ZUS1R51205
ZUS1R51205
    COSEL
    DIP4 模块
    隔离模块 直流转换器 1 输出 5V 300mA 9V - 18V 输入
ZUS1R51205 数据手册
Ordering information DC-DC Converters PCB Mount type ZUS1R5 ZU 1 S 2 1R5 3 12 4 1Series name 2Single output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT 05 5 ZUS1R50505 1.50 VOLTAGE[V] 5 CURRENT[A] 0.30 ZUS1R50512 1.56 12 0.13 ZUS1R50515 1.50 15 0.10 ZUS1R51205 1.50 5 0.30 ZUS1R51212 1.56 12 0.13 ZUS1R51215 1.50 15 0.10 ZUS1R52405 1.50 5 0.30 ZUS1R52412 1.56 12 0.13 ZUS1R52415 1.50 15 0.10 ZUS1R54805 1.50 5 0.30 ZUS1R54812 1.56 12 0.13 ZUS1R54815 1.50 15 0.10 ZUS1R52415 ZUS1R54805 ZUS1R54812 DC36 - 72 0.088typ 0.043typ 0.045typ 71typ 73typ 73typ 15 5 12 0.10 0.30 0.13 60max 20max 48max 120max 40max 100max 120max 80max 120max 150max 120max 150max 180max 50max 150max 60max 20max 48max ZUS1R54815 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * ZUS1R50505 ZUS1R50512 ZUS1R50515 ZUS1R51205 ZUS1R51212 DC4.5 - 9 DC9 - 18 0.441typ 0.459typ 0.441typ 0.176typ 0.183typ 68typ 68typ 68typ 71typ 71typ 5 12 15 5 12 0.30 0.13 0.10 0.30 0.13 20max 48max 60max 20max 48max 40max 100max 120max 40max 100max 80max 120max 120max 80max 120max 120max 150max 150max 120max 150max 50max 150max 180max 50max 150max 20max 48max 60max 20max 48max 20max (Minimum input, Io=100%) ZUS1R51215 ZUS1R52405 ZUS1R52412 DC18 - 36 0.176typ 0.088typ 0.092typ 71typ 71typ 71typ 15 5 12 0.10 0.30 0.13 60max 20max 48max 120max 40max 100max 120max 80max 120max 150max 120max 150max 180max 50max 150max 60max 20max 48max Fixed 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, EN50178, CSA C22.2 No.60950-1 Complies with IEC60950-1 27.5X7X18mm (WXHXD) / 10g max Convection Rated input 5V, 12V, 24V or 48V DC Io=100%. Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. Series/Parallel operation with other model is not possible. ZU/ZT-2 0.043typ 73typ 15 0.10 60max 120max 120max 150max 180max 60max June 29, 2011 ZUS1R5 External view ¶Recomended size for processing PCB 4-º1±0.1 8.89 (9.305) 11.43 (8.035) 21.59 (2.955) 2.5 1±0.1 0.4 6.35 8.89 [0.25] [0.35] (1.25) 21.59 2.5 (8.035) [0.7] [0.5] 17.78 12.7 6.35 ¶Specification at B part 0.4 ¶Specification at A part 4 7 ±0.3 2-B part [0.25] (2.54) -V 2-A part 12.7 OUT 2.7 IN -V 6.35 18 +V 17.78 +V Size between case pins (0.5) 27.5 Name plate (TOP VIEW) (19.465) Outline (1.25) (1.25) 2-º1.6 4-º1.5 (1.25) [0.85] ¶Weight: 10g or less. ¶Tolerance: ± 0.5 ¶Case material: Brass The converter is in contact with the slanted area of the P.C.B. To keep mm isolation, adequate wiring on the ¶Dimensions in ¶Div.: 0.1inch [inch] mounted side is required. Performance data ¡STATIC CHARACTERISTICS (ZUS1R52405) ¡RISE TIME & FALL TIME (ZUS1R52405) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUS1R52405) ¡DERATING CURVE June 29, 2011 ZU/ZT-3 Ordering information DC-DC Converters PCB Mount type ZUS3 ZU 1 S 2 3 3 12 4 1Series name 2Single output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT 