www.cincon.com
V17
EC3SBW SERIES
15 WATT 4:1 INPUT
DC-DC CONVERTERS
FEATURES
* 15W Isolated Output
* 1”x1”x0.4” Shielded Metal Case
* Efficiency to 88%
* 4:1 Input Range
* Regulated Outputs
* Fixed Switching Frequency
* Input Under Voltage Protection
* Over Current Protection
* Remote On/Off
* Continuous Short Circuit Protection
* Without Tantalum Capacitors inside
* Safety Meets IEC/EN/UL 62368-1
OUTPUT CURRENT
INPUT CURRENT
MODEL
NUMBER
INPUT
VOLTAGE
OUTPUT
VOLTAGE
MIN.
MAX.
NO LOAD
EC3SBW-24S33
EC3SBW-24S05
EC3SBW-24S12
EC3SBW-24S15
EC3SBW-24D05
EC3SBW-24D12
9-36 VDC
9-36 VDC
9-36 VDC
9-36 VDC
9-36 VDC
9-36 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
4000 mA
3000 mA
1250 mA
1000 mA
±1500 mA
±625 mA
60 mA
70 mA
30 mA
30 mA
30 mA
30 mA
EC3SBW-24D15
EC3SBW-48S33
EC3SBW-48S05
EC3SBW-48S12
EC3SBW-48S15
EC3SBW-48D05
EC3SBW-48D12
EC3SBW-48D15
9-36 VDC
18-75 VDC
18-75 VDC
18-75 VDC
18-75 VDC
18-75 VDC
18-75 VDC
18-75 VDC
±15 VDC
3.3 VDC
5 VDC
12 VDC
15 VDC
±5 VDC
±12 VDC
±15 VDC
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
0 mA
±500 mA
4000 mA
3000 mA
1250 mA
1000 mA
±1500 mA
±625 mA
±500 mA
30 mA
40 mA
40 mA
20 mA
20 mA
20 mA
20 mA
20 mA
NOTE: 1. Nominal Input Voltage 24 or 48 VDC
1
% CAPACITOR
EFF.
Load Max.
FULL LOAD
632 mA
718 mA
718 mA
710 mA
735 mA
718 mA
710 mA
313 mA
355 mA
359 mA
359 mA
368 mA
359 mA
359 mA
87
87
87
88
85
87
88
88
88
87
87
85
87
87
4000uF
3000uF
1250uF
1000uF
1500uF
625uF
470uF
4000uF
3000uF
1250uF
1000uF
1500uF
625uF
470uF
www.cincon.com
V17
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range ....……………...............………. 24V ................... 9 – 36V
48V ……..….... 18 – 75V
Input Surge Voltage (100ms max.) ……….……...… 24V …........ 50Vdc max.
48V .......... 100Vdc max.
Under voltage lockout …………….. 24Vin power up ….…….….……. 8.8V typ.
24Vin power down …….….……. 8.0V typ.
Efficiency ...........................................………….………............ See Table
Isolation Voltage .................................……………......... 1500 VDC min.
Isolation Resistance .....................…….…………………… 109 ohm min.
Isolation Capacitance ………………..…………..…………..… 1000pF typ.
Switching Frequency ............................……......................... 400KHz typ.
Operating Ambient Temperature Range ......…...…….... -40℃ to +85℃
48Vin power up ………..…….….. 17V typ.
Derating, Above 68℃ (note6) ……..…. Linearly to Zero Power at +105℃
48Vin power down ….……....... 16V typ.
Case Temperature (note4) ………………………………………….. 105℃
Input Filter ………………………………..………………..……………. LC Type
Positive Logic Remote on/off Control:
Cooling ………………………………………………… Natural Convection
Storage Temperature Range ...……..........……....…....... -55℃ to +125℃
Logic Compatibility ……….… CMOS or Open Collector TTL, Ref. to -Vin
Module On …………………….………… >+3.5 to 75VDC or Open Circuit
Module Off …………………………..………….……………. 0 to
很抱歉,暂时无法提供与“EC3SBW-24S15”相匹配的价格&库存,您可以联系我们找货
