RP114N181B-TR-FE
RP114N181B-TR-FE
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 300mA SOT-23-5
RP114N181B-TR-FE 数据手册
RP114x SERIES 300 mA LDO REGULATOR No.EA-236-230719 OUTLINE The RP114x is a CMOS-based voltage regulator IC with high output voltage accuracy, low supply current, low dropout, and high ripple rejection. This IC consists of a voltage reference unit, an error amplifier, resistors for setting output voltage, a short current limit circuit, a chip enable circuit, and so on. The RP114x features a minimum input voltage from 1.4V and the output voltage, which can be set from 0.8V to 3.6V (in 0.1V step). The output voltage of this IC is internally fixed. This IC perform with low dropout voltage due to built-in transistor with low ON resistance. Low supply current and a chip enable function prolong the battery life of each system. The ripple rejection, line transient response and load transient response of the RP114x is excellent, thus this IC is very suitable for the power supply for hand-held communication equipment. Since the packages for this IC are DFN(PL)1010-4、DFN(PL)1010-4B、SC-88A、SOT-23-5, therefore high density mounting of the IC on boards is possible. FEATURES • Supply Current ................................................................ Typ. 50µA • Standby Current ............................................................. Typ. 0.1µA • Input Voltage Range ....................................................... 1.4V to 5.25V • Output Voltage Range(1) ................................................. 0.8V to 3.6V (0.1V steps) • Output Voltage Accuracy ................................................ ±1.0% (VSET>2.0V, Ta = 25°C) • Temperature-Drift Coefficient of Output Voltage ............. Typ. ±80ppm/°C • Dropout Voltage .............................................................. Typ. 0.25V (IOUT = 300mA, VSET = 2.8V) • Ripple Rejection ............................................................. Typ. 75dB (f=1kHz) • Line Regulation ............................................................... Typ. 0.02%/V • Packages ...................................................................... DFN(PL)1010-4、DFN(PL)1010-4B、 SC-88A、SOT-23-5 • Built-in Fold Back Protection Circuit ............................... Typ. 60mA (Current at short mode) • Ceramic capacitors are recommended to be used with this IC ...... 1.0µF or more APPLICATIONS • Power source for portable communication equipment. • Power source for electrical appliances such as cameras, VCRs and camcorders. • Power source for battery-powered equipment. (1) For other voltages, please refer to Product-specific Electrical Characteristics. 1 RP114x No.EA-236-230719 SELECTION GUIDE The set output voltage, the auto discharge function(1), and the package type for the ICs are user-selectable options. Product Name Package Quantity per Reel Pb Free Halogen Free DFN(PL)1010-4 10,000 pcs Yes Yes DFN(PL)1010-4B 10,000 pcs Yes Yes RP114Qxx2∗(y)-TR-FE SC-88A 3,000 pcs Yes Yes RP114Nxx1∗(y)-TR-FE SOT-23-5 3,000 pcs Yes Yes RP114Kxx1∗(y)-TR RP114Kxx1∗(y)-TRB xx : Specify the set output voltage within the range of 0.8 V (08) to 3.6 V (36) in 0.1 V step. (y): If the output voltage includes the 3rd digit, indicate the digit of 0.01V. Ex. If the output voltage is 1.25V, RP114K121∗5-TR If the output voltage is 1.85V, RP114K181∗5-TR ∗: Specify a combination of the CE pin polarity and the auto-discharge function. (B) “H” Active, without Auto-Discharge function (D) “H” Active, with Auto-Discharge function BLOCK DIAGRAMS VDD VOUT VDD Vref Vref Current Limit CE Current Limit GND CE RP114xxxxB Block Diagram (1) VOUT GND RP114xxxxD Block Diagram Auto-Discharge function quickly lowers the output voltage to 0V by releasing the electrical charge in the external capacitor when the chip enable signal is switched from the active mode to the standby mode. 2 RP114x No.EA-236-230719 PIN DESCRIPTIONS RP114K [DFN(PL)1010-4] Top View 4 RP114K [DFN(PL)1010-4B] Bottom View 3 3 4 Bottom View Top View 4 3 3 ∗ ∗ 1 2 2 1 1 2 RP114Q (SC-88A) 5 5 (mark side) 2 2 1 RP114N (SOT-23-5) 4 1 4 4 (mark side) 3 1 2 3 RP114K Pin Description [DFN(PL)1010-4 / DFN(PL)1010-4B] Pin No Symbol Pin Description 1 VOUT Output Pin 2 GND Ground Pin 3 CE 4 VDD Chip Enable Pin ("H" Active) Input Pin ∗ Tab is GND level. (They are connected to the reverse side of this IC.) The tab is better to be connected to the GND, but leaving