RP102N331D-TR-FE
RP102N331D-TR-FE
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 300mA SOT-23-5
RP102N331D-TR-FE 数据手册
RP102x SERIES LOW NOISE 300mA LDO REGULATOR NO.EA-141-160705 OUTLINE The RP102x Series are CMOS-based voltage regulator ICs with high output voltage accuracy, extremely low supply current, low ON-resistance, and high ripple rejection. Each of these ICs consists of a voltage reference unit, an error amplifier, a resistor-net for voltage setting, a current limit circuit and a chip enable circuit. These ICs perform with low dropout voltage and "chip enable" function. The line transient response and load transient response of the RP102x Series are excellent, thus these ICs are very suitable for the power supply for hand-held communication equipment. The output voltage of these ICs is fixed with high accuracy. Since the packages for these ICs are SOT-23-5, DFN(PL)1820-6, and WLCSP-4-P2, therefore high density mounting of the ICs on boards is possible. FEATURES           Supply Current ...................................................... Typ. 50A Standby Mode ....................................................... Typ. 0.1A Dropout Voltage .................................................... Typ. 0.12V (IOUT300mA, VOUT2.8V) Ripple Rejection .................................................... Typ. 80dB (f1kHz) Temperature-Drift Coefficient of Output Voltage ... Typ. ±20ppm/C Line Regulation ..................................................... Typ. 0.02%/V Output Voltage Accuracy....................................... 0.8% Packages .............................................................. WLCSP-4-P2, DFN(PL)1820-6, SOT-23-5 Input Voltage Range ............................................. 1.7V to 5.25V Output Voltage Range ........................................... 1.2V to 3.3V (0.1V steps) (For other voltages, please refer to MARK INFORMATIONS.)  Built-in Fold Back Protection Circuit ..................... Typ. 50mA (Current at short mode)  Ceramic capacitors are recommended to be used with this IC ...... CINCOUT1F or more APPLICATIONS  Power source for portable communication equipment.  Power source for electrical appliances such as cameras, VCRs and camcorders.  Power source for battery-powered equipment. 1 RP102x NO.EA-141-160705 BLOCK DIAGRAMS RP102xxx1B RP102xxx1D VDD VOUT VDD Vref VOUT Vref Current Limit Current Limit CE GND CE GND SELECTION GUIDE The output voltage, auto discharge function, package, and the taping type, etc. for the ICs can be selected at the user’s request. Product Name RP102Zxx1-TR-F RP102Kxx1-TR RP102Nxx1-TR-FE Package Quantity per Reel Pb Free Halogen Free WLCSP-4-P2 5,000 pcs Yes Yes DFN(PL)1820-6 5,000 pcs Yes Yes 3,000 pcs Yes Yes SOT-23-5 xx : The output voltage can be designated in the range from 1.2V(12) to 3.3V(33) in 0.1V steps. (For other voltages, please refer to MARK INFORMATIONS.)  : CE pin polarity and auto discharge function at off state are options as follows. (B) "H" active, without auto discharge function at off state (D) "H" active, with auto discharge function at off state 2 RP102x NO.EA-141-160705 PIN CONFIGURATIONS  WLCSP-4-P2 Mark Side Bump Side Top View 6 5 Bottom View 4 4 2 2  SOT-23-5 • DFN(PL)1820-6 5 5 4 6 1 (mark side) 1 1 A B B 1 A 1 2 3 3 2 2 3 1 PIN DESCRIPTION  • WLCSP-4-P2 Pin No Symbol Pin Description A1 VDD Input Pin A2 VOUT Output Pin B1 CE Chip Enable Pin ("H" Active) B2 GND Ground Pin DFN(PL)1820-6 Pin No Symbol Pin Description 1 VOUT Output Pin2 2 VOUT Output Pin2 3 GND Ground Pin 4 CE Chip Enable Pin ("H" Active) 5 VDD Input Pin2 6 VDD Input Pin2  ∗1) Tab is GND level. (They are connected to the reverse side of this IC.) The tab is better to be connected to the GND, but leaving it open is also acceptable. ∗2) No.1 pin and No.2 pin, No.5 pin and No.6 pin of DFN(PL)1820-6 package must be wired when it is mounted on board.  SOT-23-5 Pin No Symbol Pin Description 1 VDD 2 GND 3 CE Chip Enable Pin ("H" Active) 4 NC No Connection 5 VOUT Output Pin Input Pin Ground Pin 3 RP102x NO.EA-141-160705 ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit VIN Input Voltage 6.0 V VCE Input Voltage (CE Pin) 6.0 V VOUT Output Voltage 0.3 to VIN0.3 V IOUT Output Current 400 mA Power Dissipation (WLCSP-4-P2)  PD Power Dissipation (SOT-23-5)  Power Dissipation (DFN(PL)1820-6) ∗ 530 420 mW 880 Topt Operating Temperature Range 40 to 85 C Tstg Storage Temperature Range 55 to 125 C ) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 4 RP102x NO.EA-141-160705 ELECTRICAL CHARACTERISTICS  RP102xxx1B/D VINSet VOUT1V for VOUT options grater than 1.5V. VIN2.5V for VOUT IOUT1mA, CINCOUT1F, unless otherwise noted.   1.5V. Topt25C Symbol Item VOUT Output Voltage IOUT Output Current Conditions VINSet VOUT1V Min. VOUT > 2.0V VOUT   2.0V Typ. Max. Unit 0.992 1.008 V 16 16 mV 300 mA 1mA   IOUT   150mA 10 20 1mA  IOUT   300mA  20 40 VOUT/ IOUT Load Regulation VDIF Dropout Voltage ISS Supply Current IOUT0mA 50 70 A Supply Current (Standby) VCE0V 0.1 2.0 A VOUT/VIN Line Regulation Set VOUT0.5V 0.02 0.10 %/V RR Ripple Rejection f1kHz, Ripple 0.2Vp-p VINSet VOUT1V, IOUT30mA (In case that VOUT   2V, VIN3V) VIN Input Voltage* Istandby Refer to the following table   VIN   5V 80 1.7 Output Voltage Temperature Coefficient 40C ISC Short Current Limit VOUT0V IPD CE Pull-down Current 0.05 VCEH CE Input Voltage “H” 1.1 VCEL CE Input Voltage “L” VOUT/Topt en RLOW mV   Topt   85C dB 5.25 V 20 ppm /C 50 mA 0.3 0.6 A V 0.3 V Output Noise BW10Hz to 100kHz, IOUT30mA 30 Vrms Low Output Nch Tr. ON Resistance (of D version) VIN4V VCE0V 30   ) The maximum Input Voltage of the ELECTRICAL CHARACTERISTICS is 5.25V. In case of exceeding this specification, the IC must be operated on condition that the Input Voltage is up to 5.5V and the total operating time is within 500hrs.  Electrical Characteristics by Output Voltage Output Voltage VOUT (V) Topt25C Dropout Voltage VDIF (V) Condition Typ. Max. Condition Typ. Max. 1.2V   VOUT < 1.5V 0.145 - 0.290 0.500 1.5V   VOUT < 1.7V 0.110 0.160 0.220 0.320 1.7V   VOUT < 2.0V 0.100 0.140 0.200 0.280 2.0V   VOUT < 2.5V 0.085 0.120 0.170 0.240 2.5V   VOUT < 2.8V 0.070 0.100 0.140 0.200 2.8V   VOUT   3.3V 0.060 0.095 0.120 0.190 IOUT150mA IOUT300mA 5 RP102x NO.EA-141-160705 TYPICAL APPLICATION VDD C1 VOUT RP102x Series CE C2 GND (External Components) C2 1.0F MURATA: GRM155B31A105KE15 TECHNICAL NOTES When using these ICs, consider the following points: Phase Compensation In these ICs, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor