S-1318A18-M5T1U4
S-1318A18-M5T1U4
    ABLIC(艾普凌科)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 100mA SOT-23-5
S-1318A18-M5T1U4 数据手册
S-1318 Series www.ablic.com © ABLIC Inc., 2018-2023 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 The S-1318 Series, developed by using the CMOS technology, is a positive voltage regulator IC, which features super low current consumption and low dropout voltage. This IC has low current consumption of 95 nA typ. and high-accuracy output voltage of ±1.0%. It is most suitable for use in portable equipment and battery-powered devices.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption : • Output current: • Input capacitor: • Output capacitor: • Built-in overcurrent protection circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free (Sn 100%), halogen-free 1.2 V, 1.5 V, 1.8 V, 2.2 V, 2.3 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V 1.7 V to 5.5 V ±1.0% (1.2 V output product: ±15 mV) (Ta = +25°C) 45 mV typ. (2.5 V output product, at IOUT = 10 mA) (Ta = +25°C) During operation: 95 nA typ. During power-off: 2 nA typ. Possible to output 75 mA (1.2 V output product, at VIN ≥ VOUT(S) + 1.0 V)*1 Possible to output 100 mA (1.5 V, 1.8 V, 2.2 V, 2.3 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V output product, at VIN ≥ VOUT(S) + 1.0 V)*1 A ceramic capacitor can be used (1.0 μF or more) A ceramic capacitor can be used (1.0 μF or more) Limits overcurrent of output transistor Ensures long battery life Discharge shunt function "available" / "unavailable" is selectable. Pull-down function "available" / "unavailable" is selectable. Ta = −40°C to +85°C *1. Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large.  Applications • Constant-voltage power supply for battery-powered device • Constant-voltage power supply for portable communication device, digital camera, and digital audio player • Constant-voltage power supply for home electric appliance  Packages • SOT-23-5 • HSNT-4(1010) 1 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00  Block Diagrams 1. S-1318 Series A type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Constant current source pull-down Status Active "H" Available Available + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 1 2. S-1318 Series B type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 2 2 Function ON / OFF logic Discharge shunt function Constant current source pull-down Status Active "H" Available Unavailable 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series 3. S-1318 Series C type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Constant current source pull-down Status Active "H" Unavailable Available + − Reference voltage circuit VSS *1. Parasitic diode Figure 3 4. S-1318 Series D type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Constant current source pull-down Status Active "H" Unavailable Unavailable + − Reference voltage circuit VSS *1. Parasitic diode Figure 4 3 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00  Product Name Structure Users can select product type, output voltage, and package type for the S-1318 Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product type" regarding the product type, "3. Packages" regarding the package drawings, "4. Product name list" regarding details of the product name. 1. Product name S-1318 x xx - xxxx U 4 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M5T1: SOT-23-5, Tape A4T2: HSNT-4(1010), Tape Output voltage*2 12, 15, 18, 22, 23, 25, 28, 30, 33 (e.g., when the output voltage is 1.2 V, it is expressed as 12.) Product type*3 A to D *1. *2. *3. Refer to the tape drawing. Contact our sales representatives when the product which has 0.05 V step is necessary. Refer to "2. Function list of product types". 2. Function list of product types Product Type ON / OFF Logic Table 1 Discharge Shunt Function Constant Current Source Pull-down A Active "H" Available Available B Active "H" Available Unavailable C D Active "H" Active "H" Unavailable Unavailable Available Unavailable 3. Packages Package Name SOT-23-5 HSNT-4(1010) 4 Table 2 Package Drawing Codes Dimension Tape MP005-A-P-SD PL004-A-P-SD MP005-A-C-SD PL004-A-C-SD Reel MP005-A-R-SD PL004-A-R-SD Land − PL004-A-L-SD 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series 4. Product name list 4. 