NJM12884DL3-33-TE1
NJM12884DL3-33-TE1
    NISSHINBO(日清纺)
    TO-252-6
    PMIC - 稳压器 - 线性 正 固定 1 输出 500mA TO-252-5
NJM12884DL3-33-TE1 数据手册
NJM12884 LDO with Reverse Current Protection / Soft Start / Discharge Function GENERAL DESCRIPTION The NJM12884 is a low dropout regulator which achieves high ripple rejection, low noise and high speed response with the bipolar technology. Adjustable soft-start function is useful for reducing inrush current and controlling power-on sequence. Moreover the discharge function makes effective sequence control with the soft-start function. In addition, the reverse current protection makes external SBD unnecessary. ■ PACKAGE OUTLINE NJM12884U2 NJM12884DL3 FEATURE Operating Voltage Range 2.3V to 6.5V Output Voltage Accuracy VO 1.0% Output Current IO(min.)=500mA Reverse Current Protection Adjustable soft-start Function Discharge Function ON/OFF Control Correspond to Low ESR capacitor (MLCC) Thermal Shutdown Circuit Over Current Protection Circuit Package Outline SOT-89-5, TO-252-5 PIN CONFIGRATION VOUT 1 5 VIN GND 2 2 GND CS 3 3 4 CONTROL 5 CS 4 VOUT 3 GND 2 VIN CONTROL 1 NJM12884DL3 NJM12884U2 BLOCK DIAGRAM VIN CONTROL VOUT Reverse Current Protection Thermal Protection CS Bandgap Reference Over Current Protection GND Ver.2015-07-28 -1- NJM12884 OUTPUT VOLTAGE RANK LIST SOT-89-5 TO-252-5 Output Device Name Device Name Voltage NJM12884U2-15 1.5V NJM12884DL3-15 NJM12884U2-18 1.8V NJM12884DL3-18 NJM12884U2-25 2.5V NJM12884DL3-25 NJM12884U2-33 3.3V NJM12884DL3-33 NJM12884U2-05 5.0V NJM12884DL3-05 ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL Input Voltage VIN Control Pin Voltage VCONT Output Voltage VOUT Soft start Pin Voltage VCS Power Dissipation PD Junction Temperature Range Operating Temperature Range Storage Temperature Range Tj Topr Tstg Output Voltage 1.5V 1.8V 2.5V 3.3V 5.0V (Ta=25 C) MAXIMUM RATING UNIT -0.3 ~ +7 -0.3 ~ +7 -0.3 ~ +5.5 Vo 1.8V -0.3 ~ +7 Vo 1.8V -0.3 ~ +4 625(*1) SOT-89-5 2400(*2) 1190(*1) TO-252-5 3125(*2) -40 +150 -40 +125 -50 +150 V V V V V mW C C C 2 (*1): Mounted on glass epoxy board. (76.2 114.3 1.6mm:based on EIA/JDEC standard size, 2Layers, Cu area 100mm ) (*2): Mounted on glass epoxy board. (76.2 114.3 1.6mm:based on EIA/JDEC standard, 4Layers) (For 4Layers: Applying 74.2 74.2mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5) Operating Voltage Range :VIN=2.3V~6.5V -2- Ver.2015-07-28 NJM12884 ELECTRICAL CHARACTERISTICS (Unless other noted, VIN = VO + 1V, CIN = 0.33µF, CO =0.33 µF(Co=0.47µF :2.9V Vo 3.4V, Co=2.2µF : 1.7V Vo 2.9V, Co=4.7µF Vo 1.7V), Cs=0.01µF, Ta = 25°C) PARAMETER Output Voltage Quiescent Current Quiescent Current at OFF-state Output Current Line Regulation Load Regulation Dropout Voltage (*3) Average Temperature Coefficient of Output Voltage SYMBOL VO IQ TEST CONDITION IO=100mA IO = 0mA, except ICONT IQ(OFF) VCONT = 0V IO VO/ VIN VO/ IO VIO VO 0.9 VIN = VO + 1V ~ 6.5V, Io=100mA IO = 0 ~ 500mA IO=300mA VO/ Ta Ta= -40 ~ +125 C, IO=100mA MAX. UNIT 200 +1.0% 280 V μA - - 10 μA 500 - 0.18 0.1 0.005 0.25 mA %/V %/mA V - ppm/ C - 50 76 74 71 68 64 15 19 24 28 40 3 12 VCONT(ON) 1.6 - - V VCONT(OFF) - - 0.6 V 2 1.2 9 - msec VIN=2.3V, VCONT=0V, VO =0.5V VIN=6.5V, VCONT=0V, VO =0.5V 15 25 - RR ein=200mVrms, f=1kHz, Io=10mA Output Noise Voltage VNO f=10Hz ~ 80kHz, Io=10mA Control Current Control Voltage at ON-state Control Voltage at OFF-state Soft Start Time ICONT VCONT =1.6V Discharge Current at OFF-state TYP. - Ripple Rejection tS(ON) IDIS Vo=1.5V Vo=1.8V Vo=2.5V Vo=3.3V Vo=5.0V Vo=1.5V Vo=1.8V Vo=2.5V Vo=3.3V Vo=5.0V MIN. -1.0% - VCONT=L→H, Io=100mA, Cs=0.022μF dB μVrms μA mA (*3): Except Output Voltage Rank less than 2.1V The above specification is a common specification for all output voltages. Therefore, it may be different from the individual specification for a specific output voltage. Ver.2015-07-28 -3- NJM12884 POWER DISSIPATION vs. AMBIENT TEMPERATURE NJM12884U2  PowerDis s ipation Power Dissipation PD (mW) (Topr=-40~+125°C,Tj=150°C) 3000 on 4 layers board 2500 2000 1500 1000 on 2 layers board 500 0 -50 -25 0 25 50 75 100 125 150 Temperature : Ta(°C) NJM12884DL3  PowerDissipation (Topr=-40~+125°C,Tj=150°C) (mW) Power Dissipation PDD(mW) 3500 3000 on 4 layers board 2500 2000 1500 1000 on 2 layers board 500 0 -50 -25 0 25 50 75 100 125 150 Temperature : Ta(°C) -4- Ver.2015-07-28 NJM12884 TEST CIRCUIT A IIN VIN VIN 0.33μF VOUT (*4) 0.33μF NJM12884 (ceramic) A ICONT (ceramic) Cs CONTROL GND V VCONT *4: 2.9V
NJM12884DL3-33-TE1 价格&库存
很抱歉,暂时无法提供与“NJM12884DL3-33-TE1”相匹配的价格&库存,您可以联系我们找货
NJM12884DL3-33-TE1
  • 3000+4.969813000+0.64329
  • 6000+4.856466000+0.62862
  • 9000+4.799729000+0.62128
  • 15000+4.7368615000+0.61314
库存:26
NJM12884DL3-33-TE1
  • 1+10.427551+1.34974
  • 10+7.5097610+0.97206
  • 25+6.7856025+0.87833
  • 100+5.99392100+0.77585
  • 250+5.61647250+0.72700
  • 500+5.38886500+0.69754
  • 1000+5.272071000+0.68242
库存:26