it open is also acceptable. RP114Q Pin Description (SC-88A) Pin No Symbol Description 1 CE Chip Enable Pin (“H” Active) 2 NC No Connection 3 GND Ground Pin 4 VOUT Output Pin 5 VDD Input Pin 3 RP114x No.EA-236-230719 RP114N Pin Description (SOT-23-5) Pin No Symbol Description 1 VDD Input Pin 2 GND Ground Pin 3 CE Chip Enable Pin (“H” Active) 4 NC No Connection 5 VOUT Output Pin 4 RP114x No.EA-236-230719 ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit VIN Input Voltage 6.0 V VCE Input Voltage (CE Pin) 6.0 V VOUT Output Voltage −0.3 to VIN+0.3 V IOUT Output Current 400 mA PD Power Dissipation(1) DFN(PL)1010-4, JEDEC STD. 51 800 DFN(PL)1010-4B, JEDEC STD. 51 800 SC-88A, Our Evaluation Board 380 SOT-23-5, JEDEC STD. 51 660 mW Tj Junction Temperature Range −40 to 125 °C Tstg Storage Temperature Range −55 to 125 °C ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings are not assured. RECOMMENDED OPERATING CONDITIONS Symbol Item VIN Input Voltage Ta Operating Temperature Range Rating 1.4 to 5.25 Unit (2) −40 to 85 V °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such ratings by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. (1) Refer to POWER DISSIPATION for detailed information. the input voltage exceeds the maximum value of 5.25 V for some reasons, the operational accumulated time becomes up to 500 hours at 5.5V. (2) If 5 RP114x No.EA-236-230719 ELECTRICAL CHARACTERISTICS VIN = VSET(1)+1.0 V (VSET > 1.5 V),VIN = 2.5 V (VSET ≤ 1.5V),IOUT = 1 mA,CIN = COUT = 1.0 µF, unless otherwise noted. The specifications in are guaranteed by design engineering at -40ºC ≤ Ta ≤ 85ºC. RP114xxxxB/D Electrical Characteristics Symbol Item (Ta=25°C) Conditions Ta = 25°C VOUT Output Voltage -40°C ≤ Ta ≤ 85°C IOUT Typ. Max. Unit VSET > 2.0 V ×0.99 ×1.01 V VSET ≤ 2.0 V -20 +20 mV VSET > 2.0 V ×0.97 ×1.03 V VSET ≤ 2.0 V -60 +60 mV Output Current ∆VOUT/∆IOUT Load Regulation Min. 300 1 mA ≤ IOUT ≤ 300 mA mA 15 40 mV VDIF Dropout Voltage ISS Supply Current IOUT = 0 mA 50 75 μA Standby Current VCE = 0 V 0.1 1.0 μA 0.02 0.10 %/V Istandby ∆VOUT /∆VIN Line Regulation Please refer to Product-specific Electrical Characteristics attached. VSET + 0.5 V ≤ VIN ≤ 5.25 V (VIN ≥ 1.4 V) f=1kHz, Ripple 0.2 Vp-p, RR Ripple Rejection VIN=VSET +1V, IOUT = 30 mA 75 dB (When VSET ≤ 2.0 V, VIN = 3.0 V) Output Voltage ∆VOUT/∆Ta Temperature Coefficient ISC Short Current Limit IPD CE Pull-down Current VCEH CE Input Voltage “H” VCEL CE Input Voltage “L” en RLOW -40°C ≤ Ta ≤ 85°C ±80 VOUT = 0 V 60 0.3 ppm /°C mA 0.6 1.0 μA V 0.4 V Output Noise BW = 10 Hz to 100 kHz, IOUT = 30 mA 75 μVrms Low Output Nch. On Resistance (RP114xxxxD Only) VIN = 4.0 V, VCE = 0 V 50 Ω All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25ºC) except for Output Noise, Ripple Rejection, and Output Voltage Temperature Coefficient. (1) VSET: Set Output Voltage 6 RP114x No.EA-236-230719 The specifications in are guaranteed by design engineering at -40ºC ≤ Ta ≤ 85ºC. Dropout Voltage by Set Output Voltage (Ta=25°C) Dropout Voltage VDIF (V) Set Output Voltage VSET (V) Typ. Max. VSET=0.8 0.560 0.720 VSET=0.9 0.510 0.650 1.0 ≤ VSET < 1.2 0.460 0.590 1.2 ≤ VSET < 1.4 0.390 0.500 0.350 0.440 1.7 ≤ VSET < 2.1 0.300 0.390 2.1 ≤ VSET < 2.5 0.260 0.340 2.5 ≤ VSET < 3.0 0.250 0.300 3.0 ≤ VSET ≤ 3.6 0.220 0.290 1.4 ≤ VSET < 1.7 Condition IOUT=300mA 7 RP114x No.EA-236-230719 Product-specific Electrical Characteristics The specifications in Product Name RP114x081x RP114x091x RP114x101x RP114x101x5 RP114x111x RP114x111x5 RP114x121x RP114x121x5 RP114x131x RP114x131x5 RP114x141x RP114x151x RP114x161x RP114x171x RP114x171x5 RP114x181x RP114x181x5 RP114x191x RP114x201x RP114x211x RP114x221x RP114x231x RP114x241x RP114x251x RP114x261x RP114x271x RP114x281x RP114x281x5 RP114x291x RP114x301x RP114x311x RP114x321x RP114x331x RP114x341x RP114x341x5 RP114x351x RP114x361x are guaranteed by design engineering at -40ºC ≤ Ta ≤ 85ºC. VOUT [V] (Ta = 25°C) Min. Typ. Max. 0.780 0.800 0.820 0.880 0.900 0.920 0.980 1.000 1.020 1.030 1.050 1.070 1.080 1.100 1.120 1.130 1.150 1.170 1.180 1.200 1.220 1.230 1.250 1.270 1.280 1.300 1.320 1.330 1.350 1.370 1.380 1.400 1.420 1.480 1.500 1.520 1.580 1.600 1.620 1.680 1.700 1.720 1.730 1.750 1.770 1.780 1.800 1.820 1.830 1.850 1.870 1.880 1.900 1.920 1.980 2.000 2.020 2.079 2.100 2.121 2.178 2.200 2.222 2.277 2.300 2.323 2.376 2.400 2.424 2.475 2.500 2.525 2.574 2.600 2.626 2.673 2.700 2.727 