C2 with good frequency characteristics and ESR (Equivalent Series Resistance). (Note: If additional ceramic capacitors are connected with parallel to the output pin with an output capacitor for phase compensation, the operation might be unstable. Because of this, test these ICs with as same external components as ones to be used on the PCB.) PCB Layout Make VDD and GND lines sufficient. If their impedance is high, noise pickup or unstable operation may result. Connect a capacitor C1 with a capacitance value as much as 1.0F or more between VDD and GND pin, and as close as possible to the pins. Set external components, especially the output capacitor C2, as close as possible to the ICs, and make wiring as short as possible. 6 RP102x NO.EA-141-160705 TEST CIRCUITS VDD VOUT RP102x Series C1 CE C2 V VOUT IOUT GND C1=Ceramic 1.0F C2=Ceramic 1.0F Basic Test Circuit VDD A RP102x Series C1 ISS VOUT CE C2 GND C1=Ceramic 1.0F C2=Ceramic 1.0F Test Circuit for Supply Current Pulse Generator VDD VOUT RP102x Series P.G. CE C2 IOUT GND C2=Ceramic 1.0F Test Circuit for Ripple Rejection VDD C1 VOUT RP102x Series CE C2 GND IOUTa IOUTb C1=Ceramic 1.0F C2=Ceramic 1.0F Test Circuit for Load Transient Response 7 RP102x NO.EA-141-160705 TYPICAL CHARACTERISTIC 1) Output Voltage vs. Output Current (CIN1.0F, COUT1.0F, Topt25C) RP102x121x RP102x251x 3.0 1.2 1.0 0.8 0.6 VIN=2.2V VIN=3.6V VIN=4.2V VIN=5.0V VIN=5.5V 0.4 0.2 0 0 Output Voltage VOUT (V) Output Voltage VOUT (V) 1.4 2.5 2.0 VIN=3.5V VIN=4.2V VIN=5.0V VIN=5.5V 1.5 1.0 0.5 0 100 200 300 400 500 600 700 Output Current IOUT (mA) 0 100 200 300 400 500 600 700 Output Current IOUT (mA) RP102x331x Output Voltage VOUT (V) 4.0 3.5 3.0 2.5 VIN=4.2V VIN=5.0V VIN=5.5V 2.0 1.5 1.0 0.5 0 0 100 200 300 400 500 600 700 Output Current IOUT (mA) 2) Output Voltage vs. Input Voltage (CIN1.0F, COUT1.0F, Topt25C) RP102x251x 1.4 2.8 1.2 2.4 1.0 0.8 IOUT=1mA IOUT=30mA IOUT=50mA 0.6 0.4 0.2 0 2.0 1.6 IOUT=1mA IOUT=30mA IOUT=50mA 1.2 0.8 0.4 0 0 8 Output Voltage VOUT (V) Output Voltage VOUT (V) RP102x121x 1 2 3 4 Input Voltage VIN (V) 5 0 1 2 3 4 Input Voltage VIN (V) 5 RP102x NO.EA-141-160705 RP102x331x Output Voltage VOUT (V) 3.5 3.0 2.5 2.0 IOUT=1mA IOUT=30mA IOUT=50mA 1.5 1.0 0.5 0 0 1 2 3 4 Input Voltage VIN (V) 5 3) Supply Current vs. Input Voltage (CIN1.0F, COUT1.0F, Topt25C) RP102x251x 60 60 50 50 Supply Current ISS (μA) Supply Current ISS (μA) RP102x121x 40 30 20 10 0 40 30 20 10 0 0 1 2 3 4 Input Voltage VIN (V) 5 0 1 2 3 4 Input Voltage VIN (V) 5 RP102x331x Supply Current ISS (μA) 60 50 40 30 20 10 0 0 1 2 3 4 Input Voltage VIN (V) 5 9 RP102x NO.EA-141-160705 4) Output Voltage vs. Temperature (CIN1.0F, COUT1.0F, IOUT1mA) 1.25 1.24 1.23 1.22 1.21 1.20 1.19 1.18 1.17 1.16 1.15 -40 -25 RP102x251x VIN=2.2V Output Voltage VOUT (V) Output Voltage VOUT (V) RP102x121x 0 25 50 Temperature Topt (°C) 75 85 2.55 2.54 2.53 2.52 2.51 2.50 2.49 2.48 2.47 2.46 2.45 -40 -25 VIN=3.5V 0 25 50 Temperature Topt (°C) 75 85 Output Voltage VOUT (V) RP102x331x 3.35 3.34 3.33 3.32 3.31 3.30 3.29 3.28 3.27 3.26 3.25 -40 -25 VIN=4.3V 0 25 50 Temperature Topt (°C) 75 85 5) Supply Current vs. Temperature (CIN1.0F, COUT1.0F, IOUT0mA) RP102x121x 55 50 45 40 -40 -25 10 VIN=2.2V 60 Supply Current ISS (μA) Supply Current