EC5BE11
EC5BE11
    CINCON
    DIP6 模块
    隔离模块 直流转换器 1 输出 5V 3A 18V - 36V 输入
EC5BE11 数据手册
V25 EC5BE SERIES ︳ 15 WATT 2:1 INPUT RANGE DC-DC CONVERTERS FEATURES * 15W Isolated Output * 2” X 1” Six-Sided Shield Metal Case * Efficiency to 83% * 2:1 Input Range * Pi Input Filter * Continuous Short Circuit Protection * Meets EN55032 Class A, Conducted * Remote On/Off Control (Option) * UL60950-1 Approval * Safety Meets IEC/EN/UL 62368-1 INPUT OUTPUT OUTPUT CURRENT INPUT CURRENT CAPACITOR MODEL % EFF. NUMBER VOLTAGE VOLTAGE LOAD MAX. MIN. MAX. NO LOAD FULL LOAD EC5BE01 9-18 VDC 5 VDC 0 mA 3000 mA 20 mA 1602 mA 78 3000uF EC5BE02 9-18 VDC 0 mA 20 mA 12 VDC 1250 mA 1524 mA 82 1250uF EC5BE03 9-18 VDC 0 mA 20 mA 15 VDC 1000 mA 1524 mA 82 1000uF EC5BE04 9-18 VDC ±12 VDC 0 mA 30 mA 1506 mA 83 625uF ±625 mA EC5BE05 9-18 VDC ±15 VDC 0 mA ±500 mA 30 mA 1506 mA 83 500uF EC5BE06 9-18 VDC 0 mA ±1500 mA ±5 VDC 30 mA 1563 mA 80 1500uF EC5BE07 9-18 VDC 3.3 VDC 0 mA 3000 mA 20 mA 1086 mA 76 3000uF EC5BE11 18-36 VDC 0 mA 5 VDC 3000 mA 20 mA 780 mA 80 3000uF EC5BE12 18-36 VDC 0 mA 20 mA 12 VDC 1250 mA 762 mA 82 1250uF EC5BE13 18-36 VDC 0 mA 20 mA 762 mA 82 1000uF 15 VDC 1000 mA EC5BE14 18-36 VDC ±12 VDC 0 mA 25 mA ±625 mA 755 mA 83 625uF EC5BE15 18-36 VDC ±15 VDC 0 mA ±500 mA 25 mA 755 mA 83 500uF EC5BE16 18-36 VDC 0 mA ±1500 mA ±5 VDC 25 mA 772 mA 81 1500uF EC5BE17 18-36 VDC 3.3 VDC 0 mA 3000 mA 20 mA 76 3000uF 543 mA EC5BE21 36-72 VDC 0 mA 5 VDC 3000 mA 15 mA 391 mA 80 3000uF EC5BE22 36-72 VDC 0 mA 12 VDC 1250 mA 15 mA 377 mA 83 1250uF EC5BE23 36-72 VDC 0 mA 15 VDC 1000 mA 15 mA 1000uF 377 mA 83 EC5BE24 36-72 VDC ±12 VDC 0 mA ±625 mA 20 mA 377 mA 83 625uF EC5BE25 36-72 VDC ±15 VDC 0 mA ±500 mA 20 mA 377 mA 83 500uF EC5BE26 36-72 VDC 0 mA ±1500 mA ±5 VDC 20 mA 1500uF 381 mA 82 EC5BE27 36-72 VDC 3.3 VDC 0 mA 3000 mA 15 mA 271 mA 76 3000uF NOTE: 1. Nominal Input Voltage 12, 24 or 48VDC 1 V25 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....………….... 12V …….……..………….…..….. 9-18V 24V ……………………………… 18-36V 48V ……………………….…..…. 36-72V Input Surge Voltage (100ms max.) ………….….… 12V …............. 25Vdc max. 24V .............. 50Vdc max. 48V .............. 100Vdc max. Efficiency ................................................................................. See Table Isolation Voltage ..............................................................… 500 VDC min Isolation Resistance .......................................….......…… 108 Ohms min. Isolation Capacitance ………………..………….………..…… 500pF typ. Switching Frequency ............................................................ 300KHz typ. Operating Ambient Temperature Range …..................... –25℃ to +71℃ Input Filter ………………………………………………….……………..... Pi Type De-rating, Above 71℃ ………………… Linearly to Zero Power at 100℃ OUTPUT SPECIFICATIONS: Case Temperature (note 3) ……........................................... 100℃ max. Voltage Accuracy ………………....…………….….......….………… ±1.0% max. Storage Temperature Range ………….…....………..... –40℃ to +100℃ Voltage Balance (Dual) …………………..………………………… ±1.0% max. Transient Response Single 25% Step Load Change ………...…………………
EC5BE11 价格&库存
很抱歉,暂时无法提供与“EC5BE11”相匹配的价格&库存,您可以联系我们找货
