P2110B
P2110B
    POWERCAST
    SMD12 模块
    无线 PMIC SMD
P2110B 数据手册
P2110B 915 MHz RF Powerharvester erharvester® Receiver DESCRIPTION APPLICATIONS The Powercast P2110B Powerharvester Powerharvester is an RF energy harvesting device that converts RF to DC. Housed in a compact SMD package, the P2110B receiver provides RF energy harvesting and power management for battery-free, micro-power power devices. The P2110B converts RF energy to DC and stores it in a capacitor. When a charge threshold on the capacitor is achieved, the P2110B boosts the voltage to the set output voltage level and enables the voltage output. When the charge on the capacitor declines to the low voltage threshold the voltage output is turned off. A microprocessor can be used to optimize the power usage from the P211 P2110B and obtain other data from the component for improving overall system operation.    Battery-free free wireless sensors - Industrial Monitoring - Smart Grid - Defense - Building automation - Oil & Gas Battery recharging -Coin cells -Thin-film cells Low power electronics FUNCTIONAL BLOCK DIAGRAM FEATURES            High conversion efficiency Converts low-level level RF signals enabling long range applications Regulated voltage output up to 5. 5.5V Up to 50mA output current Received signal strength indicator No external RF components required – Internally matched to 50 ohms Wide RF operating range Operation down to -12 dBm input power Externally resettable for microprocessor control Industrial temperature range RoHS compliant PIN CONFIGURATION TOP VIEW Powercast products and technology are covered by one or more of the following patents and other patents pending: 6,289,237 | 6,615,074 | 6,856,291 | 7,027,311 | 7,057,514 | 7,639,994 | 7,643,312 | 7,812,771 | 7,844,306 | 7,868,482 | 7,898,105 | 7,925,308 | 8,159,090 | 8,380,255 8,432,062 | 8,461,817 | 8,621,245 2016/12 © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 Page 1 P2110B 915 MHz RF Powerharvester® Receiver ABSOLUTE MAXIMUM RATINGS TA = 25°C, unless otherwise noted. Parameter Rating Unit RF Input Power 23 dBm RFIN to GND 0 V DSET to GND 6 V RESET to GND 6 V VCAP to GND 2.3 V VOUT to GND 6 V VOUT Current 100 mA Operating Temperature Range -40 to 85 °C Storage Temperature Range -40 to 140 °C Exceeding the absolute maximum ratings may cause permanent damage to the device. ESD CAUTION This is an ESD (electrostatic discharge) sensitive device. Proper ESD precautions should be taken to avoid degradation or damage to the component. PIN FUNCTIONAL DESCRIPTIONS Pin 1 2 3 Label NC GND RFIN 4 5 GND DSET 6 7 INT RESET 8 9 10 VCAP NC VSET 11 12 GND VOUT 13 DOUT 14 NC 2016/12 Function No Connection. RF Ground. Connect to analog ground plane. RF Input. Connect to 50Ω antenna through a 50Ω transmission line. Add a DC block if antenna is a DC short. RF Ground. Connect to analog ground plane. Digital Input. Set to enable measurement of harvested power. If this function is not desired leave NC. Digital Output. Indicates that voltage is present at VOUT. Digital Input. Set to disable VOUT. If this function is not desired leave NC. Connect to an external capacitor for energy storage. No Connection. Output Voltage Adjustment. Sets the output voltage by connecting a resistor to VOUT or GND. Leave NC for 3.3V. DC Ground. Connect to analog ground plane. DC Output. Connect to external device. The output is preset to 3.3V but can be adjusted with an external resistor. Analog Output. Provides an analog voltage level corresponding to the harvested power. No Connection. © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 Page 2 P2110B 915 MHz RF Powerharvester® Receiver SPECIFICATIONS TA = 25°C, RFIN = 915MHz unless otherwise noted. Parameter Symbol Condition 1 RF Characteristics Input Power RFIN Frequency DC Characteristics Output Voltage VOUT Output Current IOUT VCAP Maximum VMAX VCAP Minimum VMIN Signal Strength DOUT RFIN = 0dBm Boost Efficiency IOUT = 20mA Maximum INT Current Digital Characteristics RESET Input High DSET Input High INT Output High Timing Characteristics DSET Delay RESET Delay RESET Pulse Width 1 Min Typ -12 902 2.0 3.3 Max Unit 10 928 dBm MHz 5.5 50 V mA V V mV % mA 1.25 1.02 275 85 0.1 1 1.8 VMIN VMAX 50 6.6 20 V V V s s ns See typical performance graphs for operation at other frequencies or power levels. TIMING DIAGRAM 2016/12 © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 Page 3 P2110B 915 MHz RF Powerharvester® Receiver FUNCTIONAL DESCRIPTION RF INPUT (RFIN) The RF input is an unbalanced input from the antenna. Any standard or custom 50antenna may be used with the