1 S-1318 Series A type ON / OFF logic: Discharge shunt function: Output Voltage 1.2 V ± 15 mV 1.8 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.5 V ± 1.0% 2.8 V ± 1.0% 3.0 V ± 1.0% 3.3 V ± 1.0% Active "H" Available Constant current source pull-down: Available Table 3 SOT-23-5 S-1318A12-M5T1U4 S-1318A18-M5T1U4 S-1318A22-M5T1U4 S-1318A23-M5T1U4 S-1318A25-M5T1U4 S-1318A28-M5T1U4 S-1318A30-M5T1U4 S-1318A33-M5T1U4 HSNT-4(1010) S-1318A12-A4T2U4 S-1318A18-A4T2U4 S-1318A22-A4T2U4 S-1318A23-A4T2U4 S-1318A25-A4T2U4 S-1318A28-A4T2U4 S-1318A30-A4T2U4 S-1318A33-A4T2U4 Remark Please contact our sales representatives for products other than the above. 4. 2 S-1318 Series B type ON / OFF logic: Discharge shunt function: Output Voltage 1.2 V ± 15 mV 1.5 V ± 1.0% 1.8 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.5 V ± 1.0% 2.8 V ± 1.0% 3.0 V ± 1.0% 3.3 V ± 1.0% Active "H" Available Constant current source pull-down: Unavailable Table 4 SOT-23-5 S-1318B12-M5T1U4 S-1318B15-M5T1U4 S-1318B18-M5T1U4 S-1318B22-M5T1U4 S-1318B23-M5T1U4 S-1318B25-M5T1U4 S-1318B28-M5T1U4 S-1318B30-M5T1U4 S-1318B33-M5T1U4 HSNT-4(1010) S-1318B12-A4T2U4 S-1318B15-A4T2U4 S-1318B18-A4T2U4 S-1318B22-A4T2U4 S-1318B23-A4T2U4 S-1318B25-A4T2U4 S-1318B28-A4T2U4 S-1318B30-A4T2U4 S-1318B33-A4T2U4 Remark Please contact our sales representatives for products other than the above. 5 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 4. 3 S-1318 Series C type ON / OFF logic: Discharge shunt function: Output Voltage 1.2 V ± 15 mV 1.8 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.5 V ± 1.0% 2.8 V ± 1.0% 3.0 V ± 1.0% 3.3 V ± 1.0% Active "H" Unavailable Constant current source pull-down: Available Table 5 SOT-23-5 S-1318C12-M5T1U4 S-1318C18-M5T1U4 S-1318C22-M5T1U4 S-1318C23-M5T1U4 S-1318C25-M5T1U4 S-1318C28-M5T1U4 S-1318C30-M5T1U4 S-1318C33-M5T1U4 HSNT-4(1010) S-1318C12-A4T2U4 S-1318C18-A4T2U4 S-1318C22-A4T2U4 S-1318C23-A4T2U4 S-1318C25-A4T2U4 S-1318C28-A4T2U4 S-1318C30-A4T2U4 S-1318C33-A4T2U4 Remark Please contact our sales representatives for products other than the above. 4. 4 S-1318 Series D type ON / OFF logic: Discharge shunt function: Output Voltage 1.2 V ± 15 mV 1.8 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.5 V ± 1.0% 2.8 V ± 1.0% 3.0 V ± 1.0% 3.3 V ± 1.0% Active "H" Unavailable Constant current source pull-down: Unavailable Table 6 SOT-23-5 S-1318D12-M5T1U4 S-1318D18-M5T1U4 S-1318D22-M5T1U4 S-1318D23-M5T1U4 S-1318D25-M5T1U4 S-1318D28-M5T1U4 S-1318D30-M5T1U4 S-1318D33-M5T1U4 HSNT-4(1010) S-1318D12-A4T2U4 S-1318D18-A4T2U4 S-1318D22-A4T2U4 S-1318D23-A4T2U4 S-1318D25-A4T2U4 S-1318D28-A4T2U4 S-1318D30-A4T2U4 S-1318D33-A4T2U4 Remark Please contact our sales representatives for products other than the above. 6 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series  Pin Configurations 1. SOT-23-5 Table 7 Top view 5 4 1 2 3 Pin No. 1 2 3 4 5 Symbol VIN VSS ON / OFF NC*1 VOUT Description Input voltage pin GND pin ON / OFF pin No connection Output voltage pin Figure 5 *1. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 2. HSNT-4(1010) Table 8 Top view 1 2 4 3 Bottom view 4 3 Pin No. 1 2 3 4 Symbol VOUT VSS ON / OFF VIN Description Output voltage pin GND pin ON / OFF pin Input voltage pin 1 2 *1 Figure 6 *1. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. 7 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00  Absolute Maximum Ratings Table 9 (Ta = +25°C unless otherwise specified) Item Symbol Absolute Maximum Rating Unit VSS − 0.3 to VSS + 6.0 VIN V Input voltage VSS − 0.3 to VSS + 6.0 VON / OFF V VSS − 0.3 to VIN + 0.3 Output voltage VOUT V Output current IOUT 120 mA −40 to +85 °C Operation ambient temperature Topr −40 to +125 °C Storage temperature Tstg Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 10 Item Symbol Condition Board A Board B Board C SOT-23-5 Board D Board E Junction-to-ambient thermal resistance*1 θJA Board A Board B HSNT-4(1010) Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark 8 Refer to " Power Dissipation" and "Test Board" for details. Min. − − − − − − − − − − Typ. 192 160 − − − 378 317 − − − Max. − − − − − − − − − − Unit °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series  Electrical Characteristics Table 11 Item Output voltage*1 Output current*2 Dropout voltage*3 Line regulation Load regulation Output voltage temperature coefficient*4 Current consumption during operation Current consumption during power-off Input voltage ON / OFF pin input voltage "H" ON / OFF pin input voltage "L" Symbol VOUT(E) IOUT Vdrop Condition VOUT(S) = 1.2 V VIN = VOUT(S) + 1.0 V, VOUT(S) = 1.5 V, 1.8 V, IOUT = 10 mA 2.2 V, 2.3 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V