RP124N303B-TR-FE
RP124N303B-TR-FE
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 100mA SOT-23-5
RP124N303B-TR-FE 数据手册
RP124x Series 100 mA Ultra-low Supply Current (0.3 µA) LDO Regulator with Battery Monitor No. EA-503-191025 OVERVIEW The RP124x is an LDO regulator with a battery monitor (BM) featuring ultra-low supply current. The battery monitor has a function which divides the input voltage (VIN) into 1/3 or 1/4. The battery charge remaining can be monitored by MCU. The buffering output enables directly inputting a signal into the low voltage A/D converter (ADC) with built-in MCU. KEY BENEFITS ● Achieving Low Supply Current of 0.3 µA, Longer Battery Life and Downsizing ● Requiring Only Three External Capacitors and Suitable for Space-saving Mounting for the Smaller Packages PACKAGES KEY SPECIFICATIONS LDO Section ● Input Voltage Range: 1.7 V to 5.5 V ● Supply Current: Typ. 0.2 μA ● Output Voltage Accuracy: ±0.8% ● Output Current: 100 mA ● Ceramic Capacitor Compatible: 1.0 μF or more BM Section ● Output Voltage: VIN/3 (RP124xxx3x) VIN/4 (RP124xxx4x) ● Supply Current: Typ. 0.1 μA ● Ceramic Capacitor Compatible: 0.1 μF to 0.22 μF DFN1212-6 SOT-23-5 1.2 mm x 1.2 mm x 0.4 mm 2.9 mm x 2.8 mm x 1.1 mm • TYPICAL APPLICATIONS RP124 MCU VDD LDO VOUT VCC CIN Battery CE control CE Battery Monitor GND BM ADC COUT C BM GND The diagram is assumed to be used for RP124xxxxE. APPLICATIONS • • • • Battery powered IoT devices Energy harvesting devices Low power wireless communication modules including: Bluetooth® LE, Zigbee, and LPWA Low power consumption CPUs, memories, and sensors 1 RP124x No. EA-503-191025 SELECTION GUIDE The LDO set output voltage, the divided ratio of BM output voltage, the CE pin function and the auto-discharge function are user-selectable options. Selection Guide Product Name RP124Lxx#∗-TR RP124Nxx#∗-TR-FE Package Quantity per Reel Pb Free Halogen Free DFN1212-6 5,000 pcs Yes Yes SOT-23-5 3,000 pcs Yes Yes xx: Specify the LDO set output voltage (VSET). 1.2 V (12) / 1.5 V (15) / 1.8 V (18) / 2.1 V (21) / 2.2 V (22) / 2.3 V (23) / 2.4 V (24) / 2.5 V (25) / 2.7 V (27) / 2.8 V (28) / 3.0 V (30) / 3.1 V (31) / 3.3 V (33) / 3.6 V (36) Contact our company sales representatives for other voltages. #: Specify the divided ratio of BM output voltage. 3: VIN/3 4: VIN/4 ∗: Specify the CE pin and the auto-discharge option. 2 ∗ CE pin B Controlling LDO with the CE pin (Active-high) D Controlling LDO with the CE pin (Active-high) E Controlling BM with the CE pin (Active-high) Auto-discharge LDO No BM No LDO Yes BM No LDO No BM Yes RP124x No. EA-503-191025 BLOCK DIAGRAMS RP124xxxxB Block Diagram RP124xxxxD Block Diagram 3 RP124x No. EA-503-191025 RP124xxxxE Block Diagram 4 RP124x No. EA-503-191025 PIN DESCRIPTIONS Bottom View Top View 6 5 4 4 5 5 6 (mark side) (1) 1 2 3 3 4 2 1 1 1 RP124L (DFN1212-6) Pin Configuration 2 3 RP124N (SOT-23-5) Pin Configuration RP124L (DFN1212-6) Pin Description Pin No. Symbol Description 1 VOUT Output Pin 2 GND Ground Pin 3 BM Battery Monitoring Output Pin 4 CE Chip Enable Pin, Active-high 5 NC No Connection 6 VDD Input Pin RP124N (SOT-23-5) Pin Description Pin No. Symbol Description 1 VDD Input Pin 2 GND Ground Pin 3 CE Chip Enable Pin, Active-high 4 BM Battery Monitoring Output Pin 5 VOUT Output Pin (1) The tab on the bottom of the package enhances thermal performance and is electrically connected to GND (substrate level). It is recommended that the tab be connected to the ground plane on the board, or otherwise be left floating. 