S3ABF~S3MBF
Rev.D May.-2019
DATA SHEET
Descriptions
表面贴装整流二极管,反向电压:50V~1000V,正向电流:3.0A,薄型 SMBF 封装。
Surface Mount General Purpose Silicon Rectifiers,Reverse Voltage:50 to1000V,Forward
Current:3.0A, SMBF thin package.
特征
/ Features
玻璃钝化芯片,无铅符合欧盟 RoHS 指令 2011/65/EU,适用于表面贴装。无卤产品。
Glass Passivated Chip Junction, Lead free in comply with EU ROHS 2011/65/EU directives, For
surface mounted applications. Halogen free product.
用途
Applications
一般用途.
General purpose.
内部等效电路
/ Equivalent Circuit
引脚排列
/ Pinning
印章代码
/ Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/7
S3ABF~S3MBF
Rev.D May.-2019
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
Maximum Repetitive Peak
Reverse Voltage
Maximum RMS voltage
Maximum DC Blocking
Voltage
Maximum Average
Forward Rectified Current
at Ta= 115℃
Peak Forward Surge
Current 8.3 ms Single Half
Sine Wave Superimposed
on Rated Load
(JEDEC Method)
Typical Junction
1)
Capacitance
Typical Thermal
2)
Resistance
数值
Rating
S3ABF
S3BBF
S3DBF
S3GBF
S3JBF
S3KBF
S3MBF
VRRM
50
100
200
400
600
800
1000
V
VRMS
35
70
140
280
420
560
700
V
VDC
50
100
200
400
600
800
1000
V
IF(AV)
3.0
A
IFSM
100
A
Cj
35
pF
RθJA
45
15
℃/W
-55~+150
RθJC
Operating and Storage
Tj,Tstg
Temperature Range
Note:
1)Measured at 1MHz and applied reverse voltage of 4V D.C
2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
电性能参数
单位
Unit
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
Maximum Forward
Voltage
Maximum DC
Reverse Current
at Rated DC
Blocking Voltage
符号
Symbol
测试条件
Test
Conditions
数值
Rating
单位
Unit
VF
IF=3.0A
1.1
V
Ta=25℃
5.0
μA
Ta=125℃
150
μA
IR
2/7
S3ABF~S3MBF
Rev.D May.-2019
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
3/7
S3ABF~S3MBF
Rev.D May.-2019
外形尺寸图
DATA SHEET
/ Package Dimensions
4/7
S3ABF~S3MBF
Rev.D May.-2019
印章说明
DATA SHEET
5/7
S3ABF~S3MBF
Rev.D May.-2019
印章说明
DATA SHEET
S3AB
说明:
S3AB:
为型号代码
为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码
Note:
S3AB:
Product Type Code
Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No
Code
6/7
S3ABF~S3MBF
Rev.D May.-2019
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SMBF
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
5000
2
10000
5
50000
13〞×15
336X332X40
380X335X366
/ Notices
7/7
很抱歉,暂时无法提供与“S3MBF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.25488
- 100+0.20304
- 300+0.17712
- 1000+0.15768