VOUT(S) = 1.2 V VOUT(S) = 1.5 V, 1.8 V, VIN ≥ VOUT(S) + 1.0 V 2.2 V, 2.3 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V VOUT(S) = 1.2 V VOUT(S) = 1.5 V VOUT(S) = 1.8 V IOUT = 10 mA VOUT(S) = 2.2 V, 2.3 V VOUT(S) = 2.5 V, 2.8 V, 3.0 V, 3.3 V (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) VOUT(S) V 1 − 0.015 + 0.015 VOUT(S) × 0.99 VOUT(S) VOUT(S) × 1.01 V 1 75*5 − − mA 3 100*5 − − mA 3 0.30 − − − − 0.075 0.055 0.050 − 0.100 0.070 0.060 V V V V 1 1 1 1 − 0.045 0.050 V 1 ΔVOUT1 ΔVIN•VOUT VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 10 mA − 0.05 0.2 %/V 1 ΔVOUT2 VIN = VOUT(S) + 1.0 V, 1 μA ≤ IOUT ≤ 50 mA − 20 40 mV 1 ΔVOUT ΔTa•VOUT VIN = VOUT(S) + 1.0 V, IOUT = 10 mA, −40°C ≤ Ta ≤ +85°C − ±130 − ppm/°C 1 ISS1 VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load − 95 250 nA 2 ISS2 VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load − 2 55 nA 2 VIN − VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level A / C type VIN = 5.5 V, (with constant current VON / OFF = 5.5 V source pull-down) VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V A / B type VOUT = 0.1 V, (with discharge shunt VIN = 5.5 V function) 1.7 − 5.5 V − 1.0 − − V 4 − − 0.25 V 4 0.05 0.1 0.2 μA 4 − 50 − mA 3 − 35 − Ω 3 VSH VSL ON / OFF pin pull-down current ISH Short-circuit current Ishort Discharge shunt resistance RLOW during power-off 9 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage The output voltage when VIN = VOUT(S) + 1.0 V, IOUT = 10 mA *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 10 mA. *4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•VOUT [ppm/°C]*3 ÷ 1000 ΔTa *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 10 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series  Test Circuits VIN + VOUT ON / OFF VSS V A + Set to ON Figure 7 Test Circuit 1 + A VIN VOUT ON / OFF VSS Set to VIN or GND Figure 8 Test Circuit 2 VIN VOUT ON / OFF A V + VSS Set to VIN or GND Figure 9 Test Circuit 3 VIN + A VOUT ON / OFF V VSS + RL Figure 10 Test Circuit 4 11 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00  Standard Circuit Input Output VOUT VIN CIN*1 ON / OFF VSS Single GND *1. *2. CL *2 GND CIN is a capacitor for stabilizing the input. CL is a capacitor for stabilizing the output. Figure 11 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation including the temperature characteristics with an actual application to set the constants.  Condition of Application Input capacitor (CIN): Output capacitor (CL): Caution A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF or more is recommended. Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. Perform thorough evaluation including the temperature characteristics with an actual application using the above capacitors to confirm no oscillation occurs.  Selection of Input Capacitor (CIN) and Output Capacitor (CL) The S-1318 Series requires CL between the VOUT pin and the VSS pin for phase compensation. The operation is stabilized by a ceramic capacitor with capacitance of 1.0 μF or more. When using an OS capacitor, a tantalum capacitor or an aluminum electrolytic capacitor, the capacitance also must be 1.0 μF or more. However, an oscillation may occur depending on the equivalent series resistance (ESR). Moreover, the S-1318 Series requires CIN between the VIN pin and the VSS pin for a stable operation. Generally, an oscillation may occur when a voltage regulator is used under the conditon that the impedance of the power supply is high. Note that the output voltage transient characteristics vary depending on the capacitance of CIN and CL and the value of ESR. Caution Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. 12 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series  Explanation of Terms 1. Output voltage (VOUT) This voltage is output at an accuracy of ±1.0% or ±15 mV*2 when the input voltage, the output current and the temperature are in a certain condition*1. *1. *2. Differs depending on the product. When VOUT = 1.2 V: ±15 mV, when VOUT = 1.5 V, 1.8 V, 2.2 V, 2.3 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V: ±1.0% Caution If the certain condition is not satisfied, the output voltage may exceed the accuracy range of ±1.0% or ±15 mV. Refer to Table 11 in " Electrical Characteristics" for details. ΔVOUT1  2. Line regulation  ΔV  IN • VOUT  Indicates the dependency of the output voltage against the input voltage. The value shows how much the output voltage changes due to a change in the input voltage after fixing output current constant. 3. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage against the output current. The value shows how much the output voltage changes due to a change in the output current after fixing input voltage constant. 4. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when the output voltage becomes 98% of the output voltage value (VOUT3) at VIN = VOUT(S) + 1.0 V after the input voltage (VIN) is decreased gradually. Vdrop = VIN1 − (VOUT3 × 0.98) 13 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 ΔVOUT  5. Output voltage temperature coefficient  ΔTa•VOUT  The shaded area in Figure 12 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±130 ppm/°C. Example of S-1318A12 typ. product VOUT [V] +0.156 mV/°C *1 VOUT(E) −0.156 mV/°C −40 *1. +25 +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 12 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•VOUT [ppm/°C]*3 ÷ 1000 ΔTa *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 14 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series  Operation 1. Basic operation Figure 13 shows the block diagram of the S-1318 Series to describe the basic operation. The error amplifier compares the feedback voltage (Vfb) whose output voltage (VOUT) is divided by the feedback resistors (Rs and Rf) with the reference voltage (Vref). The error amplifier controls the output transistor, consequently, the regulator starts the operation that keeps VOUT constant without the influence of the input voltage (VIN). VIN *1 Current Supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 13 2. Output transistor In the S-1318 Series, a low on-resistance P-channel MOS FET is used between the VIN pin and the VOUT pin as the output transistor. In order to keep VOUT constant, the ON resistance of the output transistor varies appropriately according to the output current (IOUT). Caution Since a parasitic diode exists between the VIN pin and the VOUT pin due to the structure of the transistor, the IC may be damaged by a reverse current if VOUT becomes higher than VIN. Therefore, be sure that VOUT does not exceed VIN + 0.3 V. 15 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 3. ON / OFF pin The ON / OFF pin controls the internal circuit and the output transistor in order to start and stop the regulator. When the ON / OFF pin is set to OFF, the internal circuit stops operating and the output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. Note that the current consumption increases when a voltage of 0.25 V to VIN − 0.3 V is applied to the ON / OFF pin. The ON / OFF pin is configured as shown in Figure 14 and Figure 15. 3. 1 S-1318 Series A / C type The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. For the ON / OFF pin current, refer to the A / C type of the ON / OFF pin input current "H" in " Electrical Characteristics". 3. 2 S-1318 Series B / D type The ON / OFF pin is not internally pulled down to the VSS pin, so do not use it in the floating status. When not using the ON / OFF pin, connect it to the VIN pin. Product Type A/B/C/D A/B/C/D ON / OFF Pin "H": ON "L": OFF Table 12 Internal Circuit VOUT Pin Voltage Operate Constant value*1 Stop Pulled down to VSS*3 Current Consumption ISS1*2 ISS2 *1. The constant value is output due to the regulating based on the set output voltage value. *2. Note that the IC's current consumption increases as much as current flows into the constant current of 0.1 μA typ. when the ON / OFF pin is connected to the VIN pin and the S-1318 Series A / C type is operating (refer to Figure 14). *3. The VOUT pin voltage of the S-1318 Series A / B type is pulled down to VSS due to combined resistance (RLOW = 35 Ω typ.) of the discharge shunt circuit and the feedback resistors, and a load. VIN VIN ON / OFF ON / OFF VSS Figure 14 S-1318 Series A / C type 16 VSS Figure 15 S-1318 Series B / D type 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series 4. Discharge shunt function (S-1318 Series A / B type) The S-1318 Series A / B type has a built-in discharge shunt circuit to discharge the output capacitance. The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level. (1) The ON / OFF pin is set to OFF level. (2) The output transistor is turned off. (3) The discharge shunt circuit is turned on. (4) The output capacitor discharges. Since the S-1318 Series C / D type does not have a discharge shunt circuit, the VOUT pin is set to VSS level through several MΩ internal divided resistors between the VOUT pin and the VSS pin. The S-1318 Series A / B type allows the VOUT pin to reach the VSS level rapidly due to the discharge shunt circuit. S-1318 Series Output transistor: OFF *1 VOUT VIN Discharge shunt circuit : ON *1 ON / OFF ON / OFF circuit Output capacitor (CL) ON / OFF Pin: OFF Current flow GND VSS *1. Parasitic diode Figure 16 5. Constant current source pull-down (S-1318 Series A / C type) The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Note that the IC's current consumption increases as much as current flows into the constant current of 0.1 μA typ. when the ON / OFF pin is connected to the VIN pin and the S-1318 Series A / C type is operating. 17 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 6. Overcurrent protection circuit The S-1318 Series has a built-in overcurrent protection circuit to limit the overcurrent of the output transistor. When the VOUT pin is shorted to the VSS pin, that is, at the time of the output short-circuit, the output current is limited to 50 mA typ. due to the overcurrent protection circuit operation. The S-1318 Series restarts regulating when the output transistor is released from the overcurrent status. Caution This overcurrent protection circuit does not work as for thermal protection. For example, when the output transistor keeps the overcurrent status long at the time of output short-circuit or due to other reasons, pay attention to the conditions of the input voltage and the load current so as not to exceed the power dissipation. 18 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series  Precautions • Generally, when a voltage regulator is used under the condition that the load current value is small (1 μA or less), the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the temperature is high, the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the impedance of the power supply is high, an oscillation may occur. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN. • Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. The following use conditions are recommended in the S-1318 Series, however, perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF or more is recommended. • Generally, in a voltage regulator, the values of an overshoot and an undershoot in the output voltage vary depending on the variation factors of input voltage start-up, input voltage fluctuation and load fluctuation etc., or the capacitance of CIN or CL and the value of the equivalent series resistance (ESR), which may cause a problem to the stable operation. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. • Generally, in a voltage regulator, if the VOUT pin is steeply shorted with GND, a negative voltage exceeding the absolute maximum ratings may occur in the VOUT pin due to resonance phenomenon of the inductance and the capacitance including CL on the application. The resonance phenomenon is expected to be weakened by inserting a series resistor into the resonance path, and the negative voltage is expected to be limited by inserting a protection diode between the VOUT pin and the VSS pin. • Make sure of the conditions for the input voltage, output voltage and the load current so that the internal loss does not exceed the power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • When considering the output current value that the IC is able to output, make sure of the output current value specified in Table 11 in " Electrical Characteristics" and footnote *5 of the table. • Wiring patterns on the application related to the VIN pin, the VOUT pin and the VSS pin should be designed so that the impedance is low. When mounting CIN between the VIN pin and the VSS pin and CL between the VOUT pin and the VSS pin, connect the capacitors as close as possible to the respective destination pins of the IC. • In the package equipped with heat sink of backside, mount the heat sink firmly. Since the heat radiation differs according to the condition of the application, perform thorough evaluation with an actual application to confirm no problems happen. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 19 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00  Characteristics (Typical Data) 1. Output voltage vs. Output current (When load current increases) (Ta = +25°C) 1. 1 VOUT = 1.0 V 1. 2 VOUT = 1.5 V 1.2 2.0 0.8 VOUT [V] VOUT [V] 1.0 VIN = 5.5 V VIN = 3.0 V VIN = 2.0 V VIN = 1.5 V VIN = 1.3 V 0.6 0.4 0.2 0.0 0 100 200 300 IOUT [mA] 400 1.5 VIN = 5.5 V VIN = 3.5 V VIN = 2.5 V VIN = 2.0 V VIN = 1.8 V 1.0 0.5 0.0 500 0 100 200 300 IOUT [mA] 400 500 1. 