ISS (μA) 60 RP102x251x 0 25 50 Temperature Topt (°C) 75 85 VIN=3.5V 55 50 45 40 -40 -25 0 25 50 Temperature Topt (°C) 75 85 RP102x NO.EA-141-160705 RP102x331x VIN=4.3V Supply Current ISS (μA) 60 55 50 45 40 -40 -25 0 25 50 Temperature Topt (°C) 75 85 6) Dropout Voltage vs. Output Current (CIN1.0F, COUT1.0F) RP102x121x RP102x251x 200 85°C 25°C -40°C 250 200 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 300 150 100 50 0 85°C 25°C -40°C 150 100 50 0 0 50 100 150 200 250 Output Current IOUT (mA) 300 0 50 100 150 200 250 Output Current IOUT (mA) 300 RP102x331x Dropout Voltage VDIF (mV) 200 85°C 25°C -40°C 150 100 50 0 0 50 100 150 200 250 Output Current IOUT (mA) 300 11 RP102x NO.EA-141-160705 7) Dropout Voltage vs Set Output Voltage (CIN1.0F, COUT1.0F, Topt25C) Dropout voltage VDIF (mV) 300 10mA 30mA 100mA 150mA 300mA 250 200 150 100 50 0 1.0 1.5 2.0 2.5 3.0 Set Output Voltage VREG (V) 3.5 8) Ripple Rejection vs. Input Bias Voltage (CINnone, COUT1.0F, Ripple0.2Vp-p, Topt25C) RP102x121x IOUT=1mA 90 80 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 IOUT=30mA 90 Ripple Rejection RR (dB) Ripple Rejection RR (dB) RP102x121x 0 1.2 1.7 2.2 2.7 3.2 3.7 4.2 4.7 Input Voltage VIN (V) 80 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 0 1.2 1.7 2.2 2.7 3.2 3.7 4.2 4.7 Input Voltage VIN (V) RP102x281x IOUT=1mA 80 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 0 2.8 3.3 3.8 4.3 4.8 Input Voltage VIN (V) 5.3 IOUT=30mA 90 Ripple Rejection RR (dB) Ripple Rejection RR (dB) 90 12 RP102x281x 80 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 0 2.8 3.3 3.8 4.3 4.8 Input Voltage VIN (V) 5.3 RP102x NO.EA-141-160705 9) Ripple Rejection vs. Frequency (CIN1.0F, COUT1.0F, Ripple0.2Vp-p) RP102x121x VIN=2.2V 100 80 60 40 20 0 0.1 IOUT=1mA IOUT=30mA IOUT=150mA 1 10 100 Frequency f (kHz) VIN=3.5V 120 Ripple Reiection RR (dB) 120 Ripple Reiection RR (dB) RP102x251x 100 80 60 40 20 0 0.1 1000 IOUT=1mA IOUT=30mA IOUT=150mA 1 10 100 Frequency f (kHz) 1000 RP102x331x VIN=4.3V Ripple Reiection RR (dB) 120 100 80 60 40 20 0 0.1 IOUT=1mA IOUT=30mA IOUT=150mA 1 10 100 Frequency f (kHz) 1000 RP102x121x VIN=2.2V IOUT=30mA 100 80 60 40 20 0 0.1 TOUT=-40°C TOUT=25°C TOUT=85°C 1 10 100 Frequency f (kHz) 1000 VIN=3.5V IOUT=30mA 120 Ripple Reiection RR (dB) 120 Ripple Reiection RR (dB) RP102x251x 100 80 60 40 20 0 0.1 TOUT=-40°C TOUT=25°C TOUT=85°C 1 10 100 Frequency f (kHz) 1000 13 RP102x NO.EA-141-160705 RP102x331x VIN=4.3V IOUT=30mA Ripple Reiection RR (dB) 120 100 80 60 40 TOUT=-40°C TOUT=25°C TOUT=85°C 20 0 0.1 1 10 100 Frequency f (kHz) 1000 10) Input Transient Response (CINnone, COUT1.0F, IOUT30mA, trtf5s, Topt25C) RP102x121x RP102x251x 1.200 1.195 Output Voltage 1.190 20 40 60 Time t (μs) 80 100 2.500 2.495 Output Voltage 0 RP102x331x 5 Input Voltage 4 3.300 3.295 Output Voltage 3.290 0 20 40 60 Time t (μs) 80 100 Input Voltage VIN(V) 6 Output Voltage VOUT (V) 3 2.490 0 14 4 Input Voltage 20 40 60 Time t (μs) 80 100 Input Voltage VIN(V) 2 Output Voltage VOUT (V) 3 Input Voltage 5 Input Voltage VIN(V) Output Voltage VOUT (V) 4 RP102x NO.EA-141-160705 11) Load Transient Response (COUT1.0F, Topt25C) RP102x251x 50 100mA 0 1.20 1.19 Output Voltage 1.18 Output Voltage VOUT (V) 150 100 Output Current 50mA VIN=3.5V