BMR4810021/002
BMR4810021/002
    FLEX(伟创力)
    SMD20 模块
    隔离模块,数字 直流转换器 1 输出 1V 70A 40V - 60V 输入
BMR4810021/002 数据手册
Internal TABLE OF SPECIFICATION CONTENTS PRODUCT Prepared (also subject responsible if other) No. jidkzhou Kevin JID/Kevin ZhouZhou Approved BMR481 series JID/Kevin jidkzhou Kevin Zhou ZhouDirect Checked 1 (2) (5) 1/1301-BMR481 00152-BMR481 Technical Specification Date Rev Conversion 2021-5-10 3/16/2021 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Reference 28701-BMR481 revF D PA1 May 2022 © Flex Key Features • • • • • • • • Direct Conversion 48V to 1V single stage High efficiency – 92% @ 1V multi-phase Multi-phase design – up to 6 phases @ 70A each Small footprint o Main – 27.7mm x 12mm x 14mm (1.1” x 0.47” x 0.55”) o Satellite – 27.7mm x 12mm x 12.6mm (1.1” x 0.47” x 0.5”) Fast transient response Meets safety requirements per IEC/EN/UL 62368-1 PMBus 1.3 Compliant MTBF o Main – 8.7 million hours o Satellite – 9.7 million hours General Characteristics • • • • Configurable with PMBus Full configuration support with Flex Power Designer Full featured input/output telemetry Configurable protections o OV/UV o Overcurrent o Over temperature • Differential remote sense • ISO 9001/14001 certified supplier • Highly automated manufacturing ensures quality Safety Approvals Design for Environment Meets requirements in hightemperature lead-free soldering processes. Contents Ordering Information General Information Safety Specification Application Overview Connections Absolute Maximum Ratings ............................................................. 2 ............................................................. 2 ............................................................. 3 ............................................................. 5 ............................................................. 7 ........................................................... 13 Electrical Specification Main Main/Satellite BMR481 0021..................................... 13 BMR481 002x ..................................... 16 Parametric Information EMC Considerations PMBus Interface Operating Information Thermal Information PCB Layout Mechanical Information Soldering Information Delivery Information Product Qualification Specification PMBus Command Appendix ........................................................... 19 ........................................................... 24 ........................................................... 26 ........................................................... 30 ........................................................... 36 ........................................................... 37 ........................................................... 38 ........................................................... 40 ........................................................... 41 ........................................................... 43 ........................................................... 44 PRODUCT SPECIFICATION Prepared (also subject responsible if other) No. jidkzhou Kevin Zhou Approved Checked BMR481 series jidkzhou Kevin ZhouDirect 2 (5) 1/1301-BMR481 Technical Specification Date Rev Conversion 2021-5-10 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Reference 28701-BMR481 revF D 2 May 2022 © Flex Ordering Information Product program BMR4810021/002C BMR4810022C Function Main Satellite Product number and Packaging BMR481 n1n2n3n4/n5n6n7n8 / Options n1 n2 n 3 n4 Mounting x / xx Output Config n 5n 6n 7 / Package information / Compatibility with RoHS requirements xxx 0 0 Main – Open Frame, LGA Satellite – Open Frame, Box Pin n2n3 00 Vout = 1.0V, Iout = 70 A Vadjust range = 0.5 V to 1.35 V 1 2 n5n6n7 n8 x Description n1 n4 n8 / Config File (Main only) Options Satellite MTBF (mean value) for BMR481 series = 10.7 Mh MTBF at 90% confidence level = 9.7 Mh / x Functional Main MTBF (mean value) for BMR481 series = 9.6 Mh MTBF at 90% confidence level = 8.7 Mh Output 1 V / 70 A 1 V / 70 A Main Satellite 002 Single Main, AVSBus Vout Control C Antistatic tape and reel packaging The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and 2015/863 and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB, PBDE, DEHP, BBP, DBP, DIBP and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex Power products are found in the Statement of Compliance document. Flex Power fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Quality Statement Example: An open frame Main with LGA and Vout setpoint at 1.0V configured for single module operation would be BMR481 0021/002C 1) The “Main” configuration sets all PMBus registers for proper module operation. Application specific registers can be modified to customize the configuration to meet a wide variety of performance objectives. The configuration can be changed using the PMBus communication and stored in non-volatile memory. Customized configurations can be created as orderable parts and would be defined with an individual value for n5n6n7. The “002” part is configured for single phase operation with PMBus output voltage control. Please refer to additional details in this document for further definition of the “002” configuration. General Information Reliability The failure rate () and mean time between failures (MTBF= 1/) is calculated at max output power and an operating ambient temperature (TA) of +40°C. Flex Power uses Telcordia SR-332 Issue 4 Method 1 to calculate the mean steady-state failure rate and standard deviation (). Telcordia SR-332 Issue 4 also provides techniques to estimate the upper confidence levels of failure rates based on the mean and standard deviation. Mean steady-state failure rate, ( nFailures/h) Main - 104 Satellite - 93 Std. deviation,  ( nFailures/h) Main – 7.8 Satellite – 7.4 The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, Six Sigma, and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of the products. PRODUCT SPECIFICATION Prepared (also subject responsible if other) No. jidkzhou Kevin Zhou Approved BMR481 series jidkzhou Kevin ZhouDirect Checked 1/1301-BMR481 Technical Specification Date Rev Conversion 2021-5-10 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Warranty Warranty period and conditions are defined in Flex Power General Terms and Conditions of Sale. Limitation of Liability Flex Power does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex Power 2021 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex Power reserves the right to change the contents of this technical specification at any time without prior notice. 3 (5) Reference 28701-BMR481 revF D © Flex 3 May 2022 PRODUCT SPECIFICATION Prepared (also subject responsible if other) No. jidkzhou Kevin Zhou Approved BMR481 series jidkzhou Kevin ZhouDirect Checked 1/1301-BMR481 Technical Specification Date Rev Conversion 2021-5-10 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Safety Specification General information Flex Power DC/DC converters and DC/DC regulators are designed in accordance with the safety standards IEC 62368-1, EN 62368-1 and UL 62368-1 Audio/video, information and communication technology equipment Part 1: Safety requirements IEC/EN/UL 62368-1 contains requirements to prevent injury or damage due to the following hazards: • • • • • • Electrical shock Electrically-caused fire Injury caused by hazardous substances Mechanically-caused injury Skin burn Radiation-caused injury On-board DC/DC converters, Power interface modules and DC/DC regulators are defined as component power supplies. As components they cannot fully comply with the provisions of any safety requirements without “conditions of acceptability”. Clearance between conductors and between conductive parts of the component power supply and conductors on the board in the final product must meet the applicable safety requirements. Certain conditions of acceptability apply for component power supplies with limited stand-off (see Mechanical Information for further information). It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable safety standards and regulations for the final product. Component power supplies for general use shall comply with the requirements in IEC/EN/UL 62368-1. Product related standards, e.g. IEEE 802.3af Power over Ethernet, and ETS-300132-2 Power interface at the input to telecom equipment, operated by direct current (dc) are based on IEC/EN/UL 60950-1 with regards to safety. Flex Power DC/DC converters, Power interface modules and DC/DC regulators are UL 62368-1 recognized and certified in accordance with EN 62368-1. The flammability rating for all construction parts of the products meet requirements for V-0 class material according to IEC 60695-11-10, Fire hazard testing, test flames – 50 W horizontal and vertical flame test methods. Isolated DC/DC converters & Power interface modules The product may provide basic or functional insulation between input and output according to IEC/EN/UL 62368-1 (see Safety Certificate), different conditions shall be met if the output of a basic or a functional insulated product shall be considered as ES1 energy source. For basic insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the 4 (5) Reference 28701-BMR481 revF D 4 May 2022 © Flex following conditions is met: • The input source provides supplementary or double or reinforced insulation from the AC mains according to IEC/EN/UL 62368-1. • The input source provides functional or basic insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/EN/UL 62368-1. For functional insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the following conditions is met: • The input source provides double or reinforced insulation from the AC mains according to IEC/EN/UL 62368-1. • The input source provides basic or supplementary insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/EN/UL 62368-1. • The input source is reliably connected to protective earth and provides basic or supplementary insulation according to IEC/EN/UL 62368-1 and the maximum input source voltage is 60 Vdc. Galvanic isolation between input and output is verified in an electric strength test and the isolation voltage (Viso) meets the voltage strength requirement for basic insulation according to IEC/EN/UL 62368-1. It is recommended to use a slow blow fuse at the input of each DC/DC converter. If an input filter is used in the circuit the fuse should be placed in front of the input filter. In the rare event of a component problem that imposes a short circuit on the input source, this fuse will provide the following functions: • Isolate the fault from the input power source so as not to affect the operation of other parts of the system. • Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 1 (21) Specification Rev 28701-BMR481 revF E © Flex Application Overview Power supply system including one Main product and 0-5 Satellite products (in total 1-6 phases). Non-isolated solution. Complete isolated solution with included supplies for driver and controller voltages. 5 May 2022 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Fundamental Circuit Diagram - Main Fundamental Circuit Diagram – Satellite Rev 2 (21) Specification 28701-BMR481 revF E © Flex 6 May 2022 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 3 (21) Specification Rev 28701-BMR481 revF E 7 May 2022 © Flex Pin-Out Description Satellite Pin layout, top view. Pin Designation Type Function 1, 17 +IN Power Input voltage positive. 2, 16 -IN Power Input voltage negative. 3 START Input 4, 5, 13, 14 GND Power Power ground and digital ground. 6 TMN Output Temperature sense ground. Connect to common temperature sense ground TMN of Main. 7 TMP Output Temperature sense output. Connect to TMPx* input of Main. 8, 9, 10 VOUT Power Output voltage. 11 CSN Output Output current sense negative. Connect to CSNx* input of Main. 12 CSP Output Output current sense positive. Connect to CSPx* input of Main. 15 VCC Power Secondary side driver voltage supply. 