3 VOUT = 3.5 V VOUT [V] 4.0 3.0 VIN = 5.5 V VIN = 4.5 V VIN = 4.0 V VIN = 3.8 V 2.0 1.0 Remark In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 in Table 11 in " Electrical Characteristics" 2. The power dissipation 0.0 0 100 200 300 IOUT [mA] 400 500 2. Output voltage vs. Input voltage (Ta = +25°C) 2. 1 VOUT = 1.0 V 2. 2 VOUT = 1.5 V 1.2 1.0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 75 mA 0.9 0.8 0.7 0.6 VOUT [V] VOUT [V] 1.1 0.5 1.0 1.5 2.0 VIN [V] 2.5 3.0 5.0 5.5 VOUT [V] 2. 3 VOUT = 3.5 V 20 3.7 3.6 3.5 3.4 3.3 3.2 3.1 3.0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 3.0 3.5 4.0 4.5 VIN [V] 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 1.0 1.5 2.0 2.5 VIN [V] 3.0 3.5 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series 3. Dropout voltage vs. Output current 3. 1 VOUT = 1.0 V 3. 2 VOUT = 1.5 V 1.2 0.6 0.5 Ta = +85°C Ta = +25°C Ta = −40°C 0.8 0.6 Vdrop [V] Vdrop [V] 1.0 0.4 0.2 Ta = +85°C Ta = +25°C Ta = −40°C 0.4 0.3 0.2 0.1 0.0 0.0 0 25 50 IOUT [mA] 75 100 75 100 0 25 50 IOUT [mA] 75 100 3. 3 VOUT = 3.5 V 0.4 Vdrop [V] 0.3 Ta = +85°C Ta = +25°C Ta = −40°C 0.2 0.1 0.0 0 25 50 IOUT [mA] 4. Dropout voltage vs. Set output voltage 1.2 IOUT = 100 mA IOUT = 75 mA IOUT = 50 mA IOUT = 10 mA IOUT = 1 mA IOUT = 0.1 mA Vdrop [V] 1.0 0.8 0.6 0.4 0.2 0.0 1.0 1.5 2.0 2.5 VOUT(S) [V] 3.0 3.5 21 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 5. Output voltage vs. Ambient temperature 5. 2 VOUT = 1.5 V 1.10 1.70 1.05 1.60 VOUT [V] VOUT [V] 5. 1 VOUT = 1.0 V 1.00 0.95 0.90 1.40 −40 −25 1.30 0 25 Ta [°C] 50 75 85 0 25 Ta [°C] 50 75 85 5. 3 VOUT = 3.5 V 3.80 VOUT [V] 3.70 3.60 3.50 3.40 3.30 3.20 22 1.50 −40 −25 −40 −25 0 25 Ta [°C] 50 75 85 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series 6. Current consumption vs. Input voltage 6. 1 VOUT = 1.0 V 50 0.25 40 Ta = +85°C Ta = +25°C 0.15 ISS1 [μA] ISS1 [μA] 0.20 0.10 0.05 30 Ta = +85°C Ta = +25°C Ta = −40°C 20 10 Ta = −40°C 0 0.00 0.0 1.0 2.0 3.0 4.0 VIN [V] 5.0 0.0 6.0 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 5.0 6.0 6. 2 VOUT = 1.5 V 0.25 50 40 Ta = +85°C Ta = +25°C 0.15 ISS1 [μA] ISS1 [μA] 0.20 0.10 0.05 30 Ta = −40°C Ta = +25°C Ta = +85°C 20 10 Ta = −40°C 0.00 0 0.0 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 0.0 1.0 2.0 3.0 4.0 VIN [V] 6. 3 VOUT = 3.5 V 0.25 50 0.15 Ta = +25°C 0.10 0.05 0.00 Ta = +85°C Ta = +25°C Ta = −40°C 40 Ta = +85°C Ta = −40°C ISS1 [μA] ISS1 [μA] 0.20 30 20 10 0 0.0 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 0.0 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 23 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 7. Current consumption vs. Ambient temperature 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 7. 2 VOUT = 1.5 V VIN = 5.5 V −40 −25 0 ISS1 [μA] ISS1 [μA] 7. 1 VOUT = 1.0 V VIN = 2.0 V 25 Ta [°C] 50 75 85 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 VIN = 5.5 V − VIN = 2.5 V − Ta [°C] ISS1 [μA] 7. 3 VOUT = 3.5 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 VIN = 5.5 V −40 −25 0 VIN = 4.5 V 25 Ta [°C] 50 75 85 8. Current consumption vs. Output current 8. 1 VOUT = 1.0 V 8. 2 VOUT = 1.5 V 40 30 VIN = 2.0 V 20 ISS1 [μA] ISS1 [μA] 40 VIN = 5.5 V 10 0 20 40 60 IOUT [mA] 80 100 80 100 8. 3 VOUT = 3.5 V 40 ISS1 [μA] VIN = 2.5 V 20 VIN = 5.5 V 10 0 30 VIN = 4.5 V 20 VIN = 5.5 V 10 0 0 24 30 20 40 60 IOUT [mA] 0 0 20 40 60 IOUT [mA] 80 100 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series  Reference Data 1. Transient response characteristics when input (Ta = +25°C) 1. 1 VOUT = 1.0 V 1.0 VIN 0 200 400 t [μs] 600 VOUT [V] 1.4 1.2 1.0 VIN 0.8 −200 0 200 400 t [μs] 600 2.0 VOUT 0.0 0.8 −200 4.0 1.6 3.0 1.4 1.0 0.0 0 200 400 t [μs] 600 800 IOUT = 50 mA, CIN = CL = 1.0 μF, VIN = 3.0 V → 2.0 V, tf = 5.0 μs VIN 4.0 3.0 1.2 2.0 VOUT 1.0 1.0 0.0 0.8 −200 800 3.0 1.2 1.0 2.0 VOUT VIN 1.0 800 IOUT = 50 mA, CIN = CL = 1.0 μF, VIN = 2.0 V → 3.0 V, tr = 5.0 μs 1.6 1.4 2.0 VOUT 0.8 −200 3.0 4.0 VIN [V] 1.2 1.6 IOUT = 1 mA, CIN = CL = 1.0 μF, VIN = 3.0 V → 2.0 V, tf = 5.0 μs VIN [V] VOUT [V] 1.4 4.0 VIN [V] VOUT [V] 1.6 VIN [V] VOUT [V] IOUT = 1 mA, CIN = CL = 1.0 μF, VIN = 2.0 V → 3.0 V, tr = 5.0 μs 1.0 0.0 0 200 400 t [μs] 600 800 1. 