2.772 2.800 2.828 2.822 2.850 2.879 2.871 2.900 2.929 2.970 3.000 3.030 3.069 3.100 3.131 3.168 3.200 3.232 3.267 3.300 3.333 3.366 3.400 3.434 3.416 3.450 3.485 3.465 3.500 3.535 3.564 3.600 3.636 VOUT [V] (−40°C ≤ Ta ≤ 85°C) Min. Typ. Max. 0.740 0.800 0.860 0.840 0.900 0.960 0.940 1.000 1.060 0.990 1.050 1.110 1.040 1.100 1.160 1.090 1.150 1.210 1.140 1.200 1.260 1.190 1.250 1.310 1.240 1.300 1.360 1.290 1.350 1.410 1.340 1.400 1.460 1.440 1.500 1.560 1.540 1.600 1.660 1.640 1.700 1.760 1.690 1.750 1.810 1.740 1.800 1.860 1.790 1.850 1.910 1.840 1.900 1.960 1.940 2.000 2.060 2.037 2.100 2.163 2.134 2.200 2.266 2.231 2.300 2.369 2.328 2.400 2.472 2.425 2.500 2.575 2.522 2.600 2.678 2.619 2.700 2.781 2.716 2.800 2.884 2.765 2.850 2.936 2.813 2.900 2.987 2.910 3.000 3.090 3.007 3.100 3.193 3.104 3.200 3.296 3.201 3.300 3.399 3.298 3.400 3.502 3.347 3.450 3.554 3.395 3.500 3.605 3.492 3.600 3.708 VDIF [V] Typ. Max. 0.560 0.720 0.510 0.650 0.460 0.590 0.390 0.500 0.350 0.440 0.300 0.390 0.260 0.340 0.250 0.300 0.220 0.290 8 RP114x No.EA-236-230719 TEST CIRCUITS VDD VOUT RP114x Series C1 CE V C2 VOUT IOUT ↓ GND C1 = Ceramic 1.0μF C2 = Ceramic 1.0μF Figure 1. Basic Test Circuit VDD VOUT A ISS RP114x Series C1 CE VOUT C2 GND C1 = Ceramic 1.0μF C2 = Ceramic 1.0μF Figure 2. Test Circuit for Supply Current Pulse Generator VDD VOUT RP114x Series P.G. CE C2 ↓ IOUT GND C2 = Ceramic 1.0μF Figure 3. Test Circuit for Ripple Rejection VOUT VDD VOUT C1 RP114x Series CE C2 GND ↓ IOUTa ↓ IOUTb C1 = Ceramic 1.0μF C2 = Ceramic 1.0μF Figure 4. Test Circuit for Load Transient Response 9 RP114x No.EA-236-230719 TECHNICAL NOTES ON EXTERNAL COMPONENTS When using these ICs, consider the following points: Phase Compensation In this IC, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor C2 with 1.0µF or more and good ESR (Equivalent Series Resistance). (Note: If additional ceramic capacitors are connected with parallel to the output pin with an output capacitor for phase compensation, the operation might be unstable. Because of this, test this IC with as same external components as ones to be used on the PCB.) PCB Layout Make VDD and GND lines sufficient. If their impedance is high, noise pickup or unstable operation may result. Connect a capacitor C1 with a capacitance value as much as 1.0µF or more between VDD and GND pins, and as close as possible to the pins. Set external components, especially the output capacitor C2, as close as possible to the IC, and make wiring as short as possible. Typical Application Circuit VOUT VDD VOUT C1 1.0 µF CE Control RP114x Series CE C2 1.0 µF GND 10 RP114x No.EA-236-230719 ESR vs. Output Current When using these ICs, consider the following points: The relations between IOUT (Output Current) and ESR of an output capacitor are shown below. The conditions when the white noise level is under 40µV (Avg.) are marked as the hatched area in the graph. Measurement conditions Frequency Band: 10Hz to 2MHz Temperature : −40°C to 85°C C1, C2 : 1.0µF RP114x08xx RP114x25xx VIN=1.4V to 5.25V 100 VIN=2.5V to 5.25V 100 Topt=85°C Ta Topt=85°C Ta 10 Topt=-40°C Ta 1 ESR (Ω) ESR (Ω) 10 0.1 Topt=-40°C Ta 1 0.1 0.01 0.01 0 50 100 150 200 250 Output Current IOUT (mA) 300 0 50 100 150 200 250 300 Output Current IOUT (mA) RP114x36xx VIN=3.6V to 5.25V 100 Topt=85°C Ta ESR (Ω) 10 Topt=-40°C Ta 1 0.1 0.01 0 50 100 150 200 250 Output Current IOUT (mA) 300 11 RP114x No.EA-236-230719 TYPICAL CHARACTERISTICS Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed. 1) Output Voltage vs. Output Current (C1=1.0µF, C2=1.0µF, Ta=25°C) RP114x08xx 0.7 Output Voltage VOUT (V) 0.8 Output Voltage VOUT (V) RP114x25xx 3.0 0.9 VIN=1.8V VIN=2.8V VIN=3.6V VIN=4.2V VIN=5.0V VIN=5.25V 0.6 0.5 0.4 0.3 0.2 0.1 2.5 2.0 VIN=3.5V 1.5 VIN=5.0V VIN=5.25V VIN=4.2V 1.0 0.5 0 0 0 0 100 200 300 400 500 600 700 Output Current IOUT (mA) 100 200 300 400 500 600 700 Output Current IOUT (mA) RP114x36xx 4.0 Output Voltage VOUT (V) 3.5 3.0 VIN=4.6V 2.5 VIN=5.0V 2.0 VIN=5.25V 1.5 1.0 0.5 0 0 100 200 300 400 500 600 700 Output Current IOUT (mA) 2) Output Voltage vs. Input Voltage (C1=1.0µF, C2=1.0µF, Ta=25°C) RP114x08xx RP114x25xx 3.0 0.8 0.7 0.6 0.5 0.4 IOUT=1mA 0.3 IOUT=30mA 0.2 IOUT=50mA 0.1 0 Output Voltage VOUT (V) Output Voltage VOUT (V) 0.9 2.5 2.0 1.5 IOUT=1mA IOUT=30mA 1.0 IOUT=50mA 0.5 0 0 1 2 3 4 Input Voltage VIN (V) 5 0 1 2 3 4 Input Voltage VIN (V) 5 12 RP114x No.EA-236-230719 RP114x36xx