R1180N331B-TR-FE
R1180N331B-TR-FE
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 150mA SOT-23-5
R1180N331B-TR-FE 数据手册
R1180x SERIES 150mA LDO REGULATOR NO.EA-105-220531 OUTLINE The R1180x Series are CMOS-based voltage regulator ICs with high output voltage accuracy, extremely low supply current, and low ON-resistance. Each of these ICs consists of a voltage reference unit, an error amplifier, resistor-net for voltage setting, a current limit circuit which prevents the destruction by excess current, and so on. The output voltage of these ICs is fixed with high accuracy. B version has a chip enable pin, therefore ultra-low consumption current standby mode can be realized with the pin. Since the packages for these ICs are SOT-23-5 (R1180N Series), SC-82AB (R1180Q Series), and SON1612-6 (R1180D Series), therefore high density mounting of the ICs on boards is possible. FEATURES  Supply Current ......................................................... Typ. 1A (Except the current through CE pull-down circuit)  Standby Mode .......................................................... Typ. 0.1A  Dropout Voltage ....................................................... Typ. 0.25V (IOUT150mA 3.0V Output type)  Temperature-Drift Coefficient of Output Voltage ...... Typ. 100ppm/C  Line Regulation ........................................................ Typ. 0.05%/V  Output Voltage Accuracy.......................................... 2.0%  Packages ................................................................ SON1612-6, SC-82AB, SOT-23-5  Output Voltage Range.............................................. 1.2V to 3.6V (0.1V steps) (For other voltages, please refer to MARK INFORMATIONS.)  Built-in Fold Back Protection Circuit ........................ Typ. 40mA (Current at short mode)  Ceramic capacitors are recommended to be used with this IC ..... 0.1F APPLICATIONS  Stable voltage reference.  Power source for electrical appliances such as cameras, VCRs and camcorders.  Power source for battery-powered equipment. 1 R1180x NO.EA-105-220531 BLOCK DIAGRAMS R1180xxx1B VDD R1180xxx1C VOUT VDD VOUT Vref CE Vref Current Limit Current Limit GND GND SELECTION GUIDE The output voltage, CE pin polarity, package, etc. for the ICs can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free R1180Dxx1-TR-FE SON1612-6 4,000 pcs Yes Yes R1180Qxx1-TR-FE SC-82AB 3,000 pcs Yes Yes R1180Nxx1-TR-FE SOT-23-5 3,000 pcs Yes Yes xx : The output voltage can be designated in the range from 1.2V(12) to 3.6V(36) in 0.1V steps. (For other voltages, please refer to MARK INFORMATIONS.)  : CE pin polarity are options as follows. (B) "H" Active (C) without CE pin 2 R1180x NO.EA-105-220531 PIN CONFIGURATION  SON1612-6 6 5  SC-82AB 4 4  SOT-23-5 3 5 (Mark side) (mark side) 1 2 3 1 4 1 2 2 3 PIN DESCRIPTIONS    SON1612-6 Pin No Symbol Pin Description 1 VDD 2 GND Ground Pin 3 VOUT Output pin 4 NC No Connection 5 GND 6 CE or NC Input Pin Ground Pin Chip Enable Pin or No Connection SC-82AB Pin No Symbol Pin Description 1 CE or NC 2 GND Ground Pin 3 VOUT Output pin 4 VDD Input Pin Chip Enable Pin or No Connection SOT-23-5 Pin No Symbol Pin Description 1 VDD 2 GND 3 CE or NC 4 NC No Connection 5 VOUT Output pin Input Pin Ground Pin Chip Enable Pin or No Connection 3 R1180x NO.EA-105-220531 ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit VIN Input Voltage 6.5 V VCE Input Voltage (CE Pin) 6.5 V VOUT Output Voltage 0.3 to VIN0.3 V IOUT Output Current 180 mA Power Dissipation (SON1612-6)* 500 Power Dissipation (SC-82AB)* 380 Power Dissipation (SOT-23-5)* 420 Topt Operating Temperature Range 40 to 85 C Tstg Storage Temperature Range 55 to 125 C PD mW ) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 4 R1180x NO.EA-105-220531 ELECTRICAL CHARACTERISTICS  R1180xxx1B/C Topt25C Symbol Item Conditions VOUT Output Voltage VINSet VOUT1V 1A ≤ IOUT ≤ 30mA IOUT Output Current VINVOUT1.0V(VOUT ≥ 1.4V) VIN2.4V(VOUT
R1180N331B-TR-FE 价格&库存
很抱歉,暂时无法提供与“R1180N331B-TR-FE”相匹配的价格&库存,您可以联系我们找货
R1180N331B-TR-FE
    • 1+1.44483
    • 200+0.57651
    • 500+0.55728
    • 1000+0.54778
