EC2SA13N
EC2SA13N
    CINCON
    SIP5 模块
    隔离模块 直流转换器 1 输出 15V 134mA 10.8V - 13.2V 输入
EC2SA13N 数据手册
V13 EC2SAN SERIES ︳ 2WATT, UNREGULATED OUTPUT DC-DC CONVERTERS FEATURES * Industry Standard SIP Packages * Efficiency up to 86% * 1000VDC Isolation * Low Cost * Unregulated Outputs * Industry Standard Pinout * No Tantalum Capacitors inside MODEL NUMBER INPUT OUTPUT OUTPUT INPUT CURRENT VOLTAGE VOLTAGE CURRENT NO LOAD FULL LOAD % EFF. CAPACITOR LOAD MAX. EC2SA01N 5 VDC 5 VDC 400 mA 60 mA 488 mA 82 EC2SA02N 5 VDC 12 VDC 167 mA 60 mA 466 mA 86 470uF 470uF EC2SA03N 5 VDC 15 VDC 134 mA 60 mA 473 mA 85 470uF EC2SA04N 5 VDC ±12 VDC ±83 mA 60 mA 463 mA 86 470uF EC2SA05N 5 VDC ±15 VDC ±67 mA 60 mA 467 mA 86 470uF EC2SA06N 5 VDC ±5 VDC ±200 mA 60 mA 482 mA 83 470uF EC2SA11N 12 VDC 5 VDC 400 mA 40 mA 203 mA 82 470uF EC2SA12N 12 VDC 12 VDC 167 mA 40 mA 201 mA 83 470uF EC2SA13N 12 VDC 15 VDC 134 mA 40 mA 199 mA 84 470uF EC2SA14N 12 VDC ±12 VDC ±83 mA 40 mA 202 mA 82 470uF EC2SA15N 12 VDC ±15 VDC ±67 mA 40 mA 199 mA 84 470uF EC2SA16N 12 VDC ±5 VDC ±200 mA 40 mA 203 mA 82 470uF EC2SA21N 24 VDC 5 VDC 400 mA 20 mA 105 mA 79 470uF EC2SA22N 24 VDC 12 VDC 167 mA 20 mA 103 mA 81 470uF EC2SA23N 24 VDC 15 VDC 134 mA 20 mA 102 mA 82 470uF EC2SA24N 24 VDC ±12 VDC ±83 mA 20 mA 102 mA 81 470uF EC2SA25N 24 VDC ±15 VDC ±67 mA 20 mA 102 mA 82 470uF EC2SA26N 24 VDC ±5 VDC ±200 mA 20 mA 105 mA 79 470uF NOTE: 1. Nominal Input Voltage 5, 12 or 24 VDC 1 V13 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃Unless Otherwise Noted INPUT SPECIFICATIONS : GENERAL SPECIFICATIONS : Input Voltage Range ..............................……………………..... ±10% Input Surge Voltage (100ms max.) ………... 5V ................ 9Vdc max. 12V …....... 18Vdc max. 24V ….… 30Vdc max. Input Filter ……………………………………….…..……… Capacitive Efficiency .........................................…………..…………............ See Table Isolation Voltage .................................……....………......... 1000 VDC min. 9 Isolation Resistance .....................…….……..………..……… 10 ohm min. Isolation Capacitance …………………..………………………….. 15 pF typ. Switching Frequency .............................…..….......................... 80KHz typ. OUTPUT SPECIFICATIONS : Operating Ambient Temperature Range ...………...…….... -40℃ to +85℃ Voltage Accuracy …………………....……………….........… ±3.0% max. Voltage Balance (Dual) …………………………………….... ±1.0% max. Ripple and Noise, 20MHz BW …………….....…….. 150mV pk-pk max. Single output, 5V ……..….. 100mVpk-pk max. Temperature Coefficient ......................….…………...... ±0.05%/℃ max. Short Circuit Protection...................….………… Momentary 1sec. max. Line Regulation (note1) ….………...………….…………..... ±1.2% max. Load Regulation (note2) …………..……...........………….... ±10% max. De-rating, Above 75℃ …………………… Linearly to Zero power at 100℃ Case temperature (note4) ……..………….………..…..…... +100℃ max. Cooling ……………………………………..….……….. Natural Convection Storage Temperature Range ...…............………....…....... -55℃ to +125℃ Humidity .................................................... 95% RH max. Non condensing MTBF ……. MIL-STD-217F,GB …..………………………… 3.3Mhrs min. Dimensions …….………....…. 0.77x0.28x0.40 inches(19.6x7.2x10.2 mm) Case Material …………………………….…… Non-conductive black plastic Weight ………..………………………………………………………….. 2.7g NOTE: 1. Line regulation is per 1.0% change in input voltage. 2. Load regulation is for load change from 100% to 20%. 3. The output noise is measured with 0.33uF ceramic capacitor. 4. Maximum case temperature under any operating condition should not be exceeded 100℃ . 5. The EC2SA2XN input terminal need to parallel with 10uF ceramic capacitor. Typical Derating curve for Natural Convection 120% 100% LOAD(%) Dimensions: CASE SIP-7 SIP PACKAGES -40 75 80% 60% 40% Natural Convection 20% 0% -40 100 -20 0 20 40 60 o Ambient Temperature( C) All Dimensions In Inches(mm) Tolerance Inches Millimeters X.XX±0.01 X.X±0.25 X.XXX±0.005 X.XX±0.13 ±0.002 ±0.05 Pin PIN CONNECTION Pin Single Output Dual Output 1 +Vin +Vin 2 -Vin -Vin -Vout 4 -Vout 5 No Pin Common +Vout 6 +Vout 2 80 100
EC2SA13N 价格&库存
很抱歉,暂时无法提供与“EC2SA13N”相匹配的价格&库存,您可以联系我们找货
