EC4SAW-48D15N
EC4SAW-48D15N
    CINCON
    SIP-7
    隔离模块 直流转换器 2 输出 15V -15V 200mA,200mA 18V - 75V 输入
EC4SAW-48D15N 数据手册
V15 EC4SAW SERIES ︳ 5-6 WATT WIDE INPUT DC-DC CONVERTERS FEATURE * 5-6W Isolated Output * Compact SIP-8 Package * Efficiency up to 89% * 4:1 Input Range * Regulated Outputs * Remote On/Off Control * 1500VDC Isolation * Continuous Short Circuit Protection * Safety Meets IEC/EN/UL 62368-1 MODEL NUMBER INPUT OUTPUT OUTPUT CURRENT VOLTAGE VOLTAGE MIN. MAX. INPUT CURRENT NO LOAD %EFF. FULL LOAD (3) CAPACITOR (2) LOAD MAX. EC4SAW-24S33N EC4SAW-24S05N 9-36 VDC 9-36 VDC 3.3 VDC 5 VDC 0 mA 0 mA 1500 mA 1200 mA 4 mA 4 mA 252 mA 291 mA 82 86 82 86 4700uF 2200uF EC4SAW-24S12N EC4SAW-24S15N 9-36 VDC 9-36 VDC 12 VDC 15 VDC 0 mA 0 mA 500 mA 400 mA 5 mA 5 mA 284 mA 284 mA 88 89 88 88 1100uF 470uF EC4SAW-24D05N 9-36 VDC ±5 VDC 0 mA ±600 mA 4 mA 291 mA 86 86 1400uF EC4SAW-24D12N EC4SAW-24D15N 9-36 VDC 9-36 VDC ±12 VDC ±15 VDC 0 mA 0 mA ±250 mA ±200 mA 6 mA 6 mA 284 mA 284 mA 88 88 88 88 660uF 220uF EC4SAW-48S33N EC4SAW-48S05N 18-75 VDC 18-75 VDC 3.3 VDC 5 VDC 0 mA 0 mA 1500 mA 1200 mA 3 mA 3 mA 126 mA 147 mA 82 85 82 85 4700uF 2200uF EC4SAW-48S12N 18-75 VDC 12 VDC 0 mA 500 mA 3 mA 140 mA 88 89 1100uF EC4SAW-48S15N EC4SAW-48D05N 18-75 VDC 18-75 VDC 15 VDC ±5 VDC 0 mA 0 mA 400 mA ±600 mA 3 mA 4 mA 142 mA 147 mA 89 85 88 85 470uF 1400uF EC4SAW-48D12N EC4SAW-48D15N 18-75 VDC 18-75 VDC ±12 VDC ±15 VDC 0 mA 0 mA ±250 mA ±200 mA 3 mA 3 mA 140 mA 140 mA 88 88 89 89 660uF 220uF NOTE: 1. Nominal Input Voltage 24 or 48 VDC 2. Measured at Nominal Input Voltage 3. Measured at 12VDC for 24Vin, 24VDC for 48Vin 1 V15 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ........……………..................... 24V ..................... 9-36V 48V.................. 18-75V Input Surge Voltage (100 ms max.) …………...…….. 24V ……… 50VDC max. 48V……. 100VDC max. Input Filter ………………………………………………..……..……... Capacitive Remote On/Off Control: Module On …………………… Short, Open or High Impedance Module Off ………..………….……………………. 2mA to 4mA Module Off (Input Idle Current) ……..………...… 2.5mA max. Efficiency .................................................................…..……... See Table Isolation Voltage ..........…........………………....……..…. 1500VDC min. Isolation Resistance .................................…...............……. 109 ohm min. Isolation Capacitance …………………………………………... 50pF max. Switching Frequency ...........................…..................…….... 580KHz typ. Operating Ambient Temperature ……………..…... -40℃ to +85℃ De-rating, Above 61℃ …… 3.3V/5V … Linearly to Zero Power at 105℃ De-rating, Above 65℃ …… 12V/15V … Linearly to Zero Power at 105℃ OUTPUT SPECIFICATIONS: Case Temperature (note4) ……………………….…………. 105℃ max. Cooling ……………………….…………….…………. Natural Convection Voltage Accuracy ............................................………................. ±1.5% max. Voltage Balance (Dual) …………………………………………….... ±1.0% max Transient Response: 25% Step Load Change Error Band …… ±5% Vout Nominal, Recovery Time …….….. < 250µs Ripple & Noise, 20MHz BW .……………………………..... 100mV pk-pk max. Temperature Coefficient ....................……….....….......…................ ±0.03%/°C Storage Temperature ………………....….........…........ -55℃ to +125℃ Humidity …………………………………. 95% RH max. Non Condensing Short Circuit Protection .........................................................….…. Continuous NOTE: Line Regulation (note1) .…….………………..….......................…. ±0.2% max. Load Regulation (note2) ……..………… Single ..........…............ ±0.5% max. Dual ………………….. ±1.0% max. Cross Regulation (Dual note3) ……. Asymmetrical Load 25%/100% …... ±5.0% max. Current Limit ………………………………………………………….... 180% typ. Start up Time ……………………………………………………………. 15ms typ. 1. Measured from high line to low line. 2. Measured from full load to no load. 3. For asymmetric loading, both channels must be at 25% load or more. 4. Maximum case temperature under any operating condition should not be exceeded 105℃. MTBF …. MIL-HDBK-217F, GB, 25℃, Full Load ………… 1850Khrs typ. Dimensions …..…...........… 0.86x0.36x0.44 inches(21.8x9.2x11.1 mm) Case Material ……………………………… Non-Conductive Black Plastic Weight …………………………………………….……………………... 4.8g Typical Derating curve for Natural Convection 120% All Dimensions In Inches(mm) Tolerances : Inches millimeters X.XX±0.02 X.X±0.5 Pin ±0.002 ±0.05 100% LOAD(%) CASE SIP-8 DIMENSIONS: 80% 60% 0.44[11.1] 0.02 [0.5] 0.16 [4.1] 0.36[9.2] 0.14[3.5] 0.70 [17.8] 0.01 [0.3] 105 -20 0 20 40 60 Ambient Temperature(oC) PIN CONNECTION Single Dual Pin -V Input -V Input 1 2 +V Input +V Input 3 On/Off On/Off 5 NC NC 6 +V Output +V Output Common 7 -V Output 8 NC -V Output 0.10 [2.5] 5 6 7 8 3.3&5Vout 12&15Vout 40% 0% -40 Bottom View 65 20% 0.86 [21.8] 1 2 3 61 -40 0.08 [2.0] 0.02 [0.5] 2 80 100
EC4SAW-48D15N 价格&库存
很抱歉,暂时无法提供与“EC4SAW-48D15N”相匹配的价格&库存,您可以联系我们找货