tr=tf=0.5μs Output Current IOUT (mA) Output Voltage VOUT (V) VIN=2.2V tr=tf=0.5μs 1.17 150 100 50 Output Current 50mA 100mA 0 2.50 2.49 Output Voltage 2.48 Output Current IOUT (mA) RP102x121x 2.47 0 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 RP102x331x 150 100 Output Current 50mA 50 100mA 0 3.30 3.29 Output Voltage 3.28 Output Current IOUT (mA) Output Voltage VOUT (V) VIN=3.5V tr=tf=0.5μs 3.27 20 40 60 Time t (μs) 80 100 RP102x121x RP102x251x 300 150mA 150 0 1.20 Output Voltage 1.15 1.10 Output Voltage VOUT (V) Output Current 1mA VIN=3.5V tr=tf=0.5μs Output Current IOUT (mA) Output Voltage VOUT (V) VIN=2.2V tr=tf=0.5μs Output Current 1mA 300 150mA 150 0 2.50 Output Voltage 2.45 Output Current IOUT (mA) 0 2.40 0 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 15 RP102x NO.EA-141-160705 RP102x331x Output Voltage VOUT (V) Output Current 1mA 300 150mA 150 0 3.30 3.25 Output Voltage 3.20 Output Current IOUT (mA) VIN=4.3V tr=tf=0.5μs 3.15 0 20 40 60 Time t (μs) 80 100 12) Turn On Speed with CE pin (CIN1.0F, COUT1.0F, Topt25C) RP102x121x RP102x121x 2 2 1 CE Input Voltage 0 1.5 1.0 Output Voltage 0.5 0 20 40 60 Time t (μs) 80 100 1 0 1.5 1.0 Output Voltage 0.5 0 RP102x121x IOUT=150mA 2 CE Input Voltage 1 0 1.5 1.0 Output Voltage 0.5 0 0 20 40 60 Time t (μs) 80 100 CE Input Voltage VCE (V) 3 Output Voltage VOUT (V) CE Input Voltage 0 0 16 Output Voltage VOUT (V) 3 20 40 60 Time t (μs) 80 100 CE Input Voltage VCE (V) IOUT=30mA 3 CE Input Voltage VCE (V) Output Voltage VOUT (V) IOUT=0mA RP102x NO.EA-141-160705 RP102x251x RP102x251x 4 4 2 CE Input Voltage 0 3 2 Output Voltage 1 Output Voltage VOUT (V) 6 0 2 CE Input Voltage 0 3 2 Output Voltage 1 CE Input Voltage VCE (V) IOUT=30mA 6 CE Input Voltage VCE (V) Output Voltage VOUT (V) IOUT=0mA 0 0 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 RP102x251x IOUT=150mA 4 2 CE Input Voltage 0 3 2 Output Voltage 1 CE Input Voltage VCE (V) Output Voltage VOUT (V) 6 0 20 40 60 Time t (μs) 80 100 RP102x331x RP102x331x 6 4 4 2 0 4.5 3.0 Output Voltage 1.5 0 Output Voltage VOUT (V) CE Input Voltage IOUT=30mA 6 CE Input Voltage VCE (V) Output Voltage VOUT (V) IOUT=0mA CE Input Voltage 2 0 4.5 3.0 Output Voltage 1.5 CE Input Voltage VCE (V) 0 0 0 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 17 RP102x NO.EA-141-160705 RP102x331x IOUT=150mA 4 2 CE Input Voltage 0 4.5 3.0 Output Voltage 1.5 CE Input Voltage VCE (V) Output Voltage VOUT (V) 6 0 0 20 40 60 Time t (μs) 80 100 13) Turn OFF Speed with CE pin (D Version) (CIN1.0F, COUT1.0F, Topt25C) RP102x121D RP102x121D 2 2 1 CE Input Voltage 0 1.5 1.0 Output Voltage 0.5 0 100 200 300 Time t (μs) 400 1 0 1.5 1.0 Output Voltage 0.5 0 500 RP102x121D IOUT=300mA 2 CE Input Voltage 1 0 1.5 1.0 Output Voltage 0.5 0 0 20 40 60 Time t (μs) 80 100 CE Input Voltage VCE (V) 3 Output Voltage VOUT (V) CE Input Voltage 0 0 18 Output Voltage VOUT (V) 3 50 100 Time t (μs) 150 200 CE Input Voltage VCE (V) IOUT=30mA 3 CE Input Voltage VCE (V) Output Voltage VOUT (V) IOUT=0mA RP102x NO.EA-141-160705 RP102x251x RP102x251x 2.5 2.5 1.5 CE Input Voltage 0 2.5 1.5 Output Voltage 0.5 Output Voltage VOUT (V) 3.5 0 CE Input Voltage 1.5 0 2.5 1.5 Output Voltage 0.5 CE Input Voltage VCE (V) IOUT=30mA 3.5 CE Input Voltage VCE (V) Output