V25
EC5BE SERIES
15 WATT 2:1 INPUT RANGE
DC-DC CONVERTERS
FEATURES
* 15W Isolated Output
* 2” X 1” Six-Sided Shield Metal Case
* Efficiency to 83%
* 2:1 Input Range
* Pi Input Filter
* Continuous Short Circuit Protection
* Meets EN55032 Class A, Conducted
* Remote On/Off Control (Option)
* UL60950-1 Approval
* Safety Meets IEC/EN/UL 62368-1
INPUT
OUTPUT OUTPUT CURRENT
INPUT CURRENT
CAPACITOR
MODEL
% EFF.
NUMBER VOLTAGE VOLTAGE
LOAD MAX.
MIN.
MAX.
NO LOAD FULL LOAD
EC5BE01 9-18 VDC
5 VDC
0 mA
3000 mA
20 mA
1602 mA
78
3000uF
EC5BE02 9-18 VDC
0 mA
20 mA
12 VDC
1250 mA
1524 mA
82
1250uF
EC5BE03 9-18 VDC
0 mA
20 mA
15 VDC
1000 mA
1524 mA
82
1000uF
EC5BE04 9-18 VDC ±12 VDC
0 mA
30
mA
1506 mA
83
625uF
±625 mA
EC5BE05 9-18 VDC ±15 VDC
0 mA
±500 mA
30 mA
1506 mA
83
500uF
EC5BE06 9-18 VDC
0 mA ±1500 mA
±5 VDC
30 mA
1563 mA
80
1500uF
EC5BE07 9-18 VDC 3.3 VDC
0 mA
3000 mA
20 mA
1086 mA
76
3000uF
EC5BE11 18-36 VDC
0 mA
5 VDC
3000 mA
20 mA
780 mA
80
3000uF
EC5BE12 18-36 VDC
0 mA
20 mA
12 VDC
1250 mA
762 mA
82
1250uF
EC5BE13 18-36 VDC
mA
mA
762 mA
82
1000uF
15 VDC
1000 mA
EC5BE14 18-36 VDC ±12 VDC
0 mA
25
mA
±625 mA
755 mA
83
625uF
EC5BE15 18-36 VDC ±15 VDC
0 mA
±500 mA
25 mA
755 mA
83
500uF
EC5BE16 18-36 VDC
0 mA ±1500 mA
±5 VDC
25 mA
772 mA
81
1500uF
EC5BE17 18-36 VDC 3.3 VDC
0 mA
3000 mA
20 mA
76
3000uF
543 mA
EC5BE21 36-72 VDC
0 mA
5 VDC
3000 mA
15 mA
391 mA
80
3000uF
EC5BE22 36-72 VDC
0 mA
12 VDC
1250 mA
15 mA
377 mA
83
1250uF
EC5BE23 36-72 VDC
mA
15 VDC
1000 mA
15 mA
1000uF
377 mA
83
EC5BE24 36-72 VDC ±12 VDC
0 mA
±625 mA
20 mA
377 mA
83
625uF
EC5BE25 36-72 VDC ±15 VDC
0 mA
±500 mA
20 mA
377 mA
83
500uF
EC5BE26 36-72 VDC
0 mA ±1500 mA
±5 VDC
20 mA
1500uF
381 mA
82
EC5BE27 36-72 VDC 3.3 VDC
0 mA
3000 mA
15 mA
271 mA
76
3000uF
NOTE: 1. Nominal Input Voltage 12, 24 or 48VDC
1
V25
SPECIFICATIONS
All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range ....………….... 12V …….……..………….…..….. 9-18V
24V ……………………………… 18-36V
48V ……………………….…..…. 36-72V
Input Surge Voltage (100ms max.) ………….….… 12V …............. 25Vdc max.
24V .............. 50Vdc max.
48V .............. 100Vdc max.
Efficiency ................................................................................. See Table
Isolation Voltage ..............................................................… 500 VDC min
Isolation Resistance .......................................….......…… 108 Ohms min.
Isolation Capacitance ………………..………….………..…… 500pF typ.
Switching Frequency ............................................................ 300KHz typ.
Operating Ambient Temperature Range …..................... –25℃ to +71℃
Input Filter ………………………………………………….……………..... Pi Type
De-rating, Above 71℃ ………………… Linearly to Zero Power at 100℃
OUTPUT SPECIFICATIONS:
Case Temperature (note 3) ……........................................... 100℃ max.
Voltage Accuracy ………………....…………….….......….………… ±1.0% max.
Storage Temperature Range ………….…....………..... –40℃ to +100℃
Voltage Balance (Dual) …………………..………………………… ±1.0% max.
Transient Response
Single 25% Step Load Change ………...…………………
很抱歉,暂时无法提供与“EC5BE01”相匹配的价格&库存,您可以联系我们找货
