MAX3490EESA+T
MAX3490EESA+T
    TOKMAS(托克马斯)
    SOP-8
    MAX3490E 3.0V~5.5V供电,全双工低功耗RS-485收发器
MAX3490EESA+T 数据手册
MAX3490EESA+T FEATURES : ➢ 3.0V~5.5V Supply, Full-duplex ➢ 1/8 Unit Load, Allow Up to 256 Transceivers on the Bus ➢ Driver Short-Circuit Output Protection ➢ Strong Anti-Noise Ability ➢ Integrated Transient Voltage Suppression Function ➢ The Data Transmission Rate Up to 14Mbps in SOP-8 SOP-8 Electric Noise Environment ➢ ESD Protection for RS-485 I/O Pins ±15kV, Human Body Model DESCRIPTION is a 3.0V~5.5V powered,full-duplex, low power dissipation RS-485 transceiver fully meeting the requirements of RS-485/RS-422 standard. MAX3490E contains one driver and one receiver, both can transmit signals independently. The MAX3490E has a 1/8-unit-load. It allows up to 256 transceivers on the bus and error-free data transmission up to 14Mbps. MAX3490E has a working voltage range of 3.0V~5.5V, with the functions of Current-Limiting Protection, Over-voltage Protection, Control Port Hot Plug Input, etc. MAX3490E has excellent ESD release capability, and HBM reaches ±15kV. MAX3490E PIN CONFIGURATION VCC R A RO B DI Z GND D Y Figure 1 MAX3490E Pin Configuration www.tokmas.com MAX3490EESA+T LIMITING VALUES PARAMETER SYMBOL VALUE UNIT Supply voltage VCC +7 V Driver Input Voltage DI -0.3~VCC+0.3 V Receiver Input Voltage A, B -8~13 V Receiver Output Voltage RO -0.3~VCC+0.3 V Operating Temperature Ranges TA -40~125 ℃ Storage Temperature Range Tstg -60~150 ℃ 300 ℃ SOP8 400 mW DIP8 700 mW Lead Temperature Continuous Power Dissipation The maximum limit parameters mean that exceeding these values may cause irreversible damage to the device. Under these conditions, it is not conducive to the normal operation of the device. The continuous operation of the device at the maximum allowable rating may affect the reliability of the device. The reference point for all voltages is ground. PINNING PIN SYMBOL 1 VCC DESCRIPTION Positive Supply: 3.0V≤ VCC ≤5.5V 2 RO Receiver Output. If A-B≥+200mV, RO will be high; If A-B≥-200mV, RO will be low. 3 DI Driver Input. A low on DI forces output Y low and output Z high. a high on DI forces output Y high and output Z low. 4 GND 5 Y Non-inverting Driver Output 6 Z Inverting Driver Output 7 B Inverting Receiver Input 8 A Non-inverting Receiver Input Ground www.tokmas.com MAX3490EESA+T DRIVER DC ELECTRICAL CHARACTERISTICS PARAMETER SYMBOL CONDITION MIN TYP MAX Differential Driver Output (No load) VOD1 Differential Driver Output VOD2 Change in Magnitude of Driver Differential Output Voltage (NOTE1) ∆VOD Figure 2, RL = 27 Ω 0.2 V Driver Common-Mode Output Voltage VOC Figure 2, RL = 27 Ω 3 V Change in Magnitude of Common-Mode Output Voltage (NOTE1) ∆VOC Figure 2, RL = 27 Ω 0.2 V Input High Voltage VIH DI Input Low Voltage VIL DI Logic Input Current IIN1 DI Output short-circuit current, short-circuit to high IOSD1 Output short-circuit current, short-circuit to low IOSD2 5 UNIT V Figure 2, RL = 27 Ω 1.5 VCC Figure 2, RL = 50 Ω 2 VCC V 2.0 V 0.8 V -2 2 μA short-circuit to 0V~12V 35 250 mA short-circuit to 7V~0V -250 -35 mA (Unless otherwise noted, VCC=3.3V±10%, Temp=TMIN~TMAX, typical values are at VCC=+3.3V, Temp=25℃) NOTE1: ∆VOD and ∆VOC are the changes in VOD and VOC, respectively, when the DI input changes state. RECEIVER DC ELECTRICAL CHARACTERISTICS PARAMETER Input current (A, B) SYMBOL IIN2 CONDITION MIN VCC=0 or 3.3V VIN=12 V VCC=0 or 3.3V VIN=-7 V -100 www.tokmas.com TYP MAX UNIT 125 μA μA MAX3490EESA+T PARAMETER SYMBOL CONDITION MIN TYP MAX UNIT Positive input threshold voltage VIT+ -7V≤VCM≤12V +200 mV Reverse input threshold voltage VIT- -7V≤VCM≤12V -200 Input hysteresis voltage Vhys -7V≤VCM≤12V 10 Receiver Output High Voltage VOH IOUT=−4mA, VID=+200 mV VCC-1.5 Receiver Output Low Voltage VOL IOUT=+4mA, VID=-200 mV 0.4 V Three-State Output Current at Receiver IOZR 0.4 V
MAX3490EESA+T
物料型号:MAX3490EESA+T
器件简介:MAX3490E是一款3.0V~5.5V供电的全双工、低功耗RS-485收发器,完全符合RS-485/RS-422标准。它包含一个驱动器和一个接收器,两者可以独立传输信号。MAX3490E具有1/8单位负载,允许在总线上连接多达256个收发器,并且可以在电噪声环境下以高达14Mbps的数据传输速率进行无差错数据传输。
引脚分配: - VCC:正电源,3.0V~5.5V - RO:接收器输出 - DI:驱动器输入 - GND:地 - Y:非反相驱动器输出 - Z:反相驱动器输出 - B:接收器反相输入 - A:接收器非反相输入
参数特性: - 供电电压:VCC +7V - 驱动器输入电压:DI -0.3~VCC+0.3V - 接收器输入电压:A,B -8~13V - 接收器输出电压:RO -0.3~VCC+0.3V - 工作温度范围:-40~125℃ - 存储温度范围:-60~150℃C - 引脚温度:300℃ - 连续功耗:SOP8 400mW,DIP8 700mW
功能详解: - 差分驱动器输出电压:VODI 5V(无负载) - 驱动器传播延迟:tDPLH/ tDPHL 15~35ns(低到高/高到低电平) - 接收器传播延迟:tRPLH/ tRPHL 20~90ns(低到高/高到低电平) - ESD保护:A,B,Y,Z ±16kV(HBM),其他端口 ±6kV
应用信息:MAX3490E适用于RS-485/RS-422通信,具有故障安全、过压保护和过流保护,可实现高达14Mbps的无差错数据传输。
封装信息: - SOP-8 - DIP8 - MSOP8/VSSOP8
MAX3490EESA+T 价格&库存
很抱歉,暂时无法提供与“MAX3490EESA+T”相匹配的价格&库存,您可以联系我们找货
