ZTS30515
ZTS30515
    COSEL
    DIP6 模块
    隔离模块 直流转换器 1 输出 15V 200mA 4.5V - 9V 输入
ZTS30515 数据手册
Ordering information DC-DC Converters PCB Mount type ZTS1R5 ZT 1 S 2 1R5 3 12 4 1Series name 2Single output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT 05 5 ZTS1R50505 1.50 VOLTAGE[V] 5 CURRENT[A] 0.30 ZTS1R50512 1.56 12 0.13 ZTS1R50515 1.50 15 0.10 ZTS1R51205 1.50 5 0.30 ZTS1R51212 1.56 12 0.13 ZTS1R51215 1.50 15 0.10 ZTS1R52405 1.50 5 0.30 ZTS1R52412 1.56 12 0.13 ZTS1R52415 1.50 15 0.10 ZTS1R54805 1.50 5 0.30 ZTS1R54812 1.56 12 0.13 ZTS1R54815 1.50 15 0.10 ZTS1R52415 ZTS1R54805 ZTS1R54812 DC36 - 72 0.088typ 0.043typ 0.045typ 71typ 73typ 73typ 15 5 12 0.10 0.30 0.13 60max 20max 48max 120max 40max 100max 120max 80max 120max 150max 120max 150max 180max 50max 150max 60max 20max 48max ZTS1R54815 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * ZTS1R50505 ZTS1R50512 ZTS1R50515 ZTS1R51205 ZTS1R51212 DC4.5 - 9 DC9 - 18 0.441typ 0.459typ 0.441typ 0.176typ 0.183typ 68typ 68typ 68typ 71typ 71typ 5 12 15 5 12 0.30 0.13 0.10 0.30 0.13 20max 48max 60max 20max 48max 40max 100max 120max 40max 100max 80max 120max 120max 80max 120max 120max 150max 150max 120max 150max 50max 150max 180max 50max 150max 20max 48max 60max 20max 48max 20max (Minimum input, Io=100%) ZTS1R51215 ZTS1R52405 ZTS1R52412 DC18 - 36 0.176typ 0.088typ 0.092typ 71typ 71typ 71typ 15 5 12 0.10 0.30 0.13 60max 20max 48max 120max 40max 100max 120max 80max 120max 150max 120max 150max 180max 50max 150max 60max 20max 48max Fixed 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN60950-1 Complies with IEC60950-1 28X21X10mm (WXHXD) / 15g max Convection Rated input. 5V, 12V, 24V or 48V DC, Io=100% Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. Series/Parallel operation with other model is not possible. ZU/ZT-14 0.043typ 73typ 15 0.10 60max 120max 120max 150max 180max 60max June 29, 2011 ZTS1R5 External view ¶Recommended size for processing PCB (TOP VIEW) Case (Metal) 28 ¶Back View Name Plate 21 10.16 (0.4) 10.16 (0.4) 0.5 6-A part 4 6-º1.6 -V +V IN 2.54 S +V NC-V Case connecting OUT pin ( ) 12.7 Case (Resin) Pin 10 Conduction Area 7.62 (0.3) 1 7.62 1.2 7.62 Specification at A part Outline 2.55 10.16 10.16 1±0.1 Weight: 15g or less Tolerance: ±0.5 Case Material (Metal): Brass Case Material (Resin): PPS Pin Material: Phosphor Bronze (t=0.3) (Solder Plate) 2.54 (0.1) 12.7 (0.5) 7.62 (0.3) Dimensions : mm [inch] Div. : 0.1inch Performance data ¡STATIC CHARACTERISTICS (ZTS1R52405) ¡RISE TIME & FALL TIME (ZTS1R52405) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZTS1R52405) June 29, 2011 ZU/ZT-15 Ordering information DC-DC Converters PCB Mount type ZTS3 ZT 1 S 2 3 3 12 4 1Series name 2Single output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT 05 5 ZTS30505 3 VOLTAGE[V] 5 CURRENT[A] 0.60 ZTS30512 3 12 0.25 ZTS30515 3 15 0.20 ZTS31205 3 5 0.60 ZTS31212 3 12 0.25 ZTS31215 3 15 0.20 ZTS32405 3 5 0.60 ZTS32412 3 12 0.25 ZTS32415 3 15 0.20 ZTS34805 3 5 0.60 ZTS34812 3 12 0.25 ZTS34815 3 15 0.20 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * ZTS30505 ZTS30512 ZTS30515 ZTS31205 ZTS31212 ZTS31215 DC4.5 - 9 DC9 - 18 0.896typ 0.857typ 0.357typ 0.338typ 67typ 70typ 70typ 70typ 74typ 74typ 5 12 15 5 12 15 0.60 0.25 0.20 0.60 0.25 0.20 20max 48max 60max 20max 48max 60max 40max 100max 120max 40max 100max 120max 80max 120max 120max 80max 120max 120max 120max 150max 150max 120max 150max 150max 50max 150max 180max 50max 150max 180max 20max 48max 60max 20max 48max 60max 20max (Minimum input, Io=100%) ZTS32405 ZTS32412 ZTS32415 DC18 - 36 0.176typ 0.167typ 71typ 75typ 75typ 5 12 15 0.60 0.25 0.20 20max 48max 60max 40max 100max 120max 80max 120max 120max 120max 150max 150max 50max 150max 180max 20max 48max 60max Fixed 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 4.85 - 5.25 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, C-UL, EN60950-1 Complies with IEC60950-1 35.5X26X10mm (WXHXD) / 25g max Convection Rated input. 5V, 12V, 24V or 48V DC, Io=100% Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. Series/Parallel operation with other model is not possible. ZU/ZT-16 ZTS34805 ZTS34812 ZTS34815 DC36 - 72 0.088typ 0.082typ 71typ 76typ 76typ 5 12 15 0.60 0.25 0.20 20max 48max 60max 40max 100max 120max 80max 120max 120max 120max 150max 150max 50max 150max 180max 20max 48max 60max June 29, 2011 ZTS3 External view ¶Recommended size for processing PCB (TOP VIEW) Case (Metal) 35.5 ¶Back View 10.16 (0.4) 26 Name Plate 17.78 (0.7) 6-A part 1 -V +V IN S Case connecting pin ( 1.2 7.62 2.54 ) 20.32 10 Case (Resin) +V NC-V OUT Conduction Area Pin 7.62 (0.3) 4 0.5 6-º1.6 7.62 Specification at A part Outline 2.5 10.16 Weight: 25g or less Tolerance: ±0.5 Case Material (Metal): Brass Case Material (Resin): PPS Pin Material: Phosphor Bronze (t=0.3) (Solder Plate) 17.78 1±0.1 2.54 (0.1) 20.32 (0.8) 7.62 (0.3) Dimensions : mm [inch] Div. : 0.1inch Performance data ¡STATIC CHARACTERISTICS (ZTS32405) ¡RISE TIME & FALL TIME (ZTS32405) 6 4 Io=100% 30 3 20 2 0 10 20 INPUT VOLTAGE 30 ZU/ZT 10 RIPPLE 1 RIPPLE mVp-p OUTPUT VOLTAGE V OUTPUT VOLTAGE 5 40 V ¡OVERCURRENT CHARACTERISTICS (ZTS32405) June 29, 2011 Powered by TCPDF (www.tcpdf.org) ZU/ZT-17
ZTS30515 价格&库存
很抱歉,暂时无法提供与“ZTS30515”相匹配的价格&库存,您可以联系我们找货