Output Voltage VOUT (V) 4.0 3.5 3.0 2.5 2.0 1.5 IOUT=1mA 1.0 IOUT=30mA IOUT=50mA 0.5 0 0 1 2 3 4 Input Voltage VIN (V) 5 3) Supply Current vs. Input Voltage (C1=1.0µF, C2=1.0µF, Ta=25°C) RP114x25xx 70 70 60 60 Supply Current ISS (µA) Supply Current ISS (µA) RP114x08xx 50 40 30 20 10 50 40 30 20 10 0 0 0 1 2 3 4 Input Voltage VIN (V) 5 0 1 2 3 4 Input Voltage VIN (V) 5 RP114x36xx Supply Current ISS (µA) 70 60 50 40 30 20 10 0 0 1 2 3 4 Input Voltage VIN (V) 5 13 RP114x No.EA-236-230719 4) Output Voltage vs. Temperature (C1=1.0µF, C2=1.0µF, IOUT=1mA) RP114x08xx 0.83 0.82 0.81 0.80 0.79 0.78 0.77 0.76 0.75 -50 -25 0 25 50 75 Temperature Topt (°C) Ta (°C) RP114x36xx 3.65 3.64 Output Voltage VOUT (V) RP114x25xx VIN=1.8V Output Voltage VOUT (V) Output Voltage VOUT (V) 0.85 0.84 2.55 2.54 2.53 VIN=3.5V 2.52 2.51 2.50 2.49 2.48 2.47 2.46 2.45 -50 100 -25 0 25 50 75 Temperature Topt (°C) Ta (°C) 100 VIN=4.6V 3.63 3.62 3.61 3.60 3.59 3.58 3.57 3.56 3.55 -50 -25 0 25 50 75 Ta (°C) Temperature Topt (°C) 100 5) Supply Current vs. Temperature (C1=1.0µF, C2=1.0µF, IOUT=0mA) RP114x08xx 60 70 Supply Current ISS (μA) Supply Current ISS (μA) 70 RP114x25xx VIN=1.8V 50 40 30 20 10 0 VIN=3.5V 60 50 40 30 20 10 0 -50 -25 0 25 50 75 Ta (°C) Temperature Topt (°C) 100 -50 -25 0 25 50 75 Ta (°C) Temperature Topt (°C) 100 14 RP114x No.EA-236-230719 RP114x36xx VIN=4.6V Supply Current ISS (μA) 70 60 50 40 30 20 10 0 -50 -25 0 25 50 75 100 Temperature Topt (°C) Ta (°C) 6) Dropout Voltage vs. Output Current (C1=1.0µF, C2=1.0µF) RP114x08xx 600 500 400 300 -40°C 25°C 85°C 200 100 RP114x25xx 300 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 700 250 200 150 100 -40°C 25°C 85°C 50 0 0 0 50 100 150 200 250 300 Output Current IOUT (mA) 0 50 100 150 200 250 300 Output Current IOUT (mA) RP114x36xx Dropout Voltage VDIF (mV) 250 200 150 100 -40°C 25°C 85°C 50 0 0 50 100 150 200 250 300 Output Current IOUT (mA) 15 RP114x No.EA-236-230719 7) Dropout Voltage vs. Set Output Voltage (C1=1.0µF, C2=1.0µF, Ta=25°C) Dropout Voltage VDIF (mV) 600 IOUT=30mA 500 IOUT=100mA 400 IOUT=300mA 300 200 100 0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 Set Output Voltage VREG (V) 8) Dropout Voltage vs. Temperature (C1=none, C2=1.0µF) RP114x08xx RP114x25xx 300 600 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 700 50mA 150mA 300mA 500 400 300 200 100 0 250 50mA 150mA 300mA 200 150 100 50 0 -50 -25 0 25 50 75 Temperature Topt Ta (°C) (°C) 100 -50 -25 0 25 50 75 100 Temperature Topt Ta (°C) RP114x36xx Dropout Voltage VDIF (mV) 250 200 50mA 150mA 300mA 150 100 50 0 -50 -25 0 25 50 75 100 Temperature Topt Ta (°C) (°C) 16 RP114x No.EA-236-230719 9) Ripple Rejection vs. Input Voltage (C1=none, C2=1.0µF, Ripple=0.2Vp-p, Ta=25°C) Ripple Rejection RR (dB) 100 90 IOUT=1mA 80 70 60 50 40 1kHz 30 20 10 RP114x25xx 10kHz 100kHz IOUT=30mA 100 90 Ripple Rejection RR (dB) RP114x25xx 80 70 60 50 40 30 20 10 1kHz 10kHz 100kHz 0 0 2.5 3.0 3.5 4.0 4.5 5.0 Input Voltage VIN (V) 2.5 5.5 3.0 3.5 4.0 4.5 5.0 Input Voltage VIN (V) 5.5 10) Ripple Rejection vs. Frequency (C1=none, C2=1.0µF, Ta=25°C) Ripple Rejection RR (dB) 100 90 80 70 60 50 40 30 20 10 0 VIN=3.0V 1mA 30mA 150mA 0.1 1 10 100 Frequency f (kHz) RP114x36xx Ripple Rejection RR (dB) 100 90 80 70 60 50 40 30 20 10 0 RP114x25xx 100 90 80 70 60 50 40 30 20 10 0 Ripple Rejection RR (dB) RP114x08xx 1000 VIN=3.5V 1mA 30mA 150mA 0.1 1 10 100 Frequency f (kHz) 1000 VIN=4.6V 1mA 30mA 150mA 0.1 1 10 100 1000 Frequency f (kHz) 17 RP114x No.EA-236-230719 11) Input Transient Response (IOUT=30mA, tr=tf=5µs, Ta=25°C) RP114x08xx RP114x25xx 0.815 1.0 0.810 0.805 0.800 0.795 0.790 Output Voltage 4.5 4.0 2.505 2.500 2.495 2.490 Output Voltage 2.485 2.480 0 20 40 60 80 100 3.5 3.0 Input Voltage 3.5V4.5V 0 20 40 Time t (µs) 60 80 Input Voltage VIN (V) 1.5 Input Voltage 1.8V2.8V 5.0 Output Voltage VOUT (V) 2.5 2.0 Input Voltage VIN (V) Output Voltage VOUT (V) 3.0 100 Time t (µs) RP114x36xx 5.5 5.0 4.5 4.0 Input Voltage 4.6V5.6V 3.610 3.605 3.600 Output Voltage 3.595 3.590 0 20 40 60 80 Input Voltage VIN (V) Output Voltage VOUT (V) 6.0 100 Time t (µs) 12) Load Transient Response (C1=1.0µF, C2=1.0µF, tr=tf=0.5µs, Ta=25°C) Output Voltage 0.78 0.76 0.74 0 100 200 300 Time t (µs) 400 500 VIN=3.5V 200 150 100 50 Output Current 50mA100mA 2.54 2.52 2.50 2.48 0 Output Voltage 2.46 2.44 0 100 200 300 Time t (µs) 400 Output Current IOUT (mA) 200 150 100 50 0 Output Current 