95 12 165 T BKA
95 12 165 T BKA
    KNIPEX(凯尼派克)
    缆线 切割器 圆形 剪 6.50"(165.1mm)
95 12 165 T BKA 数据手册
Cable Shears 95 >> for cutting copper and aluminum cables, single and multi-stranded wire >> not suitable for steel wire and hard drawn copper conductors 95 11 165 >> precision ground, hardened blades >> clean and smooth cut without crushing and deformation >> easy cutting with one-hand operation >> pinch guard prevents operators´ fingers being pinched >> adjustable bolted joint, self-locking >> high-grade special tool steel; forged, oil-hardened Style 2 Internal opening spring, protected and captive 95 12 165 Style 4 Multifunctional tool for working on NYM cable from 3 x 1.5 mm² to 5 x 2.5 mm² (cutting, stripping insulation); universal stripping area for both solid conductor cross-sections; reliable alignment of the cable in the stripping area due to V-shaped blade geometry 95 12 165 T BKA* Pliers with integrated tether attachment point for tool drop protection system 95 12 165 T BKA 95 18 165 US ASTM Cut performed with a Diagonal Cutter: high effort required, inaccurate cut, considerable deforming and crushing of the cable Cut performed with a Cable Shear: easy, clean cut without any deformation of the cable 95 21 165 95 41 165 The locking device keeps shears with spring inside the joint closed Cutting capacities Product Number Packaging Inch mm 95 11 165 X 6 1/2 165 95 12 165 X 6 1/2 165 95 12 165 T BKA X 6 1/2 165 95 18 165 US X 6 1/2 165 95 21 165 X 6 1/2 165   Tool Handles burnished plastic coated 1 burnished multi-component grips 1 burnished ASTM   burnished multi-component grips, integrated tether attachment point insulated, multi-component grips, ASTM-tested Style 1 1 burnished plastic coated 2 95 22 165 6 1/2 165   burnished multi-component grips 2 95 41 165 6 1/2 165   burnished plastic coated 4 *Learn more about our tethered tool system on pages 207-211 Ø Inch Ø mm 19/32 15 19/32 15 19/32 15 19/32 15 19/32 15 19/32 15 15/32 12 mm² AWG lbs 50 1/0 0.49 50 1/0 0.55 50 1/0 0.56 50 1/0 0.58 50 1/0 0.50 50 1/0 0.56 35 1/0 0.49 159
95 12 165 T BKA 价格&库存
很抱歉,暂时无法提供与“95 12 165 T BKA”相匹配的价格&库存,您可以联系我们找货
