DAS504812
DAS504812
    COSEL
    DIP12 模块
    DC DC CONVERTER 12V
DAS504812 数据手册
Ordering information DC-DC Converters Power Module type DAS50 DA 1 S 2 O 50 3 4 05 5 1Series name 2Single output 3Output wattage 4Input voltage F :DC88 - 370V 48 :DC36 - 72V 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT DAS50F05 50 5V 10A DAS50F12 50.4 12V 4.2A DAS50F24 50.4 24V 2.1A DAS504805 50 5V 10A DAS504812 50.4 12V 4.2A SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION DAS ENVIRONMENT SAFETY OTHERS MODEL VOLTAGE[V] CURRENT[A] EFFICIENCY[%] LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +85C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +85C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +85C TEMPERATURE REGULATION[mV] -10 to +85C *2 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD DAS50F05 DAS50F12 DAS50F24 DC88 - 370 0.5typ (DCIN 130V, Io=100%) 0.25typ (DCIN 260V, Io=100%) 82typ 82typ 82typ 0.3max (By UL, CSA, VDE and DEN-AN) 5 12 24 10 4.2 2.1 20max 48max 96max 40max 100max 150max 80max 120max 120max 140max 160max 160max 150max 200max 200max 190max 230max 230max 85max 204max 408max 95max 228max 456max 20max 48max 96max 200max (DCIN 88V, Io=100%) Fixed (TRM pin open)t10% adjustable by external VR DAS504805 DAS504812 DC36 - 72 1.30typ (DCIN 48V, Io=100%) 1.28typ (DCIN 48V, Io=100%) 80typ 82typ 5 10 20max 40max 80max 140max 150max 190max 85max 95max 20max 200max (DCIN 36V, 4.85 - 5.35 11.4 - 12.6 22.8 - 25.2 4.85 - 5.35 11.4 - 12.6 Works over 105% of rating and recovers automatically Works at 115 - 140% of rating Provided Between RC and -side of input:short - 1.2V ---output ON, 2.4 - 5.5V(or open)---output OFF, Compatible TTL AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA max, DC500V 50MW min (At Room Temperature) -10 to +85C (Aluminum base plate), 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with DEN-AN Complies with UL60950-1, CSA C22.2 No.60950-1 and EN60950-1 58X12.7X115mm (WXHXD) / 120g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 Measured by attaching the electrolytic capacitor of 220mF at output. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. * Parallel operation with other model is not possible. DAS-2 12 4.2 48max 100max 120max 160max 200max 230max 210max 230max 48max Io=100%) June 29, 2011 DAS50 External view - V - V - S NC ¶Recomending size for processing PCB 5.08 15.24 5.08 Name Plate 22.86 104.14 (4.1) 102.87 (4.05) 7.62 DC IN 3.5 ±0.5 Input/Output Pin 1.2 t = 0.5 2- º4.5 12- º1.7 5.08 5.08 (0.2) 15.24 (0.2) 5.08 (0.6) 5.08 (0.2) (0.2) 5.08 5.08 (0.2) (0.2) RC - Outline 1.2 7.62 + + 7.62 22.86 7.62 (0.3) (0.9) (0.3) 2-M4(Depth:6mm) Mounting Hole for FG 0.5 2-M3(Depth:6mm) Mounting Hole for Heat Sink (TOP VIEW) 104.14 102.87 104.14 115 ±1 58 ±0.5 12.7±0.5 3.5 ±0.5 3† 5.08 = 15.24 5.3 ±1 5.3 ±1 3† 5.08 = 15.24 5.3 ±1 Name Plate TRM +S +V +V DC OUT ¶Weight: 120g or less. ¶Tolerance: ± 0.3 ¶Case: PBT ¶Base Plate: Aluminum ¶Dimensions in mm. ¶Mounting torque • Mounting Hole for Heat Sink: 0.4N·m( 5.0kgf·cm)max • Mounting Hole for FG: 1.2N·m(12.8kgf·cm)max mm (inch) ¶Div.0.2inch ¶Unit : Performance data ¡STATIC CHARACTERISTICS (DAS50F05) ¡RISE TIME & FALL TIME (DAS50F05) ¡OVERCURRENT CHARACTERISTICS (DAS50F05) ¡DERATING CURVE OUTPUT VOLTAGE V 6.0 5.0 DAS 4.0 Input Voltage 3.0 88V 370V 2.0 1.0 0 5 10 15 OUTPUT CURRENT A June 29, 2011 