EC5SBW-48S33
EC5SBW-48S33
    CINCON
    DIP6 模块
    隔离模块 直流转换器 1 输出 3.3V 7.5A 18V - 75V 输入
EC5SBW-48S33 数据手册
EC5SBW SERIES 30 WATT 4:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency up to 90%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully Protected (OTP/OCP/OVP/UVLO)  1500Vdc I/O Isolation  No Tantalum Capacitor Inside  Five-Sided Shielded Metal Case  Meets Industrial Standard 1”x1”x0.4”  UL62368-1 Approval  CB Test Certificate IEC62368-1  5000m Operating Altitude  -55℃ Operating Available (Suffix “-M2”) OUTPUT CURRENT MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. EC5SBW-24S33 EC5SBW-24S05 EC5SBW-24S12 EC5SBW-24S15 EC5SBW-24D12 EC5SBW-24D15 EC5SBW-48S33 EC5SBW-48S05 EC5SBW-48S12 EC5SBW-48S15 EC5SBW-48D12 EC5SBW-48D15 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 7500 mA 6000 mA 2500 mA 2000 mA ±1250 mA ±1000 mA 7500 mA 6000 mA 2500 mA 2000 mA ±1250 mA ±1000 mA INPUT CURRENT % EFF. NO LOAD FULL LOAD (2) 10 mA 10 mA 10 mA 10 mA 10 mA 10 mA 8 mA 8 mA 8 mA 8 mA 8 mA 8 mA 1172 mA 1389 mA 1404 mA 1404 mA 1404 mA 1404 mA 586 mA 694 mA 694 mA 702 mA 710 mA 702 mA 88 89 89 89 88 88 88 90 90 90 89 89 CAPACITOR (1) LOAD MAX. 88 90 89 89 88 88 88 90 89 89 88 89 7500uF 6000uF 2500uF 2000μF 1250μF 1000uF 7500uF 6000uF 2500uF 2000μF 1250μF 1000uF NOTE: 1. Nominal Input Voltage 24 or 48 VDC. 2. Measured at 12VDC for 24Vin, 24VDC for 48Vin. 3. -55℃ Start-up Screen per MIL-STD105E S1 Sampling Procedure for “-M2” Version. PART NUMBER Series EC5SBW- Nominal Input Voltage II Number of Outputs O S:Single EC5SBW 24:24 VDC 48:48 VDC D:Dual Nominal Output Voltage XX 33:3.3VDC 05:5.0VDC 12:12VDC 15:15VDC 12:±12VDC 15:±15VDC Remote On/Off Logic L None:Positive N:Negative Operating Case Temp. Range -Z (Option) None:-40~105℃ -M2:-55~105℃ Part Number Example: EC5SBW-24S12N-M2: 1.0”x1.0”, 30W, 4:1 9-36Vdc Input, Single 12Vdc Output, Negative Logic, -55~105℃ Operating Case Temp. Range www.cincon.com 1 REVISION: V17 EC5SBW Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Input Voltage Continuous Input Surge Voltage 100ms max. Operating Case Temperature At the center part of case (with Derating) Suffix “-M2” (with Derating) Storage Temperature Device Min. Typ. Max. 24Vin -0.3 36 48Vin -0.3 75 24Vin 50 48Vin 100 Units Vdc Vdc All -40 105 -M2 -55 105 All -55 125 ℃ Device Min. Max. Units ℃ INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Typ. 24Vin 9 24 36 48Vin 18 48 75 24Vin 8 8.5 8.8 48Vin 16.5 17 17.5 Vdc Input Under Voltage Lockout Turn-On Voltage Threshold 100% Load Turn-Off Voltage Threshold 100% Load Lockout Hysteresis Voltage 100% Load Maximum Input Current 24Vin 7.7 8 8.3 48Vin 15.5 16 16.5 24Vin 0.5 48Vin 1 24Vin 3900 Vin=18V, Full load 48Vin 1950 Vin=Nominal, Io=0A Input Filter Pi filter All Inrush Current (I2t) As per ETS300 132-2 All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz All Vdc Vdc Vin=9V, Full load No-Load Input Current Vdc See Model Number Table mA mA 0.1 30 A2s mA OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=Nominal, full load, Tc=25℃ All Output Voltage Balance Vin=Nominal, full load, Tc=25℃ Dual Typ. Max. Units -1.5 +1.5 % -1.5 +1.5 % Output Voltage Regulation Load Regulation Full load