V15
EC4AB SERIES
5-6 WATT 2:1 INPUT RANGE
DC-DC CONVERTERS
FEATURES
* 5-6W Isolated Output
* DIP-24/SMD Package
* Efficiency to 84%
* Regulated Outputs
* Pi Input Filter
* Continuous Short Circuit Protection
* Meets EN55032 Class B, Conducted
* Remote On/Off (Option)
* Safety Meets IEC/EN/UL 62368-1
MODEL
NUMBER(1)
INPUT
VOLTAGE(2)
OUTPUT
VOLTAGE
OUTPUT
CURRENT
EC4AB01□
EC4AB02□
EC4AB03□
EC4AB04□
EC4AB05□
EC4AB06□
EC4AB07□
EC4AB11□
EC4AB12□
EC4AB13□
EC4AB14□
EC4AB15□
EC4AB16□
EC4AB17□
EC4AB21□
EC4AB22□
EC4AB23□
EC4AB24□
EC4AB25□
EC4AB26□
EC4AB27□
9-18VDC
9-18VDC
9-18VDC
9-18VDC
9-18VDC
9-18VDC
9-18VDC
18-36VDC
18-36VDC
18-36VDC
18-36VDC
18-36VDC
18-36VDC
18-36VDC
36-72VDC
36-72VDC
36-72VDC
36-72VDC
36-72VDC
36-72VDC
36-72VDC
5VDC
12VDC
15VDC
±12VDC
±15VDC
±5VDC
3.3VDC
5VDC
12VDC
15VDC
±12VDC
±15VDC
±5VDC
3.3VDC
5VDC
12VDC
15VDC
±12VDC
±15VDC
±5VDC
3.3VDC
1000 mA
470 mA
400 mA
±230 mA
±190 mA
±500 mA
1000 mA
1000 mA
470 mA
400 mA
±230 mA
±190 mA
±500 mA
1000 mA
1000 mA
470 mA
400 mA
±230 mA
±190 mA
±500 mA
1000 mA
NOTE:
1. □ Can be None, M, H, HM, MS, HMS, HT, HMT or HMTS.
2. Nominal Input voltage 12, 24 or 48 VDC
3. Typical Value at Nominal Input Voltage and Full Load.
1
INPUT CURRENT
NO LOAD
7.5 mA
7.5 mA
7.5 mA
12 mA
12 mA
12 mA
7.5 mA
5 mA
5 mA
5 mA
7.5 mA
7.5 mA
7.5 mA
5 mA
2 mA
2 mA
2 mA
3 mA
3 mA
3 mA
3 mA
FULL LOAD
548 mA
588 mA
617 mA
568 mA
586 mA
548 mA
382 mA
264 mA
283 mA
298 mA
284 mA
290 mA
264 mA
188 mA
132 mA
143 mA
154 mA
142 mA
148 mA
132 mA
94 mA
% EFF.(3) CASE
76
80
81
81
81
76
72
79
83
84
81
82
79
73
79
82
81
81
80
79
73
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
DIP-24
V15
SPECIFICATIONS
All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
ISOLATION VOLTAGE:
Input Voltage Range ....……………..........….......... 12V ....................... 9-18V
24V .................... 18-36V
48V .................... 36-72V
500 VDC min. …………………………………………… Standard Models
3K VDC min. (note4) …………………………………… Suffix “H” Models
1.5K VDC min. …………..…………………………… Suffix “HM” Models
Positive Logic Remote On/Off (See note6)
CASE MATERIAL:
Input Filter ……………………………………………….….…….……….. Pi Type
Standard Models …………….…………… Non-Conductive Black Plastic
OUTPUT SPECIFICATIONS:
Suffix “M” Models ………... Black Coated Copper with Non-Conductive Base
Voltage Accuracy …....................................................................... ±2.0% max.
NOTE:
Voltage Balance (Dual) ….............................................................. ±1.0% max.
Temperature Coefficient ……………………………………… ±0.05%/℃ max.
Ripple & Noise, 20MHz BW ………….… 3.3V/5V ………… 100mV pk-pk max.
12V/15V ……………. 1% pk-pk max.
Short Circuit Protection ……………………………………………… Continuous
Line Regulation Single/Dual (note1) …….…………………......…±0.5% max.
Load Regulation (note2) Single ……………….……....…………. ±0.5% max.
Dual (note3) ….…………………………±1.0% max.
1. Measured from high line to low line.
2. Measured from full load to 10% load.
3. Measured from full load to 1/4 load.
4. Non-conductive black plastic only.
5. Suffix “T” to the model number with remote on/off for “H”/”HM” versions only.
6. Logic Compatibility …. CMOS or Open Collector TTL, ref. to –Vin
Module on ……………..……..……… >5.5VDC or open circuit
Module off …….……………….……………………. 0 to
很抱歉,暂时无法提供与“EC4AB16HM”相匹配的价格&库存,您可以联系我们找货
