EC1SC12
EC1SC12
    CINCON
    DIP7 模块
    隔离模块 直流转换器 1 输出 12V 1.67A 18V - 72V 输入
EC1SC12 数据手册
V14 EC1SC SERIES ︳ 20 WATT 4:1 INPUT RANGE DC-DC CONVERTERS FEATURES * 20W Isolated Output * 2” X 1.6” Six-Sided Shield Metal Case * Efficiency to 84% * 4:1 Input Range * Pi Input Filter * Continuous Short Circuit Protection * Meets EN55032 Class A, Conducted * Remote On/Off Control * UL60950-1 Approval * Safety Meets IEC/EN/UL 62368-1 MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE OUTPUT CURRENT EC1SC01 EC1SC02 EC1SC03 EC1SC04 EC1SC05 EC1SC06 EC1SC07 EC1SC11 EC1SC12 EC1SC13 EC1SC14 EC1SC15 EC1SC16 EC1SC17 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 18-72 VDC 18-72 VDC 18-72 VDC 18-72 VDC 18-72 VDC 18-72 VDC 18-72 VDC 5VDC 12VDC 15VDC ±12VDC ±15VDC ±5VDC 3.3VDC 5VDC 12VDC 15VDC ±12VDC ±15VDC ±5VDC 3.3VDC 4000 mA 1670 mA 1330 mA ±833 mA ±666 mA ±2000 mA 4000 mA 4000 mA 1670 mA 1330 mA ±833 mA ±666 mA ±2000 mA 4000 mA NOTE: 1. Nominal Input Voltage 24 or 48VDC 1 INPUT CURRENT NO LOAD 15 mA 15 mA 15 mA 20 mA 20 mA 20 mA 15 mA 10 mA 10 mA 10 mA 15 mA 15 mA 15 mA 10 mA FULL LOAD 1029 mA 1006 mA 1004 mA 1004 mA 1004 mA 1004 mA 705 mA 508 mA 497 mA 496 mA 496 mA 496 mA 496 mA 353 mA % CAPACITOR EFF. LOAD MAX. 81 83 83 83 83 83 78 82 84 84 84 84 84 78 4000uF 1670uF 1330uF 833uF 666uF 2000uF 4000uF 4000uF 1670uF 1330uF 833uF 666uF 2000uF 4000uF V14 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....………….….... 24V …..………………….…..….. 9-36V 48V ………………..…………… 18-72V Input Surge Voltage (100ms max.) ………….….… 24V …............. 50Vdc max. 48V .............. 100Vdc max. Input Filter ………………………………………….……………………..... Pi Type Positive Logic Remote On/Off Control …………….……………. See Note3 Efficiency ................................................................................. See Table Isolation Voltage ...........................................................… 1500 VDC min. Isolation Resistance .........................................……….......…… 108 ohms Isolation Capacitance …………………..…………………..… 1000pF typ. Switching Frequency ...................................................... 300KHz typ. Operating Ambient Temperature Range …..................... –25℃ to +71℃ OUTPUT SPECIFICATIONS: De-rating, Above 60℃ ……………… Linearly to Zero Power at +100℃ Voltage Accuracy Single Output …………….….…………………….….. ±1.0% max. Dual +Output ……….…………………………………. ±1.0% max. Dual –Output …………………………………….……. ±2.0% max. Voltage Balance, Dual Output at Full Load ………………………… ±1.0% max. Transient Response Single 25% Step Load Change …………………………..……………
EC1SC12
物料型号:CINCON EC1SC系列
器件简介:这是一系列20瓦特的隔离输出DC-DC转换器,具有4:1的输入范围,效率高达84%,并配有六面屏蔽金属外壳。
引脚分配: - 引脚1:开关控制 - 引脚3和4:分别为负输入和正输入 - 引脚5和6:分别为调节和负输出(对于单输出型号) - 引脚7:正输出或公共地(对于双输出型号) - 引脚8:在单输出型号中不存在,对于双输出型号是正输出
参数特性: - 输入电压范围:9-36V或18-72V - 输出电压:5VDC, 12VDC, 15VDC, ±12VDC, ±15VDC, ±5VDC, 3.3VDC - 输出电流:最高4000mA - 效率:从78%到84%不等 - 隔离电压:至少1500VDC - 开关频率:典型值300kHz - 工作温度范围:-25℃至+71℃
功能详解: - Pi型输入滤波器 - 远程开关控制 - 持续短路保护 - 符合EN55032 A级传导标准 - UL60950-1认证 - 安全符合IEC/EN/UL 62368-1标准
应用信息:文档没有明确指出具体应用,但这种DC-DC转换器通常用于需要电压转换和电源隔离的电子设备中。
封装信息:转换器采用2英寸x 1.6英寸的六面屏蔽金属外壳,重量为53克。
EC1SC12 价格&库存
很抱歉,暂时无法提供与“EC1SC12”相匹配的价格&库存,您可以联系我们找货