DAS-3 Ordering information DC-DC Converters Power Module type DAS100 DA 1 S 2 O 100 3 4 05 5 1Series name 2Single output 3Output wattage 4Input voltage F :DC88 - 370V 48 :DC36 - 72V 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT DAS100F05 100 5V 20A DAS100F12 102 12V 8.5A DAS100F24 100.8 24V 4.2A DAS1004805 100 5V 20A DAS1004812 102 12V 8.5A SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION DAS ENVIRONMENT SAFETY OTHERS MODEL VOLTAGE[V] CURRENT[A] EFFICIENCY[%] LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +85C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +85C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +85C TEMPERATURE REGULATION[mV] -10 to +85C *2 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD DAS100F05 DAS100F12 DAS100F24 DC88 - 370 1.0typ (DCIN 130V, Io=100%) 0.5typ (DCIN 260V, Io=100%) 82typ 82typ 82typ 0.3max (By UL, CSA, VDE and DEN-AN) 5 12 24 20 8.5 4.2 20max 48max 96max 40max 100max 150max 80max 120max 120max 140max 160max 160max 150max 200max 200max 190max 230max 230max 85max 204max 408max 95max 228max 456max 20max 48max 96max 200max (DCIN 88V, Io=100%) Fixed (TRM pin open)t10% adjustable by external VR DAS1004805 DAS1004812 DC36 - 72 2.60typ (DCIN 48V, Io=100%) 2.59typ (DCIN 48V, Io=100%) 80typ 82typ 5 20 20max 40max 80max 140max 150max 190max 85max 95max 20max 200max (DCIN 36V, 4.85 - 5.35 11.4 - 12.6 22.8 - 25.2 4.85 - 5.35 11.4 - 12.6 Works over 105% of rating and recovers automatically Works at 115 - 140% of rating Provided Between RC and -side of input:short - 1.2V ---output ON, 2.4 - 5.5V(or open)---output OFF, Compatible TTL AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA max, DC500V 50MW min (At Room Temperature) -10 to +85C (Aluminum base plate), 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with DEN-AN Complies with UL60950-1, CSA C22.2 No.60950-1 and EN60950-1 58X12.7X130mm (WXHXD) / 150g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 Measured by attaching the electrolytic capacitor of 220mF at output. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C,with the input voltage held constant at the rated input/output. * Parallel operation with other model is not possible. DAS-4 12 8.5 48max 100max 120max 160max 200max 230max 210max 230max 48max Io=100%) June 29, 2011 DAS100 External view - V - V - S CB 7.62 22.86 7.62 (0.3) (0.9) (0.3) 118.11 119.38 5.3 ±1 5.08 15.24 5.08 (TOP VIEW) 119.38 (4.7) 118.11 (4.65) 12.7±0.5 3.5 ±0.5 119.38 130 ±1 58 ±0.5 ¶Recomending size for processing PCB 3†5.08 =15.24 5.3 ±1 3†5.08 =15.24 5.3 ±1 Name Plate TRM +S +V +V DC OUT Outline 2-º4.5 2-M4(Depth:6mm) Mounting Hole for FG 5.08 5.08 (0.2) 15.24 (0.2) 5.08 (0.6) 5.08 (0.2) (0.2) 5.08 5.08 (0.2) (0.2) 0.5 2-M3(Depth:6mm) Mounting Hole for Heat Sink 12-º1.7 1.2 Name Plate 22.86 - + + 7.62 RC 7.62 Input/Output Pin 3.5 ±0.5 DC IN 1.2 t = 0.5 ¶Weight: 150g or less. ¶Tolerance: ± 0.3 ¶Case: PBT ¶Base Plate: Aluminum ¶Dimensions in mm. ¶Mounting torque • Mounting Hole for Heat Sink: 0.4N·m( 5.0kgf·cm)max • Mounting Hole for FG: 1.2N·m(12.8kgf·cm)max mm (inch) ¶Div.0.2inch ¶Unit : Performance data ¡STATIC CHARACTERISTICS (DAS100F05) ¡RISE TIME & FALL TIME (DAS100F05) ¡OVERCURRENT CHARACTERISTICS (DAS100F05) ¡DERATING CURVE DAS June 29, 2011 Powered by TCPDF (www.tcpdf.org) DAS-5
DAS504812 价格&库存
很抱歉,暂时无法提供与“DAS504812”相匹配的价格&库存,您可以联系我们找货
