40P6.0-JMCS-G-B-TF(N)
    JST
    CONN_11.9X3.4MM_SM
    板对板 间距0.50mm 40Pin(2x20) 镀金 插头(公) 立贴
40P6.0-JMCS-G-B-TF(N) 数据手册
Emboss Tape JMC CONNECTOR 0.5mm pitch/Board-to-board connectors • Secure mating • Distortion preventive construction • Versatile number of circuit and height • Absorbing misalignment when mating connector Absorption misalignment type Specifications ––––––––––––––––––– • Current rating: 0.5 A AC, DC • Voltage rating: 50 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 50 mΩ max. After environmental tests/ 100 mΩ max. • Insulation resistance: 50 MΩ min. • Withstanding voltage: 100 VAC/minute This JMC connector is 0.5 mm pitch SMT type board to board connector with selection of boss existence. Comparing with conventional JMC connector, more small and space saving are realized. Various types are available such as top/side entry type connectors including the development of the stacking height variation for plug and the absorption misalignment type for receptacle. * Contact JST for nitrogen (N2) reflow soldering. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout and Assembly layout Plug: Side entry type 0.5 ±0.03 0.15 0.4 ±0.05 0.85 PC board edge 1.025±0.05 0.5±0.03  0 0.3 +0.05 0.3±0.05 0.15 0.85 1.25 D±0.05 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.03 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. Top entry type Side entry type Absorption misalignment type Stacking height: 4.0 to 11.0 mm Stacking height: 3.0 to 10.0 mm Absorption misalignment type 5.1 3.4 4.15 5.15 5.1 1 4.33 4.33 3 4 10 11 3.4 6.2min 2.2±0.05 0.5 0.4±0.05 3.5max 0.25 5.5±0.05 φ0.6 +0.1  0 1 φ0.5 +0.1  0 4.7min 4.35 0.3 1.42 1.75 0.85 φ0.6 +0.1  0 0.25 +0.1 φ0.5 0 5 min 2.8max 0.3 0.5±0.03 ±0.05 0.8 0.3 ±0.05 Absorption misalignment type D±0.05 0.15 0.5 ±0.03 Receptacle D±0.05 D ±0.05 2.7max Plug: Top entry type JMC CONNECTOR Plug Top entry type Side entry type B C 3.4 0.5 0.2 B C 0.2 0.5 3.35 0.35 4.33 2.2∼9.2 0.5 A 0.5 0.2 A D 1.15 D 0.3 1.5 Top entry type Without boss With boss 18 20 24 30 40 50 60 20 24 30 40 44 50 60 Q'ty/reel 3.0 18P3.0-JMCS-G-TF(N) 20P3.0-JMCS-G-TF(N) ― 30P3.0-JMCS-G-TF(N) 40P3.0-JMCS-G-TF(N) 50P3.0-JMCS-G-TF(N) 60P3.0-JMCS-G-TF(N) 20P3.0-JMCS-G-B-TF(N) ― ― 40P3.0-JMCS-G-B-TF(N) 44P3.0-JMCS-G-B-TF(N) 50P3.0-JMCS-G-B-TF(N) 60P3.0-JMCS-G-B-TF(N) 2,500 Without boss With boss Q'ty/reel 5.0 14P5.0-JMCS-G-TF(N) 20P5.0-JMCS-G-TF(N) ― 40P5.0-JMCS-G-TF(N) 50P5.0-JMCS-G-TF(N) ― 14P5.0-JMCS-G-B-TF(N) 20P5.0-JMCS-G-B-TF(N) 30P5.0-JMCS-G-B-TF(N) 40P5.0-JMCS-G-B-TF(N) 60P5.0-JMCS-G-B-TF(N) 1,500 With boss 20 50 34 50 64 Q'ty/reel 7.0 20P7.0-JMCS-G-TF(N) 50P7.0-JMCS-G-TF(N) ― 50P7.0-JMCS-G-B-TF(N) ― 1,000 Without boss With boss 4.5 ― 20P4.5-JMCS-G-TF(N) ― ― ― ― ― 20P4.5-JMCS-G-B-TF(N) ― ― ― ― ― ― 1,500 5.5 ― 