CFM06S240-E
CFM06S240-E
    CINCON
    DIP4 模块
    封闭式 AC DC 转换器 1 输出 24V 250mA 90 ~ 264 VAC,120 ~ 370 VDC 输入
CFM06S240-E 数据手册
CFM06S SERIES 6 WATT OPEN FRAME AC-DC MODULES Features  Universal Input Range 90~264Vac  High Efficiency up to 83%  0.764”x 1.555” Compact Size  Class II  No Load Power 95% Reduction Criterion A Voltage Interruptions IEC 61000-4-11:2020, >95% Reduction Criterion B Application Note Link CFM06S Series App Notes CHARACTERISTIC CURVE Power Derating Curve Derating curve for Natural Convection Rated Load (%) 100% 75% 50% 25% 0% -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 Ambient Temperature(oC) Performance Data CFM06S050 (Eff Vs Io) 85% 80% 80% Efficiency (%) Efficiency (%) CFM06S033 (Eff Vs Io) 85% 75% 70% 65% 115V 60% 55% 50% 10% 30% 40% 50% 60% 70% 80% 65% 115V 60% 50% 10% 90% 100% Current Load (%) www.cincon.com 70% 55% 230V 20% 75% 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 4 REVISION: V16 CFM06S CFM06S120 (Eff Vs Io) 85% 85% 80% 80% Efficiency (%) Efficiency (%) CFM06S090 (Eff Vs Io) 75% 70% 65% 115V 60% 55% 50% 10% 30% 40% 50% 60% 70% 80% 75% 70% 65% 115V 60% 55% 230V 20% 50% 10% 90% 100% 230V 20% 30% Current Load (%) 80% 80% 75% 70% 65% 115V 60% 40% 50% 60% 70% 70% 80% 90% 100% 80% 75% 70% 65% 55% 10% 90% 100% Current Load (%) www.cincon.com 60% 115V 60% 230V 30% 50% CFM06S240 (Eff Vs Io) 85% Efficiency (%) Efficiency (%) CFM06S150 (Eff Vs Io) 20% 40% Current Load (%) 85% 55% 10% Series 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 5 REVISION: V16 CFM06S Series MECHANICAL SPECIFICATION CFM06SXXX CFM06SXXX-E 1.555 [39.50] 0.201 [5.10] 4 Φ0.020[Φ0.50] 0.300[7.62] 1.618 [41.10] 1.300[33.02] Φ0.020[Φ0.50] 0.159 [4.04] PIN CONNECTION Pin Function 1 ACN 2 ACL 3 +Vout -Vout 4 BOTTOM VIEW 4 2 3 0.827 [21.00] 0.600[15.24] 1 0.113 [2.88] 0.720 [18.30]max 0.201 [5.10] 0.583 [14.80]max 0.300 [7.62] 2 0.098 [2.50]max 0.600 [15.24] 0.082 [2.08] 0.764 [19.40] 3 1 0.787 [20.00] 0.128 [3.24] All Dimensions In Inches[mm] Tolerance Inches:x.xxx= ± 0.02 Millimeters: x.xx = ± 0.5 0.128 [3.25] 1.950 [49.53] 0.118 [3.00] CN2 0] 3.2 Φ [ 6 1 .12 Φ0 23 CFM06SXXX-T 1 2 0.728 [18.50] 1.714 [43.53] 0.472 [12.00] 0.128 [3.25] 1.300 [33.02] AC Input Connector(CN1):JST B3B-PH-K-S(LF)(SN) or equivalent Pin CN1 ACN 2 - 3 ACL PHR-3 or equivalent Terminal SPH-002T-P0.5L or equivalent DC Output Connector(CN2):JST B2B-PH-K-S(LF)(SN) or equivalent Pin 1 2 0.689 [17.50]max 0.591 [15.00]max 0.098 [2.50]max 0.118 [3.00] Function Mating Housing 1 Function Mating Housing +Vout PHR-2 or equivalent -Vout Terminal SPH-002T-P0.5L or equivalent All Dimensions In Inches[mm] Tolerance Inches:x.xxx= ± 0.02 Millimeters: x.xx = ± 0.5 sales@cincon.com.tw www.cincon.com 6 REVISION: V16
CFM06S240-E 价格&库存
很抱歉,暂时无法提供与“CFM06S240-E”相匹配的价格&库存,您可以联系我们找货