Voltage VOUT (V) IOUT=0mA 0 0 100 200 300 Time t (μs) 400 0 500 100 200 300 Time t (μs) 400 500 RP102x251x IOUT=300mA 2.5 1.5 CE Input Voltage 0 2.5 1.5 Output Voltage 0.5 CE Input Voltage VCE (V) Output Voltage VOUT (V) 3.5 0 100 200 300 Time t (μs) 400 500 RP102x331x RP102x331x IOUT=30mA 4.5 3.5 3.5 2.5 CE Input Voltage 1.5 0 3.5 2.5 1.5 Output Voltage 0.5 0 Output Voltage VOUT (V) 4.5 CE Input Voltage VCE (V) Output Voltage VOUT (V) IOUT=0mA 2.5 CE Input Voltage 1.5 0 3.5 2.5 1.5 Output Voltage 0.5 CE Input Voltage VCE (V) 0 0 0 100 200 300 Time t (μs) 400 500 0 100 200 300 Time t (μs) 400 500 19 RP102x NO.EA-141-160705 RP102x331x IOUT=300mA 3.5 2.5 CE Input Voltage 1.5 0 3.5 2.5 1.5 Output Voltage 0.5 0 0 20 100 200 300 Time t (μs) 400 500 CE Input Voltage VCE (V) Output Voltage VOUT (V) 4.5 RP102x NO.EA-141-160705 ESR vs. Output Current When using these ICs, consider the following points: The relations between IOUT (Output Current) and ESR of an output capacitor are shown below. The conditions when the white noise level is under 40V (Avg.) are marked as the hatched area in the graph. Measurement conditions Frequency Band: 10Hz to 2MHz Temperature: 40C to 85C RP102x121x RP102x251x VIN=2.2V to 5.5V CIN=COUT=1.0μF VIN=3.5V to 5.5V CIN=COUT=1.0μF 100 100 Topt=85°C Topt=85°C 10 Topt=-40°C ESR (Ω) ESR (Ω) 10 1 0.10 Topt=-40°C 1 0.10 0.01 0.01 0 50 100 150 200 250 Output Current IOUT (mA) 300 0 50 100 150 200 250 Output Current IOUT (mA) 300 RP102x331x VIN=4.3V to 5.5V CIN=COUT=1.0μF 100 Topt=85°C ESR (Ω) 10 Topt=-40°C 1 0.10 0.01 0 50 100 150 200 250 Output Current IOUT (mA) 300 21 RP102x NO.EA-141-160705 PACKAGE INFORMATION Power Dissipation (WLCSP-4-P2) This specification is at mounted on board. Power Dissipation (PD) depends on conditions of mounting on board. This specification is based on the measurement at the condition below: Measurement Conditions Standard Land Pattern Environment Mounting on Board (Wind velocity=0m/s) Board Material Glass cloth epoxy plastic (Double-sided) Board Dimensions 40mm x 40mm x 1.6mm Copper Ratio Top side: Approx. 50%, Back side: Approx. 50% Through-hole 0.5mm x pcs Measurement Result (Ta=25C) Standard Land Pattern Power Dissipation 530mW (Tjmax=125C) 662mW (Tjmax=150C) Thermal Resistance ja(125-25C)/0.53W189C/W 40 662 600 530 400 40 Power Dissipation PD (mW) 800 200 0 0 25 50 75 85 100 125 150 Ambient Temperature (ºC) Power Dissipation Measurement Board Pattern IC Mount Area (Unit: mm) The above graph shows the Power Dissipation of the package based on Tjmax=125C and Tjmax=150C. Operating the IC in the shaded area in the graph might have an influence on its lifetime. Operating time must be within the time limit described in the table below, in case of operating in the shaded area. Operating Time 13,000 hours 22 Estimated years (Operating 4 hours/day) 9years RP102x NO.EA-141-160705 Package Dimensions (WLCSP-4-P2) 0.79 B A 0.50 X4 2 0.50 0.79 0.05 1 INDEX B A 0.160.03 0.10 S 0.05 M S AB Bottom View 0.400.02 0.06 S S 0.080.03 (Unit: mm) Mark Specifications (WLCSP-4-P2) : Lot Number … Alphanumeric Serial Number   23 RP102x NO.EA-141-160705 Power Dissipation (DFN(PL)1820-6) This specification is at mounted on board. Power Dissipation (PD) depends on conditions of mounting on board. This specification is based on the measurement at the condition below: Measurement Conditions Standard Land Pattern Environment Mounting on Board (Wind velocity=0m/s) Board Material Glass cloth epoxy plastic (Double-sided) Board Dimensions 40mm x 40mm x 1.6mm Copper Ratio Top side: Approx. 