20P5.5-JMCS-G-TF(N) ― ― ― 60P5.5-JMCS-G-TF(N) ― 20P5.5-JMCS-G-B-TF(N) ― ― ― 1,000 7.5 ― ― ― 50P7.5-JMCS-G-B-TF(N) ― 600 9.0 ― 30P9.0-JMCS-G-TF(N) 50P9.0-JMCS-G-TF(N) ― 30P9.0-JMCS-G-B-TF(N) 40P9.0-JMCS-G-B-TF(N) 50P9.0-JMCS-G-B-TF(N) 60P9.0-JMCS-G-B-TF(N) 500 10.0 20P10.0-JMCS-G-TF(N) ― ― 20P10.0-JMCS-G-B-TF(N) ― 40P10.0-JMCS-G-B-TF(N) ― ― 500 A B C D 4.0 4.5 5.5 7.0 9.5 12.0 14.5 4.5 5.5 7.0 9.5 10.5 12.0 14.5 6.4 6.9 7.9 9.4 11.9 14.4 16.9 6.9 7.9 9.4 11.9 12.9 14.4 16.9 4.9 5.4 6.4 7.9 10.4 12.9 15.4 5.4 6.4 7.9 10.4 11.4 12.9 15.4 ― ― ― ― ― ― ― 5.7 6.7 8.2 10.7 11.7 13.2 15.7 Dimensions (mm) 6.0 ― 20P6.0-JMCS-G-TF(N) ― ― ― ― ― 20P6.0-JMCS-G-B-TF(N) ― 40P6.0-JMCS-G-B-TF(N) 60P6.0-JMCS-G-B-TF(N) 1,000 6.5 ― ― 30P6.5-JMCS-G-TF(N) 40P6.5-JMCS-G-TF(N) ― ― ― ― 30P6.5-JMCS-G-B-TF(N) 40P6.5-JMCS-G-B-TF(N) ― 1,000 A B C D 3.0 4.5 7.0 9.5 12.0 14.5 3.0 4.5 7.0 9.5 14.5 5.4 6.9 9.4 11.9 14.4 16.9 5.4 6.9 9.4 11.9 16.9 3.9 5.4 7.9 10.4 12.9 15.4 3.9 5.4 7.9 10.4 15.4 ― ― ― ― ― ― 4.2 5.7 8.2 10.7 15.7 Dimensions (mm) 8.0 ― ― ― 50P8.0-JMCS-G-B-TF(N) 64P8.0-JMCS-G-B-TF(N) 600 8.5 ― ― 34P8.5-JMCS-G-B-TF(N) ― ― 500 A B C D 4.5 12.0 8.0 12.0 15.5 6.9 14.4 10.4 14.4 17.9 5.4 12.9 8.9 12.9 16.4 ― ― 9.2 13.2 16.7 Dimensions (mm) Model No. Stacking height (mm) Circuits 20 30 50 20 30 40 50 60 4.0 ― ― ― 30P4.0-JMCS-G-TF(N) 40P4.0-JMCS-G-TF(N) 50P4.0-JMCS-G-TF(N) 60P4.0-JMCS-G-TF(N) ― 24P4.0-JMCS-G-B-TF(N) 30P4.0-JMCS-G-B-TF(N) 40P4.0-JMCS-G-B-TF(N) ― 50P4.0-JMCS-G-B-TF(N) 60P4.0-JMCS-G-B-TF(N) 2,000 Model No. Stacking height (mm) Circuits Without boss 3.5 ― 20P3.5-JMCS-G-TF(N) 24P3.5-JMCS-G-TF(N) 30P3.5-JMCS-G-TF(N) 40P3.5-JMCS-G-TF(N) ― ― 20P3.5-JMCS-G-B-TF(N) ― 30P3.5-JMCS-G-B-TF(N) 40P3.5-JMCS-G-B-TF(N) ― ― ― 2,000 Model No. Stacking height (mm) Circuits 14 20 30 40 50 60 14 20 30 40 60 Dimensions (mm) Model No. Stacking height (mm) Circuits ― ― ― ― ― ― ― ― ― ― Q'ty/reel RoHS compliance Note: 1. The stacking height of absorption misalignment type is 1.0 mm higher than that of standard type. 2. As for the overall gold plated product, "(N)" is not given to the end of model No. 3. The products listed above are supplied on embossed-tape. ― ― ― ― ― ― ― ― ― ― A B C D 4.5 7.0 12.0 4.5 7.0 9.5 12.0 14.5 6.9 9.4 14.4 6.9 9.4 11.9 14.4 16.9 5.4 7.9 12.9 5.4 7.9 10.4 12.9 15.4 ― ― ― 5.7 8.2 10.7 13.2 15.7 2 JMC CONNECTOR Plug Side entry type Circuits Without boss With boss Model No. A 20PS-JMCS-G-1-TF(N) 24PS-JMCS-G-1-TF(N) 30PS-JMCS-G-1-TF(N) 34PS-JMCS-G-1-TF(N) 40PS-JMCS-G-1-TF(N) 50PS-JMCS-G-1-TF(N) 60PS-JMCS-G-1-TF(N) 20PS-JMCS-G-1B-TF(N) 24PS-JMCS-G-1B-TF(N) 30PS-JMCS-G-1B-TF(N) 34PS-JMCS-G-1B-TF(N) 40PS-JMCS-G-1B-TF(N) 46PS-JMCS-G-1B-TF(N) 50PS-JMCS-G-1B-TF(N) 60PS-JMCS-G-1B-TF(N) 20 24 30 34 40 50 60 20 24 30 34 40 46 50 60 4.5 5.5 7.0 8.0 9.5 12.0 14.5 4.5 5.5 7.0 8.0 9.5 