18 PWMX Input 19 VDD Power 20 PWMY Input Secondary side synchronization input. Connect to STARTx* output of Main. Primary side PWM signal. Connect to PWMXx* output of Main (through digital isolator if isolation needed). Primary side driver voltage supply. References to -IN. Primary side PWM signal. Connect to PWMYx* output of Main (through digital isolator if isolation needed). ________________________________ Note 1. x = 2, 3, 4, 5 or 6 depending on satellite number in application. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 4 (21) Specification Rev 28701-BMR481 revF E 8 May 2022 © Flex Pin-Out Description Main Pin layout, top view. Pin Designation Type Function 1, 2, 41, 42 +IN Power Input voltage positive. 3-8, 35-40 -IN Power Input voltage negative. 9-16, 27-34 GND Power Output voltage ground and digital ground. 17 Reserved - 18 TMP1 Input 19-24 VOUT Power 25 CSN1 Input 26 CSP1 Input 43 PWMX Input 44 VDD Power 45 PWMY Input 46 Reserved - A1 PFAULT_IN Output A2 CSP6 Input Do not connect. Temperature sense input for Phase 1. Internally routed to Phase 1 power train in Main. For test purpose only. Do not connect. Output voltage. Output current sense negative for Phase 1. Internally routed to Phase 1 power train in Main. For test purpose only. Do not connect. Output current sense positive for Phase 1. Internally routed to Phase 1 power train in Main. For test purpose only. Do not connect. Primary side PWM signal to Phase 1 power train in Main. Connect to PWMX1 pin (through digital isolator if isolated application). Primary side driver voltage supply to Phase 1 power train in Main. References to -IN. Primary side PWM signal to Phase 1 power train in Main. Connect to PWMY1 pin (through digital isolator if isolated application). Do not connect. Analog signal output for internal testing. Connect to test point or leave floating. Output current sense input positive for Phase 6. Connect to CSP output of Satellite 5. If no Satellite 5, terminate CSP6 and CSN6 to a VOUT pin. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 5 (21) Specification Rev 28701-BMR481 revF E 9 May 2022 © Flex Pin Designation Type Function A3 CSP5 Input Output current sense input positive for Phase 5. Connect to CSP output of Satellite 4. If no Satellite 4, terminate CSP5 and CSP5 to a VOUT pin. A4 CSP4 Input Output current sense input positive for Phase 4. Connect to CSP output of Satellite 3. If no Satellite 3, terminate CSP4 and CSN4 to a VOUT pin. A5 CSP3 Input Output current sense input positive for Phase 3. Connect to CSP output of Satellite 2. If no Satellite 2, terminate CSP3 and CSN3 to a VOUT pin. A6 CSP2 Input Output current sense input positive for Phase 2. Connect to CSP output of Satellite 1. If no Satellite 1, terminate CSP2 and CSN2 to a VOUT pin. A7 FAULT A8 +S A9 -S B1 VSRMON Input B2 CSN6 Input B3 CSN5 Input B4 CSN4 Input B5 CSN3 Input B6 CSN2 Input B7 RST Input B8 SALERT B9 SADDR Input Address setting. Connect a resistor divider to VCC5/GND in order to define PMBus and VR12.5 / VR13 addresses (if applicable). See section PMBus Interface. C1 TMN Input Temperature sense input ground common for Main and Satellites. Connect to TMN of Satellites. If no Satellites, leave unconnected. C2 TMP6 Input Temperature sense input for Phase 6. Connect to TMP output of Satellite 5. If no Satellite 5, leave unconnected. C3 TMP5 Input Temperature sense input for Phase 5. Connect to TMP output of Satellite 4. If no Satellite 4, leave unconnected. C4 TMP4 Input Temperature sense input for Phase 4. Connect to TMP output of Satellite 3. If no Satellite 3, leave unconnected. Programmable fault indicator, active low. It is pulled low when any of the Output selected fault conditions are triggered. Pull-up to any external voltage Open drain equal or lower than VS. If not used leave floating. Output voltage positive sense. Connect to the positive side of the Input load to perform remote sense compensating for copper losses on the PCB. Route differentially with -S. Output voltage negative sense. Connect to the negative side of the Input load to perform remote sense compensating for copper losses on the PCB. Route differentially with +S. Input voltage monitoring and feed forward input. See section Input Voltage Sense. Output current sense input negative for Phase 5. Connect to CSN output of Satellite 4. If no Satellite 4, terminate CSPx and CSNx together to VOUT pins. Note 1, 2 Output current sense input negative for Phase 3. Connect to CSN output of Satellite 2. If no Satellite 2, terminate CSPx and CSNx together to VOUT pins. Note 1, 2 Output current sense input negative for Phase 2. Connect to CSN output of Satellite 1. If no Satellite 1, terminate CSPx and CSNx together to VOUT pins. Note 1, 2 Output current sense input negative for Phase 4. Connect to CSN output of Satellite 3. If no Satellite 3, terminate CSPx and CSNx together to VOUT pins. Note 1, 2 Output current sense input negative for Phase 6. Connect to CSN output of Satellite 5. If no Satellite 5, terminate CSPx and CSNx together to VOUT pins. Note 1, 2 Reset, active low. Puts the controller in the lowest power consumption state. Internally pulled high. Leave unconnected if unused. Output PMBus Alert. Asserted low when any of the configured protection Open drain mechanisms indicate a fault. If not used leave floating. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 6 (21) Specification 10 Rev 28701-BMR481 revF E May 2022 © Flex Pin Designation Type Function C5 TMP3 Input Temperature sense input for Phase 3. Connect to TMP output of Satellite 2. If no Satellite 2, leave unconnected. C6 TMP2 Input Temperature sense input for Phase 2. Connect to TMP output of Satellite 1. If no Satellite 1, leave unconnected. C7 EN Input Output voltage enable/CTRL pin. Can be left open if unused due to internal pull-up. See section Remote Control. C8 SCL Input PMBus Clock. Clock for PMBus communication. Requires a pull-up resistor, also when unused. See section PMBus Interface. C9 SDA D1 PUCDTI Input Optional microcontroller interface chip select. 5 V compatible. Connect to GND if unused. See section PuC Interface. D2 PUCCK Input Optional microcontroller interface clock. 5 V compatible. Connect to GND if unused. See section PuC Interface. D3 START2 Output Secondary side synchronization output for Phase 2/Satellite 1. If no Satellite 1 leave floating. D4 START3 Output Secondary side synchronization output for Phase 3/Satellite 2. If no Satellite 2 leave floating. D5 START4 Output Secondary side synchronization output for Phase 4/Satellite 3. If no Satellite 3 leave floating. D6 START5 Output Secondary side synchronization output for Phase 5/Satellite 4. If no Satellite 4 leave floating. D7 START6 Output Secondary side synchronization output for Phase 6/Satellite 5. If no Satellite 5 leave floating. D8 VR_RDY D9 SVCLK_AVSCLK Input Optional Intel domain VR1x serial bus clock or AVSBus clock. Connect to GND if unused. See sections SVID Interface and AVSBus Interface. E1 PUCDTO Output Optional microcontroller interface data output. 5 V compatible. If not used leave floating. See section PuC Interface. E2 PWM1Y Output Primary side PWMY output to Phase 1. Connect to PWMY pin (through digital isolator if isolated application). E3 PWM2Y Output Primary side PWMY output to Phase 2. Connect to PWMY pin of Satellite 1 (through digital isolator if isolated application). If no Satellite 1 leave floating. E4 PWM3Y Output Primary side PWMY output to Phase 3. Connect to PWMY pin of Satellite 2 (through digital isolator if isolated application). If no Satellite 2 leave floating. E5 PWM4Y Output Primary side PWMY output to Phase 4. Connect to PWMY pin of Satellite 3 (through digital isolator if isolated application). If no Satellite 3 leave floating. E6 PWM5Y Output Primary side PWMY output to Phase 5. Connect to PWMY pin of Satellite 4 (through digital isolator if isolated application). If no Satellite 4 leave floating. E7 PWM6Y Output Primary side PWMY output to Phase 6. Connect to PWMY pin of Satellite 5 (through digital isolator if isolated application). If no Satellite 5 leave floating. Input/ PMBus Data. Data signal for PMBus communication. Requires a pull-up Output resistor, also when unused. See section PMBus Interface. Open drain Output Power good or VR ready output. Pull-up to any external voltage Open drain equal or lower than VCTRL. If not used leave floating. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 7 (21) Specification 11 Rev 28701-BMR481 revF E May 2022 © Flex Pin Designation Type Function Input/ Optional Intel domain VR1x serial bus data or AVSBus master data. Connect Output to GND if unused. See sections SVID Interface and AVSBus Interface. Open drain E8 SVDAT_AVSMDAT E9 SVALRT_AVSSDAT F1 PUCCS Input F2 PWM1X Output Primary side PWMX output to Phase 1. Connect to PWMX pin (through digital isolator if isolated application). F3 PWM2X Output Primary side PWMX output to Phase 2. Connect to PWMX pin of Satellite 1 (through digital isolator if isolated application). If no Satellite 1 leave floating. F4 PWM3X Output Primary side PWMX output to Phase 3. Connect to PWMX pin of Satellite 2 (through digital isolator if isolated application). If no Satellite 2 leave floating. F5 PWM4X Output Primary side PWMX output to Phase 4. Connect to PWMX pin of Satellite 3 (through digital isolator if isolated application). If no Satellite 3 leave floating. F6 PWM5X Output Primary side PWMX output to Phase 5. Connect to PWMX pin of Satellite 4 (through digital isolator if isolated application). If no Satellite 4 leave floating. F7 PWM6X Output Primary side PWMX output to Phase 6. Connect to PWMX pin of Satellite 5 (through digital isolator if isolated application). If no Satellite 5 leave floating. F8 VR_HOT F9 PAD_ALERT G4 START1 Output Secondary side synchronization output to Phase 1. Internally routed to Phase 1 in Main. For test purpose only. Do not connect. G5 VCC Power Secondary side driver voltage supply to Phase 1 in Main. G6 VCTRL Power Controller supply. Output Optional Intel domain VR1x serial bus alert or AVSBus slave data. If not Open drain used leave floating. See sections SVID Interface and AVSBus Interface. Optional microcontroller interface chip select. 5 V compatible. Connect to GND if unused. See section PuC Interface. Input/ Intel Domain Voltage Regulator Hot, active low. Alarm signal being Output asserted when the temperature of one of the sensed Phases exceed the Open drain maximum programmed (TMAX). If not used leave floating. Input power sensor alert pin (pin_alert), active low. Can only be used if input Output power information is provided through the PuC interface. The threshold is set Open drain by command MFR_SVID_PIN_ALERT_THR. If not used leave floating. ________________________________ Note 1. x = 2, 3, 4, 5 or 6 depending on satellite number in application. Note 2. In the layout for the termination of CSP and CSN, pay special attention and terminate at the exact same point in order to eliminate any potential voltage drop. Keep termination lines as short as possible. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Rev 8 (21) Specification 12 28701-BMR481 revF E May 2022 © Flex Application Example Non-isolated application with one Main and one Satellite (2 phase system). ________________________________ Note 1. The optional use of SVID or AVSBus is dependent on the variant of product used and the specifications of the load. See section Additional Interfaces for more information. Note 2. Value of output capacitance will depend on the applicaion and load transient requirements. See section External Output Capacitors. Note 3. For PMBus pull-up resistor values, see section SMBus Interface. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. 