5 RP124x No. EA-503-191025 ABSOLUTE MAXIMUM RATINGS Absolute Maximum Ratings Symbol Item Rating Unit VIN Input Voltage −0.3 to 6.5 V VCE CE Pin Voltage −0.3 to 6.5 V VOUT VOUT Pin Voltage −0.3 to VIN + 0.3 V VBM BM Pin Voltage −0.3 to VIN + 0.3 V IOUT Output Current 130 mA PD Power Dissipation(1) DFN1212-6 (JEDEC STD. 51-7 Test Land Pattern) 850 mW SOT-23-5 (JEDEC STD. 51-7 Test Land Pattern) 660 mW Tj Junction Temperature Range −40 to 125 °C Tstg Storage Temperature Range −55 to 125 °C ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent damage and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS Recommended Operating Conditions Symbol VIN Input Voltage Ta Operating Temperature Item Rating RP124xxx3x 1.7 to 5.5 RP124xxx4x 2.4 to 5.5 −40 to 85 Unit V °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. (1) 6 Refer to POWEWR DISSIPATION for detailed information. RP124x No. EA-503-191025 ELECTRICAL CHARACTERISTICS VIN = VSET + 1.0 V, IOUT = 1.5 mA, CIN = COUT = 1.0 μF, unless otherwise noted. The specifications surrounded by are guaranteed by design engineering at −40°C ≤ Ta ≤ 85°C. RP124x Electrical Characteristics: LDO Section Symbol Parameters (Ta = 25°C) Test Conditions VSET > 2.0 V VOUT Output Voltage VSET ≤ 2.0 V IOUT Output Current 16 −26 26 mV mA 20 mV 40 mV Dropout Voltage IOUT = 100 mA ISS Supply Current VCE = VIN, IOUT = 0 mA Fast Mode Switching Current Low Power Mode Switching Current IOUT = From Light Load to Heavy Load, VIN = 5.0 V IOUT = From Heavy Load to Light Load, VIN = 5.0 V Line Regulation VSET + 0.5 V ≤ VIN ≤ 5.5 V Short Current Limit VOUT = 0 V RDISN −16 V −20 VDIF VCEL x1.013 VSET ≤ 2.0 V 1.5 mA ≤ IOUT ≤ 100 mA CE Pin Input Voltage, high CE Pin Input Voltage, low Auto-discharge NMOS On-resistance x0.987 % Load Regulation VCEH x1.008 1 ∆VOUT /∆IOUT ISC x0.992 Unit −1 1 µA ≤ IOUT ≤ IOUTH ∆VOUT /∆VIN Max. VSET > 2.0 V Output Voltage Deviation When Switching Mode IOUTL Typ. 100 ∆VOUT IOUTH Min. RP124xxxxB/D −40 2 Refer to Product-specific Electrical Characteristics 0.2 µA 0.5 µA 0.5 mA 0.08 mA 0.02 0.2 65 %/V mA 1.0 V RP124xxxxB/D VIN = 4.0 V, VCE = 0 V, RP124xxxxD 0.42 0.4 50 V Ω All test items listed under Electrical Characteristics are done under the pulse load condition Tj ≈ Ta = 25°C. 7 RP124x No. EA-503-191025 ELECTRICAL CHARACTERISTICS (continued) The specifications surrounded by are guaranteed by design engineering at −40°C ≤ Ta ≤ 85°C. RP124x Product-specific Electrical Characteristics: LDO Section VOUT [V] Product Ta = 25°C −40°C ≤ Ta ≤ 85°C Name Min. Typ. Max. Min. Typ. Max. RP124x12xx RP124x15xx RP124x18xx RP124x21xx RP124x22xx RP124x23xx RP124x24xx RP124x25xx RP124x27xx RP124x28xx