CMLW6045S1R0MST
CMLW6045S1R0MST
    CYBERMAX(思博)
    SMD,6x6mm
    功率电感 1μH ±20% 5.14A 11mΩ IND_6X6MM_SM 4.50mm 6.00 x 6.00mm 100MHz
CMLW6045S1R0MST 数据手册
CMLW6045S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems CMLW (1) (1) (2) (3) (4) 6045 (2) S (3) 100 M (4) (5) S T (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series A B C D E F a Typ. b Typ. c Typ. CMLW6045S 6.0±0.3 6.0±0.3 4.5Max. 4.9±0.3 1.55±0.3 2.90±0.3 2.8 1.7 5.7 Rev.03 Page 1 of 6 www.cybermaxtech.com CMLW6045S Series ◆ Electrical Characteristics 1) Operating and storage temperature range (individual chip without packing): cking): -25 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ℃ ℃ ℃ ~ +125℃ ◆ Construction and material ◆ REFLOW-PROFILE Rev.03 Page 2 of 6 www.cybermaxtech.com CMLW6045S Series ◆ Specification Inductance Part Number @100KHz,1V (µH) Frequency MHz Saturation Current(A) Heat Rating Current (A) DCR S.R.F Isat Irms DC Resistance ±30% (Ω) Min.Self-resonant ( ) CMLW6045S Series CMLW6045SR82NST 0.82±30% 0.008 140 10.40 5.90 CMLW6045S1R0MST 1.0±20% 0.011 100 9.85 5.14 CMLW6045S1R5MST 1.5±20% 0.012 65 8.80 4.95 CMLW6045S1R8MST 1.8±20% 0.012 74 7.60 4.95 CMLW6045S2R2MST 2.2±20% 0.014 52 6.75 4.60 CMLW6045S3R3MST 3.3±20% 0.021 32 5.90 3.70 CMLW6045S3R6MST 3.6±20% 0.021 28 5.25 3.70 CMLW6045S4R7MST 4.7±20% 0.026 24 5.00 3.35 CMLW6045S5R6MST 5.6±20% 0.029 23 4.15 3.15 CMLW6045S6R8MST 6.8±20% 0.031 20 3.90 3.00 CMLW6045S8R2MST 8.2±20% 0.043 21 3.90 2.60 CMLW6045S100MST 10±20% 0.048 15 3.20 2.45 CMLW6045S120MST 12±20% 0.058 13 2.80 2.20 CMLW6045S150MST 15±20% 0.068 12 2.50 2.05 CMLW6045S220MST 22±20% 0.089 10 2.05 1.80 CMLW6045S330MST 33±20% 0.137 7.8 1.65 1.45 CMLW6045S470MST 47±20% 0.200 6.4 1.40 1.20 CMLW6045S560MST 56±20% 0.221 6.4 1.30 1.10 CMLW6045S680MST 68±20% 0.289 6.4 1.20 1.00 CMLW6045S820MST 82±20% 0.341 4.9 1.05 0.90 CMLW6045S101MST 100±20% 0.433 4.2 0.95 0.80 CMLW6045S121MST 120±20% 0.484 4.2 0.85 0.77 CMLW6045S151MST 150±20% 0.580 4.2 0.80 0.70 CMLW6045S221MST 220±20% 0.834 3.5 0.70 0.59 CMLW6045S331MST 330±20% 1.270 2.8 0.57 0.57 CMLW6045S471MST 470±20% 2.570 1.5 0.45 0.50 ◆ Note :All test data is referenced to 20°C ambient; 2:Rated current: Isat or Irms, whichever is smaller; 3:Isat: DC current at which the inductance drops approximate 30% from its value without current; 4:Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. 1 Rev.03 Page 3 of 6 www.cybermaxtech.com CMLW6045S Series ◆ TYPICAL ELECTRICAL CHARACTERISTICS CMLW6045S Series Rev.03 Page 4 of 6 www.cybermaxtech.com CMLW6045S Series ◆Reliability Test Rev.03 Page 5 of 6 www.cybermaxtech.com CMLW6045S Series ◆Packaging and Marking: 1.Carrier Tape Dimensions: ITEM W DIM TOLE 12.00 0.3 ± A0 B0 K P1 F E D0 6.3 6.3 4.7 8.00 5.50 1.75 1.50 +0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 P0 P2 T 4.00 2.00 0.40 ±0.1 ±0.1 ±0.05 2.Taping Dimensions: 3.Reel Dimensions: 4. Packaging Quantity: : Standard Packing Quantity 1500 pcs/reel Rev.03 Page 6 of 6 www.cybermaxtech.com