05 5 ZUS30505 3 VOLTAGE[V] 5 CURRENT[A] 0.60 ZUS30512 3 12 0.25 ZUS30515 3 15 0.20 ZUS31205 3 5 0.60 ZUS31212 3 12 0.25 ZUS31215 3 15 0.20 ZUS32405 3 5 0.60 ZUS32412 3 12 0.25 ZUS32415 3 15 0.20 ZUS34805 3 5 0.60 ZUS34812 3 12 0.25 ZUS34815 3 15 0.20 ZUS32415 ZUS34805 ZUS34812 DC36 - 72 0.167typ 0.088typ 0.082typ 75typ 71typ 76typ 15 5 12 0.20 0.60 0.25 60max 20max 48max 120max 40max 100max 120max 80max 120max 150max 120max 150max 180max 50max 150max 60max 20max 48max ZUS34815 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * ZUS30505 ZUS30512 ZUS30515 ZUS31205 ZUS31212 DC4.5 - 9 DC9 - 18 0.896typ 0.857typ 0.857typ 0.357typ 0.338typ 67typ 70typ 70typ 70typ 74typ 5 12 15 5 12 0.60 0.25 0.20 0.60 0.25 20max 48max 60max 20max 48max 40max 100max 120max 40max 100max 80max 120max 120max 80max 120max 120max 150max 150max 120max 150max 50max 150max 180max 50max 150max 20max 48max 60max 20max 48max 20max (Minimum input, Io=100%) ZUS31215 ZUS32405 ZUS32412 DC18 - 36 0.338typ 0.176typ 0.167typ 74typ 71typ 75typ 15 5 12 0.20 0.60 0.25 60max 20max 48max 120max 40max 100max 120max 80max 120max 150max 120max 150max 180max 50max 150max 60max 20max 48max Fixed 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 35X7X23mm (WXHXD) / 16g max Convection Rated input. 5V, 12V, 24V or 48V DC, Io=100% Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. Series/Parallel operation with other model is not possible. ZU/ZT-4 0.082typ 76typ 15 0.20 60max 120max 120max 150max 180max 60max June 29, 2011 ZUS3 External view ¶Recomended size for processing PCB (TOP VIEW) [0.9] [0.6] 15.24 2-B part ¶Specification at A part 16.51 (2.895) 29.21 4-º1 ±0.1 2.5 1±0.1 0.4 2.5 2.7 (9.245) ¶Specification at B part 0.4 4 7 ±0.3 2-A part 2-º1.6 [0.3] (3.81) -V 7.62 OUT IN 22.86 23 7.62 7.62 +V +V -V Outline (1.25) (1.25) Size between case pins Name plate 22.86 (0.5) 35 6.35 (1.25) 16.51 [0.25] [0.65] (1.25) 4-º1.5 29.21 [1.15] ¶Weight: 16g or less. ¶Tolerance: ± 0.5 ¶Case material: Brass The converter is in contact with the slanted area of the P.C.B. To keep mm isolation, adequate wiring on the ¶Dimensions in mounted side is required. ¶Div.: 0.1inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUS32405) ¡RISE TIME & FALL TIME (ZUS32405) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUS32405) ¡DERATING CURVE June 29, 2011 ZU/ZT-5 Ordering information DC-DC Converters PCB Mount type ZUS6 ZU 1 S 2 6 3 12 DC OUTPUT 5 1Series name 2Single output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] 05 4 ZUS6053R3 3.3 VOLTAGE[V] 3.3 CURRENT[A] 1.0 ZUS60505 5 5 1.0 ZUS60512 6 12 0.5 ZUS60515 6 15 0.4 ZUS61205 6 5 1.2 ZUS61212 6 12 0.5 ZUS61215 6 15 0.4 ZUS62405 6 5 1.2 ZUS62412 6 12 0.5 ZUS62415 6 15 0.4 ZUS6483R3 3.96 3.3 1.2 ZUS64805 6 5 1.2 ZUS64812 6 12 0.5 ZUS64815 6 15 0.4 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * ZUS6053R3 ZUS60505 ZUS60512 ZUS60515 