2 VOUT = 1.5 V 1.5 2.5 VOUT 1.3 −200 0 200 400 t [μs] 600 VOUT [V] 1.9 1.7 1.5 VIN 1.3 −200 0 200 400 t [μs] 600 800 3.5 1.7 2.5 VOUT 1.5 0.5 1.3 −200 4.5 2.1 3.5 1.9 2.5 VOUT VIN 1.5 800 IOUT = 50 mA, CIN = CL = 1.0 μF, VIN = 2.5 V → 3.5 V, tr = 5.0 μs 2.1 1.9 4.5 1.5 0.5 0 200 400 t [μs] 600 800 IOUT = 50 mA, CIN = CL = 1.0 μF, VIN = 3.5 V → 2.5 V, tf = 5.0 μs VIN 4.5 3.5 1.7 2.5 VOUT 1.5 1.5 0.5 1.3 −200 VIN [V] VIN 3.5 IOUT = 1 mA, CIN = CL = 1.0 μF, VIN = 3.5 V → 2.5 V, tf = 5.0 μs VIN [V] 1.7 2.1 VIN [V] VOUT [V] 1.9 4.5 VIN [V] VOUT [V] 2.1 VOUT [V] IOUT = 1 mA, CIN = CL = 1.0 μF, VIN = 2.5 V → 3.5 V, tr = 5.0 μs 1.5 0.5 0 200 400 t [μs] 600 800 25 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 1. 3 VOUT = 3.5 V 3.5 VIN 0 200 400 t [μs] 600 VOUT [V] 3.9 3.7 3.5 VIN 3.3 −200 26 0 200 400 t [μs] 600 800 5.5 3.7 4.5 VOUT 3.5 2.5 3.3 −200 6.5 4.1 5.5 3.9 4.5 VOUT VIN 3.5 800 IOUT = 50 mA, CIN = CL = 1.0 μF, VIN = 4.5 V → 5.5 V, tr = 5.0 μs 4.1 3.9 4.5 VOUT 3.3 −200 5.5 6.5 3.5 2.5 0 200 400 t [μs] 600 800 IOUT = 50 mA, CIN = CL = 1.0 μF, VIN = 5.5 V → 4.5 V, tf = 5.0 μs VIN 6.5 5.5 3.7 4.5 VOUT 3.5 3.5 2.5 3.3 −200 VIN [V] 3.7 4.1 IOUT = 1 mA, CIN = CL = 1.0 μF, VIN = 5.5 V → 4.5 V, tf = 5.0 μs 3.5 2.5 0 200 400 t [μs] 600 800 VIN [V] VOUT [V] 3.9 6.5 VIN [V] VOUT [V] 4.1 VIN [V] VOUT [V] IOUT = 1 mA, CIN = CL = 1.0 μF, VIN = 4.5 V → 5.5 V, tr = 5.0 μs 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series 2. Transient response characteristics of load (Ta = +25°C) 2. 1 VOUT = 1.0 V −30 VOUT 0.8 −400 −60 600 1600 t [μs] 2600 VOUT [V] 1.6 IOUT 1.0 VOUT 0.8 −400 1600 t [μs] 2600 −30 30 1.6 600 1600 t [μs] 2600 −90 3600 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 50 mA → 10 mA, tf = 5.0 μs IOUT 60 30 1.4 0 1.2 −30 1.0 −90 3600 −60 VOUT 0.8 −400 −60 600 1.2 1.8 −30 1.2 0 60 0 30 IOUT 1.4 1.0 −90 3600 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 10 mA → 50 mA, tr = 5.0 μs 1.8 1.4 1.6 0 IOUT 1.2 1.0 30 60 −60 VOUT 0.8 −400 IOUT [mA] 1.4 1.8 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 10 mA → 1 mA, tf = 5.0 μs IOUT [mA] VOUT [V] 1.6 60 IOUT [mA] VOUT [V] 1.8 IOUT [mA] VOUT [V] VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 1 mA → 10 mA, tr = 5.0 μs 600 1600 t [μs] 2600 −90 3600 2. 2 VOUT = 1.5 V −30 VOUT 1.3 −400 −60 600 1600 t [μs] 2600 VOUT [V] 0 IOUT −30 1.7 1.5 VOUT 1.3 −400 −60 600 1600 t [μs] 2600 −90 3600 1.7 −30 2.1 −60 VOUT 600 1600 t [μs] 2600 −90 3600 VIN = 2.5 V, CIN = CL = 1.0 μF, IOUT = 50 mA → 10 mA, tf = 5.0 μs 2.3 30 2.1 0 1.3 −400 60 30 IOUT 1.9 1.5 −90 3600 VIN = 2.5 V, CIN = CL = 1.0 μF, IOUT = 10 mA → 50 mA, tr = 5.0 μs 2.3 1.9 2.1 0 IOUT 1.7 1.5 30 60 IOUT 60 30 1.9 0 1.7 −30 1.5 −60 VOUT 1.3 −400 IOUT [mA] 1.9 2.3 IOUT [mA] VOUT [V] VOUT [V] 2.1 60 VIN = 2.5 V, CIN = CL = 1.0 μF, IOUT = 10 mA → 1 mA, tf = 5.0 μs IOUT [mA] 2.3 IOUT [mA] VOUT [V] VIN = 2.5 V, CIN = CL = 1.0 μF, IOUT = 1 mA → 10 mA, tr = 5.0 μs 600 1600 t [μs] 2600 −90 3600 27 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 2. 3 VOUT = 3.5 V −30 VOUT 3.3 −400 −60 600 1600 t [μs] 2600 VOUT [V] 4.1 −30 3.7 3.5 VOUT 3.3 −400 28 0 −60 600 1600 t [μs] 2600 −90 3600 3.7 −30 4.1 −60 VOUT 600 1600 t [μs] 2600 −90 3600 VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 50 mA → 10 mA, tf = 5.0 μs 4.3 30 IOUT 0 3.3 −400 60 30 IOUT 3.9 3.5 −90 3600 VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 10 mA → 50 mA, tr = 5.0 μs 4.3 3.9 4.1 0 IOUT 3.7 3.5 30 60 IOUT 60 30 3.9 0 3.7 −30 3.5 −60 VOUT 3.3 −400 IOUT [mA] 3.9 4.3 IOUT [mA] VOUT [V] VOUT [V] 4.1 60 VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 10 mA → 1 mA, tf = 5.0 μs 600 1600 t [μs] 2600 −90 3600 IOUT [mA] 4.3 IOUT [mA] VOUT [V] VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 1 mA → 10 mA, tr = 5.0 μs 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series 3. Transient response characteristics of ON / OFF pin (Ta = +25°C) VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 1 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs 2.5 4 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 50 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs 2.5 4 2.0 2.0 1.0 −2 VOUT 0.5 −4 −6 0.0 −0.5 −100 0 0 100 200 t [μs] 300 400 VON / OFF 1.5 1.0 −4 −6 0.0 −8 −0.5 −100 0 −2 VOUT 0.5 2 0 100 200 t [μs] 300 400 VON / OFF [V] 1.5 2 VOUT [V] VON / OFF VON / OFF [V] VOUT [V] 3. 1 VOUT = 1.0 V −8 VIN = 2.5 V, CIN = CL = 1.0 μF, IOUT = 1 mA, VON / OFF = 0 V → 2.5 V, tr = 1.0 μs 5 6 VIN = 2.5 V, CIN = CL = 1.0 μF, IOUT = 50 mA, VON / OFF = 0 V → 2.5 V, tr = 1.0 μs 5 6 4 4 2 2 0 VOUT 1 −2 0 −4 −1 −100 0 100 200 t [μs] 300 400 −6 VON / OFF 3 4 2 2 0 VOUT 1 −2 0 −4 −1 −100 0 100 200 t [μs] 300 400 VON / OFF [V] 3 4 VOUT [V] VON / OFF VON / OFF [V] VOUT [V] 3. 