to no load Line Regulation Vin=High line to low line, full load Cross Regulation Load cross variation 10%/100% Temperature Coefficient Tc=-40℃ to 85℃ Single ±0.2 Dual ±1.0 Single ±0.2 Dual Dual ±0.5 ±5 All ±0.03 % % % %/℃ Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full Load, 20MHz bandwidth 10uF tantalum and 1uF ceramic capacitor Output Current Range Vin=Nominal, Over Current Protection Hiccup mode. Auto recovery www.cincon.com 75 Others 100 See Model Number Table All Short Circuit Protection External Load Capacitance 3.3 & 5Vo All Full load (resistive) 110 140 A 170 % Continuous, Auto Recovery See Model Number Table 2 mV uF REVISION: V17 EC5SBW PARAMETER Over Voltage Protection NOTES and CONDITIONS Zener clamp Device Min. Typ. 3.3Vo 3.9 5Vo 6.2 12Vo 15 15Vo 18 ±12Vo ±15 ±15Vo ±18 Series Max. Units Vdc EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=Nominal, full load, Tc=25℃ Device Min. Typ. Max. See Model Number Table Units % DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote on All 10 ms Vin_min to 10%Vo_set, Power up All 10 ms 10%Vo_set to 90%Vo_set All 10 ms ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Resistance Isolation Capacitance NOTES and CONDITIONS Device 1 Minute; input to output All Input to output All Input to output (10KHz, 0.25V) All Min. Typ. Max. Units 900 Vac 1500 Vdc 1000 MΩ 1500 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse width modulation (PWM), fixed Device Min. Typ. Max. Vo=3.3&5V 240 270 300 Others 300 330 360 Units KHz On/Off Control, Positive Remote On/Off Logic, Refer to –Vin Pin Logic Low (Module Off) Von/off at Ion/off=1.0mA Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=on -M2 0 1.0 Others 0 3.5 or Open Circuit 1.2 All V 75 V 75 V On/Off Control, Negative Remote On/Off Logic, Refer to –Vin Pin Logic High (Module Off) Von/off at Ion/off=0.0uA, Pin open=off Logic Low (Module On) Von/off at Ion/off=1.0mA On/Off Current (for both remote on/off logic) Leakage Current (for both remote on/off logic) Off Converter Input Current Over Temperature Shutdown Over Temperature Recovery www.cincon.com -M2 3.5 or Open Circuit 0 1.0 Others 0 1.2 All Ion/off at Von/off=0V All Logic high, Von/off=15V All 0.4 V 1 mA 30 uA 10 mA Shutdown input idle current All 4 Temperature at the center part of case, nonlatching All 110 ℃ All 100 ℃ 3 REVISION: V17 EC5SBW Series GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Io=100% of Io_max; MIL-HDBK - 217F_Notice 1, GB, 25℃ Weight Case Material Plastic, DAP Potting Material UL 94V-0 Base: Copper Plating: Matte Tin MIL-STD-810F Compliant Shock/Vibration Min. Typ. 24S33 903 24S05 24S12 799 1090 24S15 1125 24D12 1149 24D15 1221 48S33 925 48S05 813 48S12 48S15 1114 1215 48D12 1156 48D15 1244 All 18 Max. Units K hours grams Black Coated Copper Base plate Material Pin Material Device Humidity 95% RH max. Non Condensing Altitude Thermal Shock Fire & Smoke EMI 5000m Operating Altitude, 12000m Transport Altitude MIL-STD-810F EN45545-2 Compliant Meets EN55032, Conducted with external input filter Class A ESD IEC61000-4-2 Level 3: Air ±8kV, Level 2: Contact ±4kV Perf. Criteria A Radiated immunity EN61000-4-3 Level 2: 80~1000MHz, 3V/m Perf. Criteria