RP124x30xx RP124x31xx RP124x33xx RP124x36xx 8 1.184 1.484 1.784 2.084 2.183 2.282 2.381 2.480 2.679 2.778 2.976 3.076 3.274 3.572 1.200 1.500 1.800 2.100 2.200 2.300 2.400 2.500 2.700 2.800 3.000 3.100 3.300 3.600 1.216 1.516 1.816 2.116 2.217 2.318 2.419 2.520 2.721 2.822 3.024 3.124 3.326 3.628 1.174 1.474 1.774 2.073 2.172 2.271 2.369 2.468 2.665 2.764 2.961 3.060 3.258 3.554 1.200 1.500 1.800 2.100 2.200 2.300 2.400 2.500 2.700 2.800 3.000 3.100 3.300 3.600 1.226 1.526 1.826 2.127 2.228 2.329 2.431 2.532 2.735 2.836 3.039 3.140 3.342 3.646 VDIF [V] Typ. Max. 0.640 0.410 0.230 0.150 0.975 0.660 0.380 0.285 0.130 0.230 0.110 0.180 0.100 0.160 0.090 0.145 RP124x No. EA-503-191025 ELECTRICAL CHARACTERISTICS (continued) CIN = 1.0 μF, CBM = 0.22 μF, unless otherwise noted. The specifications surrounded by are guaranteed by design engineering at −40°C ≤ Ta ≤ 85°C. RP124x Electrical Characteristics: Battery Monitor Section Symbol VBM Parameters Output Voltage IBM Output Current ISSBM Supply Current VCEHBM CE Pin Input Voltage, high VCELBM CE Pin Input Voltage, low Auto-discharge RDISNBM NMOS Onresistance Test Conditions −10 μA ≤ IBM ≤ 10 μA (Ta = 25°C) Typ. Max. 1.7 V ≤ VIN ≤ 5.5 V, VIN/3−20 RP124xxx3x VIN/3−25 VIN/3 VIN/3+20 VIN/3 VIN/3+25 2.4 V ≤ VIN ≤ 5.5 V, VIN/4−20 RP124xxx4x VIN/4−25 VIN/4 VIN/4+20 VIN/4 VIN/4+25 1.7 V ≤ VIN ≤ 5.5 V, RP124xxx3x 2.4 V ≤ VIN ≤ 5.5 V, RP124xxx4x Min. −10 VIN = VCE = 3.6 V , IBM = 0 μA 1.7 V ≤ VIN ≤ 5.5 V, RP124xxx3E 2.4 V ≤ VIN ≤ 5.5 V, RP124xxx4E 0.1 mV 10 µA 0.2 µA 1.0 V 1.7 V ≤ VIN ≤ 5.5 V, RP124xxx3E 0.4 2.4 V ≤ VIN ≤ 5.5 V, RP124xxx4E VIN = 4.0 V, VCE = 0 V, RP124xxxxE Unit 50 V Ω All test items listed under Electrical Characteristics are done under the pulse load condition Tj ≈ Ta = 25°C. 9 RP124x No. EA-503-191025 APPLICATION INFORMATION TYPICAL APPLICATION MCU VIN Power Management IC VOUT VCC RP124xxxxB/D VDD ADC Battery Monitor CIN CE control Battery CE LDO BM GND VOUT CBM GND COUT VDD Peripheral (Sensor) RP124xxxxB/D Typical Application Circuit RP124xxxxE MCU VDD LDO CIN Battery CE control CE Battery Monitor GND VOUT VCC BM ADC COUT CBM RP124xxxxE Typical Application Circuit 10 GND RP124x No. EA-503-191025 VIN VCE tW tW VBM ADC Sampling Timing Chart Example of RP124xxxxE Circuit The above diagram shows the example of using the RP124xxxxE typical application circuit and its timing chart. Connecting BM pin and ADC input pin of MCU enables monitoring the battery voltage. Controlling the start-up and stop of Battery Monitor with CE pin by the timing based on the ADC sampling reduces power consumption of the entire system. When monitoring the battery voltage, set the waiting time (tW) in order to stabilize waveform after the CE input voltage is set to “H”. It is recommended to set tW ≥ 10 ms for this product. Notes on External Components • Phase compensation is provided to secure stable operation even when the load current is varied. For this purpose, use a 1.0-µF or more output capacitor (COUT) between the VOUT and GND pins, and a 0.1-µF to 0.22-µF capacitor (CBM) between the BM and GND pins with shortest-distance wiring. In case of using a tantalum type capacitor with a large ESR (Equivalent Series Resistance), the output might become unstable. Evaluate your circuit including consideration of frequency characteristics. • Connect a 1.0-µF or more input capacitor (CIN) between the VDD and GND pins with shortest-distance wiring. 