EC5A-12S15
EC5A-12S15
    CINCON
    DIP14 模块
    非隔离 PoL 模块 直流转换器 1 输出 15V 666mA 9V - 32V 输入
EC5A-12S15 数据手册
http://www.cincon.com/ REVISION: May 30, 2013 V14 EC5A SERIES ︳ 6-24WATT WIDE INPUT DC-DC CONVERTERS FEATURES * 6-24W Non-Isolated Output * DIP-24/SMD Package * Efficiency to 94% * Regulated Outputs * Input LC Filter MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE OUTPUT CURRENT EC5A-05S33 4.7-6 VDC 3.3 VDC 2000 mA 15 mA 1553 mA 85 DIP-24 EC5A-12S33 EC5A-12S05 9-32 VDC 9-32 VDC 3.3 VDC 5 VDC 2000 mA 2000 mA 15 mA 15 mA 655 mA 947 mA 84 88 DIP-24 DIP-24 EC5A-12S12 9-32 VDC 12 VDC 830 mA 954 mA 87 DIP-24 EC5A-12S15 9-32 VDC 15 VDC 666 mA 15 mA 15 mA 957 mA 87 DIP-24 EC5A-24S12 EC5A-24S15 16-32 VDC 19-32 VDC 12 VDC 15 VDC 1600 mA 1600 mA 15 mA 15 mA 860 mA 1064 mA 93 94 DIP-24 DIP-24 NOTE: 1. Nominal Input Voltage: 5, 12 or 24 VDC 1 % INPUT CURRENT CASE NO LOAD FULL LOAD EFF. http://www.cincon.com/ REVISION: May 30, 2013 V14 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: NOTE: Input Voltage Range ....……………..........….......... 5.0V ....................... 4.7-6V 12V ......................... 9-32V 24V ....................... 16-32V 24V ....................... 19-32V Input Filter ………………………………………………….…….……..... LC Type 1. Measured from high line to low line. 2. Measured from full load to 10% load. 3. Suffix “S” to the model number with SMD packages. 4. Maximum case temperature under any operating condition should not be exceeded 100℃ . OUTPUT SPECIFICATIONS: Voltage Accuracy .......................................................................... ±2.0% max. Temperature Coefficient ………………………………………..…… ±0.05%/℃ Ripple & Noise, 20MHz BW ………… 3.3V/5V ……..…… 100mV pk-pk max. 12V/15V ……….……. 1% pk-pk max. Over Current Protection …………………………….……………… 120 ~ 160% Line Regulation (note1) …………………………………….........…±0.5% max. Load Regulation (note2) …………..………….…….......……….... ±0.5% max. Typical Derating curve for Natural Convection 120% GENERAL SPECIFICATIONS: 71 -25 LOAD(%) Efficiency .......................................................................................... See Table Switching Frequency .................................................................. 150KHz typ. Isolation Voltage (Input/Output) …………………………………… Non-Isolation Operating Ambient Temperature Range .................................. -25℃ to +71℃ De-rating, Above 71℃ …………………… Linearly to Zero power at 100℃ Case Temperature (note4) ……………........................................ 100℃ max. Cooling ……………………………………………….. Natural Convection Storage Temperature Range ………....….......……........ -40℃ to +100℃ Dimensions …… DIP ….……..… 1.25x0.80x0.40 inches(31.8x20.3x10.2 mm) SMD …..…..… 1.25x0.80x0.45 inches(31.8x20.3x11.4 mm) Weight …………………………………………………………..…………... 17.8g Case Material …………Black Coated Copper with Non-conductive Base 100% 80% 60% Natural Convection 40% 20% 0% -25 100 0 25 50 75 Ambient Temperature(oC) 100 Case A Dimensions: NOTE:Pin Size is 0.02±0.002 Inch (0.5±0.05 mm)DIA All Dimensions In Inches (mm) Tolerances Inches: X.XX= ±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX=±0.25 CASE AS PIN CONNECTION SEE NOTE Pin BOTTOM VIEW TOP 1,24 VIEW 2,3 4,5 9,16 Function DIP SMD NP NC -V Input -V Output 10,15 11,14 NC NP NC +V Output 12,13 NP NC 20,21 NP NC 22,23 +V Input * NC-NO CONNECTION WITH PIN * NP-NO PIN 2
EC5A-12S15 价格&库存
很抱歉,暂时无法提供与“EC5A-12S15”相匹配的价格&库存,您可以联系我们找货