A Fast Transient EN61000-4-4 Level 1: On power input port, ±0.5kV, external input TVS required Perf. Criteria A Surge EN61000-4-5 Level 1: Line to line, ±0.5kV Perf. Criteria A Conducted immunity EN61000-4-6 Level 2: 0.15~80MHz, 3V Perf. Criteria A Application Note Link EC5SBW Series App Notes Packaging Information Link Packaging Information Immunity to Environmental Conditions Phenomenon Reference Clause Reference Standard Vibration Test MIL-STD-810F Table 514.5C-VIII Figure 514.5C-6 MIL-STD-810F Shock Test MIL-STD-810F 516.5 Table 516.5-I MIL-STD-810F Thermal Shock Cycling Test MIL-STD-810F 503.4 Figure 503.4-1 MIL-STD-810F Thermal Humidity Cycling Test MIL-STD-810F Notice 3 Method 507.4 MIL-STD-810F www.cincon.com 4 Test Conditions Unit are Non-Operating Vibration Waveform: Random Vibration Frequency: 15 ~ 2000 Hz Vibration axis: X、Y、Z axis Duration: 1hr / axis Wave form: Sawtooth Wave Test Category: Crash Hazard Test for Ground Equipment Duration: 10 ms Peak Acceleration: 75 G Cross-Over Frequency:80 Hz No. of Shock: Each axis 3 times Shock Direction: ±X , ±Y, ±Z axis Temperature: -55℃ to 105℃ Humidity: 95%RH Duration: 8hrs/ 3 times cycling& 4hrs dwell time Temperature: 60℃ to 30℃ Humidity: 95%RH Duration: 240 hrs Result Pass Pass Pass Pass REVISION: V17 EC5SBW Series EN45545-2 Fire & Smoke Test Conditions Item Standard Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Power Derating Curve EC5SBW-XXS33 Derating Curve (Vin=Nominal) EC5SBW-XXS05 Derating Curve (Vin=Nominal) 100% 120% 54 -40 63 Output Power (%) Output Power (%) 120% 100% 80% 60% 40% without heatsink 20% 60% 40% without heatsink with heatsink 105 105 0% -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 Ambient Temperature (℃) Ambient Temperature (℃) EC5SBW-XXS12 Derating Curve (Vin=Nominal) EC5SBW-XXS15 Derating Curve (Vin=Nominal) 120% 100 120% 49 -40 59 Output Power (%) Output Power (%) 80% 20% with heatsink 0% 100% 55 63 -40 100% 80% 60% 40% without heatsink 20% 49 -40 80% 60% 40% without heatsink 20% with heatsink with heatsink 105 0% 59 105 0% -40 -20 0 20 40 60 80 100 -40 Ambient Temperature (℃) www.cincon.com -20 0 20 40 60 80 100 Ambient Temperature (℃) 5 REVISION: V17 EC5SBW EC5SBW-24D12, 24D15 Derating Curve (Vin=Nominal) EC5SBW-48D12, 48D15 Derating Curve (Vin=Nominal) 120% 44 -40 54 Output Power (%) Output Power (%) 120% 100% Series 100% 80% 60% 40% without heatsink 20% 49 -40 80% 60% 40% without heatsink 20% with heatsink 59 with heatsink 105 0% 105 0% -40 -20 0 20 40 60 80 100 -40 Ambient Temperature (℃) -20 0 20 40 60 80 100 Ambient Temperature (℃) Performance Data EC5SBW-24S33 Eff Vs Io @25 Deg. C EC5SBW-24S33 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 9V 12V 70% 24V 36V 60% 10% 9V 12V 24V 36V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 0% 90% 100% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC5SBW-24S05 Eff Vs Io @25 Deg. C EC5SBW-24S05 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 9V 12V 70% 24V 36V 60% 10% 9V 12V 24V 36V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC5SBW-24S12 Eff Vs Io @25 Deg. C EC5SBW-24S12 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 9V 12V 70% 24V 36V 60% 10% 9V 12V 24V 