50mA100mA 0.84 0.82 0.80 RP114x25xx Output Voltage VOUT (V) VIN=1.8V Output Current IOUT (mA) Output Voltage VOUT (V) RP114x08xx 500 18 RP114x VIN=4.6V Output Current 50mA100mA Output Voltage 200 300 Time t (µs) Output Voltage VOUT (V) RP114x08xx 500 RP114x25xx VIN=1.8V 450 300 150 0 Output Current 1mA300mA 1.0 0.9 0.8 Output Voltage 0.7 0.6 0.5 0 100 200 300 Time t (µs) RP114x36xx Output Voltage VOUT (V) 400 400 VIN=4.6V Output Current 1mA300mA 3.8 3.7 3.6 3.5 3.4 3.3 450 300 150 0 Output Voltage 0 100 200 300 Time t (µs) 400 Output Current 1mA300mA 2.7 2.6 2.5 2.4 2.3 2.2 450 300 150 0 Output Voltage 0 500 VIN=3.5V 100 200 300 Time t (µs) 400 500 500 19 Output Current IOUT (mA) 100 Output Voltage VOUT (V) 0 Output Current IOUT (mA) 3.62 3.60 3.58 3.56 3.54 200 150 100 50 0 Output Current IOUT (mA) Output Voltage VOUT (V) RP114x36xx Output Current IOUT (mA) No.EA-236-230719 RP114x No.EA-236-230719 13) Turn On Speed with CE pin (C1=1.0µF, C2=1.0µF, Ta=25°C) RP114x25xx VIN=3.5V 2 CE Input Voltage 1 0 0.8 0.6 Output Voltage 0.4 IOUT=0mA IOUT=30mA IOUT=300mA 0.2 0.0 0 40 80 Time t (µs) 120 Output Voltgage VOUT (V) 3 6 4 CE Input Voltage 2 IOUT=0mA IOUT=30mA IOUT=300mA 4 3 2 0 Output Voltage 1 CE Input Voltage VCE (V) VIN=1.8V CE Input Voltage VCE (V) Output Voltgage VOUT (V) RP114x08xx 0 0 160 40 80 Time t (µs) 120 160 RP114x36xx 4 CE Input Voltage 2 IOUT=0mA IOUT=30mA IOUT=300mA 4 6 0 3 Output Voltage 2 1 CE Input Voltage VCE (V) Output Voltgage VOUT (V) VIN=4.6V 0 0 40 80 Time t (µs) 120 160 14) Turn Off Speed with CE pin (B version) (C1=1.0µF, C2=1.0µF, Ta=25°C) 3 2 CE Input Voltage 1 0 0.8 IOUT=0mA 0.6 0.4 Output Voltage 0.2 VIN=3.5V 6 4 2 CE Input Voltage 0 4 IOUT=0mA 3 2 Output Voltage 1 CE Input Voltage VCE (V) RP114x25xB Output Voltgage VOUT (V) VIN=1.8V CE Input Voltage VCE (V) Output Voltgage VOUT (V) RP114x08xB 0 0.0 0 2 4 6 8 10 12 14 16 18 Time t (ms) 0 2 4 6 8 10 12 14 16 18 Time t (ms) 20 RP114x No.EA-236-230719 RP114x36xB 6 4 CE Input Voltage 2 0 4 IOUT=0mA 3 2 Output Voltage 1 CE Input Voltage VCE (V) Output Voltgage VOUT (V) VIN=4.6V 0 0 2 4 6 8 10 12 14 16 18 Time t (ms) 15) Turn Off Speed with CE pin (D version) (C1=1.0µF, C2=1.0µF, Ta=25°C) 2 CE Input Voltage 1 0 0.8 IOUT=0mA IOUT=30mA IOUT=300mA 0.6 0.4 0.2 Output Voltage 4 CE Input Voltage 2 0 IOUT=0mA IOUT=30mA IOUT=300mA 4 3 2 1 Output Voltage VIN=4.6V 6 4 CE Input Voltage IOUT=0mA IOUT=30mA Time t (µs) 2 0 IOUT=300mA 2 Output Voltage CE Input Voltage VCE (V) Output Voltgage VOUT (V) RP114x36xD 1 6 0 100 200 300 400 500 600 700 800 0 100 200 300 400 500 600 700 800 Time t (µs) 3 VIN=3.5V 0 0.0 4 Output Voltgage VOUT (V) 3 CE Input Voltage VCE (V) RP114x25xD VIN=1.8V CE Input Voltage VCE (V) Output Voltgage VOUT (V) RP114x08xD 0 0 100 200 300 400 500 600 700 800 Time t (µs) 21 POWER DISSIPATION DFN(PL)1010-4 PD-DFN(PL)1010-4-(85125150)-JE-B The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Environment Board Material Board Dimensions Measurement Conditions Mounting on Board (Wind Velocity = 0 m/s) Glass Cloth Epoxy Plastic (Four-Layer Board) 76.2 mm × 114.3 mm × 0.8 mm Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square φ 0.2 mm × 21 pcs Copper Ratio Through-holes Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation Thermal Resistance (θja) Thermal Characterization Parameter (ψjt) 800 mW θja = 125°C/W ψjt = 58°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 1200 1000 Power Dissipation (mW) 1000 800 800 600 400 200 0 0 25 50 75 85 100 125 150 Ambient Temperature (°C) Power Dissipation vs. Ambient Temperature Measurement Board Pattern The above graph shows the power dissipation of the package at Tjmax = 125°C and Tjmax = 150°C. Operating the device in the hatched range might have a negative influence on its lifetime. The total hours of use and the total years of use must be limited as follows: Total Hours of Use Total Years of Use (4 hours/day) 13,000 hours 9 years i PACKAGE DIMENSIONS DFN(PL)1010-4 DM-DFN(PL)1010-4-JE-C DFN(PL)1010-4 Package Dimensions i POWER DISSIPATION DFN(PL)1010-4B PD-DFN(PL)1010-4B-(85125150)-JE-B The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Environment Board Material Board Dimensions Measurement Conditions Mounting on Board (Wind Velocity = 0 m/s) Glass Cloth Epoxy Plastic (Four-Layer Board) 76.2 mm × 114.3 mm × 0.8 mm Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square φ 0.2 mm × 21 pcs Copper Ratio