9 (21) Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date Specification 13 Rev BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 28701-BMR481 revF May 2022 E © Flex Absolute Maximum Ratings Characteristics min TP1 Operating temperature (see Thermal Consideration section) TS Storage temperature VI max Unit -20 125 °C -40 125 °C Input voltage (See Operating Information Section for input and output voltage relations) -0.3 75 V VDD Primary side driver voltage -0.3 14 V VCC Secondary side driver voltage -0.3 7 V VCTRL Secondary side controller voltage -0.3 7 V Cout Output capacitance 470 Viso Isolation voltage (input to output qualification test voltage) 1500 Vdc Vtr Input voltage transient Signal I/O voltage typ µF TBD V PWMX, PWMY (Satellite inputs, referenced to -IN) -0.3 6 V CSN, CSP -0.3 4 V All other -0.3 7 V Ground voltage differential -S, GND -0.3 0.3 V Analog pin voltage VO, +S -0.3 4 V Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the Electrical Specification section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Configuration File (Main) The Main product is designed with a digital control circuit. The control circuit uses a configuration file which determines the functionality and performance of the product. The Electrical Specification table shows parameter values of functionality and performance with the Standard configuration, unless otherwise specified. The Standard configuration is designed for standalone Main product operation only. Changes in Standard configuration is required if adding additional external Satellites connected to the Main. Changes in Standard configuration might also be required to optimize performance in specific application. Electrical Specification – Control and Monitoring (Main) This section includes parameter specifications related to controller incorporated in the Main product. In the table below, PMBus commands for configurable parameters are written in capital letters. TP1 = -20 °C to +95 °C, VCTRL = 4.5 to 5.5 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25 °C, VCTRL = 5.0 V, unless otherwise specified under Conditions. Standard configuration. Single phase. Characteristics Conditions Power Good Threshold VR_RDY pin Turn-on input voltage From VCTRL > 4.2 V to ready to be enabled Turn on delay duration Delay duration range PMBus configurable, TON_DELAY Ramp duration Ramp duration range, PMBus configurable, DVID_SR_SLOW_STEP MFR_SVID_SLOW_SR_SELECTOR Rising Falling VI rising threshold VIon Turn-on input voltage range PMBus configurable VIN_ON TINIT Initialization Time TONdel Output voltage On Delay Time TONrise/ TOFFfall Output voltage On/Off Ramp Time (0-100%-0 of VO) min typ Standard config. max 12 ms 0 ms 0 127 1.3 0.02 ms ms 5.1 100 When output voltage disabled 0 0 Unit ms % VO V 60 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date Conditions UVLOVDD Under Voltage Lock-Out UVLOVCC Under Voltage Lock-Out UVLOVCTRL Under Voltage Lock-Out Remote Sense Protection Threshold 28701-BMR481 revF © Flex min VDD rising threshold Hysteresis VCC rising threshold Hysteresis VCTRL rising threshold Hysteresis +S vs VOUT pin -S vs GND pin Input Over Voltage Protection, IOVP Input Peak Protection Output voltage Under Voltage Protection, UVP Output voltage Over Voltage Protection, OVP Over Current Protection, OCP Over Temperature Protection, OTP Threshold range PMBus configurable VIN_UV_FAULT_LIMIT Set point accuracy Fault response Threshold VIN_UV_FAULT_RESPONSE Threshold range PMBus configurable VIN_OV_FAULT_LIMIT Set point accuracy Response time Fault response Threshold Offset threshold VIN_OV_FAULT_RESPONSE Offset threshold range PMBus configurable VOUT_UV_FAULT_LIMIT Fault response Offset threshold Offset threshold range Response time Fault response Peak OCP threshold Peak OCP threshold range Peak OCP response time Average OCP threshold Average OCP threshold range Average OCP warning threshold Average OCP warning threshold range Response time Fault response Threshold Threshold range Warning threshold Response time Fault response Input voltage Output voltage Monitoring accuracy Output current Temperature May 2022 E Threshold Input Under Voltage Protection, IUVP Specification 14 Rev BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Characteristics 10 (21) typ Standard config. 4.4 200 3.6 300 4.2 500 700 500 35 0 max 4.3 V mV V mV V mV mV mV V 60 V 4.1 125 Ignore (0x00) 65 0 mV V 70 125 Latch (0x80) 3.045 150 50 PMBus configurable VOUT_OV_FAULT_LIMIT Set value PMBus configurable IOUT_OC_FAULT_LIMIT 500 READ_VOUT, VO = 1.0 V READ_IOUT, VO = 1.0 V, VI = 40-60 V, IO > (0.25 x max IO) READ_TEMPERATURE, TREAD = 8 to +100 °C A A 0 500 A 400 us Latch (0x80) 130 25 C 130 Latch (0x80) 0.25 C C 115 400 OT_FAULT_RESPONSE READ_VIN, VI = 53 V A ns A 75 IOUT_OC_FAULT_RESPONSE PMBus configurable OT_FAULT_LIMIT PMBus configurable A 600 0 mV ns 150 80 Set value PMBus configurable IOUT_OC_WARN_LIMIT 400 0 mV mV 90 Latch (0x80) 86 VOUT_OV_FAULT_RESPONSE Set value PMBus configurable MFR_IMON, TEL_IOUT_FSR 400 50 us V mV Latch (0x80) 150 VOUT_UV_FAULT_RESPONSE V mV 400 VSRMON pin Unit us V 2.5 mV 3 % of value 3 C INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date VSENSE VIL VIH Input resistance Internal resistance to VOUT/GND Logic input low threshold Logic input high threshold RLO Logic output low resistance @ 5 mA VOL VOH IOL II_LEAK CI_PIN Logic output low signal level Logic output high signal level Logic output low sink current Logic input leakage current Logic input capacitance RI_PU Internal pull-up resistance to VCTRL RI_PD fSMB Internal pull-down resistance SMBus Operating frequency TBUF SMBus Bus free time tset thold SMBus SDA setup time from SCL SMBus SDA hold time from SCL Conditions 28701-BMR481 revF May 2022 E © Flex min typ Standard config. 64 1 max Unit 1.4 kΩ kΩ V 0.45 V 1.5 0.4 1.8 V V V 0.65 V 1.7 0.7 25 V V Ω 13 Ω 45 250 Ω mV V mA uA pF +S/-S SCL, SDA SVDAT_AVSMDAT, SVCLK_AVSCLK PUCCS, PUCDTI, RST EN SCL, SDA SVDAT_AVSMDAT, SVCLK_AVSCLK PUCCS, PUCDTI, RST EN SDA, SALERT SVDAT_AVSMDAT, SVALRT_AVSSDAT, PIN_ALERT, VR_HOT, VR_RDY FAULT PUCDO @ 5 mA PUCDO @ 1 mA Open drain outputs Specification 15 Rev BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Characteristics 11 (21) 125 4.5 20 1 10 SCL, SDA, SALERT, SVCLK_ASCLK, SVDAT_AVSMDAT, SVALRT_AVSSDAT EN, RST VSRMON No internal pull-up 10 10 10 STOP bit to START bit See section SMBus – Timing See section SMBus – Timing See section SMBus – Timing 400 kΩ kΩ kHz 1.3 µs 100 300 ns ns INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) 12 (21) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Specification 16 Rev 28701-BMR481 revF May 2022 E © Flex Electrical Specification – Main / Satellite BMR 481 002x (1.0V) TP1 = -20 °C to +95 °C, VI = 40 to 60 V, VDD = VCC = VCTRL = 5.0 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25 °C, VI = 53 V, VO = 1.0 V, max IO, unless otherwise specified under Conditions. Measurements made on Reference board ROA 170 014 P5A. Standard configurations used. External CIN = 1 x 47 μF OSCON (2 x 47 μF for multiphase) + 2 x 1 μF ceramic for each Main or Satellite. External COUT = 1 x 470 μF/3 mΩ POSCAP (5 x 470 μF for multiphase) + 20 x 10 μF ceramic. Characteristics VI VDD VCC VCTRL Conditions VOac fSW CI CO Input supply Primary side driver supply Secondary side driver supply Controller supply Default output voltage Output voltage adjustment range Output voltage set-point resolution Output voltage accuracy (including line, load, temp.) Line regulation Load regulation Output ripple & noise Switching frequency Main / Satellite internal input cap. Main / Satellite internal output cap. IO Output current (Main / Satellite) VO η PD η PD 5 5 5 1.0 0.5 VO ≤ 1.0 V VO > 1.0 V Unit 60 13 5.5 5.5 V V V V V V mV mV % VO mV mV mVp-p kHz nF μF 1.35 VO ≤ 1.0 V VO > 1.0 V IO = 0 - 100% VO = 1.0 V, 20 MHz BW TP1 = +25 °C, Note 1 VI = 0 V VO = 0 V max 520 5 10 1 1 1 2 730 600 300 1120 0 70 See Output Current Capability graph A Peak value VO = 1.0 V 91.6 IO = max IO VO = 1.0 V 88.8 % IO = max IO VO = 1.0 V 8.8 W No load VO = 1.0 V 1.7 W Efficiency Main + 5 Satellites Note 2 Power dissipation Main + 5 Satellites Note 2 Peak value VO = 1.0 V 92.0 % IO = max IO VO = 1.0 V 89.2 % IO = max IO VO = 1.0 V 50 W No load VO = 1.0 V 1.9 W Controller power dissipation (Main) IVDD VDD input current (Main / Satellite) VCC input current (Main / Satellite) IVCTRL 40 4.75 4.5 4.5 typ Standard config. Efficiency Main only Note 2 Power dissipation Main only Note 2 PCTRL IVCC min VCTRL input current (Main) Phase 1 active only For each added phase For each active phase VO = 1.0 V For each inactive phase For each active phase VO = 1.0 V For each inactive phase Phase 1 active only For each added phase Turned off with EN pin RST de-asserted 450 12 20 For VO ≠ 1.0 V, see graphs 6 60 For VO ≠ 1.0 V, see graphs 1 90 2.4 70 10 ________________________________ Note 1. Measurement from single unit. Note 2. Including VCC/VDD driver losses. Excluding controller power dissipation P CTRL. See figure below. % mW mW 22 mA mA 63 100 mA mA mA mA mA mA INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 13 (21) Specification 17 Rev 28701-BMR481 revF E May 2022 © Flex Driver losses included, controller losses excluded: PD = VI IVI + VDD IVDD + VCC IVCC − VO IO ŋ= VO IO PD + VO IO Driver and controller losses included: PTOT = PD +PCTRL ŋTOT = ŋ Calculation of efficiency and power dissipation. PD + VO IO PD +PCTRL + VO IO INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 14 (21) Specification 18 Rev 28701-BMR481 revF May 2022 E © Flex Typical Output Characteristics, VO = 1.0 V BMR 481 002x (1.0V) Multiphase, TP1=+25 °C, Standard configuration T P1=+25 °C Efficiency [%] 93.0 92.5 92.0 91.5 91.0 90.5 90.0 89.5 89.0 88.5 88.0 87.5 87.0 86.5 86.0 85.5 85.0 1 phase 2 phases 3 phases 4 phases 5 phases 6 phases 0 25 50 75 100 125 150 175 200 225 250 275 300 325 350 375 400 [A] 400 [A] Efficiency vs. load current and fixed number of phases. VI= 53 V. Driver losses included (VCC, VDD). Controller losses excluded (VCTRL). Efficiency [%] 93.0 92.5 92.0 91.5 91.0 90.5 90.0 89.5 89.0 88.5 88.0 87.5 87.0 86.5 86.0 85.5 85.0 Driver and controller losses excluded. Driver losses included. Controller losses excluded. Driver and controller losses included. 0 25 50 75 100 125 150 Efficiency vs. load current. 6-phase with phase shedding . VI= 53 V. 175 200 225 250 275 300 325 350 375 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. 15 (21) Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date Specification 19 Rev BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 28701-BMR481 revF May 2022 E © Flex BMR 481 002x (1.0V) Typical Output Characteristics, VO = 0.5 V Main only, TP1=+25 °C, Standard configuration Power Dissipation (PD) Efficiency (ŋ) [%] 90 [W] 8 89 7 88 VI 6 VI 5 87 40 V 40 V 4 86 48 V 85 53 V 84 60 V 83 48 V 3 53 V 2 60 V 1 0 82 0 7 14 21 28 35 42 49 56 63 0 70 [A] 7 14 21 28 35 42 49 56 63 70 [A] Efficiency vs. load current and input voltage. Driver losses included (VCC, VDD). Controller losses excluded (VCTRL). Dissipated power vs. load current and input voltage. Driver losses included (VCC, VDD). Controller losses excluded (VCTRL). Output Current Derating Output Ripple and Noise [A] 70 65 60 55 50 45 40 35 30 25 20 15 4.0 m/s 3.0 m/s 2.0 m/s 1.0 m/s 0.5 m/s 60 70 80 90 100 110 120 [°C] Available load current vs. ambient air temperature and airflow at VI= 53 V. See section Thermal Consideration. Full bandwidth, VI = 53 V, IO = max IO. COUT = 1 x 470 μF/3 mΩ POSCAP + 20 x 10 μF ceramic. Scale: 5 mV/div, 0.5 µs/div See section Output Ripple and Noise. VDD Input Current VCC Input Current [A] 0.020 [A] 0.055 0.050 0.018 0.045 0.016 40 V 48 V 0.014 40 V 0.040 48 V 0.035 53 V 60 V 0.012 53 V 0.030 60 V 0.025 0.010 0.020 0 10 20 30 40 50 VDD input current vs. load and input voltage. For each active phase. 60 70 [A] 0 10 20 30 40 50 VCC input current vs. load and input voltage. For each active phase. 60 70 [A] INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. 