H6OSC-SUG-7.3728M
H6OSC-SUG-7.3728M
    YXC(扬兴科技)
    HC-49S/SMD
    无源晶振 7.3728MHz ±20ppm 20pF 60Ω HC-49S/SMD 表面贴装 -20℃~+70℃ 和老料号X49SM73728MSD2SC-1完全相同
H6OSC-SUG-7.3728M 数据手册
Crystal Unit HC-49SMD Applications Features ‧Industrial Control Consumers. ‧Dimensions: 11.5 x 4.80 x3.8mm. ‧Standard Frequency: 3.2768~64MHz ‧Surface mount type crystal units. ‧A great number of standard frequencies. Specifications(规格参数) Item Symbol Specifications f_nom 3.2768~64MHz - AT Fundamental CL 12pF, 20pF, or specify Frequency Tolerance(频率偏差) (at 25℃ ) f_tol ±10ppm, ±20ppm, or specify Frequency Versus Temperature Characteristics(频率-温度特性) f_tem ±20ppm, or specify Operating Temperature(工作温度) T_use -20~+70℃, or specify Storage Temperature(储存温度) T_stg -40~+85℃ Shunt Capacitance(静态电容) C0 7pF Max. Level of Drive(激励电平) DL 1~500μW Max.(100μW typical) f_age ±3ppm/year Max. Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Aging (老化)(at 25℃ ) Equivalent Series Resistance(等效串联电阻(ESR)) HC-49SMD 3.2768 ~ 4MHz 180 Ω Max. 6 ~ 7MHz 80 Ω Max. 4 ~ 5MHz 120 Ω Max. 7 ~ 10MHz 60 Ω Max. 5 ~ 6 MHz 100 Ω Max. 10 ~ 30MHz 40 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) 4.47±0.5 9.9±0.1 3.5±0.5 12.6±0.5 www.yxc.hk 1
H6OSC-SUG-7.3728M 价格&库存
很抱歉,暂时无法提供与“H6OSC-SUG-7.3728M”相匹配的价格&库存,您可以联系我们找货
H6OSC-SUG-7.3728M
  • 10+0.41850
  • 100+0.39150
  • 500+0.36450
  • 2000+0.32400
  • 5000+0.31050
  • 10000+0.30240
库存:1863
H6OSC-SUG-7.3728M
  • 1+0.55826
  • 50+0.32857
  • 1000+0.29561
库存:1004
H6OSC-SUG-7.3728M
  • 5+0.60150
  • 50+0.48730
  • 150+0.40970
  • 500+0.37700
  • 1000+0.35340
  • 3000+0.33260
库存:802
