EC4BW07
EC4BW07
    CINCON
    DIP5 模块
    隔离模块 直流转换器 1 输出 3.3V 2A 9V - 36V 输入
EC4BW07 数据手册
V13 EC4BW SERIES ︳ 10 WATT 4:1 INPUT RANGE DC-DC CONVERTERS FEATURES * 10W Isolated Output * 2”x1” Six-Sided Shield Metal Case * Efficiency to 82% * 4:1 Input Range * Pi Input Filter * Continuous Short Circuit Protection * Meets EN55022 Class A, Conducted MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE EC4BW01 9-36 VDC 5 VDC EC4BW02 9-36 VDC EC4BW03 OUTPUT CURRENT INPUT CURRENT % EFF. CAPACITOR LOAD MAX. NO LOAD FULL LOAD 2000 mA 15 mA 534 mA 78 2000uF 12 VDC 830 mA 15 mA 520 mA 80 830uF 9-36 VDC 15 VDC 666 mA 15 mA 520 mA 80 666uF EC4BW04 9-36 VDC ±12 VDC ±415 mA 80 T.B.D. EC4BW05 ±15 VDC ±333 mA 20 mA 20 mA 520 mA 9-36 VDC 520 mA 80 T.B.D. EC4BW06 9-36 VDC ±5 VDC ±1000 mA 20 mA 520 mA 80 T.B.D. EC4BW07 9-36 VDC 3.3 VDC 2000 mA 15 mA 362 mA 76 2000uF EC4BW11 18-72 VDC 5 VDC 2000 mA 10 mA 260 mA 80 2000uF EC4BW12 18-72 VDC 12 VDC 830 mA 10 mA 257 mA 81 830uF EC4BW13 18-72 VDC 15 VDC 666 mA 10 mA 257 mA 81 666uF EC4BW14 18-72 VDC ±12 VDC ±415 mA 15 mA 257 mA 81 T.B.D. EC4BW15 18-72 VDC ±15 VDC ±333 mA 82 T.B.D. EC4BW16 ±5 VDC ±1000 mA 15 mA 15 mA 253 mA 18-72 VDC 253 mA 82 T.B.D. EC4BW17 18-72 VDC 3.3 VDC 2000 mA 10 mA 181 mA 76 2000uF NOTE: 1. Nominal Input Voltage 24 or 48VDC 1 V13 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....………….... 24V …………………….….…..….. 9-36V 48V …….…....………….…..…. 18-72V Input Surge Voltage (100ms max.) ……….….… 24V ……............ 50Vdc max. 48V ................. 100Vdc max. Input Filter ………………………………………………….……………..... Pi Type Efficiency ................................................................................... See Table Isolation Voltage ......................................................................… 500 VDC 9 Isolation Resistance ...............................................…….… 10 ohm min. Isolation Capacitance …………………..…………………..…… 500pF typ. Switching Frequency .............................................................. 300KHz typ. OUTPUT SPECIFICATIONS: Operating Ambient Temperature Range ……................... –25℃ to +71℃ Voltage Accuracy ………………....……………….......…………… ±1.0% max. De-rating, Above 71°C …….………….. Linearly to Zero power at 100°C Voltage Balance Dual Output at Full Load …………………..…… ±1.0% max. Transient Response Single 25% Step Load Change ………………………………..………
EC4BW07 价格&库存
很抱歉,暂时无法提供与“EC4BW07”相匹配的价格&库存,您可以联系我们找货
