V12
EC3A-E SERIES
3 WATT 2:1 INPUT RANGE
DC-DC CONVERTERS
FEATURES
* 3W Isolated Output
* 24-Pin DIP Package
* Efficiency to 87%
* 2:1 Input Range
* Regulated Outputs
* Pi Input Filter
* Continuous Short Circuit Protection
* Meet EMI EN55032 Class A
* No Tantalum Capacitor Inside
* Wide Operating Temperature Range
* UL60950-1 2nd Approval
* Safety Meets IEC/EN/UL 62368-1
MODEL
NUMBER(1)
EC3A01□-E
EC3A02□-E
EC3A03□-E
EC3A04□-E
EC3A05□-E
EC3A06□-E
EC3A07□-E
EC3A11□-E
EC3A12□-E
EC3A13□-E
EC3A14□-E
EC3A15□-E
EC3A16□-E
EC3A17□-E
EC3A21□-E
EC3A22□-E
EC3A23□-E
EC3A24□-E
EC3A25□-E
EC3A26□-E
EC3A27□-E
EC3A31□-E
EC3A32□-E
EC3A33□-E
EC3A34□-E
EC3A35□-E
EC3A36□-E
EC3A37□-E
INPUT
VOLTAGE(2)
4.5-9 VDC
4.5-9 VDC
4.5-9 VDC
4.5-9 VDC
4.5-9 VDC
4.5-9 VDC
4.5-9 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
9-18 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
18-36 VDC
36-72 VDC
36-72 VDC
36-72 VDC
36-72 VDC
36-72 VDC
36-72 VDC
36-72 VDC
OUTPUT
VOLTAGE
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
±15 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
±15 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
±15 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
±15 VDC
3.3 VDC
OUTPUT
CURRENT
600 mA
250 mA
200 mA
±300 mA
±125 mA
±100 mA
600 mA
600 mA
250 mA
200 mA
±300 mA
±125 mA
±100 mA
600 mA
600 mA
250 mA
200 mA
±300 mA
±125 mA
±100 mA
600 mA
600 mA
250 mA
200 mA
±300 mA
±125 mA
±100 mA
600 mA
NOTE:
1. □ Can be None, M, H, HM, S, MS, HS or HMS.
2. Nominal Input Voltage is 5, 12, 24 or 48VDC.
3. Typical Value at Nominal Input Voltage and Full Load.
1
INPUT CURRENT
NO LOAD
FULL LOAD
15 mA
779 mA
15 mA
750 mA
15 mA
750 mA
25 mA
779 mA
25 mA
750 mA
25 mA
750 mA
15 mA
550 mA
7.5 mA
309 mA
10 mA
298 mA
10 mA
294 mA
15 mA
305 mA
12 mA
298 mA
15 mA
294 mA
7.5 mA
212 mA
7.5 mA
152 mA
7.5 mA
145 mA
7.5 mA
145 mA
7.5 mA
152 mA
10 mA
147 mA
10 mA
145 mA
5 mA
106 mA
3 mA
74 mA
3 mA
73 mA
5 mA
73 mA
5 mA
74 mA
5 mA
72 mA
5 mA
72 mA
3 mA
52 mA
% EFF.(3)
77
80
80
77
80
80
72
81
84
85
82
84
85
78
82
86
86
82
85
86
78
84
86
86
85
87
87
79
CAPACITOR
LOAD MAX.
2200uF
2200uF
2200uF
1000uF
1000uF
1000uF
2200uF
2200uF
2200uF
2200uF
1000uF
1000uF
1000uF
2200uF
2200uF
2200uF
2200uF
1000uF
1000uF
1000uF
2200uF
2200uF
2200uF
2200uF
1000uF
1000uF
1000uF
2200uF
V12
SPECIFICATIONS
All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range ….………….......……....... 5V …………….............. 4.5-9V
12V …..................... 9-18V
24V …..................... 18-36V
48V …..................... 36-72V
Input Surge Voltage (100ms max.) …….…… 5V ….………....... 10Vdc max.
12V …................. 25Vdc max.
24V …................. 50Vdc max.
48V …............... 100Vdc max.
Under Voltage Lockout ………...…… 5V power up ….…….……........ 4.4Vdc
5V power down ………............ 4.2Vdc
12V power up ….………...... 8.8Vdc
12V power down ………..…..... 8Vdc
24V power up ….…………..... 17Vdc
24V power down …………….... 16Vdc
48V power up ….…………........ 34Vdc
48V power down ………........... 31Vdc
Input Filter ………………………………………………….…………….. Pi Type
Efficiency ….............................................................................. See Table
Isolation Voltage:
500 VDC min. ……………………….………………… Standard Models
3K VDC min. …… (Non-Conductive Black Plastic Only) ….. Suffix “H” Models
1.5K VDC min. ………..…..……………………… Suffix “HM” Models
Isolation Resistance ….....................................................… 109 ohm min.
