98 55
98 55
    KNIPEX(凯尼派克)
    刀 符合人体工学,手术不锈钢
98 55 数据手册
Product information 98 55 ● ● ● ● ● ● ● ● ● ● Dismantling Knife IEC 60900 DIN EN 60900 ● ● ● ● solid, fixed hook blade, sickle shaped with guide shoe at the blade point no damage of the conductor insulation blade made of stainless steel, vacuum hardened ergonomically shaped insulating handle transparent protective cap VDE tested according to DIN EN/IEC 60900 : 2004 ergonomically designed handle shape with comfortable slip guard particularly confident grip thanks to slip-proof soft components thumb recess and "finger hook" at the end of the handle ensure a good transmission of force when the blade is pulled solid, fixed hook blade, sickle shaped with guide shoe at the blade point no damage of the conductor insulation blade: surgical steel, stainless, vacuum-hardened Allgemein Article No. 98 55 EAN 4003773022558 Handles insulating multi-component handle, VDE-tested weight 68 g Dimensions 180 x 46 x 52 mm Technische Attribute Blade length 38 mm Radius 23.5 mm VDE tested yes Klassifikation eCl@ss 5.1.4 21040602 ETIM 5.0 EC000155 ETIM 6.0 EC000155 proficl@ss 6.0 EAB554c020 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 26.03.2019 | page 1 1
98 55 价格&库存
很抱歉,暂时无法提供与“98 55”相匹配的价格&库存,您可以联系我们找货