16 (21) Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date Specification 20 Rev BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 28701-BMR481 revF May 2022 E © Flex BMR 481 002x (1.0V) Typical Output Characteristics, VO = 0.75 V Main only, TP1=+25 °C, Standard configuration Power Dissipation (PD) Efficiency (ŋ) [%] 91 [W] 9 90 8 7 89 VI 88 87 86 85 40 V 5 40 V 48 V 4 48 V 3 53 V 2 60 V 53 V 84 VI 6 60 V 83 1 0 82 0 7 14 21 28 35 42 49 56 63 0 70 [A] Efficiency vs. load current and input voltage. Driver losses included (VCC, VDD). Controller losses excluded (VCTRL). 7 14 21 28 35 42 49 56 63 70 [A] Dissipated power vs. load current and input voltage. Driver losses included (VCC, VDD). Controller losses excluded (VCTRL). Output Ripple and Noise Full bandwidth, VI = 53 V, IO = max IO. COUT = 1 x 470 μF/3 mΩ POSCAP + 20 x 10 μF ceramic. Scale: 5 mV/div, 0.5 µs/div See section Output Ripple and Noise. VDD Input Current VCC Input Current [A] 0.020 [A] 0.080 0.018 0.070 0.016 40 V 0.060 40 V 48 V 0.014 53 V 60 V 0.012 0.010 48 V 0.050 53 V 60 V 0.040 0.030 0 10 20 30 40 50 VDD input current vs. load and input voltage. For each active phase. 60 70 [A] 0 10 20 30 40 50 VCC input current vs. load and input voltage. For each active phase. 60 70 [A] INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. 17 (21) Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date Specification 21 Rev BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 28701-BMR481 revF May 2022 E © Flex BMR 481 002x (1.0V) Typical Output Characteristics, VO = 1.0 V Main only, TP1=+25 °C, Standard configuration Power Dissipation (PD) Efficiency (ŋ) [%] 92 [W] 11 91 10 9 90 VI 89 88 40 V 8 VI 7 40 V 6 87 48 V 5 85 53 V 4 84 60 V 3 86 48 V 53 V 60 V 2 83 1 82 0 7 14 21 28 35 42 49 56 63 0 70 [A] 7 14 21 28 35 42 49 56 63 70 [A] Efficiency vs. load current and input voltage. Driver losses included (VCC, VDD). Controller losses excluded (VCTRL). Dissipated power vs. load current and input voltage. Driver losses included (VCC, VDD). Controller losses excluded (VCTRL). Output Current Derating Output Ripple and Noise [A] 70 65 60 55 50 45 40 35 30 25 20 15 4.0 m/s 3.0 m/s 2.0 m/s 1.0 m/s 0.5 m/s 40 50 60 70 80 90 100 110 [°C] Available load current vs. ambient air temperature and airflow at VI= 53 V. See section Thermal Consideration. Full bandwidth, VI = 53 V, IO = max IO. COUT = 1 x 470 μF/3 mΩ POSCAP + 20 x 10 μF ceramic. Scale: 5 mV/div, 0.5 µs/div See section Output Ripple and Noise. VDD Input Current VCC Input Current [A] 0.026 [A] 0.095 0.024 0.085 0.022 0.075 40 V 40 V 0.020 48 V 0.065 48 V 0.018 53 V 0.055 53 V 60 V 0.016 60 V 0.045 0.014 0.035 0 10 20 30 40 50 VDD input current vs. load and input voltage. For each active phase. 60 70 [A] 0 10 20 30 40 50 VCC input current vs. load and input voltage. For each active phase. 60 70 [A] INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. 18 (21) Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date Specification 22 Rev BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 28701-BMR481 revF May 2022 E © Flex BMR 481 002x (1.0V) Typical Output Characteristics, VO = 1.35 V Main only, TP1=+25 °C, Standard configuration Power Dissipation (PD) Efficiency (ŋ) [%] 93 [W] 11 92 10 9 91 VI 90 89 40 V 8 VI 7 40 V 6 88 48 V 5 86 53 V 4 85 60 V 3 87 48 V 53 V 60 V 2 84 1 83 0 7 14 21 28 35 42 49 56 63 0 70 [A] 7 14 21 28 35 42 49 56 63 70 [A] Efficiency vs. load current and input voltage. Driver losses included (VCC, VDD). Controller losses excluded (VCTRL). Dissipated power vs. load current and input voltage. Driver losses included (VCC, VDD). Controller losses excluded (VCTRL). Output Current Derating Output Ripple and Noise [A] 70 65 60 55 50 45 40 35 30 25 20 15 4.0 m/s 3.0 m/s 2.0 m/s 1.0 m/s 0.5 m/s 30 40 50 60 70 80 90 100 110 [°C] Available load current vs. ambient air temperature and airflow at VI= 53 V. See section Thermal Consideration. Full bandwidth, VI = 53 V, IO = max IO. COUT = 1 x 470 μF/3 mΩ POSCAP + 20 x 10 μF ceramic. Scale: 5 mV/div, 0.5 µs/div See section Output Ripple and Noise. VDD Input Current VCC Input Current [A] 0.029 [A] 0.110 0.027 0.100 0.025 0.090 40 V 40 V 0.023 48 V 0.080 48 V 0.021 53 V 0.070 53 V 60 V 0.019 60 V 0.060 0.017 0.050 0 10 20 30 40 50 VDD input current vs. load and input voltage. For each active phase. 60 70 [A] 0 10 20 30 40 50 VCC input current vs. load and input voltage. For each active phase. 60 70 [A] INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. Technical 2/1301-BMR 481 Uen KARALARS Andreas Larsson Approved (Document resp) Checked Date 19 (21) Specification 23 Rev BMR481 series Direct Conversion(KARTHOLM) 2021-11-10 DALGEDMO Gary Edmonds Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A 28701-BMR481 revF May 2022 E © Flex BMR 481 002x (1.0V) Typical Characteristics Main only, Standard configuration, TP1 = +25 °C Enable by EN pin Disable by EN pin EN EN VO VO VR_RDY VR_RDY Output enabled by EN pin. VI = 53 V, VO = 1.0 V, IO = max IO. VR_RDY pulled up to external voltage. Scale from top: 5, 0.5, 2 V/div, 0.5 ms/div. Output disabled by EN pin. VI = 53 V, VO = 1.0 V, IO = max IO. VR_RDY pulled up to external voltage. Scale from top: 5, 0.5, 2 V/div, 1 ms/div. Output Current Capability Switching Frequency [A] 71 [kHz] 1200 69 1100 67 VO 65 PID_LP_PRE = 85. PID_LP_POST = 25nSec/(25nSec + tPOST)*2^7; max 0x7F. E.g. tPOST = 50 ns => PID_LP_POST = 43. Format Integer Unsigned Integer Unsigned MFR_DUTY_PARAMETER (0xD9) Description: Used to configure TSTART Correction to control average Duty Cycle for the regulation in case of low VIN value. Through System register TON_RED_CONFIG[6], it is possible to disable phase shedding and enable all phases when input voltage is below the threshold (VOLTAGE_DUTY_ENABLE). Note. KDUTY duty cycle threshold is 8 bit wide and split between this command and MFR_KK_FEEDFRWD_GAIN_CTRL. Only for resonant topology. Bit 23:14 13:9 8:3 2:0 Function Vin voltage threshold (VOLTAGE_D UTY_ENABLE ) KDUTY Proportional coeff KDUTY Integrative coeff KDUTY Duty cycle threshold [2:0] Description Input voltage value below which the correction engages. [#of 0.125V steps]; max 127.875V. Format Fixed Point Unsigned Contains PID coefficient KDUTY_PROPORTIONAL. Max value is 0x1F. Integer Unsigned Contains PID coefficient KDUTY_INTEGRATIVE. Max value is 0x3F. Integer Unsigned kDUTY duty cycle [# of 0.195% Steps]; max = 50%, 0d = OFF. Duty cycle value above which the correction engages. 5 remaining bits are stored into MFR_KK_FEEDFRWD_CTRL. Integer Unsigned Unit V MFR_UNLOCK (0xDA) Description: Unlocks write AND read access to critical PMBus commands. Takes password as an argument. Needs WRITE_PROTECT to be set accordingly. Password can be changed by modifying UNLOCK_PWD SysReg and NVM accordingly. Unlocks the following PMBus commands: MFR_BODY_BRAKE_CONFIG, MFR_CS_PROP_INTEGR, MFR_DUTY_PARAMETER, MFR_FILT_PRE_POST, MFR_FSWITCH_PROTECT_COEFF, MFR_KK_FEEDFRWD_GAIN_CTRL, MFR_PID, MFR_T_START_PH_SHIFT_DELTA_DELAY, MFR_VEXT_NVM, MFR_SECT_L, MFR_SECT_H, MFR_SECT_RD, MFR_SECT_WR, MFR_MEMORY_WORD, MFR_MEMORY_RD, MFR_MEMORY_WR. Bit 39:0 Description Format Byte Array MFR_LOCK (0xDB) Description: Locks the access to Low Level commands. Needs WRITE_PROTECT to be set accordingly. MFR_FAULT_CONFIG (0xDC) Description: Used to set up the FAULT# pin behavior. 0b = The event do NOT trigger the FAULT# pin assertion. 1b = The event triggers the FAULT# pin assertion. Bit 10 Function PUC Error Description PUC Error. Value 1 0 Description Trigger enabled Trigger blocked INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 60 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 9 8 7 6 5 4 3 2 1 0 18 (42) No. Function Vin Over-Voltage Fault VSRMON peak fault Description Vin Over-Voltage Fault. Vout Over-Voltage Fault (HW) Iout Over-Current Fault (HW) Catastrophic Fault Vout Over-Voltage Fault (HW). Vput Over-Voltage Fault (HW) Pout Over-power Fault Feedback disconnection fault Vin Under-voltage Fault Over-Temperature Fault Vput over-voltage Fault (HW). Rev 28701-BMR481 revF B May 2022 © Flex Value 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 VSRMON pin peak fault. Iout Over-Current Fault (HW) Catastrophic Fault. Pout Over-power Fault. Feedback disconnection fault. Vin under voltage Fault. Over-temperature fault. Description Trigger enabled Trigger blocked Trigger enabled Trigger blocked Trigger enabled Trigger blocked Trigger enabled Trigger blocked Trigger enabled Trigger blocked Trigger enabled Trigger blocked Trigger enabled Trigger blocked Trigger enabled Trigger blocked Trigger enabled Trigger blocked Trigger enabled Trigger blocked MFR_IMON (0xDE) Description: Mfr Imon. Bit 5:0 Description Used to define RIMON/RG ratio from 2.678 to 174.120 in 64 steps; RIMON/RG = 2.678571 * (MFR_IMON + 1), RG=~560 Ohm. Peak OCP limit is impacted as PEAK_OCP = 2.1 / IMONx2 / DCReq / (RIMON/RG) where IMONx2 is given by System Register IMONX2 (OCP is triggered when the drop across RIMON reaches 2.1V). Impacts also READ_IOUT reporting. Format Fixed Point Unsigned MFR_STORE_MAP (0xDF) Description: Copies the entire RAM content (PMBus commands and system Register values) into NVM, calculating CRC accordingly. The payload data reflects the settings of WRITE_PROTECT and MFR_PROTECT_DEFAULT registers that the stored map will feature (in order to store a map write-protected). Bit 3:0 7:4 Function MFR_PROTE CT_DEFAULT payload WRITE_PROT ECT payload Description Format Fixed Point Unsigned Fixed Point Unsigned MFR_RESTORE_MAP (0xE0) Description: Restores the NVM content into RAM, as happens during device initial startup. MFR_CELL_CONFIG (0xE4) Description: Used to define the number of phases in design. Bit 2:0 Description Number of phases/modules in design. MFR_OV_LIMIT_OFFSET (0xE5) Description: MFR_OV_LIMIT_OFFSET. Value 000 001 010 011 100 101 Function 1 phase 2 phases 3 phases 4 phases 5 phases 6 phases Description Main only 1 Main + 1 Satellite. 1 Main + 2 Satellites. 1 Main + 3 Satellites. 1 Main + 4 Satellites. 1 Main + 5 Satellites. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 61 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 2:0 19 (42) No. Rev 28701-BMR481 revF May 2022 B © Flex Description Used to program the VOUT over voltage threshold as positive offset from 50mV (0x00) to 400mV (0x07) in 50mV steps. OV threshold is set above the commanded Vout setpoint, regardless of the voltage positioning offset (droop). Format Fixed Point Unsigned Unit ΔmV Format Fixed Point Unsigned Unit ΔmV Format Fixed Point Unsigned Unit V MFR_UV_LIMIT_OFFSET (0xE6) Description: MFR_UV_LIMIT_OFFSET. Bit 2:0 Description Used to program the VOUT under voltage threshold as negative offset from 50mV (0x00) to 400mV (0x07) in 50mV steps. UV threshold is set below the commanded setpoint considering the voltage positioning offset (droop). MFR_VBOOT_SET (0xE7) Description: MFR_VBOOT_SET. Bit 9:0 Description Used to define VBOOT to which the device regulate after receiving valid enable. [VID] data need to be compliant with format specified in VOUT_MODE. This is the default boot voltage in SVI Mode (Reg26h) and AVS Mode (when OPERATION is set accordingly). MFR_SVI_PMBUS_SELECT (0xE8) Description: Switch ON (0x01) or OFF (0x00) the Vout control on PMBus domain. In AVS mode this command is NACKed. Bit 0 Description [0]: 0b0 = CPU-Link / 0b1 = PMBus" Value 0 1 Function SVID Bus PMBus Description SVID CPU-Link PMBus MFR_ICC_MAX_ADD (0xE9) Description: Additional bytes to standard SVID commands. Formatted per CPU-link definition. LSB = 2A. Check HC_SUPPORT for further info. Bit 7:0 Description MFR_ICC_MAX_ADD [A]. Format Integer Unsigned MFR_PWR_IN_MAX_ADD (0xEA) Description: Additional bytes to standard SVID commands. Formatted per CPU-link definition. LSB = 4W. Check HC_SUPPORT for further info. Bit 7:0 Description MFR_PWR_IN_MAX_ADD [W]. Format Integer Unsigned MFR_PWR_IN_ALERT_ADD (0xEB) Description: Additional bytes to standard SVID commands. Formatted per CPU-link definition. LSB = 4W. Check HC_SUPPORT for further info. Bit 7:0 Description MFR_PWR_IN_ALERT_ADD [W]. Format Integer Unsigned MFR_READ_PIN_PUC (0xEF) Description: Used to read the Input Power communicated through PuC interface, value averaged over configured MFR_AVERAGE_TIME_SCALE. Bit 15:0 Description LSB=1W. Format Linear Unit W INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 62 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) 20 (42) No. Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Rev 28701-BMR481 revF May 2022 B © Flex MFR_READ_VIN_PUC (0xF0) Description: Used to read the Input voltage communicated through PuC interface, value averaged over configured MFR_AVERAGE_TIME_SCALE. Bit 15:0 Description LSB=0.125 V. Format Linear Unit V MFR_DPM1_THR (0xF1) Description: Sets the phase shedding; phase 1 to 2 threshold. Offset by DPM_OFFSET to compensate for current ripple. Realtime current used to increase # of phases, time averaged current used to reduce # of phases. Can be handled as Linear format when reading, and also when writing if bits(15:11) = exponent = -1 (0b11111). Bit 9:0 Description LSB weight is given by System Register IOUT_EXP. Format Fixed Point Unsigned Unit A MFR_DPM2_THR (0xF2) Description: Sets the phase shedding; phase 1 to 2 threshold. Offset by DPM_OFFSET to compensate for current ripple. Realtime current used to increase # of phases, time averaged current used to reduce # of phases. Can be handled as Linear format when reading, and also when writing if bits(15:11) = exponent = -1 (0b11111). Bit 9:0 Description LSB weight is given by System Register IOUT_EXP. Format Fixed Point Unsigned Unit A MFR_DPM3_THR (0xF3) Description: Sets the phase shedding; phase 1 to 2 threshold. Offset by DPM_OFFSET to compensate for current ripple. Realtime current used to increase # of phases, time averaged current used to reduce # of phases. Can be handled as Linear format when reading, and also when writing if bits(15:11) = exponent = -1 (0b11111). Bit 9:0 Description LSB weight is given by System Register IOUT_EXP. Format Fixed Point Unsigned Unit A MFR_DPM4_THR (0xF4) Description: Sets the phase shedding; phase 1 to 2 threshold. Offset by DPM_OFFSET to compensate for current ripple. Realtime current used to increase # of phases, time averaged current used to reduce # of phases. Can be handled as Linear format when reading, and also when writing if bits(15:11) = exponent = -1 (0b11111). Bit 9:0 Description LSB weight is given by System Register IOUT_EXP. Format Fixed Point Unsigned Unit A MFR_DPM5_THR (0xF5) Description: Sets the phase shedding; phase 1 to 2 threshold. Offset by DPM_OFFSET to compensate for current ripple. Realtime current used to increase # of phases, time averaged current used to reduce # of phases. Can be handled as Linear format when reading, and also when writing if bits(15:11) = exponent = -1 (0b11111). Bit 9:0 Description LSB weight is given by System Register IOUT_EXP. Format Fixed Point Unsigned Unit A MFR_FSWITCH_PROTECT_COEFF (0xF6) Description: Resonant Loop Only. Used to configure FSW protection during ACLL. Enabled/Disabled through sys reg DISABLE_DPM_PROT Bit 3:0 Description FSW_AVG computed as the average frequency of the previous [16 - FSW_AVGd] cycles. 0x01 = 15 cycles; 0x0F = 1 cycles; 0x00 = 0 cycles. Format Integer Unsigned INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 63 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) 21 (42) No. Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Rev 28701-BMR481 revF B May 2022 © Flex MFR_CS_PROP_INTEGR (0xF7) Description: Sets Proportional (Kp) and Integral (Ki) correction for Active Current Sharing. In resonant topologies: In order to enable the feature you need to set Ki to 1 or more. The higher value, the faster the regulator recovers current balancing after a load (or number of turned on phases) change. Leave Kp=0. Algorithm: when a phase current is less than average value of load/number of phases, then PWMx to START delay is increased. In non-resonant topologies (PSFB): In order to enable the feature you need to set Kp to 1 or more. The higher value, the faster the regulator recovers current balancing after load (or number of turned on phases) change. Leave Ki=0. Algorithm: when a phase current is less than average value of load/number of phases, then PWMx to PWMy time width is increased. Bit 13:7 6:0 Function Current Sharing Loop Ki Current Sharing Loop Kp Description Integral correction for active current sharing Format Integer Unsigned Proportional correction for active current sharing Integer Unsigned MFR_KK_FEEDFRWD_GAIN_CTRL (0xF9) Description: Setups Input Voltage Feed-Forward Compensation. It also allow to setup other parameters. K Feed Forward: It is the input voltage FeedForward Gain for resonant topologies. As default value, it is an integer number which value is =(Tsw_noload*VOUT/VIN*1000) where Tsw_noload is the switching period of one secondary phase at no load in uSeconds. KDUTY sets the duty cycle value above which the TSTART correction applies (See MFR_DUTY_PARAMETER). Note. kDUTY is 8 bit wide and split between this command and MFR_KK_FEEDFRWD_GAIN_CTRL. Enable Ph Order: Enables/disables phase order memory during load transients. V_ERR_CLAMP_SOFTSTART: Used to override ErrorClamp setting (active only during SoftStart). Enable Memory: Enables Pulse memory during ACLL. If the VCO drives more pulses during the current Pulse, these are memorized and fired after the current Pulse has elapsed. K_GAIN_CTRL. Defines the bandwidth of the feed forward loop. Bit 42:24 Function Feed Forward Constant 23:19 KDUTY Duty cycle threshold [7:3] Error clamp threshold at soft-start 15:10 7:0 Feed Forward Gain Bit 18 Function Enable Ph Order On 17 Enable Err Clamp Pre Enable Integrative During Phase Memory On Secure Off Enable Enable Memory 16 9 8 Description Feed forward constant, integer. As default value, calculate it as (Tsw_noload*VOUT/VIN*1000) where Tsw_noload is the switching period of one secondary phase at no load in useconds. For resonant topology only. kDUTY duty cycle [# of 0.195% Steps]; max = 50%, 0d = OFF. Duty cycle value above which the correction engages. 3 remaining bits are stored in MFR_DUTY_PARAMETER. During soft-start (Vout ramp-up) this setting overrides the error clamp setting by CTRL_VERR_CLAMP. LSB = 2mV. Error clamp threshold = 2mV * (63 - set value). Max 126mV (0x01). Set 128mV (0x00) to disable function. Sets K_GAIN_CTRL, the FeedForward Gain. Set to 0x01. Format Integer Unsigned Integer Unsigned Integer Unsigned Value 0xb1 0xb0 Function Description Enabled. Disabled. 0xb1 Enabled Enabled. 0xb1 Enabled Enabled. Secure Off Enable. Reserved, need to be 1 (enabled). Enables pulse memory during ACLL. 0xb1 Enable Secure Off enabled. 0xb0 mV Integer Unsigned Description Phase Order On Enable. 0x01 = Enable sequential; 0x00 = Disables Sequential (=Shuffle). Error Clamp Pre. Reserved, need to be 1 (enabled). Integrative During Phase Memory On Enable. Reserved, need to be 1 (enabled). 0xb1 Unit Pulse memory during ACLL enabled. Pulse memory during ACLL disabled. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 64 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) 22 (42) No. Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Rev 28701-BMR481 revF May 2022 B © Flex MFR_VOUT_TRIM (0xFA) Description: Mfr Vout Trim Bit 7:0 Description Sets Mfr VOUT trim value. Applies a fixed offset voltage to the value set by VOUT_COMMAND (in # of VID steps). [# of VID]. Applied only in PMBus Domain. # of VID steps to add or remove from setpoint. In AVS mode, if applied, need to be in tracking with EXTRA_OFFSET. Format Integer Signed Unit VID steps MFR_MANUAL_CELL_SHED (0xFB) Description: Sets DPM_NPH_PS00, DPM_NPH_PS01 and DPM_NPH_PS02 which are the minimum # of phases for Intel VR power states PS00, PS01 and PS02. Unless otherwise commanded by SVID interface, PS00 power state is used. If trying to set a min # phases higher than # of phases set by MFR_CELL_CONFIG, the write will have no effect and the Unsupported Data bit in STATUS_CML is set. Bit 9:6 Function OFFSET_FRA CT Description Optimizes PSKIP behavior Bit 12:10 Function Min # of phases (PS02SVID) Description Minimum # of phases for power state PS02 (Intel VR/SVID only). 5:3 Min # of phases (PS01SVID) Minimum # of phases for power state PS01 (Intel VR/SVID only). 2:0 Min # of phases (PS00) Minimum # of phases for power state PS00 (default). Format Integer Unsigned Value 001 010 011 100 101 110 001 010 011 100 101 110 001 010 011 100 101 110 Function Min 1 phase Min 2 phases Min 3 phases Min 4 phases Min 5 phases Min 6 phases Min 1 phase Min 2 phases Min 3 phases Min 4 phases Min 5 phases Min 6 phases Min 1 phase Min 2 phases Min 3 phases Min 4 phases Min 5 phases Min 6 phases Description MFR_SVID_TEMPZONE (0xFE02) Description: SVID Temperature Zone Register (reg12h). Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 7:0 Description Format Integer Unsigned MFR_SVID_IOUT (0xFE03) Description: SVID Output Current Register (reg15h). Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 7:0 Description Format Integer Unsigned MFR_SVID_VIDSETTING (0xFE04) Description: Last VID code commanded, i.e. actial regulation setpoint. Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 9:0 Description Format Integer Unsigned INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 65 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) 23 (42) No. Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Rev 28701-BMR481 revF B May 2022 © Flex MFR_SVID_PWRSTATE (0xFE05) Description: Last PWRState Commanded. Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 7:0 Description Format Integer Unsigned MFR_SVID_OFFSET (0xFE06) Description: SVID Commanded Offset (reg33h). See System Register CRC_SPI_EN for additional information. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 7:0 Description Format Integer Unsigned MFR_START_THREAD (0xFE07) Description: When sent, IC starts to compute the total power delivered. Average Power delivered in 1.2 mSec interval is progressively added until the max time programmed T_THREAD = 1.2mSec * MFR_START_THREAD" Bit 19:0 Description Number of 1 mSec interval to collect the measure on. Max 1,048,576 => 20.97min. Unit in ms. Format Fixed Point Unsigned Unit ms MFR_SVID_ICCMAX (0xFE08) Description: ICCMAX Register (reg21h). This is not linked to OC protection in any way. Write unlocked by MFR_SVID_REGLOCK Bit 7:0 Description Format Integer Unsigned MFR_SVID_TEMPMAX (0xFE09) Description: TMAX Register (reg22h). This is not linked to OT protection in any way. Write unlocked by MFR_SVID_REGLOCK. Bit 7:0 Description Format Integer Unsigned MFR_SVID_SRFAST (0xFE0A) Description: Slew Rate Fast (reg24h). Write unlocked by MFR_SVID_REGLOCK. This is for CPU-Link reading only. Actual slew rate is set through System Register DVID_SR_FAST_STEP. Bit 7:0 Description Format Integer Unsigned MFR_SVID_SRSLOW (0xFE0B) Description: Slew Rate Slow (reg25h). Write unlocked by MFR_SVID_REGLOCK. This is for CPU-Link reading only. Actual slew rate is set through System Register DVID_SR_SLOW_STEP. Bit 7:0 Description Format Integer Unsigned MFR_SVID_MULTI_VR_CONFIG (0xFE0C) Description: SVID Multi VR Config (reg34h). Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 1:0 Description MFR_SVID_VOUTMAX (0xFE0D) Description: VOUTMAX (reg30h). Write unlocked by MFR_SVID_REGLOCK Format Integer Unsigned INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 66 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 7:0 24 (42) No. Rev 28701-BMR481 revF May 2022 B © Flex Description Formatted as per CPU-Link definition Format Integer Unsigned Unit V MFR_SVID_SLOW_SR_SELECTOR (0xFE0E) Description: Select SVID SR Slow range as fraction of SVID SR Fast range. Write unlocked by MFR_SVID_REGLOCK. It affects real slew rate as programmed by System Registers DVID_SR_FAST_STEP and DVID_SR_SLOW_STEP. Setting of VR13.1 HC options. Bit 7 Function Enable HC support 6 Activate HC Description Configures VR13.HC support Can only be written directly to NVM, read-only in RAM! 0b0: VR13 Protocol support. Exponent for Iout and Pout read/settings and TEL_IOUT_FSR is set by IOUT_EXP. Registers PWR_IN_MAX_ADD and PWR_IN_ALERT_ADD are ignored. 