Isolation Capacitance ………………..…………………..…… 250pF Typ.
Switching Frequency …........................................................ 100KHz min.
Operating Ambient Temperature Range …...................... -40℃ to +85℃
De-Rating, Above 85℃ …….………….. Linearly to Zero Power at 100℃
Case Temperature (note4) ……………………………….… 100℃ max.
Cooling ……………………………………………….. Natural Convection
Storage Temperature Range ………….……....……..... -40℃ to +100℃
EMI ……………………….. Conductive EMI Meet EN55032 Class A
Humidity ................................................. 95% RH max. Non Condensing
MTBF ………. MIL-HDBK-217F ..……..…………………… 2500Khrs typ.
Dimensions ….. DIP …..… 1.25×0.80x0.40 inches (31.8x20.3×10.2 mm)
OUTPUT SPECIFICATIONS:
MS/HMS Models …..… 1.25×0.80x0.45 inches (31.8x20.3×11.4 mm)
Voltage Accuracy …...................................................................... ±1.5% max.
Voltage Balance (Dual) ….............................................................. ±1.0% max.
Temperature Coefficient ……………………..………………… ±0.05%/℃ max.
Ripple & Noise, 20MHz BW (note5) …… 3.3V/5V ……… 100mV pk-pk, max.
12V/15V ………… 1% pk-pk max.
Short Circuit Protection ……………………………………………… Continuous
S/HS Models …….…... 1.25×0.80x0.41 inches (31.8x20.3×10.4 mm)
Case Material:
Standard Models …………………….… Non-Conductive Black Plastic
Suffix “M” Models .. Black Coated Copper with Non-Conductive Base
Suffix “S” Models ………….……………….…………… SMD Package
Weight ………………………………………………….……………… 12.5g
Line Regulation ………… Single/Dual (note1) …………………. ±0.5% max.
NOTE:
Load Regulation ……..… Single (note2) …………....…………. ±0.5% max.
Dual (note3) ….….…….…………… ±1.0% max.
Start up Time …………………………………….………..….…..……10 ms max.
1. Measured from high line to low line.
2. Measured from full load to 10% load.
3. Measured from full load to 1/4 load.
4. Maximum case temperature under any operating condition should
not exceed 100℃.
5. The output noise is measured with 0.1uF MLCC across for SMD
package.
Figure1.Ty pical Derating curv e f or Natural Conv ection
120%
-40
LOAD(%)
100%
85
80%
Natural Convection
60%
40%
20%
100
0%
-40
Case A Dimensions:
-20
BOTTOM VIEW
0.08
[2.0]
CASE AS
500 VDC
Pin
9
15
10
14
11
13
12
0.600
[15.24]
0.80
[20.3]
100
0.04
[1.0]
0.02
[0.5]
0.15
[3.8]
0.40
[10.2]
0.08
[2.0]
+V Input
2,23
NC
-V Output
2,3
Common
4,5
NC
1.25
[31.8]
*0.41(10.4) for S/HS Models
2
NP
NC
NP
1,24
NC
9
Single Output
SMD
DIP
SMD
NP
NC
NP
NC
-V Input
NP
NC
NC
5
NP
NC
NP
NC
10,15
NC
NP
NC
NP
NC
11
NC
10,15
-V Output
Common
12,13
11,14
+V Output
+V Output
14
-V Input
-V Input
16
16
NP
NC
NP
NC
20,21
20,21
NP
NC
NP
NC
22,23
* NP-NO PIN
* NC-NO CONNECTION WITH PIN
Dual Output
DIP
9
12,13
0.100
[2.54]
Pin
DIP
1,24
4
SMD
1.5K & 3K VDC
Dual Output
SMD
+V Input
3,22
0.45*
[11.4]
1.25
[31.8]
16
0.43
[10.9]
3
0.80
[20.3]
22
Single Output
DIP
1.00
[25.4]
2
0.100
[2.54]
1
23
80
PIN CONNECTION
TOP VIEW
SEE NOTE
24
60
Ambient Temperature( oC)
NP
NP
NC
Common
NC
-V Output
NC
+V Output
-V Output
NP
-V Input
NC
+V Input
NP
NC
+V Output
Common
NP
NC
+V Input
NOTE:Pin Size is 0.02 ±0.002 Inch (0.5±0.05 mm)DIA
All Dimensions In Inches (mm)
Tolerances
Inches: X.XX= ±0.02 , X.XXX= ±0.010
Millimeters: X.X= ±0.5 , X.XX=±0.25
很抱歉,暂时无法提供与“EC3A17H-E”相匹配的价格&库存,您可以联系我们找货