ZUS61205 ZUS61212 ZUS61215 ZUS62405 ZUS62412 ZUS62415 ZUS6483R3 ZUS64805 ZUS64812 ZUS64815 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 72 0.94typ 1.41typ 1.63typ 1.63typ 0.69typ 0.65typ 0.65typ 0.35typ 0.33typ 0.33typ 0.09typ 0.18typ 0.17typ 0.17typ 70typ 71typ 74typ 74typ 73typ 78typ 78typ 73typ 78typ 78typ 73typ 73typ 78typ 78typ 3.3 5 12 15 5 12 15 5 12 15 3.3 5 12 15 1.0 1.0 0.5 0.4 1.2 0.5 0.4 1.2 0.5 0.4 1.2 1.2 0.5 0.4 20max 20max 48max 60max 20max 48max 60max 20max 48max 60max 20max 20max 48max 60max 40max 40max 100max 120max 40max 100max 120max 40max 100max 120max 40max 40max 100max 120max 80max 80max 120max 120max 80max 120max 120max 80max 120max 120max 80max 80max 120max 120max 120max 120max 150max 150max 120max 150max 150max 120max 150max 150max 120max 120max 150max 150max 50max 50max 150max 180max 50max 150max 180max 50max 150max 180max 50max 50max 150max 180max 20max 20max 48max 60max 20max 48max 60max 20max 48max 60max 20max 20max 48max 60max 20max (Minimum input, Io=100%) Fixed 3.20 - 3.47 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 3.20 - 3.47 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 44.5X7X28mm (WXHXD) / 25g max Convection Rated input. 5V, 12V, 24V or 48V DC, Io=100% Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. Series/Parallel operation with other model is not possible. ZU/ZT-6 June 29, 2011 ZUS6 External view ¶Recomended size for processing PCB (TOP VIEW) (9.55) 25.4 (3.2) 38.1 ¶Specification at A part 4-º 1 ±0.1 ¶Specification at B part 0.4 0.4 6.35 2.5 [0.25] (1.25) 25.4 (1.25) [1.1] [0.8] 4-º1.5 [1] 38.1 2.7 2-B part 4 7 ±0.3 2-A part 2-º1.6 [0.6] (3.81) -V 15.24 20.32 OUT IN -V 27.94 15.24 28 +V (1.25) 20.32 Outline (1.25) +V Size between case pins Name plate 27.94 (0.5) 44.5 [1.5] 2.5 1±0.1 ¶Weight: 25g or less. ¶Tolerance: ± 0.5 ¶Case material: Brass The converter is in contact with the slanted area of the P.C.B. To keep mm isolation, adequate wiring on the ¶Dimensions in mounted side is required. ¶Div.: 0.1inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUS62405) ¡RISE TIME & FALL TIME (ZUS62405) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUS62405) ¡DERATING CURVE June 29, 2011 ZU/ZT-7 Ordering information DC-DC Converters PCB Mount type ZUS10 ZU 1 S 2 10 3 12 DC OUTPUT 5 1Series name 2Single output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] 05 4 ZUS10053R3 5.28 VOLTAGE[V] 3.3 CURRENT[A] 1.6 ZUS100505 8.0 5 1.6 ZUS100512 8.4 12 0.7 ZUS100515 9.0 15 0.6 ZUS101205 10.0 5 2.0 ZUS101212 10.8 12 0.9 ZUS101215 10.5 15 0.7 ZUS102405 10.0 5 2.0 ZUS102412 10.8 12 0.9 ZUS102415 10.5 15 0.7 ZUS10483R3 6.6 3.3 2.0 ZUS104805 10.0 5 2.0 ZUS104812 10.8 12 0.9 ZUS104815 10.5 15 0.7 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * ZUS10053R3 ZUS100505 ZUS100512 ZUS100515 ZUS101205 ZUS101212 ZUS101215 ZUS102405 ZUS102412 ZUS102415 ZUS10483R3 ZUS104805 ZUS104812 ZUS104815 