V13
EC2SAN SERIES
2WATT, UNREGULATED OUTPUT
DC-DC CONVERTERS
FEATURES
* Industry Standard SIP Packages
* Efficiency up to 86%
* 1000VDC Isolation
* Low Cost
* Unregulated Outputs
* Industry Standard Pinout
* No Tantalum Capacitors inside
MODEL
NUMBER
INPUT
OUTPUT OUTPUT
INPUT CURRENT
VOLTAGE VOLTAGE CURRENT NO LOAD FULL LOAD
EFF.
CAPACITOR
LOAD MAX.
EC2SA01N
5 VDC
5 VDC
400 mA
60 mA
488 mA
82
EC2SA02N
5 VDC
12 VDC
167 mA
60 mA
466 mA
86
470uF
470uF
EC2SA03N
5 VDC
15 VDC
134 mA
60 mA
473 mA
85
470uF
EC2SA04N
5 VDC
±12 VDC
±83 mA
60 mA
463 mA
86
470uF
EC2SA05N
5 VDC
±15 VDC
±67 mA
60 mA
467 mA
86
470uF
EC2SA06N
5 VDC
±5 VDC
±200 mA
60 mA
482 mA
83
470uF
EC2SA11N
12 VDC
5 VDC
400 mA
40 mA
203 mA
82
470uF
EC2SA12N
12 VDC
12 VDC
167 mA
40 mA
201 mA
83
470uF
EC2SA13N
12 VDC
15 VDC
134 mA
40 mA
199 mA
84
470uF
EC2SA14N
12 VDC
±12 VDC
±83 mA
40 mA
202 mA
82
470uF
EC2SA15N
12 VDC
±15 VDC
±67 mA
40 mA
199 mA
84
470uF
EC2SA16N
12 VDC
±5 VDC
±200 mA
40 mA
203 mA
82
470uF
EC2SA21N
24 VDC
5 VDC
400 mA
20 mA
105 mA
79
470uF
EC2SA22N
24 VDC
12 VDC
167 mA
20 mA
103 mA
81
470uF
EC2SA23N
24 VDC
15 VDC
134 mA
20 mA
102 mA
82
470uF
EC2SA24N
24 VDC
±12 VDC
±83 mA
20 mA
102 mA
81
470uF
EC2SA25N
24 VDC
±15 VDC
±67 mA
20 mA
102 mA
82
470uF
EC2SA26N
24 VDC
±5 VDC
±200 mA
20 mA
105 mA
79
470uF
NOTE: 1. Nominal Input Voltage 5, 12 or 24 VDC
1
V13
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃Unless Otherwise Noted
INPUT SPECIFICATIONS :
GENERAL SPECIFICATIONS :
Input Voltage Range ..............................……………………..... ±10%
Input Surge Voltage (100ms max.) ………... 5V ................ 9Vdc max.
12V …....... 18Vdc max.
24V ….… 30Vdc max.
Input Filter ……………………………………….…..……… Capacitive
Efficiency .........................................…………..…………............ See Table
Isolation Voltage .................................……....………......... 1000 VDC min.
9
Isolation Resistance .....................…….……..………..……… 10 ohm min.
Isolation Capacitance …………………..………………………….. 15 pF typ.
Switching Frequency .............................…..….......................... 80KHz typ.
OUTPUT SPECIFICATIONS :
Operating Ambient Temperature Range ...………...…….... -40℃ to +85℃
Voltage Accuracy …………………....……………….........… ±3.0% max.
Voltage Balance (Dual) …………………………………….... ±1.0% max.
Ripple and Noise, 20MHz BW …………….....…….. 150mV pk-pk max.
Single output, 5V ……..….. 100mVpk-pk max.
Temperature Coefficient ......................….…………...... ±0.05%/℃ max.
Short Circuit Protection...................….………… Momentary 1sec. max.
Line Regulation (note1) ….………...………….…………..... ±1.2% max.
Load Regulation (note2) …………..……...........………….... ±10% max.
De-rating, Above 75℃ …………………… Linearly to Zero power at 100℃
Case temperature (note4) ……..………….………..…..…... +100℃ max.
Cooling ……………………………………..….……….. Natural Convection
Storage Temperature Range ...…............………....…....... -55℃ to +125℃
Humidity .................................................... 95% RH max. Non condensing
MTBF ……. MIL-STD-217F,GB …..………………………… 3.3Mhrs min.
Dimensions …….………....…. 0.77x0.28x0.40 inches(19.6x7.2x10.2 mm)
Case Material …………………………….…… Non-conductive black plastic
Weight ………..………………………………………………………….. 2.7g
NOTE:
1. Line regulation is per 1.0% change in input voltage.
2. Load regulation is for load change from 100% to 20%.
3. The output noise is measured with 0.33uF ceramic capacitor.
4. Maximum case temperature under any operating condition should
not be exceeded 100℃ .
5. The EC2SA2XN input terminal need to parallel with 10uF ceramic
capacitor.
Typical Derating curve for Natural Convection
120%
100%
LOAD(%)
Dimensions:
CASE SIP-7
SIP PACKAGES
-40
75
80%
60%
40%
Natural Convection
20%
0%
-40
100
-20
60
o
Ambient Temperature( C)
All Dimensions In Inches(mm)
Tolerance Inches
Millimeters
X.XX±0.01
X.X±0.25
X.XXX±0.005 X.XX±0.13
±0.002
±0.05
Pin
PIN CONNECTION
Pin Single Output Dual Output
1
+Vin
+Vin
2
-Vin
-Vin
-Vout
4
-Vout
5
No Pin
Common
+Vout
6
+Vout
2
80
100
很抱歉,暂时无法提供与“EC2SA06N”相匹配的价格&库存,您可以联系我们找货