11 RP124x No. EA-503-191025 TECHNICAL NOTES The performance of a power source circuit using this device is highly dependent on a peripheral circuit. A peripheral component or the device mounted on PCB should not exceed its rated voltage, rated current or rated power. When designing a peripheral circuit, please be fully aware of the following points. • The high impedance of the wirings may result in noise pickup and unstable operation of the device. Reduce the impedance of the VDD and GND wirings. • When an intermediate voltage other than VIN or GND is input to the CE pin, a supply current may be increased with a through current of a logic circuit in the IC. The CE pin is neither pulled up nor pulled down, therefore an operation is not stable at open. 12 RP124x No. EA-503-191025 TYPICAL CHARACTERISTICS Typical Characteristics are intended to be used as reference data; they are not guaranteed. 1) LDO Output Voltage vs. Temperature (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF) RP124x18xx, VIN = 2.8 V, IOUT = 1.5 mA RP124x12xx, VIN = 2.2 V, IOUT = 1.5 mA RP124x28xx, VIN = 3.8 V, IOUT = 1.5 mA RP124x36xx, VIN = 4.6 V, IOUT = 1.5 mA 2) LDO Supply Current vs. Temperature (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF) RP124x18xx, VIN = 2.8 V RP124x12xx, VIN = 2.2 V 13 RP124x No. EA-503-191025 RP124x28xx, VIN = 3.8 V RP124x36xx, VIN = 4.6 V 3) BM Supply Current vs. Temperature (CIN = Ceramic 1.0 µF, CBM = Ceramic 0.1 µF) RP124xxx4x, VIN = 3.6 V RP124xxx3x, VIN = 3.6 V 4) BM Output Voltage vs. Input Voltage (CIN = Ceramic 1.0 µF, CBM = Ceramic 0.1 µF, Ta = 25°C) RP124xxx3x RP124xxx4x 14 RP124x No. EA-503-191025 5) BM Output Voltage vs. Temperature (CIN = Ceramic 1.0 µF, CBM = Ceramic 0.1 µF) RP124xxx4x, VIN = 3.6 V RP124xxx3x, VIN = 3.6 V 6) BM Supply Current vs. Input Voltage (CIN = Ceramic 1.0 µF, CBM = Ceramic 0.1 µF, Ta = 25°C) RP124xxx3x RP124xxx4x 7) LDO Dropout Voltage vs. Temperature (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF) RP124x12xx RP124x18xx 15 RP124x No. EA-503-191025 RP124x28xx RP124x36xx 8) LDO Dropout Voltage vs. Output Current (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF) RP124x12xx RP124x18xx RP124x28xx 16 RP124x36xx RP124x No. EA-503-191025 9) LDO Dropout Voltage vs. Set Output Voltage (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25℃) 10) LDO Output Voltage vs. Output Current (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25℃) RP124x12xx RP124x18xx RP124x28xx RP124x36xx 17 RP124x No. EA-503-191025 11) LDO Output Voltage vs. Input Voltage (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25℃) RP124x12xx RP124x18xx RP124x28xx RP124x36xx 12) LDO Supply Current vs. Input Voltage (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25℃) RP124x12xx 0.25 