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 72 1.48typ 2.14typ 2.24typ 2.40typ 1.05typ 1.10typ 1.07typ 0.53typ 0.55typ 0.54typ 0.18typ 0.27typ 0.28typ 0.27typ 72typ 75typ 75typ 75typ 80typ 82typ 82typ 80typ 82typ 82typ 75typ 80typ 82typ 82typ 3.3 5 12 15 5 12 15 5 12 15 3.3 5 12 15 1.6 1.6 0.7 0.6 2.0 0.9 0.7 2.0 0.9 0.7 2.0 2.0 0.9 0.7 20max 20max 48max 60max 20max 48max 60max 20max 48max 60max 20max 20max 48max 60max 40max 40max 100max 120max 40max 100max 120max 40max 100max 120max 40max 40max 100max 120max 80max 80max 120max 120max 80max 120max 120max 80max 120max 120max 80max 80max 120max 120max 120max 120max 150max 150max 120max 150max 150max 120max 150max 150max 120max 120max 150max 150max 50max 50max 150max 180max 50max 150max 180max 50max 150max 180max 50max 50max 150max 180max 20max 20max 48max 60max 20max 48max 60max 20max 48max 60max 20max 20max 48max 60max 20max (Minimum input, Io=100%) Fixed 3.20 - 3.47 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 3.20 - 3.47 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 45X7X35mm (WXHXD) / 40g max Convection Rated input. 5V, 12V, 24V or 48V DC, Io=100% Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. Series/Parallel operation with other model is not possible. ZU/ZT-8 June 29, 2011 ZUS10 External view ¶Recomended size for processing PCB (TOP VIEW) (0.5) 45 Name plate Outline (1.25) (1.25) 2-º1.6 [1.35] [1.1] 34.29 27.94 27.94 (3.18) -V [0.8] 20.32 OUT 34.29 20.32 35 IN -V Size between case pins +V +V (9.8) 25.4 (3.45) 38.1 6.35 0.4 2.5 4-º1 ±0.1 ¶Specification at B part 0.4 ¶Specification at A part 1 ±0.1 [0.25] 2.7 2-B part 4 7 ±0.3 2-A part (1.25) 4-º1.5 [1] 38.1 2.5 ¶Weight: 40g or less. ¶Tolerance: ± 0.5 ¶Case material: Brass (1.25) 25.4 [1.5] The converter is in contact with the slanted area of the P.C.B. To keep mm isolation, adequate wiring on the ¶Dimensions in mounted side is required. ¶Div.: 0.1inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUS102405) ¡RISE TIME & FALL TIME (ZUS102405) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUS102405) ¡DERATING CURVE June 29, 2011 ZU/ZT-9 Ordering information DC-DC Converters PCB Mount type ZUS15 ZU 1 S 2 15 3 12 4 05 5 1Series name 2Single output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZUS15053R3 6.6 VOLTAGE[V] 3.3 CURRENT[A] 2.0 ZUS150505 10.0 5 2.0 ZUS150512 12.0 12 1.0 ZUS151205 12.0 5 2.4 ZUS151212 15.6 12 1.3 ZUS152405 12.0 5 2.4 ZUS152412 15.6 12 1.3 ZUS15483R3 7.92 3.3 2.4 ZUS154805 12.0 5 2.4 ZUS154812 15.6 12 1.3 SPECIFICATIONS INPUT ZU/ZT OUTPUT MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] 0 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] ZUS15053R3 ZUS150505 ZUS150512 ZUS151205 ZUS151212 ZUS152405 ZUS152412 ZUS15483R3 ZUS154805 ZUS154812 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 75 1.83typ 2.50typ 2.96typ 1.25typ 1.57typ 0.63typ 0.78typ 0.21typ 0.31typ 0.39typ 72typ 80typ 81typ 