YAS1012E
YAS1012E
    COSEL
    DIP5 模块
    AC/DC CONVERTER 12V 11W
YAS1012E 数据手册
Ordering information AC-DC Power Supplies PCB Mount type YAS5 YA 1 S 2 5 3 05 4 E 5 1Series name 2Single output 3Output wattage 4Output voltage 5UL recognized,TuV approved CSA certified:E R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT YAS505 5.0 5V 1.0A YAS512 5.4 12V 0.45A YAS505 AC85 - 264 1f or DC110 - 370 0.07typ (Io=100%) 47 - 440 or DC 65typ 20typ (Io=100%) 40typ (Io=100%) YAS512 SPECIFICATIONS INPUT YA OUTPUT PROTECTION CIRCUIT ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS MODEL VOLTAGE[V] ACIN 200V CURRENT[A] FREQUENCY[Hz] EFFICIENCY[%] ACIN 100V INRUSH CURRENT[A] ACIN 200V VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *1 RIPPLE[mVp-p] RIPPLE NOISE[mVp-p] *1 TEMPERATURE REGULATION[mV] 0 to +55C OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[%] HOLD-UP TIME[ms] OVERCURRENT PROTECTION INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE 5 12 1 0.45 20max 48max 40max 100max 80max 120max 120max 150max 50max 150max Fixed t5max (Rated input/output, Ta=25 C) 10typ (ACIN 85V, Io=100%) Works over 105% of rating and recovers automatically AC3,000V 1minute, Cutoff current = 15mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current=100mA, DC500V 50MWmin (At Room Temperature) -10 to +70C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, EN50178, CSA C22.2 No.60950-1 Complies with IEC60950-1 Complies with FCC-B, VCCI-B, Additional capacitors required for meeting CISPR22-B, EN55022-B (External Fuse is required) *1 Measured by 20MHz oscilloscope. * Parallel operation with other model is not possible. YA-2 67typ October 08, 2013 YAS5 External view Performance data ¡STATIC CHARACTERISTICS (YAS512 ) ¡RISE TIME (YAS512 ) YA 100 ms/DIV ¡OVERCURRENT CHARACTERISTICS (YAS512 ) ¡DERATING CURVE [ª] October 08, 2013 YA-3 Ordering information AC-DC Power Supplies PCB Mount type YAS10 YA 1 S 2 10 3 05 4 E 5 1Series name 2Single output 3Output wattage 4Output voltage 5UL recognized,TuV approved CSA certified:E R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT YAS1005 10.0 5V 2.0A YAS1012 10.8 12V 0.9A YAS1005 AC85 - 264 1f or DC110 - 370 0.14typ (Io=100%) 47 - 440 or DC 70typ 20typ (Io=100%) 40typ (Io=100%) YAS1012 SPECIFICATIONS INPUT YA OUTPUT PROTECTION CIRCUIT ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS MODEL VOLTAGE[V] ACIN 200V CURRENT[A] FREQUENCY[Hz] EFFICIENCY[%] ACIN 100V INRUSH CURRENT[A] ACIN 200V VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *1 RIPPLE[mVp-p] RIPPLE NOISE[mVp-p] *1 TEMPERATURE REGULATION[mV] 0 to +55C OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[%] HOLD-UP TIME[ms] OVERCURRENT PROTECTION INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE 5 12 2 0.9 20max 48max 40max 100max 80max 120max 120max 150max 50max 150max Fixed t5max (Rated input/output, Ta=25 C) 10typ (ACIN 85V, Io=100%) Works over 105% of rating and recovers automatically AC3,000V 1minute, Cutoff current = 15mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current=100mA, DC500V 50MWmin (At Room Temperature) -10 to +70C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, EN50178, CSA C22.2 No.60950-1 Complies with IEC60950-1 Complies with FCC-B, VCCI-B, Additional capacitors required for meeting CISPR22-B, EN55022-B (External Fuse is required) *1 Measured by 20MHz oscilloscope. * Parallel operation with other model is not possible. YA-4 72typ October 08, 2013 YAS10 External view Performance data ¡STATIC CHARACTERISTICS (YAS1012 ) ¡RISE TIME (YAS1012 ) YA 100 ms/DIV ¡OVERCURRENT CHARACTERISTICS (YAS1012 ) ¡DERATING CURVE [ª] October 08, 2013 Powered by TCPDF (www.tcpdf.org) YA-5
YAS1012E 价格&库存
很抱歉,暂时无法提供与“YAS1012E”相匹配的价格&库存,您可以联系我们找货
