YS1505A 数据手册
Ordering information AC-DC Power Supplies PCB Mount type YS5 Y 1 S 2 5 3 05A 4 1Series name 2Single output 3Output wattage 4Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT YS505A 5.0 5V 1.0A YS512A 5.4 12V 0.45A YS505A AC85 - 132 1f or DC110 - 170 0.15typ (Io=100%) 47 - 440 or DC 68typ (Io=100%) 15typ (Io=100%) YS512A SPECIFICATIONS INPUT OUTPUT Y PROTECTION CIRCUIT ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS MODEL VOLTAGE[V] ACIN 100V CURRENT[A] FREQUENCY[Hz] EFFICIENCY[%] ACIN 100V INRUSH CURRENT[A] ACIN 100V VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *1 RIPPLE[mVp-p] RIPPLE NOISE[mVp-p] *1 TEMPERATURE REGULATION[mV] 0 to +55C START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[%] HOLD-UP TIME[ms] OVERCURRENT PROTECTION INPUT-FG, OUTPUT OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE 5 12 1 0.45 20max 48max 40max 100max 80max 120max 120max 150max 50max 150max 200max (ACIN 85V, Io=100%) Fixed t5max (Rated input/output, Ta=25 C) 10typ (ACIN 85V, Io=100%) Works over 105% of rating and recovers automatically AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -10 to +70C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 30minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, C-UL Complies with FCC-B *1 Measured by 20MHz oscilloscope. * Parallel operation with other model is not possible. Y-2 70typ (Io=100%) October 08, 2013 YS5 External view Performance data ¡STATIC CHARACTERISTICS (YS512A) ¡RISE TIME & FALL TIME (YS512A) Y 20ms/DIV ¡OVERCURRENT CHARACTERISTICS (YS512A) ¡DERATING CURVE October 08, 2013 Y-3 Ordering information AC-DC Power Supplies PCB Mount type YS10 Y 1 S 2 10 3 05A 4 1Series name 2Single output 3Output wattage 4Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT YS1005A 10.0 5V 2.0A YS1012A 10.8 12V 0.9A YS1005A AC85 - 132 1f or DC110 - 170 0.3typ (Io=100%) 47 - 440 or DC 73typ (Io=100%) 15typ (Io=100%) YS1012A SPECIFICATIONS INPUT OUTPUT Y PROTECTION CIRCUIT ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS MODEL VOLTAGE[V] ACIN 100V CURRENT[A] FREQUENCY[Hz] EFFICIENCY[%] ACIN 100V INRUSH CURRENT[A] ACIN 100V VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *1 RIPPLE[mVp-p] RIPPLE NOISE[mVp-p] *1 TEMPERATURE REGULATION[mV] 0 to +55C START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[%] HOLD-UP TIME[ms] OVERCURRENT PROTECTION INPUT-FG, OUTPUT OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE 5 12 2 0.9 20max 48max 40max 100max 80max 120max 120max 150max 50max 150max 200max (ACIN 85V, Io=100%) Fixed t5max (Rated input/output, Ta=25 C) 10typ (ACIN 85V, Io=100%) Works over 105% of rating and recovers automatically AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -10 to +70C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 30minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, C-UL Complies with FCC-B *1 Measured by 20MHz oscilloscope. * Parallel operation with other model is not possible. Y-4 75typ (Io=100%) October 08, 2013 YS10 External view Performance data ¡STATIC CHARACTERISTICS (YS1012A) ¡RISE TIME & FALL TIME (YS1012A) Y 20ms/DIV ¡OVERCURRENT CHARACTERISTICS (YS1012A) ¡DERATING CURVE October 08, 2013 Y-5 Ordering information AC-DC Power Supplies PCB Mount type YS15 Y 1 S 2 15 3 05A 4 1Series name 2Single output 3Output wattage 4Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT YS1505A 15.0 5V 3.0A YS1512A 15.6 12V 1.3A YS1505A AC85 - 132 1f or DC110 - 170 0.4typ (Io=100%) 47 - 440 or DC 75typ (Io=100%) 25typ (Io=100%) YS1512A SPECIFICATIONS INPUT OUTPUT Y PROTECTION CIRCUIT ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS MODEL VOLTAGE[V] ACIN 100V CURRENT[A] FREQUENCY[Hz] EFFICIENCY[%] ACIN 100V INRUSH CURRENT[A] ACIN 100V VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *1 RIPPLE[mVp-p] RIPPLE NOISE[mVp-p] *1 TEMPERATURE REGULATION[mV] 0 to +55C START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[%] HOLD-UP TIME[ms] OVERCURRENT PROTECTION INPUT-FG, OUTPUT OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE 5 12 3 1.3 20max 48max 40max 100max 80max 120max 120max 150max 50max 150max 200max (ACIN 85V, Io=100%) Fixed t5max (Rated input/output, Ta=25 C) 10typ (ACIN 85V, Io=100%) Works over 105% of rating and recovers automatically AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -10 to +70C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 30minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, C-UL Complies with FCC-B *1 Measured by 20MHz oscilloscope. * Parallel operation with other model is not possible. Y-6 78typ (Io=100%) October 08, 2013 YS15 External view Performance data ¡STATIC CHARACTERISTICS (YS1512A) ¡RISE TIME & FALL TIME (YS1512A) Y 20ms/DIV ¡OVERCURRENT CHARACTERISTICS (YS1512A) ¡DERATING CURVE October 08, 2013 Powered by TCPDF (www.tcpdf.org) Y-7
YS1505A 价格&库存
很抱歉,暂时无法提供与“YS1505A”相匹配的价格&库存,您可以联系我们找货