Through-holes Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Power Dissipation Thermal Resistance (θja) Thermal Characterization Parameter (ψjt) Measurement Result 800 mW θja = 125°C/W ψjt = 58°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 1200 1000 Power Dissipation (mW) 1000 800 800 600 400 200 0 0 25 50 75 85 100 Ambient Temperature (°C) 125 150 Power Dissipation vs. Ambient Temperature Measurement Board Pattern The above graph shows the power dissipation of the package at Tjmax = 125°C and Tjmax = 150°C. Operating the device in the hatched range might have a negative influence on its lifetime. The total hours of use and the total years of use must be limited as follows: Total Hours of Use Total Years of Use (4 hours/day) 13,000 hours 9 years i PACKAGE DIMENSIONS DFN(PL)1010-4B DM-DFN(PL)1010-4B-JE-B DFN (PL) 1010-4B Package Dimensions * The tab on the bottom of the package is a substrate potential (GND/VDD). It is recommended that this tab be connected to the ground plane/VDD pin on the board but it is possible to leave the tab floating. i PART MARKINGS RP114K MK-RP114K-JE-B : Product Code … Refer to Part Marking List : Lot Number … Alphanumeric Serial Number ①② ③④ RP114K [DFN(PL)1010-4B], DFN(PL)1010-4 Part Markings NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. i PART MARKINGS RP114K MK-RP114K-JE-B RP114Kxx1B Part Marking List Product Name ①② RP114K081B RP114K091B RP114K101B RP114K111B RP114K121B RP114K131B RP114K141B RP114K151B RP114K161B RP114K171B RP114K181B RP114K191B RP114K201B RP114K211B RP114K221B RP114K231B RP114K241B RP114K251B RP114K261B RP114K271B RP114K281B RP114K291B RP114K301B RP114K311B RP114K321B RP114K331B RP114K341B RP114K351B RP114K361B RP114K121B5 RP114K181B5 RP114K281B5 RP114K341B5 RP114K101B5 RP114K171B5 RP114K111B5 RP114K131B5 L0 L1 L2 L3 L4 L5 L6 L7 L8 L9 M0 M1 M2 M3 M4 M5 M6 M7 M8 M9 N0 N1 N2 N3 N4 N5 N6 N7 N8 N9 P0 P1 P2 P3 P4 P5 P6 Set Output Voltage 0.8V 0.9V 1.0V 1.1V 1.2V 1.3V 1.4V 1.5V 1.6V 1.7V 1.8V 1.9V 2.0V 2.1V 2.2V 2.3V 2.4V 2.5V 2.6V 2.7V 2.8V 2.9V 3.0V 3.1V 3.2V 3.3V 3.4V 3.5V 3.6V 1.25V 1.85V 2.85V 3.45V 1.05V 1.75V 1.15V 1.35V RP114Kxx1D Part Marking List Product Name ①② RP114K081D RP114K091D RP114K101D RP114K111D RP114K121D RP114K131D RP114K141D RP114K151D RP114K161D RP114K171D RP114K181D RP114K191D RP114K201D RP114K211D RP114K221D RP114K231D RP114K241D RP114K251D RP114K261D RP114K271D RP114K281D RP114K291D RP114K301D RP114K311D RP114K321D RP114K331D RP114K341D RP114K351D RP114K361D RP114K121D5 RP114K181D5 RP114K281D5 RP114K341D5 RP114K101D5 RP114K171D5 RP114K111D5 RP114K131D5 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q8 Q9 R0 R1 R2 R3 R4 R5 R6 R7 R8 R9 S0 S1 S2 S3 S4 S5 S6 S7 S8 S9 T0 T1 T2 T3 T4 T5 T6 Set Output Voltage 0.8V 0.9V 1.0V 1.1V 1.2V 1.3V 1.4V 1.5V 1.6V 1.7V 1.8V 1.9V 2.0V 2.1V 2.2V 2.3V 2.4V 2.5V 2.6V 2.7V 2.8V 2.9V 3.0V 3.1V 3.2V 3.3V 3.4V 3.5V 3.6V 1.25V 1.85V 2.85V 3.45V 1.05V 1.75V 1.15V 1.35V ii POWER DISSIPATION SC-88A PD-SC-88A-(85125150)-JE-B The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following conditions are used in this measurement. Measurement Conditions Item Our Evaluation Board Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Double-Sided Board) Board Dimensions 40 mm × 40 mm × 1.6 mm Top Side: Approx. 50% Copper Ratio Bottom Side: Approx. 50% Through-holes φ 0.5 mm × 44 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Our Evaluation Board Power Dissipation 380 mW Thermal Resistance (θja) θja = 263°C/W Thermal Characterization Parameter (ψjt) ψjt = 75°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 600 40 475 400 380 300 40 Power Dissipation (mW) 500 200 100 0 0 25 50 75 85 100 125 Ambient Temperature (°C) 150 Power Dissipation vs. Ambient Temperature Measurement Board Pattern The above graph shows the power dissipation of the package at Tjmax = 125°C and Tjmax = 150°C. Operating the device in the hatched range might have a negative influence on its lifetime. The total hours of use and the total years of use must be limited as follows: Total Hours of Use 13,000 hours Total Years of Use (4 hours/day) 9 years i PACKAGE DIMENSIONS SC-88A DM-SC-88A-JE-A SC-88A Package Dimensions i PART MARKINGS RP114Q MK-RP114Q-JE-A : Product Code … Refer to Part Marking List : Lot Number … Alphanumeric Serial Number 5 4 ①②③ ④⑤⑥ 1 2 3 RP114Q (SC-88A) Part Markings NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. i PART MARKINGS