receiver. The P2110B has been optimized for operation in the 902-928MHz band but will operate outside this band with reduced efficiency. Contact Powercast for custom frequency requirements. The RF input must be isolated from ground. For antennas that are a DC short, a high-Q DC blocking capacitor should be added in series with the antenna. STORAGE CAPACITOR SELECTION (VCAP) The P2110B requires an external storage capacitor connected at VCAP. The value of the capacitor will determine the amount of energy available from the VOUT pin. The capacitor should have a leakage current as small as possible. It is recommended that the leakage current of the capacitor be less than 1μA at 1.2V. The capacitor ESR should be 200mor less. Smaller capacitors will charge more quickly but will result in shorter operation cycles. Larger capacitors will charge more slowly, but will provide for longer operation cycles. The minimum required capacitor value can be estimated using the following equation. = 15 Where, - Output voltage - Average output current - On-time of the output voltage 2016/12 When using the RESET function, the size of the capacitor is less important. A larger capacitor can be used to facilitate intermittent functions that require more energy. The RESET will control the amount of energy removed from the capacitor during operation which will minimize the required recharge time. It should be noted that when RESET is used, a larger capacitor will not affect charge time during operation, but it will require more time to initially charge from a completely discharged state. The voltage on the VCAP pin under normal operation will vary between approximately 1.25V and 1.02V. If the harvested energy becomes too large, the voltage on the capacitor will be internally clamped to protect low voltage supercapacitors. Clamping will begin at approximately 1.8V and will limit the voltage to less than 2.3V at the maximum rated input power. RSSI OPERATION (DOUT, DSET) The RSSI functionality allows the sampling of the received signal to provide an indication of the amount of energy being harvested. When DSET is driven high the harvested DC power will be directed to an internal sense resistor, and the corresponding voltage will be provided to the DOUT pin. The voltage on the DOUT pin can be read after a 50μs settling time. When the RSSI functionality is being used, the harvested DC power is not being stored. © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 Page 4 P2110B 915 MHz RF Powerharvester® Receiver If the RSSI functionality is not used, DOUT and DSET should be left unconnected. DSET is internally pulled down. If the RESET functionality is not used, RESET should be left unconnected. RESET in internally pulled down DATA RETRIEVAL (DOUT, DSET) Using DOUT and DSET it is possible to collect data from the RF transmitter that is supplying power to the P2110B. As discussed above, with DSET high, DOUT will provide a voltage across R3 that can be read by an ADC. However, the voltage on DOUT will also follow the power level of the RF field as the power level changes. If the RF field is being provided by a transmitter that is also communicating by modulating its amplitude, such as the Powercast TX915013W-ID Powercaster® transmitter, the data can be read by the P2110B. The voltage level will need gained up using operation amplifiers and supplied to a device that can read the data pattern supplied by the transmitter. INTERRUPT (INT) The interrupt function provides a digital indication that voltage (or current) is present at the VOUT pin. INT can be used in more sophisticated systems that contain other storage elements and can be used as an external interrupt to bring a device such as microcontroller out of a deep sleep mode. The digital high level of the INT pin will be between VMIN and VMAX. The INT pin can provide a maximum of 0.1mA of current. RESET The RESET function allows the voltage from VOUT to be turned off before the storage capacitor reaches the lower threshold, VMIN, thereby saving energy and improving the recharge time back to the activation threshold, VMAX. The RESET function can be implemented by a microcontroller. When the function of the microcontroller is completed, driving RESET high will disable the voltage from VOUT. Care should be taken to ensure that the microcontroller, especially during power-on, does not inadvertently drive RESET high. This will immediately shutdown the output voltage. 