80typ 83typ 80typ 83typ 78typ 80typ 83typ 3.3 5 12 5 12 5 12 3.3 5 12 2.0 2.0 1.0 2.4 1.3 2.4 1.3 2.4 2.4 1.3 20max 20max 48max 20max 48max 20max 48max 20max 20max 48max 40max 40max 100max 40max 100max 40max 100max 40max 40max 100max 80max 80max 120max 80max 120max 80max 120max 80max 80max 120max 120max 120max 150max 120max 150max 120max 150max 120max 120max 150max 50max 50max 150max 50max 150max 50max 150max 50max 50max 150max 20max 20max 48max 20max 48max 20max 48max 20max 20max 48max 100max (Minimum input, Io=100%) Internally fixed (TRM pin open), adjustable by external VR 3.20 - 3.47 t5% 3.20 - 3.47 t5% 3.20 - 3.47 4.85 - 5.25 11.4 - 12.6 4.85 - 5.25 11.4 - 12.6 4.85 - 5.25 11.4 - 12.6 3.20 - 3.47 4.85 - 5.25 11.4 - 12.6 Works over 105% of rating and recovers automatically 4.0 - 5.25V Works at 115 - 140% of rating 4.0 - 5.25V Works at 115 - 140% of rating Between RC and -side of input:short - 1.2V ---output ON, 2.4V - 5.5V(or open)---output OFF, Compatible to TTL AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 45X8.5X50mm (WXHXD) / 55g max OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION CIRCUIT REMOTE ON/OFF INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD Convection *1 *2 *3 * Rated input. 5V, 12V, 24V or 48V DC, Io=100% Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. Series/Parallel operation with other model is not possible. ZU/ZT-10 June 29, 2011 ZUS15 External view ¶Recomended size for processing PCB 45 Name plate (4.72) 35.56 note 6-º1 note)Internal parts ¶Weight: 55g or less. ¶Tolerance: ± 0.5 ¶Case material: Aluminum (5) [0.6] [0.2] 35.56 (5) ±0.1 [0.2] (4.68) (5) 1 (5) 1 4 8.5± 0.3 (5) 5.08 (5) -V TRM 6-º1.5 5.08 15.24 -V RC 5.08 15.24 5.08 OUT 5.08 15.24 IN 15.24 5.08 50 +V [0.2] [0.6] +V (4.68) (TOP VIEW) Outline (5) (5) (5) (5) [1.4] (5) The converter is in contact with the slanted area of the P.C.B. To keep isolation, adequate wiring on the ¶Dimensions in mm mounted side is required. ¶Div.: 0.2inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUS151205) ¡RISE TIME & FALL TIME (ZUS151205) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUS151205) ¡DERATING CURVE June 29, 2011 ZU/ZT-11 Ordering information DC-DC Converters PCB Mount type ZUS25 ZU 1 S 2 25 3 12 4 05 5 1Series name 2Single output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZUS25053R3 13.2 VOLTAGE[V] 3.3 CURRENT[A] 4.0 ZUS250505 16.0 5 3.2 ZUS250512 20.4 12 1.7 ZUS251205 20.0 5 4.0 ZUS251212 25.2 12 2.1 ZUS252405 20.0 5 4.0 ZUS252412 25.2 12 2.1 ZUS25483R3 13.2 3.3 4.0 ZUS254805 20.0 5 4.0 ZUS254812 25.2 12 2.1 SPECIFICATIONS INPUT ZU/ZT OUTPUT MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] 0 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] ZUS25053R3 ZUS250505 ZUS250512 ZUS251205 ZUS251212 ZUS252405 ZUS252412 ZUS25483R3 ZUS254805 ZUS254812 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 75 3.66typ 4.00typ 4.98typ 