36V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) Current Load (%) 6 REVISION: V17 EC5SBW EC5SBW-24S15 Eff Vs Io @25 Deg. C EC5SBW-24S15 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 9V 12V 70% 24V 36V 60% 10% 9V 12V 24V 36V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 0% 90% 100% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC5SBW-24D12 Eff Vs Io @25 Deg. C EC5SBW-24D12 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 9V 12V 70% 24V 36V 60% 10% 9V 12V 24V 36V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC5SBW-24D15 Pd Vs Po @25 Deg. C EC5SBW-24D15 Eff Vs Io @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 9V 12V 70% 24V 36V 60% 10% 9V 12V 24V 36V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) Current Load (%) EC5SBW-48S33 Eff Vs Io @25 Deg. C EC5SBW-48S33 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 18V 24V 70% 48V 75V 60% 10% Series 18V 24V 48V 75V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 0% 90% 100% Current Load (%) www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V17 EC5SBW EC5SBW-48S05 Eff Vs Io @25 Deg. C EC5SBW-48S05 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 18V 24V 70% 48V 75V 60% 10% 18V 24V 48V 75V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 0% 90% 100% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC5SBW-48S12 Eff Vs Io @25 Deg. C EC5SBW-48S12 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 18V 24V 70% 48V 75V 60% 10% 18V 24V 48V 75V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC5SBW-48S15 Pd Vs Po @25 Deg. C EC5SBW-48S15 Eff Vs Io @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 18V 24V 70% 48V 75V 60% 10% 18V 24V 48V 75V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) Current Load (%) EC5SBW-48D12 Eff Vs Io @25 Deg. C EC5SBW-48D12 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 18V 24V 70% 48V 75V 60% 10% Series 18V 24V 48V 75V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 0% 90% 100% Current Load (%) www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 8 REVISION: V17 EC5SBW EC5SBW-48D15 Eff Vs Io @25 Deg. C EC5SBW-48D15 Pd Vs Po @25 Deg. C 5 Power Dissipation (W) Efficiecncy (%) 100% 90% 80% 18V 24V 70% 48V 75V 60% 10% Series 18V 24V 48V 75V 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 0% 90% 100% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) MECHANICAL SPECIFICATION 0.200 [5.08] 1.00 [25.4] 0.800 [20.32] 0.10 [2.5] 6 2 0.40 [10.2] 1 BOTTOM VIEW 5 3 4 0.400 [10.16] 0.400 [10.16] 0.04 [1.0] DIA 0.300 [7.62] 0.22 min. [5.6] 0.40±0.02 [10.2±0.5] 1.00 [25.4] 0.200 [5.08] 0.800 [20.32] 0.10 [2.5] 1.00 [25.4] 6 2 0.40 [10.2] 3 4 0.400 [10.16] PIN 1 2 3 4 5 6 1 BOTTOM VIEW 5 Suffix "+SBC100" Type 0.400 [10.16] 0.04 [1.0] DIA 0.300 [3.76] NOTE:Pin Size is 0.04±0.004 Inch [1.0±0.1 mm]DIA All Dimensions In Inches [mm] Tolerances Inches: X.XX= ±0.04 , X.XXX= ±0.010 Millimeters: X.X= ±1.0 , X.XX=±0.25 PIN CONNECTION Single Dual +Input +Input -Input -Input +V Output +V Output Trim Common -V Output -V Output Remote Remote 0.22 min. [5.6] 0.81 [20.5] 1.13 [28.8] sales@cincon.com.tw www.cincon.com 9 REVISION: V17
EC5SBW-48S33 价格&库存
很抱歉,暂时无法提供与“EC5SBW-48S33”相匹配的价格&库存,您可以联系我们找货