2016/12 If the INT functionality is not used, INT should be left unconnected. SETTING THE OUTPUT VOLTAGE (VOUT) The DC output voltage from the P2110 is preset to 3.3V. However, it can be adjusted by adding an external resistor to increase or decrease the output voltage using the following equations. ( = 10 ) To decrease the output voltage, place a resistor calculated by the following equation from VSET to VOUT. The voltage can be set to a minimum of 2.0V. = © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com 1 ( − 1.21) (3.32 − ) +1 (412) 455-5800 Page 5 P2110B 915 MHz RF Powerharvester® Receiver To increase the output voltage, place a resistor calculated by the following equation from VSET to GND. The voltage can be set to a maximum of 5.5V. = ( 1.21 − 3.32) LAYOUT CONSIDERATIONS The RFIN feed line should be designed as a 50Ω trace and should be as short as possible to minimize feed line losses. The following table provides recommended dimensions for 50Ω feed lines (CPWG) for different circuit board configurations. PCB Side View Material FR4 (εr = 4.2) FR4 (εr = 4.2) Thickness (H) 62 Trace Width (S) 50 Spacing (W) 9 31 50 20 The GND pins on each side of the RFIN pin should be connected to the PCB ground plane through a via located next to the pads under the receiver. When setting the output voltage, the resistor connected to the VSET pin should be as close as possible to the pin. No external capacitance should be added to this pin. The DOUT pin can contain low-level analog voltage signals. If a long trace is connected to this pin, additional filtering capacitance next to the A/D converter may be required. Additional capacitance on this pin will increase the DSET delay time. The trace from VCAP to the storage capacitor should be as short as possible and have a width of greater than 20mils to minimize the series resistance of the trace. *All dimensions are in mils. 2016/12 © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 Page 6 P2110B 915 MHz RF Powerharvester erharvester® Receiver TYPICAL PERFORMANCE GRAPHS 2016/12 TA = 25°C, VOUT = 3.3V, VCAP = 1.2V, unless otherwise noted Powerharvester Efficiency vs. RFIN (dBm) Powerharvester Efficiency vs. RFIN (mW) Powerharvester Efficiency vs. Frequency Powerharvester Efficiency vs. Frequency © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 Page 7 P2110B 915 MHz RF Powerharvester® Receiver TYPICAL PERFORMANCE GRAPHS TA = 25°C, VOUT = 3.3V, VCAP = 1.2V, unless otherwise noted Received Signal Strength Indicator vs. RFIN (dBm) Received Signal Strength Indicator vs. RFIN (mW) Initial CAP Charge Time to First Activation vs. RFIN (dBm) Initial CAP Charge Time to First Activation vs. RFIN (mW) 2016/12 © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 Page 8 P2110B 915 MHz RF Powerharvester® Receiver Mechanical Specifications 2016/12 © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 Page 9 P2110B 915 MHz RF Powerharvester® Receiver P2110 MODULE SERIES MODULE P2110 P2110B 2016/12 STATUS End-of-life Replaced P2110 FUNCTIONAL DIFFERENCES N/A  Increased RF-to-DC conversion efficiency  VSET resistor values modified © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 P a g e 10 P2110B 915 MHz RF Powerharvester® Receiver IMPORTANT NOTICE Information furnished by Powercast Corporation (Powercast) is believed to be accurate and reliable. However, no responsibility is assumed by Powercast for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Powercast. Trademarks and registered trademarks are the property of their respective owners. POWERCAST PRODUCTS (INCLUDING HARDWARE AND/OR SOFTWARE) ARE NOT DESIGNED OR INTENDED TO BE FAIL-SAFE, FAULT TOLERANT OR FOR USE IN ANY APPLICATION THAT COULD LEAD TO DEATH, PERSONAL INJURY OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE (INDIVIDUALLY AND COLLECTIVELY, “CRITICAL APPLICATIONS”), SUCH AS LIFE-SUPPORT OR SAFETY DEVICES OR SYSTEMS, CLASS III MEDICAL DEVICES, NUCLEAR FACILITIES, APPLICATIONS THAT AFFECT CONTROL OF A VEHICLE OR AIRCRAFT, APPLICATIONS RELATED TO THE DEPLOYMENT OF AIRBAGS, OR ANY OTHER CRITICAL APPLICATIONS. CUSTOMER AGREES, PRIOR TO USING OR DISTRIBUTING ANY SYSTEMS THAT INCORPORATE POWERCAST PRODUCTS, TO THOROUGHLY TEST THE SAME FOR SAFETY PURPOSES. CUSTOMER ASSUMES THE SOLE RISK AND LIABILITY OF ANY USE OF POWERCAST PRODUCTS IN CRITICAL APPLICATIONS, SUBJECT ONLY TO APPLICABLE LAWS AND REGULATIONS GOVERNING LIMITATIONS ON PRODUCT LIABILITY. Powercast warrants its products in accordance with Powercast’s standard warranty available at www.powercastco.com. 2016/12 © 2016 Powercast Corporation, All rights reserved. www.powercastco.com / contact@powercastco.com +1 (412) 455-5800 P a g e 11
P2110B 价格&库存
很抱歉,暂时无法提供与“P2110B”相匹配的价格&库存,您可以联系我们找货