RP114Q MK-RP114Q-JE-A RP114Qxx2B Part Marking List Product Name  RP114Q082B RP114Q092B RP114Q102B RP114Q112B RP114Q122B RP114Q132B RP114Q142B RP114Q152B RP114Q162B RP114Q172B RP114Q182B RP114Q192B RP114Q202B RP114Q212B RP114Q222B RP114Q232B RP114Q242B RP114Q252B RP114Q262B RP114Q272B RP114Q282B RP114Q292B RP114Q302B RP114Q312B RP114Q322B RP114Q332B RP114Q342B RP114Q352B RP114Q362B RP114Q122B5 RP114Q182B5 RP114Q282B5 RP114Q342B5 RP114Q102B5 AG08 AG09 AG10 AG11 AG12 AG13 AG14 AG15 AG16 AG17 AG18 AG19 AG20 AG21 AG22 AG23 AG24 AG25 AG26 AG27 AG28 AG29 AG30 AG31 AG32 AG33 AG34 AG35 AG36 AG37 AG38 AG39 AG40 AG41 Set Output Voltage 0.8 V 0.9 V 1.0 V 1.1 V 1.2 V 1.3 V 1.4 V 1.5 V 1.6 V 1.7 V 1.8 V 1.9 V 2.0 V 2.1 V 2.2 V 2.3 V 2.4 V 2.5 V 2.6 V 2.7 V 2.8 V 2.9 V 3.0 V 3.1 V 3.2 V 3.3 V 3.4 V 3.5 V 3.6 V 1.25 V 1.85 V 2.85 V 3.45 V 1.05 V RP114Qxx2D Part Marking List Product Name  RP114Q082D RP114Q092D RP114Q102D RP114Q112D RP114Q122D RP114Q132D RP114Q142D RP114Q152D RP114Q162D RP114Q172D RP114Q182D RP114Q192D RP114Q202D RP114Q212D RP114Q222D RP114Q232D RP114Q242D RP114Q252D RP114Q262D RP114Q272D RP114Q282D RP114Q292D RP114Q302D RP114Q312D RP114Q322D RP114Q332D RP114Q342D RP114Q352D RP114Q362D RP114Q122D5 RP114Q182D5 RP114Q282D5 RP114Q342D5 RP114Q102D5 AH08 AH09 AH10 AH11 AH12 AH13 AH14 AH15 AH16 AH17 AH18 AH19 AH20 AH21 AH22 AH23 AH24 AH25 AH26 AH27 AH28 AH29 AH30 AH31 AH32 AH33 AH34 AH35 AH36 AH37 AH38 AH39 AH40 AH41 Set Output Voltage 0.8 V 0.9 V 1.0 V 1.1 V 1.2 V 1.3 V 1.4 V 1.5 V 1.6 V 1.7 V 1.8 V 1.9 V 2.0 V 2.1 V 2.2 V 2.3 V 2.4 V 2.5 V 2.6 V 2.7 V 2.8 V 2.9 V 3.0 V 3.1 V 3.2 V 3.3 V 3.4 V 3.5 V 3.6 V 1.25 V 1.85 V 2.85 V 3.45 V 1.05 V ii POWER DISSIPATION SOT-23-5 PD-SOT-23-5-(85/125/150)-JE-A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Board Material Mounting on Board (Wind Velocity = 0 m/s) Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square φ 0.3 mm × 7 pcs Copper Ratio Through-holes Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 660 mW Thermal Resistance (θja) θja = 150°C/W Thermal Characterization Parameter (ψjt) ψjt = 51°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 1000 900 830 Power Dissipation (mW) 800 700 600 660 500 400 300 200 100 0 0 25 50 75 85 100 125 Ambient Temperature (°C) 150 Power Dissipation vs. Ambient Temperature Measurement Board Pattern The above graph shows the power dissipation of the package at Tjmax = 125°C and Tjmax = 150°C. Operating the device in the hatched range might have a negative influence on its lifetime. The total hours of use and the total years of use must be limited as follows: Total Hours of Use 13,000 hours Total Years of Use (4 hours/day) 9 years i SOT-23-5 PACKAGE DIMENSIONS DM-SOT-23-5-JE-B 2.9±0.2 1.1±0.1 1.9±0.2 0.8±0.1 (0.95) 4 1 2 0~0.1 0.2min. +0.2 1.6-0.1 5 2.8±0.3 (0.95) 3 0.4±0.1 +0.1 0.15-0.05 SOT-23-5 Package Dimensions i PART MARKINGS RP114N MK-RP114N-JE-A : Product Code … Refer to Part Marking List : Lot Number … Alphanumeric Serial Number 5 4  1 2 3 RP114N (SOT-23-5) Part Markings NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. i PART MARKINGS RP114N MK-RP114N-JE-A RP114Nxx1B Part Marking List Product Name  RP114N081B RP114N091B RP114N101B RP114N111B RP114N121B RP114N131B RP114N141B RP114N151B RP114N161B RP114N171B RP114N181B RP114N191B RP114N201B RP114N211B RP114N221B RP114N231B RP114N241B RP114N251B RP114N261B RP114N271B RP114N281B RP114N291B RP114N301B RP114N311B RP114N321B RP114N331B RP114N341B RP114N351B RP114N361B RP114N121B5 RP114N181B5 RP114N281B5 RP114N341B5 RP114N101B5 QAA QAB QAC QAD QAE QAF QAG QAH QAJ QAK QAL QAM QAN QAP QAQ QAR QAS QAT QAU QAV QAW QAX QAY QAZ RAA RAB RAC RAD RAE RAF RAG RAH RAJ RAK Set Output Voltage 0.8 V 0.9 V 1.0 V 1.1 V 1.2 V 1.3 V 1.4 V 1.5 V 1.6 V 1.7 V 1.8 V 1.9 V 2.0 V 2.1 V 2.2 V 2.3 V 2.4 V 2.5 V 2.6 V 2.7 V 2.8 V 2.9 V 3.0 V 3.1 V 3.2 V 3.3 V 3.4 V 3.5 V 3.6 V 1.25 V 1.85 V 2.85 V 3.45 V 1.05 V RP114Nxx1D Part Marking List Product Name  RP114N081D RP114N091D RP114N101D RP114N111D RP114N121D RP114N131D RP114N141D RP114N151D RP114N161D RP114N171D RP114N181D RP114N191D RP114N201D RP114N211D RP114N221D RP114N231D RP114N241D RP114N251D RP114N261D RP114N271D RP114N281D RP114N291D RP114N301D RP114N311D RP114N321D RP114N331D RP114N341D RP114N351D RP114N361D RP114N121D5 RP114N181D5 RP114N281D5 RP114N341D5 RP114N101D5 QBA QBB QBC QBD QBE QBF QBG QBH QBJ QBK QBL QBM QBN QBP QBQ QBR QBS QBT QBU QBV QBW QBX QBY QBZ RBA