Supply Current[μA] 0.2 0.15 0.1 0.05 0 0 1 2 3 4 Input Voltage[V] 18 5 6 RP124x No. EA-503-191025 RP124x18xx (10µA/div) RP124x18xx (0.05µA/div) 45 0.25 0.2 35 Supply Current[μA] Supply Current[μA] 40 30 25 20 15 10 0.15 0.1 0.05 5 0 0 0 1 2 3 4 Input Voltage[V] 5 6 0 1 2 3 4 5 6 Input Voltage[V] RP124x28xx (10µA/div) RP124x28xx (0.05µA/div) RP124x36xx (10µA/div) RP124x36xx (0.05µA/div) 19 RP124x No. EA-503-191025 13) LDO Supply Current vs. Output Current (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP124x12xx RP124x18xx RP124x28xx RP124x36xx 14) Ripple Rejection vs. Frequency (CIN = none, COUT = Ceramic 1.0 µF, Ta = 25°C) RP124x18xx, VIN = 2.8 V RP124x12xx, VIN = 2.2 V 20 RP124x No. EA-503-191025 RP124x28xx, VIN = 3.8V RP124x36xx, VIN = 4.6V 15) Ripple Rejection vs. Input Voltage (CIN = none, COUT = Ceramic 1.0 µF, Ta = 25°C) RP124x18xx, IOUT = 100 µA RP124x12xx, IOUT = 100 µA RP124x28xx, IOUT = 100µA RP124x36xx, IOUT = 100µA 21 RP124x No. EA-503-191025 RP124x12xx, IOUT = 30mA RP124x18xx, IOUT = 30mA RP124x28xx, IOUT = 30mA RP124x36xx, IOUT = 30mA 16) LDO Input Transient Response (CIN = Ceramic 0.1 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP124x12xx, IOUT = 30 mA, tR = tF = 5 µs RP124x12xx, IOUT = 100 µA, tR = tF = 5 µs 22 RP124x No. EA-503-191025 RP124x18xx, IOUT = 100 µA, tR = tF = 5 µs RP124x18xx, IOUT = 30 mA, tR = tF = 5 µs RP124x28xx, IOUT = 100 µA, tR = tF = 5 µs RP124x28xx, IOUT = 30 mA, tR = tF = 5 µs RP124x36xx, IOUT = 100 µA, tR = tF = 5 µs RP124x36xx, IOUT = 30 mA, tR = tF = 5 µs 23 RP124x No. EA-503-191025 17) LDO Load Transient Response (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP124x12xx RP124x12xx VIN = 2.2 V, IOUT = 1.5 mA 10 mA, tR = tF = 5 µs VIN = 2.2 V, IOUT = 1 µA 10 mA, tR = tF = 5 µs RP124x12xx VIN = 2.2 V, IOUT = 10 mA 30 mA, tR = tF = 5 µs RP124x18xx VIN = 2.8 V, IOUT = 1 µA 10 mA, tR = tF = 5 µs 24 RP124x18xx VIN = 2.8 V, IOUT = 1.5 mA 10 mA, tR = tF = 5 µs RP124x No. EA-503-191025 RP124x18xx VIN = 2.8 V, IOUT = 10 mA 30 mA, tR = tF = 5 µs RP124x28xx VIN = 3.8 V, IOUT = 1 µA 10 mA, tR = tF = 5 µs RP124x28xx VIN = 3.8 V, IOUT = 1.5 mA 10 mA, tR = tF = 5 µs RP124x28xx VIN = 3.8 V, IOUT = 10 mA 30 mA, tR = tF = 5 µs 25 RP124x No. EA-503-191025 RP124x36xx VIN = 4.6 V, IOUT = 1 µA 10 mA, tR = tF = 5 µs RP124x36xx VIN = 4.6 V, IOUT = 1.5 mA 10 mA, tR = tF = 5 µs RP124x36xx VIN = 4.6 V, IOUT = 10 mA 30 mA, tR = tF = 5 µs RP124x364x VIN = 4.6 V, IOUT = 1 µA 10 mA, tR = tF = 5 µs 18) LDO Turning-on with CE Pin (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP124x18xD, VIN = 2.8 V, VCE = 0 V => 2.8 V RP124x12xD, VIN = 2.2 V, VCE = 0 V => 2.2 V 26 RP124x No. EA-503-191025 RP124x28xD, VIN = 3.8 V, VCE = 0 V => 3.8 V RP124x36xD, VIN = 4.6 V, VCE = 0 V => 4.6 V 19) LDO Turning-off with CE Pin (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP124x18xD, VIN = 2.8 V, VCE = 2.8 V => 0 V RP124x12xD, VIN = 2.2 V, VCE = 2.2 V => 0 V RP124x28xD, VIN = 3.8 V, VCE = 3.8 V => 0 V RP124x36xD, VIN = 4.6 V, VCE = 4.6 V => 0 V 27 RP124x No. EA-503-191025 RP124x364D, VIN = 4.6 V, VCE = 0 V 4.6 V 20) BM