EC1SA01NS
EC1SA01NS
    CINCON
    SMD6 模块
    隔离模块 直流转换器 1 输出 5V 200mA 4.5V - 5.5V 输入
EC1SA01NS 数据手册
V28 EC1SAN SERIES ︳ 1WATT, UNREGULATED OUTPUT DC-DC CONVERTERS FEATURES * Industry Standard SIP/SMD Packages * Efficiency Up to 83% * 1500VDC Isolation * Low Cost * Unregulated Outputs * Low Ripple and Noise * No Tantalum Capacitors Inside MODEL NUMBER EC1SA01N EC1SA02N EC1SA03N EC1SA04N EC1SA05N EC1SA06N EC1SA11N EC1SA12N EC1SA13N EC1SA14N EC1SA15N EC1SA16N EC1SA21N EC1SA22N EC1SA23N EC1SA24N EC1SA25N EC1SA26N INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT 5 VDC 5 VDC 5 VDC 5 VDC 5 VDC 5 VDC 12 VDC 12 VDC 12 VDC 12 VDC 12 VDC 12 VDC 24 VDC 24 VDC 24 VDC 24 VDC 24 VDC 24 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC ±5 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC ±5 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC ±5 VDC 200 mA 84 mA 67 mA 42 mA 33 mA 100 mA 200 mA 84 mA 67 mA 42 mA 33 mA 100 mA 200 mA 84 mA 67 mA 42 mA 33 mA 100 mA INPUT CURRENT NO LOAD 40 mA 40 mA 40 mA 40 mA 40 mA 40 mA 15 mA 15 mA 15 mA 15 mA 15 mA 15 mA 7 mA 7 mA 7 mA 7 mA 7 mA 7 mA NOTE: 1. Nominal Input Voltage 5, 12 or 24VDC 1 FULL LOAD 253 mA 255 mA 254 mA 258 mA 254 mA 270 mA 104 mA 104 mA 103 mA 105 mA 102 mA 108 mA 52 mA 51 mA 52 mA 52 mA 50 mA 53 mA % CAPACITOR EFF. LOAD MAX. 79 79 79 78 78 74 80 81 81 80 81 77 80 83 81 81 82 79 220uF 220uF 220uF 100uF 100uF 100uF 220uF 220uF 220uF 100uF 100uF 100uF 220uF 220uF 220uF 100uF 100uF 100uF V28 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS : GENERAL SPECIFICATIONS: Input Voltage Range ….………………....................................... ±10% Efficiency …........................................……….…………….......... See Table Isolation Voltage …....................................…….………....... 1500 VDC min. 9 Isolation Resistance …..................…….…………….………. 10 ohm min. Isolation Capacitance …………………..………………………….. 10pF typ. Switching Frequency …..........................………................... 100KHz typ. Input Surge Voltage (100ms max.) ………….. 5V ................ 9Vdc max. 12V ……...... 18Vdc max. 24V ……..… 30Vdc max. Input Filter ……………………………………………..……… Capacitive OUTPUT SPECIFICATIONS : 24Vin …..….... 75KHz typ. Operating Ambient Temperature Range …………………… -40℃ to +85℃ Voltage Accuracy ………………….…………………......… ±3.0% max. Voltage Balance (Dual) ………………………………….………±1.0% max. Ripple & Noise, 20MHz BW …..... SIP Models ..........… 75mV pk-pk max. SMD Models …….. 120mV pk-pk max. De-rating, Above 85℃ …………...……… Linearly to Zero power at 100℃ Case temperature (note5) ………..………….………..…..……+100℃ max. Cooling ……………………………………..….……….. Natural Convection Storage Temperature Range ……….........………..…..... -55℃ to +125℃ Humidity .................................................... 95% RH max. Non condensing Temperature Coefficient …..........................………………..... ±0.05%/℃ Short Circuit Protection …..................….………… Momentary 1sec. max. Line Regulation (note1) ..….……………..…………………….. ±1.2% max. Load Regulation (note2) ………………..……......……………. ±10% max. MTBF ………. MIL-HDBK-217F, GB ..……..………………… 1.5Mhrs min. NOTE: Lead-Free Reflow Solder Process (SMD Models) ….. Meet J-STD-020D.1 1. Line regulation is per 1.0% change in input voltage. 2. Load regulation is for load change from 100% to 20%. 3. The output noise is measured with 0.33uF ceramic capacitor. 4. Suffix “S” to the model number with SMD packages, 5&12Vin Dimensions: SIP Models …………...…... 0.77x0.24x0.40 inches(19.5x6.1x10.2 mm) SIP Models(24Vin) ……...... 0.77x0.28 x0.40 inches(19.5x7.2x10.2 mm) SMD Models(Single) …...... 0.54×0.36×0.29 Inches (13.7×9.2×7.4 mm) models only. SMD Models(Dual) …...... 0.64×0.36×0.29 Inches (16.2×9.2×7.4 mm) Case Material ………………………….……… Non-conductive black plastic Weight ………..………………………………… 24Vin …..…..…………. 2.7g Others …….………….. 1.8g SMD Tpye ………….. 1.4g 5. Maximum case temperature under any operating condition should not be exceeded 100℃ . 6. The EC1SA2XN input terminal need to parallel with 4.7uF ceramic capacitor. CASE Miniature: All Dimensions In Inches(mm) Tolerance Inches Millimeters X.XX±0.01 X.X±0.25 X.XXX±0.005 X.XX±0.13 ±0.002 ±0.05 Pin Typical Derating curve for Natural Convection 120% 100% LOAD(%) SIP PACKAGES 20% 0% -40 24Vin 4 5 6 1 2 0.020[0.50] -20 0 20 40 60 80 o Ambient Temperature( C) 0.64(16.2) SMD PACKAGES 5-0.024(0.60) 7 6 5 1 2 3 4 0.36(9.2) 8 0.100(2.54) PIN CONNECTION Pin Single Output 1 -V Input 2 +V Input 3 No Pin -V Output 4 +V Output 5 No Pin 6 7 No Pin 8 NA PIN CONNECTION Pin Dual Output 1 -V Input 2 +V Input 3 No Pin Common 4 -V Output 5 6 No Pin 7 +V Output 8 No Pin No Pin 9 NA 10 10 9 8 7 6 0.36(9.2) 0.300(7.62) 6-0.024(0.60) 0.120(3.00) 0.300(7.60) 1 2 3 4 5 0.100(2.54) 0.400(10.2) NA:Not Available for Electrical Connection 0.54(13.7) 0.39(9.8) 0.44(11.2) 0.29(7.4) 0.01(0.3) 0.29(7.4) NA:Not Available for Electrical Connection 0.01(0.3) 0.12(3.0) Natural Convection 40% 0.28[7.2] 0.24 [6.1] 0.020[0.50] 60% 0.73 [18.5] 0.010 [0.25] 0.06 [1.6] 4 5 6 1 2 80% 0.010 [0.25] 0.07 [1.8] 0.02 [0.5] 0.100 [2.54] 0.73 [18.5] Pin 1 2 4 5 6 PIN CONNECTION Single Output Dual Output +V Input +V Input -V Input -V Input -V Output -V Output No Pin Common +V Output +V Output 0.13 [3.2] 0.08 [2.1] 0.40 [10.2] 0.77 [19.5] 0.39(9.8) 0.44(11.2) 2 100
EC1SA01NS 价格&库存
很抱歉,暂时无法提供与“EC1SA01NS”相匹配的价格&库存,您可以联系我们找货