50%, Back side: Approx. 50% Through-hole 0.54mm x 30pcs Measurement Result (Ta=25C) Standard Land Pattern Power Dissipation 880mW(Tjmax=125C) 1100mW(Tjmax=150C) Thermal Resistance ja=(125-25C)/0.88W=114C /W 40 1100 1000 800 880 600 40 Power Dissipation PD (mW) 1200 400 200 0 0 25 50 75 85 100 125 150 Ambient Temperature (ºC) Power Dissipation Measurement Board Pattern IC Mount Area (Unit: mm) The above graph shows the Power Dissipation of the package based on Tjmax=125C and Tjmax=150C. Operating the IC in the shaded area in the graph might have an influence on its lifetime. Operating time must be within the time limit described in the table below, in case of operating in the shaded area. Operating Time 13,000 hours 24 Estimated years (Operating 4 hours/day) 9years RP102x NO.EA-141-160705 Package Dimensions (DFN(PL)1820-6) 1.60.1 A 1.80 0.200.1 B 5 4 6 0.250.1 0.250.1 X4 0.05 * 1.00.1 2.00 0.05 M AB INDEX S 0.05min 0.6MAX. 3 0.05 S 0.5 2 1 0.1NOM. 0.30.1 Bottom View (Unit: mm) is GND level. (They are connected to the *Tab reverse side of this IC.) The tab is better to be connected to the GND, but leaving it open is also acceptable. Mark Specifications (DFN(PL)1820-6) : Product Code … Refer to “RP102K Series Mark Specification Table”. : Lot Number … Alphanumeric Serial Number 6 5 4   1 2 3 25 RP102x NO.EA-141-160705 RP102K Series Mark Specification Table PKG: DFN(PL)1820-6 RP102Kxx1B 26 RP102Kxx1D Part Number  Vset Part Number  Vset RP102K121B AC01 1.2V RP102K121D AD01 1.2V RP102K131B AC02 1.3V RP102K131D AD02 1.3V RP102K151B AC03 1.5V RP102K151D AD03 1.5V RP102K181B AC04 1.8V RP102K181D AD04 1.8V RP102K251B AC05 2.5V RP102K251D AD05 2.5V RP102K261B AC06 2.6V RP102K261D AD06 2.6V RP102K281B AC07 2.8V RP102K281D AD07 2.8V RP102K281B5 AC08 2.85V RP102K281D5 AD08 2.85V RP102K291B AC09 2.9V RP102K291D AD09 2.9V RP102K301B AC10 3.0V RP102K301D AD10 3.0V RP102K331B AC11 3.3V RP102K331D AD11 3.3V RP102K181B5 AC12 1.85V RP102K181D5 AD12 1.85V RP102K271B AC13 2.7V RP102K271D AD13 2.7V RP102K121B5 AC14 1.25V RP102K121D5 AD14 1.25V RP102K311B AC15 3.1V RP102K311D AD15 3.1V RP102K171B5 AC16 1.75V RP102K171D5 AD16 1.75V RP102K211B AC17 2.1V RP102K211D AD17 2.1V RP102K141B AC18 1.4V RP102K141D AD18 1.4V RP102K321B AC19 3.2V RP102K321D AD19 3.2V RP102K171B AC20 1.7V RP102K171D AD20 1.7V RP102K201B AC21 2.0V RP102K201D AD21 2.0V RP102K291B5 AC22 2.95V RP102K291D5 AD22 2.95V RP102K321B5 AC23 3.25V RP102K321D5 AD23 3.25V RP102K161B AC24 1.6V RP102K161D AD24 1.6V RP102K191B AC25 1.9V RP102K191D AD25 1.9V RP102K221B AC26 2.2V RP102K221D AD26 2.2V RP102K231B AC27 2.3V RP102K231D AD27 2.3V RP102K241B AC28 2.4V RP102K241D AD28 2.4V RP102x NO.EA-141-160705 Power Dissipation (SOT-23-5) This specification is at mounted on board. Power Dissipation (PD) depends on conditions of mounting on board. This specification is based on the measurement at the condition below: (Power Dissipation (SOT-23-5) is substitution of SOT-23-6.) Measurement Conditions Standard Test Land Pattern Mounting on Board (Wind velocity=0m/s) Glass cloth epoxy plastic (Double sided) 40mm * 40mm * 1.6mm Top side: Approx. 