Turning-on/off with CE Pin (CIN = Ceramic 1.0 µF, CBM = Ceramic 0.1 µF, 0.22 µF, Ta = 25°C) RP124xxx4x, VIN = 3.6 V, VCE = 0 V 3.6 V RP124xxx3x, VIN = 3.6 V, VCE = 0 V 3.6 V RP124xxx3x, VIN = 5.5 V, VCE = 0 V 5.5 V 28 RP124xxx4x, VIN = 5.5 V, VCE = 0 V 5.5 V RP124x No. EA-503-191025 21) Inrush Current at CE Pin’s Activation (CIN = Ceramic 0.1 µF, Ta = 25°C) RP124x12xx, VIN = 2.2 V, VCE = 0 V => 2.2 V ② RP124x12xx, VIN = 2.2 V, VCE = 0 V => 2.2 V ① RP124x18xx, VIN = 2.8 V, VCE = 0 V => 2.8 V ① RP124x18xx, VIN = 2.8 V, VCE = 0 V => 2.8 V ② RP124x28xx, VIN = 3.8 V, VCE = 0 V => 3.8 V ① RP124x28xx, VIN = 3.8 V, VCE = 0 V => 3.8 V ② 29 RP124x No. EA-503-191025 RP124x36xx, VIN = 4.6 V, VCE = 0 V => 4.6 V ① RP124x36xx, VIN = 4.6 V, VCE = 0 V => 4.6 V ② 22) ESR vs. Output Current (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, CBM = Ceramic 0.1 µF) Measuring Frequency:10 Hz to 2 MHz、Ambient Temperature:-40°C to 5°C LDO BM RP124xxx3x, VIN= 1.7V to 5.5V RP124x12xx, VIN= 1.7V to 5.5V LDO RP124x28xx, VIN = 2.8 V to 5.5 V 30 BM RP124xxx4x, VIN = 2.4 V to 5.5 V RP124x No. EA-503-191025 LDO RP124x36xx, VIN = 3.6 V to 5.5 V 31 POWER DISSIPATION DFN1212-6 Ver. A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square Through-holes  0.2 mm × 14 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 850 mW Thermal Resistance (ja) ja = 117°C/W Thermal Characterization Parameter (ψjt) ψjt = 50°C/W ja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 1000 900 850 Power Dissipation (mW) 800 700 600 500 400 300 200 100 0 0 25 50 75 85 100 Ambient Temperature (°C) 125 Power Dissipation vs. Ambient Temperature Measurement Board Pattern i DFN1212-6 PACKAGE DIMENSIONS Ver. B DFN1212-6 Package Dimensions ∗ The tab on the bottom of the package is substrate level (GND). It is recommended that the tab be connected to the ground plane on the board, or otherwise be left floating. i POWER DISSIPATION SOT-23-5 Ver. A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square Through-holes  0.3 mm × 7 pcs (Ta = 25°C, Tjmax = 125°C) Measurement Result Item Measurement Result Power Dissipation 660 mW Thermal Resistance (ja) ja = 150°C/W Thermal Characterization Parameter (ψjt) ψjt = 51°C/W ja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter Power Dissipation vs. Ambient Temperature Measurement Board Pattern i SOT-23-5 PACKAGE DIMENSIONS Ver. A 2.9±0.2 1.1±0.1 1.9±0.2 0.8±0.1 (0.95) 4 1 2 0~0.1 0.2min. +0.2 1.6-0.1 5 2.8±0.3 (0.95) 3 0.4±0.1 +0.1 0.15-0.05 SOT-23-5 Package Dimensions i 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP124N303B-TR-FE 价格&库存
很抱歉,暂时无法提供与“RP124N303B-TR-FE”相匹配的价格&库存,您可以联系我们找货
RP124N303B-TR-FE
  • 1+7.236471+0.93623
  • 10+5.1808010+0.67028
  • 25+4.6603825+0.60295
  • 100+4.08669100+0.52873
  • 250+3.81377250+0.49342
  • 500+3.64906500+0.47211
  • 1000+3.513581000+0.45458
库存:2736
RP124N303B-TR-FE
  • 3000+3.346223000+0.43293
  • 6000+3.264326000+0.42233
  • 9000+3.223329000+0.41703
  • 15000+3.1778815000+0.41115
  • 21000+3.1513021000+0.40771
库存:2736
RP124N303B-TR-FE
    • 1+2.01809
    • 200+0.78106
    • 500+0.75363
    • 1000+0.74002
