EC4AB04H
EC4AB04H
    CINCON
    DIP14 模块
    隔离模块 直流转换器 2 输出 12V -12V 230mA,230mA 9V - 18V 输入
EC4AB04H 数据手册
V15 EC4AB SERIES ︳ 5-6 WATT 2:1 INPUT RANGE DC-DC CONVERTERS FEATURES * 5-6W Isolated Output * DIP-24/SMD Package * Efficiency to 84% * Regulated Outputs * Pi Input Filter * Continuous Short Circuit Protection * Meets EN55032 Class B, Conducted * Remote On/Off (Option) * Safety Meets IEC/EN/UL 62368-1 MODEL NUMBER(1) INPUT VOLTAGE(2) OUTPUT VOLTAGE OUTPUT CURRENT EC4AB01□ EC4AB02□ EC4AB03□ EC4AB04□ EC4AB05□ EC4AB06□ EC4AB07□ EC4AB11□ EC4AB12□ EC4AB13□ EC4AB14□ EC4AB15□ EC4AB16□ EC4AB17□ EC4AB21□ EC4AB22□ EC4AB23□ EC4AB24□ EC4AB25□ EC4AB26□ EC4AB27□ 9-18VDC 9-18VDC 9-18VDC 9-18VDC 9-18VDC 9-18VDC 9-18VDC 18-36VDC 18-36VDC 18-36VDC 18-36VDC 18-36VDC 18-36VDC 18-36VDC 36-72VDC 36-72VDC 36-72VDC 36-72VDC 36-72VDC 36-72VDC 36-72VDC 5VDC 12VDC 15VDC ±12VDC ±15VDC ±5VDC 3.3VDC 5VDC 12VDC 15VDC ±12VDC ±15VDC ±5VDC 3.3VDC 5VDC 12VDC 15VDC ±12VDC ±15VDC ±5VDC 3.3VDC 1000 mA 470 mA 400 mA ±230 mA ±190 mA ±500 mA 1000 mA 1000 mA 470 mA 400 mA ±230 mA ±190 mA ±500 mA 1000 mA 1000 mA 470 mA 400 mA ±230 mA ±190 mA ±500 mA 1000 mA NOTE: 1. □ Can be None, M, H, HM, MS, HMS, HT, HMT or HMTS. 2. Nominal Input voltage 12, 24 or 48 VDC 3. Typical Value at Nominal Input Voltage and Full Load. 1 INPUT CURRENT NO LOAD 7.5 mA 7.5 mA 7.5 mA 12 mA 12 mA 12 mA 7.5 mA 5 mA 5 mA 5 mA 7.5 mA 7.5 mA 7.5 mA 5 mA 2 mA 2 mA 2 mA 3 mA 3 mA 3 mA 3 mA FULL LOAD 548 mA 588 mA 617 mA 568 mA 586 mA 548 mA 382 mA 264 mA 283 mA 298 mA 284 mA 290 mA 264 mA 188 mA 132 mA 143 mA 154 mA 142 mA 148 mA 132 mA 94 mA % EFF.(3) CASE 76 80 81 81 81 76 72 79 83 84 81 82 79 73 79 82 81 81 80 79 73 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 DIP-24 V15 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: ISOLATION VOLTAGE: Input Voltage Range ....……………..........….......... 12V ....................... 9-18V 24V .................... 18-36V 48V .................... 36-72V 500 VDC min. …………………………………………… Standard Models 3K VDC min. (note4) …………………………………… Suffix “H” Models 1.5K VDC min. …………..…………………………… Suffix “HM” Models Positive Logic Remote On/Off (See note6) CASE MATERIAL: Input Filter ……………………………………………….….…….……….. Pi Type Standard Models …………….…………… Non-Conductive Black Plastic OUTPUT SPECIFICATIONS: Suffix “M” Models ………... Black Coated Copper with Non-Conductive Base Voltage Accuracy …....................................................................... ±2.0% max. NOTE: Voltage Balance (Dual) ….............................................................. ±1.0% max. Temperature Coefficient ……………………………………… ±0.05%/℃ max. Ripple & Noise, 20MHz BW ………….… 3.3V/5V ………… 100mV pk-pk max. 12V/15V ……………. 1% pk-pk max. Short Circuit Protection ……………………………………………… Continuous Line Regulation Single/Dual (note1) …….…………………......…±0.5% max. Load Regulation (note2) Single ……………….……....…………. ±0.5% max. Dual (note3) ….…………………………±1.0% max. 1. Measured from high line to low line. 2. Measured from full load to 10% load. 3. Measured from full load to 1/4 load. 4. Non-conductive black plastic only. 5. Suffix “T” to the model number with remote on/off for “H”/”HM” versions only. 6. Logic Compatibility …. CMOS or Open Collector TTL, ref. to –Vin Module on ……………..……..……… >5.5VDC or open circuit Module off …….……………….……………………. 0 to
EC4AB04H 价格&库存
很抱歉,暂时无法提供与“EC4AB04H”相匹配的价格&库存,您可以联系我们找货