0b1: VR13.HC Protocol support. Iout exponent = -1 (LSB=0.5A), Pout exponent = 1 (LSB=2W), TEL_IOUT_FSR exponent = 1 (LSB=2A), regardless of HC active or not. Registers PWR_IN_MAX_ADD and PWR_IN_ALERT_ADD are supported according to VR13.HC specs. The following commands are affected by the exponent setting: IOUT_OC_FAULT_LIMIT. IOUT_OC_WARN_LIMIT. POUT_OP_FAULT_LIMIT. READ_IOUT. READ_POUT. MFR_DPM1_THR. MFR_DPM2_THR. MFR_DPM3_THR. MFR_DPM4_THR. MFR_DPM5_THR. MFR_READ_PIN_POUT. TEL_IOUT_FSR. DPM_HYSTERESIS. Value 1 1 Function HC supported Description HC supported HC activated INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 67 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit Function 3:0 Slow vs fast slew rate range FRACTION 25 (42) No. Description Pre-sets the HC_ACTIVE bit supposed to be commanded through the SVI interface. Can only be written directly to NVM, read-only in RAM! 0b0: HC mode not active. The device behaves as a VR13 controller. -> DEFAULT. ICCMAX = MFR_SVID_ICCMAX [A]. PIN_MAX = MFR_SVID_PIN_MAX*2 [W]. PIN_ALERT_THRESHOLD = MFR_SVID_PIN_ALERT_THR*2 [W]. 0b1: HC mode active. ICCMAX = MFR_SVID_ICCMAX + MFR_ICC_MAX_ADD*2 [A]. PIN_MAX = MFR_SVID_PIN_MAX*2 + MFR_PWR_IN_MAX_ADD*4 [W]. PIN_ALERT_THRESHOLD = MFR_SVID_PIN_ALERT_THR*2 + MFR_PWR_IN_ALERT_ADD*4 [W]. 0x01 = 1/2; 0x02 = 1/4; 0x04 = 1/8; 0x08 = 1/16 Others are rejected" Rev 28701-BMR481 revF May 2022 B © Flex Value 0 Function 0x01 0x02 0x04 0x08 1/2 1/4 1/8 1/16 Description HC not activated MFR_SVID_PIN_MAX (0xFE0F) Description: PINMAX (reg2Eh). Used to set the PIN protection threshold. Set threshold to max allowable to disable the protection. Write unlocked by MFR_SVID_REGLOCK. Formatted per CPU-link definition. LSB = 2W. Bit 7:0 Description Format Integer Unsigned MFR_SVID_PIN_ALERT_THR (0xFE10) Description: Used to set the PIN protection ALERT threshold. Set threshold to max allowable to disable the warning signal. Write unlocked by MFR_SVID_REGLOCK. Formatted per CPU-link definition. LSB = 2W. Bit 7:0 Description Format Integer Unsigned MFR_SVID_WP0 (0xFE11) Description: SVID Working point #0 (reg3Ah). Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 7:0 Description Format Integer Unsigned MFR_SVID_WP1 (0xFE12) Description: SVID Working point #1 (reg3Bh). Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 7:0 Description Format Integer Unsigned MFR_SVID_WP2 (0xFE13) Description: SVID Working point #2 (reg3Ch). Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 68 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 7:0 26 (42) No. Rev 28701-BMR481 revF May 2022 B © Flex Description Format Integer Unsigned MFR_SVID_WP3 (0xFE14) Description: SVID Working point #3 (reg3Dh). Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 7:0 Description Format Integer Unsigned MFR_SVID_WP4 (0xFE15) Description: SVID Working point #4 (reg3Eh). Not stored in NVM. Formatted as per CPU-link definition. Write unlocked by MFR_SVID_REGLOCK. Bit 7:0 Description Format Integer Unsigned MFR_RD_TEMPERATURE_PHASE1 (0xFE16) Description: Reads the temperature for Phase 1. Reporting is active only when Phase 1 is switching. Bit 15:0 Description Phase 1 temperature. Format Linear Unit °C Format Linear Unit °C Format Linear Unit °C Format Linear Unit °C Format Linear Unit °C Format Linear Unit °C MFR_RD_TEMPERATURE_PHASE2 (0xFE17) Description: Reads the temperature for Phase 2. Reporting is active only when Phase 2 is switching. Bit 15:0 Description Phase 2 temperature. MFR_RD_TEMPERATURE_PHASE3 (0xFE18) Description: Reads the temperature for Phase 3. Reporting is active only when Phase 3 is switching. Bit 15:0 Description Phase 3 temperature. MFR_RD_TEMPERATURE_PHASE4 (0xFE19) Description: Reads the temperature for Phase 4. Reporting is active only when Phase 4 is switching. Bit 15:0 Description Phase 4 temperature. MFR_RD_TEMPERATURE_PHASE5 (0xFE1A) Description: Reads the temperature for Phase 5. Reporting is active only when Phase 5 is switching. Bit 15:0 Description Phase 5 temperature. MFR_RD_TEMPERATURE_PHASE6 (0xFE1B) Description: Reads the temperature for Phase 6. Reporting is active only when Phase 6 is switching. Bit 15:0 Description Phase 6 temperature. MFR_CTRL_ID (0xFE1C) Description: Used to read controller internal reference code. Bit 15:0 Description Used to read controller internal reference code. Format Byte Array INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 69 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) 27 (42) No. Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Rev 28701-BMR481 revF May 2022 B © Flex MFR_SVID_REGLOCK (0xFE1E) Description: CPU-Link registers are by default accessible only with read operations (locked). This command allows to lock (0x01) or unlock (0x00) access to these registers. This command is not stored in NVM but will be set to lock state (0x01) efter a RESTORE from NVM command (e.g. MFR_RESTORE_MAP). Bit 0 Description Value 1 0 Description Protects SVID Registers Unprotects SVID Registers MFR_SECT_L (0xFE20) Description: 8 bytes low sector image data - Used to access read NVM data after writing MFR_SECT_RD or to write NVM data before writing MFR_SECT_WR. [63..56] = byte 00 ... [7..0] = byte 07. Bit 63:0 Description Format Integer Unsigned MFR_SECT_H (0xFE21) Description: 8 bytes high sector image data - Used to access read NVM data after writing MFR_SECT_RD or to write NVM data before writing MFR_SECT_WR. [63..56] = byte 08 ... [7..0] = byte 15. Bit 63:0 Description Format Integer Unsigned MFR_SECT_RD (0xFE24) Description: Copy from specified NVM sector (0x01 to 0x0E) into a register accessible by PMBus commands MFR_SECT_L and MFR_SECT_H. Bit 7:0 Description Format Integer Unsigned MFR_SECT_WR (0xFE25) Description: Copy from register written by PMBus commands MFR_SECT_L and MFR_SECT_H into specified NVM sector (0x01 to 0x0E). Bit 7:0 Description Format Integer Unsigned MFR_MEMORY_WORD (0xFE26) Description: 8 bytes - Data for read/write of specified RAM memory location (used by MFR_MEMORY_RD or MFR_MEMORY_WR). [63..56] = Base Address +7 ... [7..0] = Base Address as specified into MFR_MEMORY_RD, MFR_MEMORY_WR. Bit 63:0 Description Format Integer Unsigned MFR_MEMORY_RD (0xFE27) Description: 3 bytes - Used to copy 8 bytes of the specified RAM memory location into PMBusTM accessible register, read by MFR_MEMORY_WORD. Byte 1 [7:0] : RAM address low byte. Byte 2 [15:8]: RAM address high byte. Byte 3 [23:16]: Source. 0x00 to read from RAM. Other combinations are reserved. Protected by MFR_UNLOCK. Bit 23:0 Description Format Integer Unsigned INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 28 (42) No. Technical Specification 70 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Rev 28701-BMR481 revF May 2022 B © Flex MFR_MEMORY_WR (0xFE28) Description: "4 bytes - Used to copy the content of PMBusTM accessible registers, written to MFR_MEMORY_WORD, into the specified RAM memory location. Byte 1 [7:0] : RAM address low byte. Byte 2 [15:8] : RAM address high byte. Byte 3 [23:16]: Source. 0x00 to read from RAM. Other combinations are reserved. Byte 4 [31:24]: Number of bytes to be written, 1 to 8. Other combinations are reserved. Protected by MFR_UNLOCK. Bit 31:0 Description Format Integer Unsigned MFR_READ_BLACKBOX (0xFE29) Description: NVM BBR Access. Used to copy the content of NVM that contains BBR data into accessible PMBusTM register MFR_BLACKBOX. MFR_BLACKBOX (0xFE2A) Description: NVM BBR Access - Shadow register containing the BBR NVM Sector being read. Status Register array is reported before and after the BBR trigger. Bit 125 124 123 122 121 120 115 114 113 112 110 103 102 101 100 99 98 97 96 Function After trigger VSRMON peak fault After trigger PATCH_DOWNLOA D After trigger MEM_FAULT After trigger POUT_OP_FAULT After trigger DATACMD_RCV_FA ULT After trigger IOUT_OC_WARN After trigger CATASTROPHIC_FA ULT After trigger VIN_UV_FAULT After trigger VIN_OV_FAULT After trigger PUC_CRC_FAULT After trigger CURR_SHARE_WAR N After trigger - OFF After trigger VOUT_OV_FAULT After trigger VOUT_UV_FAULT After trigger IOUT_OC_FAULT After trigger Feedback disconnection After trigger VOUT_MAX_WARNI NG After trigger OT_FAULT Description Value 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 Description INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 71 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 93 92 91 90 89 88 83 82 81 80 78 71 70 69 68 67 66 65 64 Function After trigger OT_WARNING Before trigger VSRMON peak fault Before trigger PATCH_DOWNLOA D Before trigger MEM_FAULT Before trigger POUT_OP_FAULT Before trigger DATACMD_RCV_FA ULT Before trigger IOUT_OC_WARN Before trigger CATASTROPHIC_FA ULT Before trigger VIN_UV_FAULT Before trigger VIN_OV_FAULT Before trigger PUC_CRC_FAULT Before trigger CURR_SHARE_WAR N Before trigger - OFF 29 (42) No. Description Rev 28701-BMR481 revF B May 2022 © Flex Value 1 Description 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 Before trigger VOUT_OV_FAULT Before trigger VOUT_UV_FAULT Before trigger IOUT_OC_FAULT Before trigger Feedback disconnection Before trigger VOUT_MAX_WARNI NG Before trigger OT_FAULT Before trigger OT_WARNING 0 1 0 1 0 1 MFR_CLEAR_BB (0xFE2B) Description: Clear the content of NVM that contains BBR data. MFR_CONFIG_BBR (0xFE2C) Description: "Select which events trigger the writing of the BBR in NVM. Set 1b to enable event to trigger BBR, 0b to disable." Bit 11 Function PUC_CRC_FAULT 10 Feedback disconnection fault VSRMON peak fault 9 Description Value 0 1 0 1 0 1 Description Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 72 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 8 Function VOUT_OV 7 IOUT_OC 6 2 CATASTROFIC FAULT VOUT Under Voltage Fault Over Output Power Fault Current Sharing Unbalance Warning VIN OV Fault VIN Over Voltage Fault 1 VIN UV Fault VIN Under Voltage Fault 0 Over Temperature Fault Over Temperature Fault 5 4 3 30 (42) No. Description Rev 28701-BMR481 revF May 2022 B © Flex Value 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 Description Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault Do not trigger on fault Trigger event on fault MFR_PROTECT_DEFAULT (0xFE2E) Description: Protects non volatile memory from writing by inhibiting commands STORE_DEFAULT_ALL and MFR_STORE_MAP. In case, the PMB_ALRT# signal is asserted and “other ML flag” bit is STATUS_CML register is set. 0x00 = Unprotected; 0x01 = Protected. Bit 0 Description [7:1]: Don't Care [0]: 0b0 = Unprotected; 0b1 = Protected Value 0 1 Description Unprotected Protected MFR_POUT_THREAD (0xFE2F) Description: When sent, stops the computation started with MFR_START_THREAD and returns the total energy delivered in the programmed time (max 1GW). Bit 31:0 Description LSB weight is given by System Register IOUT_EXP. Format Integer Unsigned Unit Wms MFR_PMBUSCFG_REVISION (0xFE30) Description: Can be used for user/custom data. Bit 15:0 Description Can be used for user/custom data. Format Byte Array MFR_PMBUSCFG_TIMESTAMP (0xFE31) Description: Contains product number and revision information. Example: For product number BMR 481 0021/031B R2C the fields will be: BMR number = 4810021031. Preliminary revision = Not = 0. Product revision number = 2. Product revision letter = C. Bit 63:24 22:16 15:8 7:0 Function BMR number Product revision number Product revision letter Configuration revision Description Number 1-999 9999 999. Number 1-127 Format Integer Unsigned Integer Unsigned Letter ASCII coded ASCII Letter ASCII coded ASCII INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 73 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 23 Function Preliminary revision 31 (42) No. Rev 28701-BMR481 revF B May 2022 © Flex Description 0=Non-preliminary revision (e.g. R1A), 1=Preliminary revision (e.g. P1A) Value 0 1 Description Non-preliminary revision (e.g. R1A) Preliminary revision (e.g. P1A) MFR_PEAK_FAULT_RESPONSE (0xFE32) Description: Used to configure how to respond to a peak fault read through VSRMON pin. When enabled, fault is set if VSRMON pin > 3.045V. Bit 7:0 Description Describes the device interruption operation. For all modes set by bits [7:6], the device pulls SALERT low and sets the related fault bit in the status registers. Only 0x00 (Fault Ignored) and 0x80 (Latched) are implemented. Value 0x00 Function Ignore Fault 0x80 Latch Description Continue operation without interruption. Immediate and definite shutdown of output voltage until fault is cleared and the output voltage is re-enabled. MFR_PMBUSCFG_USERID (0xFE33) Description: Can be used for user/custom data. Bit 15:0 Description Can be used for user/custom data. Format Byte Array INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 74 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) 32 (42) No. Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Rev 28701-BMR481 revF May 2022 B © Flex System Registers Details CURRENT_SHARING_RESET (0xA408) Bit Function Description 5:0 Activation Activation threshold for current sharing reset. 0x00=126mV, 0x01=124mV, threshold 0x02=122mV, ... , 0x26=50 mV, ... , 0x3D=4mV, 0x3E=2mV, 0x3F=0 mV. Bit 7 Function Enable current sharing Reset 6 Correction division Description For resonant mode only. Enable Current sharing Reset. Needed in case of heavy load transient release to suddenly reduce the TSTART signal delay vs PWMx, in order to avoid secondary phases overvoltage. Adjusts the current sharing correction (dividing its correction /2 or /4) when the current sharing error exceeds a programmable threshold in order to optimize load release. Dividing correction for current sharing reset. HIGH_CURR_PROT_EN (0xA40B) Bit Function Description 7 Add 12.5 ns to Adds 12.5 ns to the base Tshift base Tshift correction set by correction MFR_T_START_PH_SHIFT_DEL TA_DELAY[35:31]. 6 Add 12.5 ns to Adds 12.5 ns to the base Tshift base Tshift set by MFR_T_START_PH_SHIFT_DEL TA_DELAY[8:0]. Cannot be 0 (do not add 12.5 ns) in Resonant application if NCHECKS = 0x00. Cannot be 1 (add 12.5 ns) in NonResonant PSFB if TPHASE_SHIFT = 0nSec or 25nSec. 5 Enable one GAIN_REDU_1PH_EN. Reduces Phase gain by 1/2 the control loop gain when reduction working in single phase. 4 Enable soft GAIN_REDU_SS_EN. Reduces start gain by 1/2 the control loop gain during reduction SoftStart. 3 Enable TGB hysteresis 2 Current Enables/disables current sharing sharing correction to be memorized when correction shedding phases. Reserved, set storage. to 0x01 (not stored). 1 AVSBus 0b0: EXP = -2; 0b1: EXP = -1 current monitor 0 Enable High Reserved, set to 0 (disabled). Current Protection AVS_CONFIG (0xA40D) Format Byte Array Value 0 1 Function Description Disable Enabled 0 1 Divide with 2 Divide with 4 Divide with 2. Divide with 4. Value 0 1 Function Description Do not add 12.5 ns Add 12.5 ns 0 1 Do not add 12.5 ns Add 12.5 ns 0 1 Disable Enabled 0 1 Disable Enabled 0 1 0 Disable Enabled 1 0 1 0 1 Correction stored Correction not stored EXP = -2 EXP = -1 EXP = -2 EXP = -1 Disable Enabled INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 75 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 3 Function SDATA release method 2 Do not produce response to wrong address 1 Do not produce status response 0 Do not produce interrupt over data line Description Controls when SDATA is released (open) at the end of a frame. 0x00: As per protocol at CLK edge (rising). 0x01: Data line release 1/2 CLK in advance (CLK falling edge). Controls the response to command with address that doesn’t match VRM address. 0x00: Response is produced; 0x01: No Response. Controls the production of status response frame and response to broadcast commands. 0x00: Response is produced; 0x01: No Response. Controls interrupt produced from the interface in case of OC OT on DAT line of the interface. 0x00: Interrupt is produced over data line; 0x01: No interrupt is produced. HIZ_HALFB_SYMMETRIC (0xA418) Bit Function Description 5 SFAS Current reading Chopper displacement Amplifiers Control. Configures which phase shift is applied once enabled by SFAS. Reserved, set to 0x01. 4 SFAS enable Current reading Chopper Amplifiers Control. Enables phase shifting between the clock of the six chopper amplifiers. Reserved, set to 0x01. 3 HiZ mode for PWM Value 0 1 1 0 Symmetric mode Bridge functionality Rev 28701-BMR481 revF B Function At CLK edge (per protocol) 1/2 CLK in advance Description Disable Enabled 0 1 Disable Enabled 0 1 Disable Enabled Value 0 1 Function 12.5 ns 25 ns 0 1 0 0 1 0 1 0 May 2022 © Flex 0 1 1 2 33 (42) No. Description _ _ Disabled Enabled PWMX/PWMY never HiZ PWMX/PWMY HiZ @ no operation Asymmetric Symmetric Full bridge Half bridge Soft-off _ _ _ _ _ _ Use the configured fall time (slew rate). INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 76 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit Function Immediate (HiZ) or softoff 34 (42) No. Description When set, immediate off (HiZ) is used rather than soft-off when the output voltage is disabled. When set, also forces immediate off for all protection shutdowns. Because, in some cases, even if the immediate OFF is configured by OPERATION, the device is defaulting the behavior to soft-off. Vout OVP and OV peak protections by default always make a soft-off even if the OPERATION configures immediate OFF. This removes these default; it overrides and forces a real HiZ when stopping the operations after a FAULT event. For Vin UV/OV, Vout UV, Iout OC, over power and over temperature protections immediate off (HiZ) is always used and this bit has no impact. CTRL_PFM_ENA_PS (0xB006) Bit Description 1:0 Enable the PFM working mode vs power state. Rev 28701-BMR481 revF B © Flex Value 1 Function Immediate off Description Turn off the output and stop transferring energy to the output as fast as possible. Value 00 Function PFM enabled in any PS PFM enabled in PS01-03 PFM enabled in PS02-03 PFM disabled Description 01 10 11 DPM_HYSTERESIS (0xB007) Bit Description 7:0 Used to define the hysteresis for Phase Shedding. DPM_OFFSET may optimize the hysteresis settings. LSB weight is given by System Register IOUT_EXP. DVID_SR_FAST_STEP (0xB00C) Bit Description 5:0 Programs the [# of 25nSec] to step VOUT by 5mV. This setting actively drives the reference slew. dV/dt = 5mV / (SR_FAST_STEP * 25nSec) Actual fast slew rate (mV/us) = 200 / DVID_SR_FAST_STEP[5:0]. [7:6]: Don't Care [5:0]: SR_FAST_STEP. Values accepted from 0x01 to 0x3F. If 0x00, wraps to 0x3F. May 2022 Value 0x01 0x02 0x03 0x04 0x05 0x06 0x07 0x08 0x09 0x0A 0x0B 0x0C 0x0D 0x0E 0x0F 0x10 0x11 0x12 0x13 0x14 Function 200 mV/us 100 mV/us 66.67 mV/us 50.00 mV/us 40.00 mV/us 33.33 mV/us 28.57 mV/us 25.00 mV/us 22.22 mV/us 20.00 mV/us 18.18 mV/us 16.67 mV/us 15.38 mV/us 14.29 mV/us 13.33 mV/us 12.50 mV/us 11.76 mV/us 11.11 mV/us 10.53 mV/us 10.00 mV/us Description Format Fixed Point Unsigned Unit A INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 77 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 35 (42) No. Description DVID_SR_SLOW_STEP (0xB00D) Bit Description 5:0 Programs the [# of 25nSec] to step VOUT by 5mV. This setting actively drives the reference slew. Data computed over MFR_SVID_SLOW_SR_SELECTOR. Actual slow slew rate (mV/us) = FRACTION x 200 / DVID_SR_SLOW_STEP[5:0] where FRACTION = 2 x MFR_SVID_SLOW_SR_SELECTOR[3:0]. [7:6]: Don't Care. [5:0]: SR_SLOW_STEP. Values accepted from 0x01 to 0x3F. If 0x00, wraps to 0x3F. Rev 28701-BMR481 revF B © Flex Value 0x15 0x16 0x17 0x18 0x19 0x1A 0x1B 0x1C 0x1D 0x1E 0x1F 0x20 0x21 0x22 0x23 0x24 0x25 0x26 0x27 0x28 0x29 0x2A 0x2B 0x2C 0x2D 0x2E 0x2F 0x30 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x3A 0x3B 0x3C 0x3D 0x3E 0x3F Function 9.52 mV/us 9.09 mV/us 8.70 mV/us 8.33 mV/us 8.00 mV/us 7.69 mV/us 7.41 mV/us 7.14 mV/us 6.90 mV/us 6.67 mV/us 6.45 mV/us 6.25 mV/us 6.06 mV/us 5.88 mV/us 5.71 mV/us 5.56 mV/us 5.41 mV/us 5.26 mV/us 5.13 mV/us 5.00 mV/us 4.88 mV/us 4.76 mV/us 4.65 mV/us 4.55 mV/us 4.44 mV/us 4.35 mV/us 4.26 mV/us 4.17 mV/us 4.08 mV/us 4.00 mV/us 3.92 mV/us 3.85 mV/us 3.77 mV/us 3.70 mV/us 3.64 mV/us 3.57 mV/us 3.51 mV/us 3.45 mV/us 3.39 mV/us 3.33 mV/us 3.28 mV/us 3.23 mV/us 3.17 mV/us Description Value 0x01 Function FRACTION x 200 mV/us FRACTION x 100 mV/us FRACTION x 66.67 mV/us FRACTION x 50.00 mV/us FRACTION x 40.00 mV/us FRACTION x 33.33 mV/us FRACTION x 28.57 mV/us Description 0x02 0x03 0x04 0x05 0x06 0x07 May 2022 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 78 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit Description 36 (42) No. Value 0x08 0x09 0x0A 0x0B 0x0C 0x0D 0x0E 0x0F 0x10 0x11 0x12 0x13 0x14 0x15 0x16 0x17 0x18 0x19 0x1A 0x1B 0x1C 0x1D 0x1E 0x1F 0x20 0x21 0x22 0x23 0x24 0x25 Rev 28701-BMR481 revF B © Flex Function FRACTION x 25.00 mV/us FRACTION x 22.22 mV/us FRACTION x 20.00 mV/us FRACTION x 18.18 mV/us FRACTION x 16.67 mV/us FRACTION x 15.38 mV/us FRACTION x 14.29 mV/us FRACTION x 13.33 mV/us FRACTION x 12.50 mV/us FRACTION x 11.76 mV/us FRACTION x 11.11 mV/us FRACTION x 10.53 mV/us FRACTION x 10.00 mV/us FRACTION x 9.52 mV/us FRACTION x 9.09 mV/us FRACTION x 8.70 mV/us FRACTION x 8.33 mV/us FRACTION x 8.00 mV/us FRACTION x 7.69 mV/us FRACTION x 7.41 mV/us FRACTION x 7.14 mV/us FRACTION x 6.90 mV/us FRACTION x 6.67 mV/us FRACTION x 6.45 mV/us FRACTION x 6.25 mV/us FRACTION x 6.06 mV/us FRACTION x 5.88 mV/us FRACTION x 5.71 mV/us FRACTION x 5.56 mV/us FRACTION x 5.41 mV/us Description May 2022 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 79 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit Description 37 (42) No. Value 0x26 0x27 0x28 0x29 0x2A 0x2B 0x2C 0x2D 0x2E 0x2F 0x30 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x3A 0x3B 0x3C 0x3D 0x3E 0x3F Rev 28701-BMR481 revF B May 2022 © Flex Function FRACTION x 5.26 mV/us FRACTION x 5.13 mV/us FRACTION x 5.00 mV/us FRACTION x 4.88 mV/us FRACTION x 4.76 mV/us FRACTION x 4.65 mV/us FRACTION x 4.55 mV/us FRACTION x 4.44 mV/us FRACTION x 4.35 mV/us FRACTION x 4.26 mV/us FRACTION x 4.17 mV/us FRACTION x 4.08 mV/us FRACTION x 4.00 mV/us FRACTION x 3.92 mV/us FRACTION x 3.85 mV/us FRACTION x 3.77 mV/us FRACTION x 3.70 mV/us FRACTION x 3.64 mV/us FRACTION x 3.57 mV/us FRACTION x 3.51 mV/us FRACTION x 3.45 mV/us FRACTION x 3.39 mV/us FRACTION x 3.33 mV/us FRACTION x 3.28 mV/us FRACTION x 3.23 mV/us FRACTION x 3.17 mV/us Description DVID_VAR_OFFSET_PARAM (0xB00E) Bit Function Description 47:42 RISE_FAST Offset can be added to the reference to compensate for the apparent offset Droop generated by dV/dt. Offset are expressed in # of VID_Step. Signed Integer. Offset [+/- # of 5mV Steps]. 