H1OSI-SUG-25M
H1OSI-SUG-25M
    YXC(扬兴科技)
    HC49S
    无源晶振 25MHz ±20ppm 20pF 40Ω HC49S 插件 和老料号X49SD25MSD2SI完全相同
H1OSI-SUG-25M 数据手册
Crystal Unit HC-49US DIP Applications Features Consumers. ‧Standard Frequency: 3.2768~32MHz ‧Industrial Control ‧Dimensions: 11.5 x 4.50 x3.68mm. ‧Through hole type crystal units. ‧A great number of standard frequencies. Specifications(规格参数) Item Symbol Specifications f_nom 3.2768~32MHz - AT Fundamental CL 12pF, 20pF, or specify Frequency Tolerance(频率偏差) (at 25℃ ) f_tol ±10ppm, ±20ppm, or specify Frequency Versus Temperature Characteristics(频率-温度特性) f_tem ±20ppm,or specify Operating Temperature(工作温度) T_use -20~+70℃,or specify Storage Temperature(储存温度) T_stg -40~+85℃ Shunt Capacitance(静态电容) C0 7pF Max Level of Drive(激励电平) DL 1~500μW Max.(100μW typical) f_age ±3ppm/year Max. Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Aging (老化)(at 25℃ ) Equivalent Series Resistance(等效串联电阻(ESR)) HC-49US 3.2768 ~ 4MHz 180 Ω Max. 6 ~ 17MHz 80 Ω Max. 4 ~ 5MHz 120 Ω Max. 7 ~ 10MHz 60 Ω Max. 5 ~ 6 MHz 100 Ω Max. 10 ~ 32MHz 40 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) 10.8±0.1 3.45±0.1 0.45±0.05 www.yxc.hk 1
H1OSI-SUG-25M 价格&库存
很抱歉,暂时无法提供与“H1OSI-SUG-25M”相匹配的价格&库存,您可以联系我们找货
H1OSI-SUG-25M
  • 10+0.37200
  • 100+0.34800
  • 500+0.32400
  • 2000+0.28800
  • 5000+0.27600
  • 10000+0.26880
库存:7000
H1OSI-SUG-25M
  • 5+0.56770
  • 50+0.45850
  • 150+0.38460
  • 500+0.35350
  • 1000+0.33130
  • 3000+0.31160
库存:427
H1OSI-SUG-25M
  • 1+0.35020
  • 200+0.29149
库存:1413
H1OSI-SUG-25M
  • 10+0.37200
  • 100+0.34800
  • 500+0.32400
  • 2000+0.28800
  • 5000+0.27600
  • 10000+0.26880
库存:2699
