EC3SBW-48D12
EC3SBW-48D12
    CINCON
    DIP6 模块
    隔离模块 直流转换器 2 输出 12V -12V 625mA,625mA 18V - 75V 输入
EC3SBW-48D12 数据手册
www.cincon.com V17 EC3SBW SERIES 15 WATT 4:1 INPUT DC-DC CONVERTERS ︳ FEATURES * 15W Isolated Output * 1”x1”x0.4” Shielded Metal Case * Efficiency to 88% * 4:1 Input Range * Regulated Outputs * Fixed Switching Frequency * Input Under Voltage Protection * Over Current Protection * Remote On/Off * Continuous Short Circuit Protection * Without Tantalum Capacitors inside * Safety Meets IEC/EN/UL 62368-1 OUTPUT CURRENT INPUT CURRENT MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE MIN. MAX. NO LOAD EC3SBW-24S33 EC3SBW-24S05 EC3SBW-24S12 EC3SBW-24S15 EC3SBW-24D05 EC3SBW-24D12 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 4000 mA 3000 mA 1250 mA 1000 mA ±1500 mA ±625 mA 60 mA 70 mA 30 mA 30 mA 30 mA 30 mA EC3SBW-24D15 EC3SBW-48S33 EC3SBW-48S05 EC3SBW-48S12 EC3SBW-48S15 EC3SBW-48D05 EC3SBW-48D12 EC3SBW-48D15 9-36 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA ±500 mA 4000 mA 3000 mA 1250 mA 1000 mA ±1500 mA ±625 mA ±500 mA 30 mA 40 mA 40 mA 20 mA 20 mA 20 mA 20 mA 20 mA NOTE: 1. Nominal Input Voltage 24 or 48 VDC 1 % CAPACITOR EFF. Load Max. FULL LOAD 632 mA 718 mA 718 mA 710 mA 735 mA 718 mA 710 mA 313 mA 355 mA 359 mA 359 mA 368 mA 359 mA 359 mA 87 87 87 88 85 87 88 88 88 87 87 85 87 87 4000uF 3000uF 1250uF 1000uF 1500uF 625uF 470uF 4000uF 3000uF 1250uF 1000uF 1500uF 625uF 470uF www.cincon.com V17 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....……………...............………. 24V ................... 9 – 36V 48V ……..….... 18 – 75V Input Surge Voltage (100ms max.) ……….……...… 24V …........ 50Vdc max. 48V .......... 100Vdc max. Under voltage lockout …………….. 24Vin power up ….…….….……. 8.8V typ. 24Vin power down …….….……. 8.0V typ. Efficiency ...........................................………….………............ See Table Isolation Voltage .................................……………......... 1500 VDC min. Isolation Resistance .....................…….…………………… 109 ohm min. Isolation Capacitance ………………..…………..…………..… 1000pF typ. Switching Frequency ............................……......................... 400KHz typ. Operating Ambient Temperature Range ......…...…….... -40℃ to +85℃ 48Vin power up ………..…….….. 17V typ. Derating, Above 68℃ (note6) ……..…. Linearly to Zero Power at +105℃ 48Vin power down ….……....... 16V typ. Case Temperature (note4) ………………………………………….. 105℃ Input Filter ………………………………..………………..……………. LC Type Positive Logic Remote on/off Control: Cooling ………………………………………………… Natural Convection Storage Temperature Range ...……..........……....…....... -55℃ to +125℃ Logic Compatibility ……….… CMOS or Open Collector TTL, Ref. to -Vin Module On …………………….………… >+3.5 to 75VDC or Open Circuit Module Off …………………………..………….……………. 0 to
EC3SBW-48D12 价格&库存
很抱歉,暂时无法提供与“EC3SBW-48D12”相匹配的价格&库存,您可以联系我们找货