50%, Back side: Approx. 50% Environment Board Material Board Dimensions Copper Ratio Through-holes  0.5mm * 44pcs Measurement Result (Ta=25C) Power Dissipation Thermal Resistance Standard Test Land Pattern 420mW(Tjmax=125C) 525mW(Tjmax=150C) ja = (125-25C)/0.42W= 263C/W Free Air 250mW(Tjmax=125C) 400C/W 600 40 On Board 500 400 420 Free Air 300 250 40 Power Dissipation PD (mW) 525 200 100 0 0 25 50 75 85 100 125 150 Ambient Temperature (°C) Power Dissipation Measurement Board Pattern IC Mount Area (Unit: mm) The above graph shows the Power Dissipation of the package based on Tjmax=125C and Tjmax=150C. Operating the IC in the shaded area in the graph might have an influence it's lifetime. Operating time must be within the time limit described in the table below, in case of operating in the shaded area. Operating Time 2,300 hours Estimated years (Operating four hours/day) 1.5years 27 RP102x NO.EA-141-160705 Package Dimensions (SOT-23-5) 2.9±0.2 1.1±0.1 1.9±0.2 0.8±0.1 (0.95) 4 1 2 0~0.1 0.2min. +0.2 1.6-0.1 5 2.8±0.3 (0.95) 3 +0.1 0.15-0.05 0.4±0.1 (Unit: mm) Mark Specifications (SOT-23-5) : Product Code … Refer to “RP102N Series Mark Specification Table”. : Lot Number … Alphanumeric Serial Number 5 4  1 28 2 3 RP102x NO.EA-141-160705 RP102N Series Mark Specification Table PKG: SOT-23-5 RP102Nxx1B RP102Nxx1D   RP102N121B 60A Vset 1.2V RP102N131B 60B 1.3V RP102N131D 61B 1.3V RP102N151B 60C 1.5V RP102N151D 61C 1.5V RP102N181B 60D 1.8V RP102N181D 61D 1.8V RP102N251B 60E 2.5V RP102N251D 61E 2.5V RP102N261B 60F 2.6V RP102N261D 61F 2.6V RP102N281B 60G 2.8V RP102N281D 61G 2.8V RP102N281B5 60H 2.85V RP102N281D5 61H 2.85V RP102N291B 60J 2.9V RP102N291D 61J 2.9V RP102N301B 60K 3.0V RP102N301D 61K 3.0V RP102N331B 60L 3.3V RP102N331D 61L 3.3V RP102N181B5 60M 1.85V RP102N181D5 61M 1.85V RP102N271B 60N 2.7V RP102N271D 61N 2.7V RP102N121B5 60P 1.25V RP102N121D5 61P 1.25V RP102N311B 60Q 3.1V RP102N311D 61Q 3.1V RP102N171B5 60R 1.75V RP102N171D5 61R 1.75V RP102N211B 60S 2.1V RP102N211D 61S 2.1V RP102N141B 60T 1.4V RP102N141D 61T 1.4V RP102N321B 60U 3.2V RP102N321D 61U 3.2V RP102N171B 60V 1.7V RP102N171D 61V 1.7V RP102N201B 60W 2.0V RP102N201D 61W 2.0V RP102N291B5 60X 2.95V RP102N291D5 61X 2.95V RP102N321B5 60Y 3.25V RP102N321D5 61Y 3.25V RP102N161B5 60Z 1.6V RP102N161D 61Z 1.6V RP102N191B5 62A 1.9V RP102N191D 63A 1.9V RP102N221B5 62B 2.2V RP102N221D 63B 2.2V RP102N231B5 62C 2.3V RP102N231D 63C 2.3V RP102N241B5 62D 2.4V RP102N241D 63D 2.4V Part Number RP102N121D 61A Vset 1.2V Part Number 29 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP102N331D-TR-FE 价格&库存
很抱歉,暂时无法提供与“RP102N331D-TR-FE”相匹配的价格&库存,您可以联系我们找货
RP102N331D-TR-FE
  • 3000+3.845833000+0.49756
  • 6000+3.754016000+0.48569
  • 9000+3.708049000+0.47974
  • 15000+3.6571215000+0.47315
  • 21000+3.6273321000+0.46930
库存:10923
RP102N331D-TR-FE
  • 1+8.207741+1.06189
  • 10+5.9044510+0.76390
  • 25+5.3169925+0.68790
  • 100+4.67542100+0.60489
  • 250+4.36985250+0.56536
  • 500+4.18535500+0.54149
  • 1000+4.051371000+0.52416
库存:10923
RP102N331D-TR-FE
    • 1+2.31671
    • 200+0.89662
    • 500+0.86508
    • 1000+0.84953