RBB RBC RBD RBE RBF RBG RBH RBJ RBK Set Output Voltage 0.8 V 0.9 V 1.0 V 1.1 V 1.2 V 1.3 V 1.4 V 1.5 V 1.6 V 1.7 V 1.8 V 1.9 V 2.0 V 2.1 V 2.2 V 2.3 V 2.4 V 2.5 V 2.6 V 2.7 V 2.8 V 2.9 V 3.0 V 3.1 V 3.2 V 3.3 V 3.4 V 3.5 V 3.6 V 1.25 V 1.85 V 2.85 V 3.45 V 1.05 V ii 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. The materials in this document may not be copied or otherwise reproduced in whole or in part without the prior written consent of us. This product and any technical information relating thereto are subject to complementary export controls (so-called KNOW controls) under the Foreign Exchange and Foreign Trade Law, and related politics ministerial ordinance of the law. (Note that the complementary export controls are inapplicable to any application-specific products, except rockets and pilotless aircraft, that are insusceptible to design or program changes.) Accordingly, when exporting or carrying abroad this product, follow the Foreign Exchange and Foreign Trade Control Law and its related regulations with respect to the complementary export controls. The technical information described in this document shows typical characteristics and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our or any third party's intellectual property rights or any other rights. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death should first contact us. • Aerospace Equipment • Equipment Used in the Deep Sea • Power Generator Control Equipment (nuclear, steam, hydraulic, etc.) • Life Maintenance Medical Equipment • Fire Alarms / Intruder Detectors • Vehicle Control Equipment (automotive, airplane, railroad, ship, etc.) • Various Safety Devices • Traffic control system • Combustion equipment In case your company desires to use this product for any applications other than general electronic equipment mentioned above, make sure to contact our company in advance. Note that the important requirements mentioned in this section are not applicable to cases where operation requirements such as application conditions are confirmed by our company in writing after consultation with your company. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. The products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. We shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. Quality Warranty 8-1. Quality Warranty Period In the case of a product purchased through an authorized distributor or directly from us, the warranty period for this product shall be one (1) year after delivery to your company. For defective products that occurred during this period, we will take the quality warranty measures described in section 8-2. However, if there is an agreement on the warranty period in the basic transaction agreement, quality assurance agreement, delivery specifications, etc., it shall be followed. 8-2. Quality Warranty Remedies When it has been proved defective due to manufacturing factors as a result of defect analysis by us, we will either deliver a substitute for the defective product or refund the purchase price of the defective product. Note that such delivery or refund is sole and exclusive remedies to your company for the defective product. 8-3. Remedies after Quality Warranty Period With respect to any defect of this product found after the quality warranty period, the defect will be analyzed by us. On the basis of the defect analysis results, the scope and amounts of damage shall be determined by mutual agreement of both parties. Then we will deal with upper limit in Section 8-2. This provision is not intended to limit any legal rights of your company. Anti-radiation design is not implemented in the products described in this document. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. Warning for handling Gallium and Arsenic (GaAs) products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP114N181B-TR-FE 价格&库存
很抱歉,暂时无法提供与“RP114N181B-TR-FE”相匹配的价格&库存,您可以联系我们找货
RP114N181B-TR-FE
  • 3000+3.233273000+0.41735
  • 6000+3.153596000+0.40707
  • 9000+3.113689000+0.40192
  • 15000+3.0694915000+0.39621
  • 21000+3.0436521000+0.39288
库存:1836
RP114N181B-TR-FE
    • 1+1.94325
    • 200+0.75201
    • 500+0.72566
    • 1000+0.71259
    RP114N181B-TR-FE
    • 1+6.996051+0.90306
    • 10+5.0150910+0.64735
    • 25+4.5113325+0.58233
    • 100+3.95336100+0.51030
    • 250+3.68787250+0.47604
    • 500+3.52785500+0.45538
    • 1000+3.396021000+0.43836
    库存:1836