11.0 12.0 14.5 Dimensions (mm) C B 5.4 6.4 7.9 8.9 10.4 12.9 15.4 5.4 6.4 7.9 8.9 10.4 11.9 12.9 15.4 7.9 8.9 10.4 11.4 12.9 15.4 17.9 7.9 8.9 10.4 11.4 12.9 14.4 15.4 17.9 Q'ty/ reel D ― ― ― ― ― ― ― 5.55 6.55 8.05 9.05 10.55 12.05 13.05 15.55 1,500 1,500 1,500 1,500 1,500 1,500 1,500 1,500 1,500 1,500 1,500 1,500 1,500 1,500 1,500 Material and Finish Contact: Phosphor bronze, nickel-undercoated, gold-plated (nickel-stripe) Housing: PA 6T, UL94V-0 Solder tab: Brass, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Note: 1. The products listed above are supplied on embossed-tape. 2. As for the overall gold plated product, "(N)" is not given to the end of model No. Receptacle Circuits C B 3.3 0.5 2.3 0.5 0.5 Dimensions (mm) Model No. Without boss With boss A B C D Q'ty/ reel 14 14R-JMCS-G-TF(NSA) 14R-JMCS-G-B-TF(NSA) 3.0 4.8 3.9 4.2 2,500 18 18R-JMCS-G-TF(NSA) 4.0 5.8 4.9 5.2 2,500 20 20R-JMCS-G-TF(NSA) 20R-JMCS-G-B-TF(NSA) 4.5 6.3 5.4 5.7 2,500 24 24R-JMCS-G-TF(NSA) 24R-JMCS-G-B-TF(NSA) 5.5 7.3 6.4 6.7 2,500 30 30R-JMCS-G-TF(NSA) 30R-JMCS-G-B-TF(NSA) 7.0 8.8 7.9 8.2 2,500 34 34R-JMCS-G-TF(NSA) 34R-JMCS-G-B-TF(NSA) 8.0 9.8 8.9 9.2 2,500 40 40R-JMCS-G-TF(NSA) 40R-JMCS-G-B-TF(NSA) 9.5 11.3 10.4 10.7 2,500 ― 46 46R-JMCS-G-TF(NSA) 46R-JMCS-G-B-TF(NSA) 11.0 12.8 11.9 12.2 2,500 50 50R-JMCS-G-TF(NSA) 50R-JMCS-G-B-TF(NSA) 12.0 13.8 12.9 13.2 2,500 60 60R-JMCS-G-TF(NSA) 60R-JMCS-G-B-TF(NSA) 14.5 16.3 15.4 15.7 2,500 0.18 Material and Finish A D Contact: Phosphor bronze, nickel-undercoated, gold-plated (nickel-stripe) Housing: PA 6T, UL94V-0 RoHS compliance Note: 1. The products listed above are supplied on embossed-tape. 2. As for the overall gold plated product, "(S)" instead of "(NSA)" shall be given to the end of model No. Absorption misalignment type Absorption misalignment type C Circuits With boss A B C D Q'ty/ reel 20 20RF-JMCS-G-1-TF(N) 20RF-JMCS-G-1B-TF(N) 4.5 8.0 5.4 6.75 1,000 30 30RF-JMCS-G-1-TF(N) 30RF-JMCS-G-1B-TF(N) 7.0 10.5 7.9 9.25 1,000 40 40RF-JMCS-G-1-TF(N) 40RF-JMCS-G-1B-TF(N) 9.5 13.0 10.4 11.75 1,000 44 2.5 Dimensions (mm) Model No. Without boss ― 44RF-JMCS-G-1B-TF(N) 10.5 14.0 11.4 12.75 1,000 50 50RF-JMCS-G-1-TF(N) 50RF-JMCS-G-1B-TF(N) 12.0 15.5 12.9 14.25 1,000 60 60RF-JMCS-G-1-TF(N) 60RF-JMCS-G-1B-TF(N) 14.5 18.0 15.4 16.75 1,000 ― 64RF-JMCS-G-1B-TF(N) 15.5 19.0 16.4 17.75 1,000 3.3 64 Material and Finish 0.5±0.1 φ0.5 0.18 A D B 3 Contact: Phosphor bronze, nickel-undercoated, gold-plated (nickel-stripe) Housing: PA 6T, UL94V-0 Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) 2.2 0.25 5.1 0.25 RoHS compliance This product displays (LF)(SN) on a label. Note: 1. The products listed above are supplied on embossed-tape. 2. Not CSA approved.
40P6.0-JMCS-G-B-TF(N) 价格&库存
很抱歉,暂时无法提供与“40P6.0-JMCS-G-B-TF(N)”相匹配的价格&库存,您可以联系我们找货
