71 01 160
71 01 160
    KNIPEX(凯尼派克)
    螺栓割刀 铬钼钒钢,软握把
71 01 160 数据手册
71 01 160 KNIPEX CoBolt® S Compact Bolt Cutters ● ● ● ● ● ● ● ● Specially suitable for small hands Precision cutting edges for soft and hard wire as well as piano wire Cuts components such as bolts, nails, rivets etc. up to Ø 4.4 mm Most efficient joint design ensures exceptional cutting performance with little effort Cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC The microstructure on cutters keeps the material to be cut in a good insertion position: makes optimal use of the mechanics With gripping surface below the joint for gripping and pulling wires with a diameter as from 1.0 mm Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened 60 % less effort required compared to conventional high-leverage diagonal cutters The ingenious lever action mechanism guarantees an extremely favourable lever ratio with very low friction. Manual force is reinforced up to 30 times Article No. 71 01 160 EAN 4003773082668 Style Pliers black atramentized Handles plastic coated Cutting capacities medium hard wire (diameter) Ø mm 4,4 Powerful through to the tips Slim head for ideal accessibility Compact, light and always to hand Cutting capacities hard 3,2 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 3,0 Cutting capacities soft wire (diameter) Ø mm 5,3 Length mm 160 Net weight g 195 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
71 01 160 价格&库存
很抱歉,暂时无法提供与“71 01 160”相匹配的价格&库存,您可以联系我们找货