2 VOUT = 1.5 V −6 3. 3 VOUT = 3.5 V 6 2 4 0 VOUT 2 −2 −4 0 −2 −200 4 300 800 t [μs] −6 1300 8 VOUT [V] VON / OFF VON / OFF [V] VOUT [V] 8 VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 50 mA, VON / OFF = 0 V → 4.5 V, tr = 1.0 μs 10 6 VON / OFF 6 2 4 0 VOUT 2 −2 −4 0 −2 −200 4 300 800 VON / OFF [V] VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 1 mA, VON / OFF = 0 V → 4.5 V, tr = 1.0 μs 10 6 −6 1300 t [μs] 29 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00 4. Ripple rejection (Ta = +25°C) 4. 2 VOUT = 1.5 V VIN = 2.0 V, CL = 1.0 μF 100 Ripple Rejection [dB] Ripple Rejection [dB] 4. 1 VOUT = 1.0 V IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 75 mA 80 60 40 20 0 10 100 1k 10k 100k Frequency [Hz] 1M Ripple Rejection [dB] 4. 3 VOUT = 3.5 V VIN = 4.5 V, CL = 1.0 μF 100 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 80 60 40 20 0 10 30 100 1k 10k 100k Frequency [Hz] 1M VIN = 2.5 V, CL = 1.0 μF 100 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 80 60 40 20 0 10 100 1k 10k 100k Frequency [Hz] 1M 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR Rev.1.3_00 S-1318 Series 5. Output capacitance vs. Characteristics of discharge time (Ta = +25°C) tDSC [ms] 2.0 VIN = VOUT + 1.0 V, IOUT = no load, VON / OFF = VOUT + 1.0 V → VSS, tf = 1.0 μs 1 μs VON / OFF VOUT(S) = 1.0 V VOUT(S) = 1.5 V VOUT(S) = 3.5 V 1.5 1.0 VSS tDSC VOUT 0.5 0.0 0 2 4 6 CL [μF] 8 10 12 VOUT × 10% VIN = VOUT + 1.0 V VON / OFF = VOUT + 1.0 V → VSS Figure 17 S-1318 Series A / B type (with discharge shunt function) Figure 18 Measurement Condition of Discharge Time 6. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) VOUT(S) = 1.5 V, 1.8 V, 2.2 V, 2.3 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V CIN = CL = 1.0 μF 100 VIN RESR [Ω] VOUT CIN Stable ON / OFF 0 0.01 S-1318 Series VSS 100 CL *1 RESR IOUT [mA] *1. CL : TDK Corporation Figure 19 C3216X7R1H105K160AB (1.0 μF) Figure 20 31 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series Rev.1.3_00  Power Dissipation SOT-23-5 HSNT-4(1010) Tj = +125°C max. 0.8 B 0.6 A 0.4 0.2 0.0 0 25 50 75 100 125 150 175 Tj = +125°C max. 1.0 Power dissipation (PD) [W] Power dissipation (PD) [W] 1.0 0.8 0.6 0.4 B 0.2 A 0.0 0 25 Ambient temperature (Ta) [°C] 32 Board Power Dissipation (PD) A B C D E 0.52 W 0.63 W − − − 50 75 100 125 150 Ambient temperature (Ta) [°C] Board A B C D E Power Dissipation (PD) 0.26 W 0.32 W − − − 175 SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. HSNT-4(1010) Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. HSNT4-B-Board-SD-1.0 ABLIC Inc. 2.9±0.2 1.9±0.2 4 5 1 2 0.16 3 +0.1 -0.06 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) ø1.5 ø1.0 +0.1 -0 +0.2 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. +1.0 - 0.0 9.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-2.0 TITLE SOT235-A-Reel No. MP005-A-R-SD-2.0 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 0.38±0.02 0.65 3 4 1 2 1.00±0.04 0.20±0.05 +0.05 0.08 -0.02 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PL004-A-P-SD-1.1 TITLE HSNT-4-B-PKG Dimensions No. PL004-A-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. 2.0±0.05 +0.1 ø1.5 -0 1.12±0.05 2 1 3 4 ø0.5 4.0±0.05 +0.1 -0 0.25±0.05 2.0±0.05 0.5±0.05 Feed direction No. PL004-A-C-SD-2.0 TITLE HSNT-4-B-C a r r i e r Tape No. PL004-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 9.0 +1.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PL004-A-R-SD-2.0 HSNT-4-B-Reel TITLE PL004-A-R-SD-2.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 10,000 Land Pattern 0.30min. 0.38~0.48 0.38~0.48 0.07 0.65±0.02 (1.02) Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Metal Mask Pattern Aperture ratio Aperture ratio Caution Mask aperture ratio of the lead mounting part is 100%. Mask aperture ratio of the heat sink mounting part is 40%. Mask thickness: t0.10mm to 0.12 mm 100% 40% t0.10mm ~ 0.12 mm TITLE No. PL004-A-L-SD-2.0 HSNT-4-B -Land Recommendation PL004-A-L-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1318A18-M5T1U4 价格&库存
很抱歉,暂时无法提供与“S-1318A18-M5T1U4”相匹配的价格&库存,您可以联系我们找货
S-1318A18-M5T1U4
  • 1+14.007131+1.80959
  • 10+10.2012410+1.31790
  • 25+9.2636725+1.19678
  • 100+8.22853100+1.06305
  • 250+7.73539250+0.99934
  • 500+7.43782500+0.96090
  • 1000+7.372381000+0.95244
库存:4084
S-1318A18-M5T1U4
  • 3000+6.890623000+0.89020
  • 6000+6.742596000+0.87108
  • 9000+6.668489000+0.86151
库存:4084
