R1180x SERIES
150mA LDO REGULATOR
NO.EA-105-220531
OUTLINE
The R1180x Series are CMOS-based voltage regulator ICs with high output voltage accuracy, extremely low
supply current, and low ON-resistance. Each of these ICs consists of a voltage reference unit, an error amplifier,
resistor-net for voltage setting, a current limit circuit which prevents the destruction by excess current, and so on.
The output voltage of these ICs is fixed with high accuracy. B version has a chip enable pin, therefore ultra-low
consumption current standby mode can be realized with the pin.
Since the packages for these ICs are SOT-23-5 (R1180N Series), SC-82AB (R1180Q Series), and SON1612-6
(R1180D Series), therefore high density mounting of the ICs on boards is possible.
FEATURES
Supply Current ......................................................... Typ. 1A
(Except the current through CE pull-down circuit)
Standby Mode .......................................................... Typ. 0.1A
Dropout Voltage ....................................................... Typ. 0.25V (IOUT150mA 3.0V Output type)
Temperature-Drift Coefficient of Output Voltage ...... Typ. 100ppm/C
Line Regulation ........................................................ Typ. 0.05%/V
Output Voltage Accuracy.......................................... 2.0%
Packages ................................................................ SON1612-6, SC-82AB, SOT-23-5
Output Voltage Range.............................................. 1.2V to 3.6V (0.1V steps)
(For other voltages, please refer to MARK INFORMATIONS.)
Built-in Fold Back Protection Circuit ........................ Typ. 40mA (Current at short mode)
Ceramic capacitors are recommended to be used with this IC ..... 0.1F
APPLICATIONS
Stable voltage reference.
Power source for electrical appliances such as cameras, VCRs and camcorders.
Power source for battery-powered equipment.
1
R1180x
NO.EA-105-220531
BLOCK DIAGRAMS
R1180xxx1B
VDD
R1180xxx1C
VOUT
VDD
VOUT
Vref
CE
Vref
Current Limit
Current Limit
GND
GND
SELECTION GUIDE
The output voltage, CE pin polarity, package, etc. for the ICs can be selected at the user’s request.
Product Name
Package
Quantity per Reel
Pb Free
Halogen Free
R1180Dxx1-TR-FE
SON1612-6
4,000 pcs
Yes
Yes
R1180Qxx1-TR-FE
SC-82AB
3,000 pcs
Yes
Yes
R1180Nxx1-TR-FE
SOT-23-5
3,000 pcs
Yes
Yes
xx : The output voltage can be designated in the range from 1.2V(12) to 3.6V(36) in 0.1V steps.
: CE pin polarity are options as follows.
(B) "H" Active
(C) without CE pin
2
R1180x
NO.EA-105-220531
PIN CONFIGURATION
SON1612-6
6
5
SC-82AB
4
4
SOT-23-5
3
5
(Mark side)
(mark side)
1
2
3
1
4
1
2
2
3
PIN DESCRIPTIONS
SON1612-6
Pin No
Symbol
Pin Description
1
VDD
2
GND
Ground Pin
3
VOUT
Output pin
4
NC
No Connection
5
GND
6
CE or NC
Input Pin
Ground Pin
Chip Enable Pin or No Connection
SC-82AB
Pin No
Symbol
Pin Description
1
CE or NC
2
GND
Ground Pin
3
VOUT
Output pin
4
VDD
Input Pin
SOT-23-5
Pin No
Symbol
Pin Description
1
VDD
2
GND
3
CE or NC
4
NC
No Connection
5
VOUT
Output pin
Input Pin
Ground Pin
3
R1180x
NO.EA-105-220531
ABSOLUTE MAXIMUM RATINGS
Symbol
Item
Rating
Unit
VIN
Input Voltage
6.5
V
VCE
Input Voltage (CE Pin)
6.5
V
VOUT
Output Voltage
0.3 to VIN0.3
V
IOUT
Output Current
180
mA
Power Dissipation (SON1612-6)*
500
Power Dissipation (SC-82AB)*
380
Power Dissipation (SOT-23-5)*
420
Topt
Operating Temperature Range
40 to 85
C
Tstg
Storage Temperature Range
55 to 125
C
PD
mW
) For Power Dissipation, please refer to PACKAGE INFORMATION.
Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the
permanent damages and may degrade the life time and safety for both device and system using the device
in the field.
The functional operation at or over these absolute maximum ratings is not assured.
RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS)
All of electronic equipment should be designed that the mounted semiconductor devices operate within the
recommended operating conditions. The semiconductor devices cannot operate normally over the
recommended operating conditions, even if when they are used over such conditions by momentary
electronic noise or surge. And the semiconductor devices may receive serious damage when they continue
to operate over the recommended operating conditions.
4
R1180x
NO.EA-105-220531
R1180xxx1B/C
Topt25C
Symbol
Item
Conditions
VOUT
Output Voltage
VINSet VOUT1V
1A ≤ IOUT ≤ 30mA
IOUT
Output Current
VINVOUT1.0V(VOUT ≥ 1.4V)
VIN2.4V(VOUT
很抱歉,暂时无法提供与“R1180N361B-TR-FE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+2.344793000+0.30336
- 6000+2.283626000+0.29545
- 9000+2.253009000+0.29149
- 15000+2.2190715000+0.28710
- 21000+2.1992221000+0.28453
- 30000+2.1801630000+0.28207
- 国内价格 香港价格
- 1+5.301821+0.68594
- 10+3.7123510+0.48029
- 25+3.3239025+0.43004
- 100+2.89762100+0.37489
- 250+2.69363250+0.34850
- 500+2.57094500+0.33262
- 1000+2.469711000+0.31953