2.03typ 2.47typ 1.02typ 1.23typ 0.35typ 0.51typ 0.62typ 72typ 80typ 82typ 82typ 85typ 82typ 85typ 78typ 82typ 85typ 3.3 5 12 5 12 5 12 3.3 5 12 4.0 3.2 1.7 4.0 2.1 4.0 2.1 4.0 4.0 2.1 20max 20max 48max 20max 48max 20max 48max 20max 20max 48max 40max 40max 100max 40max 100max 40max 100max 40max 40max 100max 80max 80max 120max 80max 120max 80max 120max 80max 80max 120max 120max 120max 150max 120max 150max 120max 150max 120max 120max 150max 50max 50max 150max 50max 150max 50max 150max 50max 50max 150max 20max 20max 48max 20max 48max 20max 48max 20max 20max 48max 100max (Minimum input, Io=100%) Internally fixed (TRM pin open), adjustable by external VR 3.20 - 3.47 t5% 3.20 - 3.47 t5% 3.20 - 3.47 4.85 - 5.25 11.4 - 12.6 4.85 - 5.25 11.4 - 12.6 4.85 - 5.25 11.4 - 12.6 3.20 - 3.47 4.85 - 5.25 11.4 - 12.6 Works over 105% of rating and recovers automatically 4.0 - 5.25V Works at 115 - 140% of rating 4.0 - 5.25V Works at 115 - 140% of rating Between RC and -side of input:short - 1.2V ---output ON, 2.4V - 5.5V(or open)---output OFF, Compatible to TTL AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 65X8.5X50mm (WXHXD) / 65g max OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION CIRCUIT REMOTE ON/OFF INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD Convection *1 *2 *3 * Rated input. 5V, 12V, 24V or 48V DC, Io=100% Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. Series/Parallel operation with other model is not possible. ZU/ZT-12 June 29, 2011 ZUS25 External view ¶Recomended size for processing PCB 65 (5) (TOP VIEW) (5) Outline (4.56) note note 55.88 6-º 1 (4.68) (5) 15.24 [0.6] 5.08 [0.2] 1 (5) 1 4 8.5± 0.3 (4.68) (5) 5.08 (5) -V TRM [0.2] 6-º1.5 [0.2] [0.6] OUT 15.24 IN -V RC 5.08 15.24 5.08 50 +V (5) +V 5.08 15.24 5.08 (5) (5) Name plate 55.88 (5) [2.2] (5) ±0.1 note)Internal parts ¶Weight: 65g or less. ¶Tolerance: ± 0.5 ¶Case material: Aluminum The converter is in contact with the slanted area of the P.C.B. To keep mm isolation, adequate wiring on the ¶Dimensions in [inch] mounted side is required. ¶Div.: 0.2inch Performance data ¡STATIC CHARACTERISTICS (ZUS251205) ¡RISE TIME & FALL TIME (ZUS251205) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUS251205) ¡DERATING CURVE June 29, 2011 Powered by TCPDF (www.tcpdf.org) ZU/ZT-13
ZUS1R51205
物料型号: - 型号遵循一定的命名规则,例如ZUS1R50505,其中包含系列名、输出类型、输出功率、输入电压和输出电压信息。
器件简介: - 这些是PCB安装类型的DC-DC转换器,具有不同的输出功率和输入/输出电压选项,适用于多种应用场景。
引脚分配: - 文档提供了详细的引脚分配图和尺寸,包括输入输出的引脚布局,以及安装时的注意事项。
参数特性: - 包括输入电压范围、输出电压和电流规格、效率、线路调节、负载调节、纹波等关键参数。
功能详解: - 描述了转换器的过流保护、过压保护、远程开关控制等功能。
应用信息: - 虽然没有具体的应用案例,但从参数特性可以推断,这些转换器适用于需要稳定直流电源的电子设备。
封装信息: - 提供了转换器的尺寸、重量和冷却方法,例如自然对流冷却。
环境规格: - 包括工作和存储时的温度、湿度和海拔高度要求。
安全认证: - 列出了转换器符合的安全标准和认证,如UL60950-1、EN60950-1等。
性能数据: - 提供了包括静态特性、上升和下降时间、过流特性和降额曲线等性能图表。
注意事项: - 文档中提到了安装时的注意事项,例如保持隔离和在PCB安装侧需要适当的布线。
ZUS1R51205 价格&库存
很抱歉,暂时无法提供与“ZUS1R51205”相匹配的价格&库存,您可以联系我们找货
ZUS1R51205
    • 1+180.537991+23.30389