41:36 RISE_SLOW Offset can be added to the reference to compensate for the apparent offset Droop generated by dV/dt. Offset are expressed in # of VID_Step. Signed Integer. Offset [+/- # of 5mV Steps]. Format Integer Signed Integer Signed INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 80 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 35:30 Function FALL_FAST offset 29:24 FALL_SLOW offset 23:10 Offset expiration TauDVID OC mask after DVID ends 9:0 Rev 28701-BMR481 revF B Description Offset can be added to the reference to compensate for the apparent Droop generated by dV/dt. Offset are expressed in # of VID_Step. Signed Integer. Offset [+/- # of 5mV Steps]. Offset can be added to the reference to compensate for the apparent Droop generated by dV/dt. Offset are expressed in # of VID_Step. Signed Integer. Offset [+/- # of 5mV Steps]. Offset application/removal time constant. LP_CONST = (25 * 2^14) / (25 + TauDVID[nSec]). [# of non-linear steps -> value[ns]= 25 *(1(LP_CONST/2^14)) / (LP_CONST/2^14)]. [9..0] = OCP_TAU = (TOCP-25nSec) / 100nSec. OC Disable TOCP after DVID ends. [# of 100nSec steps +25ns internal offset]. THERMAL_GAIN (0xB01A) Bit Description 7:0 Used to set T_COMP variable for Thermal Compensation of output current sense. T_COMP makes an adjustment of the correction factor that is ideal for copper, according to: Iinfo_TC = Iinfo x Kcorr = Iinfo x 1 / (1 + alfa x deltaT_DCR) = Iinfo x 1 / (1 + alfa x deltaT_NTC x T_COMP / 128) where alfa = 0.0039 and deltaT_NTC is calculated difference from Tmin, given by TEL_NTC_MAP_Q6. Thus, T_COMP is used to compensate for the temp difference between NTC-resistor and output inductor DCR. T_COMP = 128 means ideal correction alfa is used. Note that Kcorr must always be in the range 0.67 to 1.0, which limits the maximum deltaT_NTC that can be handled. TEL_IOUT_FSR (0xB01B) Bit Description 8:0 Defines the READ_IOUT monitoring ADC Full scale. Shall be set to match the peak OCP limit as defined by MFR_IMON. LSB weight is given by System Register IOUT_EXP. TEL_OFFSET_VIN (0xB027) Bit Function Description 10 Sign 1 = Positive 0 = Negative Number of 0.125V steps VSRMON ADC: Used to define the Offset correction for VIN monitoring over VSRMON when Opto Mode is Enabled. TEL_GAIN_IMON (0xB029) Bit Description 7:0 Sets the gain correction to be applied to IMON reading (both PMBus and CPU-Link). Computed at controller startup as TEL_GAIN_IMON_RAM adjusted per trimming calibration. Ranges linearly from 0 (0x00) to 2 (0xFF). Note. If modified, when MFR_STORE_MAP is issued, IC automatically stores into TEL_GAIN_IMON_RAM the RAW value adjusted per trimming calibration. SVI_ADDITIONAL_OFFSET (0xB02B) Bit Function Description 1:0 DPM # of 0x01 = NCELL=1 through 0x06 = NCELL=6. Other combinations are not phases PS2 supported. Configures the minimum number of operating phases in PS02. Bit 7 Function Description Value 0 May 2022 © Flex TEL_GAIN_VIN (0xB018) Bit Description 7:0 VSRMON ADC: Used to define the Gain correction for VIN monitoring over VSRMON when Opto Mode is Enabled. Ranges linearly from 0 (0x00) to 2 (0xFF). 0x80 = Gain = 1 shall be used for a 1/40 divider, which is the recommended configuration. VSRMON ADC range is 0 to 3.2V and VSRMON pin has an internal 10k pull-down resistor, thus a 1/40 divider is achieved by a 390k resistance to VIN. 9:0 38 (42) No. Function Format Integer Signed Integer Signed Integer Unsigned Integer Unsigned Format Integer Unsigned Format Fixed Point Unsigned Format Fixed Point Unsigned Unit A Format Integer Unsigned Integer Unsigned Unit V Format Fixed Point Unsigned Format Integer Unsigned Description Disable hiccup mode INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 81 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit Function Enable hiccup mode 6 IMON divider @ dynamic VID 5:4 IMON divider @ soft start 3 Enable soft bias current sense 39 (42) No. Description Enable hiccup fault response mode. When enabled, after a fault occurred, the controller reattempts to startup Vout after 1 mSec. When enabled, the hiccup fault response mode applies for the fault types that are enabled in MFR_FAULT_CONFIG. After a restart due to hiccup, the fault flag set in STATUS_WORD will be cleared. IMON divider in dynamic VID condition. Delivers reduced IMON current to the IMON resistor to prevent from false OC being trip. IMON divider in soft start transitions. Delivers reduced IMON current to the IMON resistor to prevent from false OC being trip. Enable soft bias to allow current sense below Vout 0.7V. Prevent damage at startup with short circuit for full bridge. Optimizes current reading amplifier biasing at low output voltages preventing saturation. Reserved, need to be 0b1 (enabled). VIN_FEED_FWD_SOURCE (0xB038) Bit Description 0 Used to define which input to be used for VIN FeedForward Compensation. 0x00 = Uses data from PuC. 0x01 = Uses data from VSRMON at secondary. Other combinations are not supported. Rev 28701-BMR481 revF B © Flex Value 1 Function Description Enable hiccup mode 0 1 IMON/2 IMON/4 Divide by 2. Divide by 4. 00 01 10 11 IMON IMON/2 IMON/4 IMON/8 Divide by 1. Divide by 2. Divide by 4. Divide by 8. 0 1 Disable Enable Value 00 01 Function PuC VSRMON at secondary Description Value 00 01 Function PuC VSRMON at secondary Description IOUT_VR125_PERC_EN (0xB03C) Bit Description 0 Used to define whether the IOUT reporting on reg15h is to be in percentage of ICCMAX (given by MFR_SVID_ICCMAX) or absolute value in Amperes. Value 0 1 Function Absolute in [A] % of ICCMAX Description VR13_TIME_FRAME (0xB040) Bit Description 0 Used to define averaging interval for VR1xx IMON reporting register. Update interval is always 100uSec while averaging can be programmed. Value 0 Function Averaging on 200 us Averaging on 100 us Description VIN_MONITORING_SOURCE (0xB039) Bit Description 0 Used to define which input to be used for VIN monitoring and Protection between PuC and VSRMON. VSRMON needs to be further configured. 0x00 = Uses data from PuC. 0x01 = Uses data from VSRMON at secondary. Other combinations are not supported. CTRL_VERR_CLAMP (0xB041) May 2022 1 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 82 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 5:0 Rev 28701-BMR481 revF B Description When the voltage regulation error increases above the “Unload” threshold, integrator stops to limit the overshoot at load release. LSB = 2mV. Error clamp threshold = 2mV * (63 - set value). Max 126mV (0x01). Set 128mV (0x00) to disable function. TGB_CONFIG (0xB046) Bit Function 7:2 TGB/NLR Load Threshold Function TGB/NLR Load Mode Value 0 1 Value 00 01 10 11 Function Disabled Enabled when # of phases >= 2 Enabled Enabled with 2x threshold when # of phases=1 Function Virtual Droop Timeframe Description Duration of Virtual Droop. Expires after this time has elapsed. 1:0 Virtual Droop Mode Virtual Droop slows the load transient response in order to keep the control loop (PID) in linear region, avoiding control loop saturation. Typically used in applications without voltage positioning (droop) since it adds a virtual voltage positioning. Virtual Droop reduces the regulation error (when overcoming the set threshold) for the programmed timeframe. Enabling Virtual Droop provides a load transient response worse than without Virtual Droop but it ensures a better response at high frequency load transients. Value 00 01 10 11 00 01 10 11 Function 0.8 us 1.6 us 2.4 us 3.2 us Disabled Enabled for load release Enabled for load apply + release Enabled for load apply + release with half timeframe Unit mV Format Fixed Point Unsigned Unit mV Format Fixed Point Unsigned Unit mV Description VDROOP_CONFIG (0xB047) Bit Function Description 5:2 Virtual Droop Activation threshold over Control Error (+/-). LSB = 4mV. Error Threshold Bit 1:0 Format Fixed Point Unsigned Description DPM Protection Enabled - # of phases reset in load transient DPM Protection Disabled - # of phases NOT reset in load transient Description LSB = 2mV, max 126mV (0b111111) Description Used to configure Transient Gain Boost to improve transient response. When the voltage regulation error decreases below the “Load” threshold, the control loop gain is doubled to limit the undershoot during load application. May 2022 © Flex DISABLE_DPM_PROT (0xB044) Bit Description 0 Used to disable DPM Protection that, during ACLL, increases the # of phases by 1 if instantaneous FSW gets greater than averaged FSW_AVG. FSW_AVG set by MFR_FSWITCH_PROTECT_COEFF in Resonant Loop while in Non Resonant Loop the comparison is made over the nominal FSW set. Trigger threshold changes with the number of active phases: # of active phases = 1 => Fthreshld = 2.00*FSW_AVG. # of active phases = 2 => Fthreshld = 1.50*FSW_AVG. # of active phases = 3 => Fthreshld = 1.33*FSW_AVG. # of active phases = 4 => Fthreshld = 1.25*FSW_AVG. # of active phases = 5 => Fthreshld = 1.20*FSW_AVG. Bit 1:0 40 (42) No. Description INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 41 (42) No. Technical Specification 83 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Rev 28701-BMR481 revF B © Flex TON_RED_CONFIG (0xB04A) Bit Function Description 1:0 ZCDM offset Used to set an offset on ZCD to optimize PFM (not for Phase 1 which uses ZCD1_OFFSET). Offset in [uA], how this is translated into [A] on inductor ripple depends on the real application implemented. 0x03 = 2.4uA ; 0x02 = 4uA; 0x01 = 5.6uA; 0x00 = 7.2uA. Other combinations are not supported. Bit 7 6 Function Boost on Phase number change Enable all phases at low Vin 5 Force VR_READY 3 Prevent spec patterns 2 Enable all phases Vin hysteresis Description Reserved, disable/set to 0. Value 0 If enabled, all phases will be turned on if duty cycle is high and input voltage is lower than the threshold (VOLTAGE_DUTY_ENABLE) set by MFR_DUTY_PARAMETER[23:14] . This will improve transient response at low input voltage. Only for resonant topology. When set/enabled, VRREADY = 0 regardless of regulation. Reserved bit #4 need to be set to 0b. NO_PINTA: Prevents issuing special patterns in case of primary driver replacement. Adds 1V hysteresis on the All phases enable activation Vin threshold. See TON_RED_CONFIG[6] and MFR_DUTY_PARAMETER[23:14] . Only for resonant topology. 0 1 Disabled Enabled 0 1 Disabled Enabled 1 Function Disabled Enabled 0 1 Value 00 01 VR_READY_FAST_DISABLE (0xB051) Bit Description 0 Used to allow immediate VR_RDY signal deassertion in case of disable from EN pin. If not set, VR_RDY may be delayed from EN de-assertion up to 400 us. MULTIFUNCTION_PIN_MUX (0xB057) Value 00 01 Format Fixed Point Unsigned Description Disabled Enabled Disabled Enabled EN_DROOP_START (0xB04B) Bit Description 0 Enables fake droop effect at startup to keep Control-ADC Error negative to avoid bumps on VOUT at start-up. Other combinations than 0x00 and 0x01 are not supported. CS_OVERFLOW_DISABLE_IRQ (0xB04E) Bit Description 0 Used to disable current sharing overflow fault. 0x00 = Current Sharing FAULT Enable. 0x01 = Current Sharing FAULT Disable. Other combinations are not supported. May 2022 Value 0 1 Description Disable startup droop Enable startup droop Function Enable Current Sharing FAULT Disable Current Sharing FAULT Description Function Disable fast de-assertion Enable fast de-assertion Description INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) Technical Specification 84 6/1301-BMR 481 Uen karalars Andreas Larsson Approved (Document resp) Checked Date BMR481 Direct Conversion dalgedmoseries Gary Edmonds 2019-06-20 Input 40-60 V, Output 0.5 V to 1.35 V up to 70 A Bit 2 Function Enable IMON filtering 1:0 Configure droop effect at startup 42 (42) No. Description Enable additional analog filtering on IMON (800nSec time constant) to prevent from false OC tripping and to reduce overall ripple noise. Should always be enabled. Configure droop effect at startup, see EN_DROOP_START. Rev 28701-BMR481 revF B May 2022 © Flex Value 1 Function Enable Description Enable IMON filtering 00 Regulation error only (standard) Regulation error and Droop Regulation error and 2 x Droop Regulation error and 3 x Droop Use regulation error only. 01 10 11 Use regulation error + droop value by VOUT_DROOP. Use regulation error + 2 x droop value by VOUT_DROOP Use regulation error + 3 x droop value by VOUT_DROOP MONITOR_OFFSET (0xB05E) Bit Description 4:0 Vout monitoring offset applied to READ_VOUT (not applied to MFR_READ_VOUT). LSB depends on the table used (10mV or 5mV by VR_TAB_RAIL). Signed. It is an additional contribute to MFR_VOUT_CAL_OFFSET which is usually tuned to compensate internal ADC VSS (0.5V). Format Fixed Point Signed Unit mV EXTRA_OFFSET (0xB063) Bit Description 7:0 Additional offset for SVID and AVSBus domain (does not apply to PMBus) In AVSBus mode, if applied, need to be in tracking with MFR_VOUT_TRIM. # of VID LSB to add to setpoint (unsigned, always positive). Format Fixed Point Unsigned Unit mV DPM_OFFSET (0xB064) Bit Description 7:0 DPM threshold offset. Always Negative. Used to offset phase shedding thresholds in order to compensate for each phase current ripple without playing with DPM_HYSTERESYS. LSB weight based on IOUT_EXP and HC support enabled or disabled. Format Fixed Point Unsigned Unit A
BMR4810021/002 价格&库存
很抱歉,暂时无法提供与“BMR4810021/002”相匹配的价格&库存,您可以联系我们找货
